busta
21.06.2025 18:37:33
| Üks paras tüütus. Käin osadel mängudel peale igat drivu vahetust seda sisse lülitamas @nvidiaProfileInspector. Siis veel Nvidia control panelis ka veel midagi sätin alati.
| Kommentaarid: 16 loe/lisa |
14 |
Vael
22.06.2025 11:40:12
| Ma ei tea kui hästi Nvidial töötab, aga ma olen proovinud sisse lükitada AMD kaartidel ja suurt edasiminekut ei näe seal kus vaja(Stalker2). Samas framepacing/stutter tuleb sisse...
| Kommentaarid: 17 loe/lisa |
16 |
rene p
23.06.2025 18:30:31
https://www.computerbase.de/artikel/grafikkarten/blackwell-lovelace-rdna-4-rdna-3-performance-vergleich.93228/
Nvidia Blackwell is not faster than its predecessor Lovelace in games, neither in rasterizer nor in ray tracing or path tracing scenarios. Yes, there are individual games in which Blackwell is ahead, but there are also titles that offer more performance on Lovelace. In general, the architecture does not bring more performance. The GeForce RTX 5000 generation gets its performance advantages over RTX 4000 via more execution units, more clock, higher power consumption and newer features.
68 |
23.06.2025 23:45:58
| rene p kirjutas: |
Nvidia Blackwell is not faster than its predecessor Lovelace in games, neither in rasterizer nor in ray tracing or path tracing scenarios. Yes, there are individual games in which Blackwell is ahead, but there are also titles that offer more performance on Lovelace. In general, the architecture does not bring more performance. The GeForce RTX 5000 generation gets its performance advantages over RTX 4000 via more execution units, more clock, higher power consumption and newer features. |
Blackwell aka Big Lovelace...
| Kommentaarid: 92 loe/lisa |
217 |
kraaks
29.06.2025 00:32:16
| Fugitive kirjutas: |
Kuna hr kraaks pole kommenteerinud, milleks tal kaarti vaja on, siis 5090 soovitamine kohe ei ole nagu asjakohane, kui masin minecrafti vms mängib.
Hoiaks kodanik ehk kena kopika kokku ja ei peaks see 5080 ka tippklassi oma olema ning vb saaks ka nõrgem kaart vajalikuga hakkama. |
Vabandust, tere.
Mängin COD-i ja Flight simulatorit. 4K resolutsioonil.
_________________ lillekasvatus.ee |
| Kommentaarid: 4 loe/lisa |
rene p
68 |
Fugitive
29.06.2025 13:35:30
| kraaks kirjutas: |
Vabandust, tere.
Mängin COD-i ja Flight simulatorit. 4K resolutsioonil. |
Flight sim 2024? Siis nvidia poolelt alla 5070TI ei vaataks ja kõiki seadeid ultra peale ei sätiks, kui tahad 60+ fps saada. Kui raha on ja kõik põhja tahad keerata siis jah, 5090 kuna isegi 4090 sai hädaga 60 kätte kõik max peal.
Youtubest leiad muidugi benchmarke ka, pane vastav mudel ja msfs 24 ultra 4k otsingusse.
See mäng tahab ka head CPU-d, ehk siis vaata ka, et see hoopis jalgu ei jää.
| Kommentaarid: 13 loe/lisa |
rene p
29.06.2025 15:57:35
NVIDIA GeForce RTX 5070 Ti SUPER To Feature 24 GB Memory, Same Core Count & 350W Power
https://wccftech.com/nvidia-geforce-rtx-5070-ti-super-to-24-gb-memory-350w-power/
So, in a nutshell, the RTX 5070 Ti SUPER offers (vs 5070 Ti):
Same Core Count (8960 GB203)
50% More VRAM (24 GB vs 16 GB)
Same Memory Bandwidth & Bus (256-bit)
Same Memory Speed (28 Gbps)
16% Higher Power (350W vs 300W)
68 |
heretic666
29.06.2025 18:31:07
| Ma kipun kahtlustama need 24GB Ti isendid kaovad nagu soojad saiad LLM vendade laua alla, 7900 XTX ka "kütitakse" siiani samal põhjusel.
| Kommentaarid: 73 loe/lisa |
Optimist
03.07.2025 13:09:41
| heretic666 kirjutas: |
| Ma kipun kahtlustama need 24GB Ti isendid kaovad nagu soojad saiad LLM vendade laua alla, 7900 XTX ka "kütitakse" siiani samal põhjusel. |
Pakun 24GB Ti saadavus saab probleemiks olema. USAs on 7900 XTX otsas aga EU's täitsa veel laojäägid liiguvad.
_________________ LLM gang be like: Bro do you even MCP |
| Kommentaarid: 10 loe/lisa |
Kristoferr
03.07.2025 14:37:50
Oleneb, mis need maksma hakkavad, aga muidu jah.
Kuna LLM tegelikult väga võimsat core ei nõua, siis etem oleks turule saada lasta hoopis 5060(ti) koos 48GB mäluga. See läheks ilmselt ka 1000€/tk.
_________________ Liitu Z.ai soodsa coding plaaniga
Liitu Wise'ga! |
| Kommentaarid: 266 loe/lisa |
217 |
03.07.2025 17:57:13
Kristoferr, 48gb läheks raskeks vist. 24gb saaks ja kui 4gb kivid ka kohal, siis 32gb
_________________ - londiste
217 |
Optimist
03.07.2025 19:45:53
| Kristoferr kirjutas: |
| Kuna LLM tegelikult väga võimsat core ei nõua, siis etem oleks turule saada lasta hoopis 5060(ti) koos 48GB mäluga. |
Inferencing, ehk valmis mudelite kasutamise puhul on võtmesõnaks mälu ribalaius. 5060 oma 128-bitise 448.0 GB/s GDDR7ga eriti ei hiilgaks.
04.07.2025 10:12:11
| Shockingly, while usually the 12VHPWR has a total of 12+4 pin configuration, the adapter cable shipped with the GPU had a connector with 4 pins absent. These are the sense pins, which essentially ensure a proper connection. |
217 |
heretic666
Snaxez
05.08.2025 21:35:08
| Mirage kirjutas: |
| Arx07 kirjutas: |
Mirage, ma sain 9343, samade seadetega vanade driveritega oli 8842.
https://www.3dmark.com/3dm/131317883?
Kui flashiks vängema BIOSi peale siis saaks ka Ventusega 10k ilmselt kätte, aga selle jahutiga pole mõtet piinata kaarti  |
Samasse kanti, margin of error, aga jah, enamjaolt jääb power limit ja jahutuse taha (üllatavalt suur vahe n-ö. top kaartidega, kuni 10%).
Ventusele on iseenesest alphacool waterblock täiesti olemas, selle aspekti saaks teoreetiliselt välistada pidurina, power limiti jaoks tuleb sobiv bios leida.
"Odav juust", aga ma siiani suht rahul. |
Müüsin oma 3090 maha ja panin ka lõpuks 5080 Ventuse alphacool blockiga masinasse. Tuli 10149 Steel Nomad ära ilusti. http://www.3dmark.com/sn/7871513 (world #48 )
viimati muutis Snaxez 06.08.2025 22:31:54, muudetud 3 korda |
| Kommentaarid: 61 loe/lisa |
54 |
Hardi
05.08.2025 21:57:38
Snaxez, hea isend, oleks pidanud ka odavama 5080 ostma vist vanguardi asemel max millega benchida saab on 3100 midagi , üle selle pang. https://www.3dmark.com/sn/7851788
_________________ ツ |
| Kommentaarid: 84 loe/lisa |
Snaxez
54 |
Hardi
05.08.2025 22:04:16
Seda mälu teemat tean juba jah, pole viitsinud tegeleda kuna 99% jookseb def mälu ja undervoldiga kaart.
busta
08.08.2025 19:45:50
Natuke jääb jah puudu 3090'st. Olen ka mõelnud 3090 pealt liikuda 5080'le.
Dlls ei ole teema, ikka native dlla ja teravus 100%. Selles jääb 3090 UW1440 hätta. Veeplokk juurde, siis läheb 1500 ära.
16 giga kaarti ostmine tundub, mitte nii tulevikukindel.
Millal üldse midagi mälumahult paremat ja kiiremat oodata on? Ei ole vast vahet, kas amd või nvidia.
14 |
Snaxez
08.08.2025 20:10:29
| busta kirjutas: |
Millal üldse midagi mälumahult paremat ja kiiremat oodata on? Ei ole vast vahet, kas amd või nvidia. |
Kui veel midagi ostnud pole, siis soovitaks oodata. Mingid kuulujutud on, et tahetakse pricecuti teha 5000 seeriale, aga eks peab ootama ja vaatama.
According to a new report, Nvidia has overstocked the RTX 50 series.
This inventory continues to pile up because of a massive decline in sales.
Now, it seems like there will be some massive price cuts on the RTX 50 series this month.
Mingi aeg Q4 peaks super kaardid ka tulema, siis on 5080 super ilmselt 24gb mäluga
54 |
08.08.2025 20:22:32
5080 hetkel osta oleks kõige halvem ost. See on liiga kallis selle eest mida see pakub.
Vs 5070 Ti on see ainult 15% kiirem, aga 30% kallim (Eesti hinnad: 850 vs 1100).
15% on näiteks 30fps vs 34fps. 60fps vs 69fps või 144fps vs 165fps. Nii väike vahe, et ilma frame rate jälgimata seda praktiliselt ei tunneta.
See ei paku isegi rohkem mälu olles sama 16GB mis 5070 Ti.
Tehnilistelt andmetelt on see rohkem nagu 5070 Ti Super, sest see kasutab samuti GB203 nagu 5070 Ti.
Tegelik 5080 koos 24GB mäluga peaks tulema aastavahetuse paiku. Paraku ilmselt ka see kasutab GB203, mitte GB202.
Vähemalt Super versioon on 3090 ja 3090 Ti omanikele mõistlikum upgrade, kui praegune kastreeritud versioon koos mälukoguse downgrade'ga.
5070 Ti on 31% kiirem, kui 3090. Seda juba tunneb ka numbreid nägemata. Muidugi mälukogus on downgrade.
