uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  AMD RX400/500 "Polaris" seeria arutelu märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 21, 22, 23 ... 51, 52, 53  järgmine
Kristoferr
Kristoferr
sõnum 02.07.2016 08:52:29 vasta tsitaadiga
Nahu näha, siis PCI voolutarve on rohkem pseudoprobleem. Küll aga pole seda TDP ületamine.
Liitu Opencode Go soodsa coding plaaniga ja saa 5€ soodust!
Liitu Wise'ga!
Kommentaarid: 268 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 219
sõnum 02.07.2016 09:12:54 vasta tsitaadiga
sõnum 02.07.2016 10:08:43 vasta tsitaadiga
sannukas00 kirjutas:
http://www.pcper.com/reviews/Graphics-Cards/Power-Consumption-Concerns-Radeon-RX-480/Evaluating-ASUS-GTX-960-Strix
- londiste
anubis
anubis
sõnum 02.07.2016 10:38:15 vasta tsitaadiga
http://www.tomshardware.com/reviews/geforce-gtx-750-ti-review,3750-20.html
http://www.tomshardware.com/reviews/amd-radeon-rx-480-polaris-10,4616-9.html
GTX750Ti'd peaks järelikult samamoodi emaplaate põletama, pole kuulnud. Torm veeklaasis?
sõnum 02.07.2016 10:40:14 vasta tsitaadiga
anubis, 62w ja 64w? in spec.
http://www.pcper.com/reviews/Graphics-Cards/Power-Consumption-Concerns-Radeon-RX-480/Evaluating-ASUS-GTX-960-Strix kirjutas:
One interesting note on our data compared to what Tom’s Hardware presents – we are using a second order low pass filter to smooth out the data to make it more readable and more indicative of how power draw is handled by the components on the PCB. Tom’s story reported “maximum” power draw at 300 watts for the RX 480 and while that is technically accurate, those figures represent instantaneous power draw. That is interesting data in some circumstances, and may actually indicate other potential issues with excessively noisy power circuitry, but to us, it makes more sense to sample data at a high rate (10 kHz) but to filter it and present it more readable way that better meshes with the continuous power delivery capabilities of the system.
Some gamers have expressed concern over that “maximum” power draw of 300 watts on the RX 480 that Tom’s Hardware reported. While that power measurement is technically accurate, it doesn’t represent the continuous power draw of the hardware. Instead, that measure is a result of a high frequency data acquisition system that may take a reading at the exact moment that a power phase on the card switches. Any DC switching power supply that is riding close to a certain power level is going to exceed that on the leading edges of phase switches for some minute amount of time. This is another reason why our low pass filter on power data can help represent real-world power consumption accurately. That doesn’t mean the spikes they measure are not a potential cause for concern, that’s just not what we are focused on with our testing.
- londiste
anubis
anubis
sõnum 02.07.2016 10:44:54 vasta tsitaadiga
Seda mõtlesin.
Vondur
Vondur
sõnum 02.07.2016 10:49:33 vasta tsitaadiga
londiste kirjutas:
http://www.tomshardware.com/reviews/nvidia-geforce-gtx-960,4038-8.html
Aga siis ma küll ei näinud, et sa hädakella oleksid löönud ja "epic fail" igasse ilmakaarde hõiganud... icon_biggrin.gif
Kaua selle pcper artikli otsas veel ratsutada saab? Kus on teised? Kus on kõik need miljonid maha põlenud emaplaadid?
anubis
anubis
sõnum 02.07.2016 10:57:10 vasta tsitaadiga
Midagi ilusat hetkelandmetel, jah, ei paista. Samas midagi eriti koledat ka mitte.
Niiumbes viie päeva pärast saan ise testida, kahju, et korralikku varustust pole voolutarbe täpseks mõõtmiseks icon_sad.gif
hondaa
hondaa
sõnum 02.07.2016 10:58:38 vasta tsitaadiga
kogu probleem oleneb selles, et tomshw mõõdetud hetkeline voolutarve läheb üle 150w? päris paljud kaardid tõmbavad hetkeliselt nende testis korralikke numbreid, mingi hetk keegi tahtis isegi suuremaid 600-700w toiteid soovitada nende mõõtmiste pärast. Pole kuulnud, et 400w toited kõik maha põleks, niiet see mõõtmise metood on üsnagi küsitav. Aga nagu ikka peab custom versioonid ära ootama. Hetkel minu jaoks pettumus, 980 võinuks kiirem olla. eks custom versioonid ja uued driverid võivad asja leevendada, aga eks ole näha, hetkel jääb 1060 ootama.
elukaz
elukaz
sõnum 02.07.2016 11:16:51 vasta tsitaadiga
Paistab et läheb ikka päris koledaks mida rohkem tagasikutsumisega oodatakse. Kui vähegi crossfire kasutada nagu kogu aeg on rõhutatud siis hakkab plaate minema nagu leiba.
6 tundi kaevandamist mahakellatud kaartidega: https://bitcointalk.org/index.php?topic=1433925.msg15438988#msg15438988
kaspar737
sõnum 02.07.2016 11:17:56 vasta tsitaadiga
anubis kirjutas:
Seda mõtlesin.
Peak ei ole probleem, see kui kaardi keskmine voolutarve on 10W üle speci on probleem.
Timoo87
Timoo87
sõnum 02.07.2016 11:23:23 vasta tsitaadiga
rx 480 laseb pidevalt üle pcie speci, need mõned nvidia kaardid ainult peak-ivad sellest üle.
selline quote ka pcper artiklist:
With our ability to measure voltage and current, we return back to Metro: Last Light at 4K to find that amperage draw over the motherboard's +12V line stays right at 2.5A. That is a drastic difference compared to the RX 480 hitting more than 7A over the same line, especially considering the 5.5A limit from the PCI Express specification.
anubis
anubis
sõnum 02.07.2016 11:39:08 vasta tsitaadiga
elukaz kirjutas:
https://bitcointalk.org/index.php?topic=1433925.msg15439621#msg15439621
wrong he was using unpowered ribbon risers , recipe for disaster long term
Timoo87 kirjutas:
Nägin nüüd, jep. 62-65W avg 750Ti vs 80W avg RX 480.
BIOSi uuendusest peaks piisama, et muuta vahekord 1/3 PEG 2/3 PCIe 6p.
viimati muutis anubis 02.07.2016 11:39:45, muudetud 1 kord
elukaz
elukaz
sõnum 02.07.2016 11:39:11 vasta tsitaadiga
anubis kirjutas:
elukaz kirjutas:
See ongi sama kui sa ühendad kaardi otse emaplaadile, mängurid ju ei kasuta risereid. Kuigi nüüd peaks hakkama, AMD võiks pakki juurde visata 16>16 power riseri icon_biggrin.gif
anubis
anubis
sõnum 02.07.2016 11:41:11 vasta tsitaadiga
Mängimine ei tekita kunagi sellist koormust nagu kaevandamine.
Ja toome mängu selle toreda fakti, et ükski tavakasutajadetail ei ole mõeldud töötama 24/7 täiskoormusel. Out-of-spec töökoormus. Omal vastutusel.
elukaz
elukaz
sõnum 02.07.2016 11:44:16 vasta tsitaadiga
Misasi on out of spec? Kas furmarkiga võib kaardi stabiilsust testida? Kui kaua? Mitu tükki korraga? Kas Metro Last Night võib 4x crossfires mängida? Kui kaua?
Timoo87
Timoo87
sõnum 02.07.2016 11:53:21 vasta tsitaadiga
elukaz kirjutas:
pcie slotist ei tohiks üle 75W tõmmata, kui tõmbab rohkem vatte siis võib pahasti minna. seda ilma spets tehnikata mõõta ei saa. crossfire kohta jään vastuse võlgu. jutt oli muidu 4K resolutsioonist, mitte crossfirest.
viimati muutis Timoo87 02.07.2016 11:56:03, muudetud 1 kord
anubis
anubis
sõnum 02.07.2016 12:12:10 vasta tsitaadiga
24/7 arvutuskoormuse jaoks on sertifitseeritud Teslad. Lisaks on sertifitseeritud platvorm kus need kaardid paiknema saavad (toiteplokid, emaplaat, õhuvool, temperatuur õhu sissevõtu poolel jne)
Kui sa jooksutad furmarki üle tunni siis sa otsid probleeme, mitte ei testi kaarti.
edit: lisaks, 3 v 4x Crossfire võimaldavad emaplaadid peaksid omama lisatoidet PEG siinidele (molexi vms ühendusege) ja olema EPS12 emaplaadi lisatoite pistikuga, mitte ATX 4pin.
Timoo87
Timoo87
sõnum 02.07.2016 12:14:44 vasta tsitaadiga
https://www.techpowerup.com/223833/official-statement-from-amd-on-the-pci-express-overcurrent-issue
fix tuleb
Le Inc
Le Inc
sõnum 02.07.2016 12:18:24 vasta tsitaadiga
Vaadates RX480 CrossFire kooslust siis on selle võimsus enam-vähem ühe GTX1070 kanti, seda siis ainult neis mängudes kus kahe videokaardi tugi on toetatud. Arvestades et kahe RX480 hind on enam-vähem samasse auku (teoorias võiks olla) 1070, siis on nVidia lahendus igati pidi mõistlikum. Lisaks saab 1070 korralikumalt kellata.
Huvitav on see et keskeltläbi on RX480 3..5% kiirem kui GTX970, seda eriti üle FHD resolutsioonil (ilmselt tänu 8 GB mälule).
Kaart oleks võinud välja tulla koos 970, siis oleks asjal pointi olnud. thumbs_up.gif
viimati muutis Le Inc 02.07.2016 12:19:09, muudetud 1 kord
Timoo87
Timoo87
Le Inc kirjutas:
See kaart oleks võinud välja tulla koos 970, siis oleks asjal pointi olnud. thumbs_up.gif
970 tuli 199$ välja?
Evil14
Evil14
sõnum 02.07.2016 12:19:58 vasta tsitaadiga
Timoo87 kirjutas:
Le Inc kirjutas:
viimati muutis Evil14 02.07.2016 12:20:16, muudetud 1 kord
Kommentaarid: 226 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 197
Le Inc
Le Inc
sõnum 02.07.2016 12:20:45 vasta tsitaadiga
Timoo87 kirjutas:
Le Inc kirjutas:
Ma ei räägi hinnast, vaid võimsusest. Siis oleks AMD võinud ka 2x rohkem raha küsida. Aga noh mis teha kui oled sammukese teisest maas. Asi ikka. icon_biggrin.gif
Timoo87
Timoo87
sõnum 02.07.2016 12:24:18 vasta tsitaadiga
Le Inc kirjutas:
See kaart millest sa räägid kõlab nagu r 390.
elukaz
elukaz
sõnum 02.07.2016 12:28:49 vasta tsitaadiga
anubis, kas tegu on siis selle konkreetse kaardi jaoks välja mõeldud vandenõuga ja tegelikult probleemi polegi?
Aeg on näidanud et atx 24pin 12V otsad ei talu eriti voolu, ise sellega rohkem kui korra kokku puutunud. Kui masina tervist hinnatakse tavaliselt prose ja videokaardi temperatuuride järgi siis kahjuks ei saa juhtmeühenduste tempi lihtsate meetoditega mõõta. Ja nii võidki vaadata et oh mul kena stabiilne masin ja tempid kontrolli all, aga mingi hetk hakkavad lambi restardid, kindel märk on see kui masin kohe käima ei lähe vaid 10 minutit jahtuda tahab.
donaldTBD
sõnum 02.07.2016 12:29:04 vasta tsitaadiga
Le Inc kirjutas:
Timoo87 kirjutas:
Le Inc kirjutas:
Selles asi ongi, et sa ei räägi hinnast vaid ainult võimsusest. Need kaks asja käivad ikka käsikäes. Kui nad oleks 480 saanud samal ajal välja lasta kui 970 oleks nad pigem kaks sammu ees olnud. Praegu sama võimsusega kaart tunduvalt odavamalt on ikka veel üks samm ees. Seda muidugi seni kuni 1060 välja tuleb ehk siis ainult paar päeva - siis on poisid taas tagasi ühel joonel icon_razz.gif
anubis
anubis
sõnum 02.07.2016 12:36:38 vasta tsitaadiga
RX 480 ei ole GTX1070 konkurent, 2x RX 480 ei ole GTX1070 konkurent vaid huvitav riistvarakooslus entusiastidele nikerdamiseks.
GTX1070 on GTX970 asendaja, MSRP oli GTX970'l $329 vs GTX1070 $379 (+$50), pakkudes eelmise põlvkonna tippmudeli kiirust (GTX980Ti). Reaalselt müüakse teda mitusada kallimalt. Kõik plaksutavad.
RX 480 on R9 380 asendaja (ehk siis GTX960 kategooria Nvidia poolelt, aste allpool tippmudelitest), samas hinnaklassis, kuid R9 290/GTX970...GTX980 kiirusega. Hind jäi samaks. Kõik nurisevad, et miks kiirem pole.
Ma ei saa inimestest aru. Ausalt.
elukaz kirjutas:
Ma ei ole vandenõuteoreetik. Hetkeolukord on see, et äärmised stsenaariumid toovad välja probleemi kaardi voolutarbes. Nagu näha on AMD probleemi tuvastanud ja fix on tulekul. Pole nagu midagi rohkem rääkida. thumbs_up.gif beer_yum.gif
Timoo87 kirjutas:
fix tuleb
donaldTBD
sõnum 02.07.2016 12:49:20 vasta tsitaadiga
anubis kirjutas:
http://i.imgur.com/LzDaZ78.png
Tegelikult on inimesed alati sellised olnud. Tänapäeval on lihtsalt igaühel võimalik anonüümselt ja turvaliselt oma arvamust avaldada ning selle pärast me viimasel ajal seda igal pool nii palju näemegi. Just täna hommikul lugesin järjekordset PC vs console teemat - täpselt sama asi. Nooruspõlvest tuleb meelde täitsa tõsine juhtum, kus ühel inimesel oli vaja foorumis tekitada konflikt mis põhines sellel, et tema sõitis audiga ning mina bmwga.
Millegipärast on inimestel jube vajadus endale ja teistele pidevalt tõestada, et nemad (või misiganes kommuun või arvamusgrupp kuhu nad kuuluvad) on parem kui kõik konkurendid. See vajadus on suurem kui igasugune ratsionaalne võime olukordadest aru saada ning neid objektiivselt hinnata. Antud juhul siis ei suudeta aru saada sellest mida sina just kirjutasid ning on vaja ikka võrrelda asju mis ei ole võrreldavad ning ära mainida, et amd on ikkagi nvideast maas sest rx480 < 1070.
elukaz
elukaz
sõnum 02.07.2016 12:58:06 vasta tsitaadiga
Fiks tuleb neile kes võtavad vaevaks seda rakendada, pealegi ma kahtlustan et driveriga ei saa jagada kummast pesast voolu võetakse vaid tõmmatakse lihtsalt perfi maha et jeeli jeeli spekki mahtuda, näiteks kohitsetakse power limiti heeblit ja kõik. Mis ei lahenda midagi sest suurusjärkudes jääb kõik samaks, 75W on ka liiga palju aga siiski jokk.
Peale selle jääb ikkagi järjest suurenev riskigrupp sest fiks ei rakendata mitte kaardile vaid tulevasele tarkvarale ja miks peaks average joe seda uuendama kui vana töötab? See peaks ikka rauas kinni olema või vähemalt bioses.
anubis
anubis
sõnum 02.07.2016 13:03:57 vasta tsitaadiga
Seoses WattMani kasutusega on AMD'l üsna lihtne driveriuuendusega igal Pstatel väikseid muutusi teha. Driveriuuendused on nädal peale kaardi launchi nagunii elementaarsed asjad mida teha ja see uudis on juba kella külge pandud nagunii.
Nvidial on seoses lukustatud voltidega midagi sellist palju keerulisem parandada, GPU BIOSi uuendus on midagi mida 99,99% kasutajatest ise ei tee.
edit: isiklik kogemus, voolulimiidi madaldamine toob tavakasutuse juures enamasti võitu, äärmuslikumad stsenaariumid (furmark, gpgpu ja mündikaevandamine) näevad selle järel kiiruslangust kuid mängudes jääb tänu kivi madalamale temperatuurile kaardil enamasti võimekust kõrgemaid sagedusi püüda. Ehk et kerge undervolt tähendab enamasti paremat jõudlust.
viimati muutis anubis 02.07.2016 13:06:57, muudetud 1 kord
Vondur
Vondur
sõnum 02.07.2016 13:14:50 vasta tsitaadiga
anubis, Hea, et keegi on veel selge mõistuse juures!
Muidu on neid rohelisi doomsday kuulutajaid juba piinlik lugeda.
Kõige rohkem undavad need, kelle profiilis on permanentselt nVidia kaardid ja kes ei plaanigi AMD omi osta...
See paneb mind alati imestama, miks on kõige häälekamad just need, kellel asjaga kõige vähem pistmist.
Minu järgmiseks kaardiks saab küll mitte AMD, vaid nVidia, aga no kurat, see roheliste tobe ja fanaatiline ristiretk AMD vastu ajab mind alati õelaks. icon_biggrin.gif
anubis
anubis
sõnum 02.07.2016 13:24:28 vasta tsitaadiga
Ma võtaks isegi GTX1070'ne kui hinnas poleks €100..200 õhku sees. Praeguse seisuga saan kaks RX 480 sama hinnaga.
Diesel157
sõnum 02.07.2016 13:33:41 vasta tsitaadiga
Loodan, et järgmine nädal lähevad ka meil hinnad alla ära ja tuleb 4GB variante kah. Hetkel ikka soodne €319 vs €269 saksa omad, kaarte jagub kah küllaga.
Kommentaarid: 162 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 146
Vael
sõnum 02.07.2016 13:37:53 vasta tsitaadiga
ot:
anubis kirjutas:
EPS 8pin pistik on minu arusaaamist mööda olnud ikka CPU-de ülekellamiseks...ei näe peale ATX power connectorite nagu suurt midagi: http://dlcdnet.asus.com/pub/ASUS/mb/LGA2011/X99-A/E10088_X99-A_UG_V3_U_for_web_only.pdf?_ga=1.62870570.783023283.1417050335
tegemist 3xSLI emaplaadiga ja NVidial asjad rangelt regullitud...
sõnum 02.07.2016 14:10:13 vasta tsitaadiga
anubis, Võta kasutaja liiv käest? Temal hulga normaalsemad hinnad thumbs_up.gif
kaspar737
sõnum 02.07.2016 14:22:12 vasta tsitaadiga
anubis kirjutas:
Võimalik, et AMD testis nt 1000 kaarti ja pani voldid paika kõigile kõige kehvema kaardi järgi, ehk mõned kaardid võivad peale uuendust ebastabiilseks minna.
anubis
anubis
sõnum 02.07.2016 14:47:09 vasta tsitaadiga
EPS12v 8pin annab emaplaadile maksimaalselt 28A 12v liinil. Ehk siis peak 336W. Enam kui piisav et ainult sellekaudu tavakasutuse juures 3x PCIe graafikakaarti üle PCIe (225W) + CPU (100W) ära toita (eeldame siis hetkel mitte-AMD cpud), juhul kui toitejuhtmed on korralikud.
ATX12v 4pin annab emaplaadile maksimaalselt 16A 12v liinil. Ehk siis peak 192W.
ATX 24pin annab emaplaadile maksimaalselt 12A 12v liinil. Ehk siis peak 144W. (see siis lisaks EPS12v ja ATX12v pistikule, max 480W/336W kokku). Kui kasutada kolme videokaarti kuid emaplaati, millel ATX12v 4pin toide ja MITTE kasutada PCIe extenderitel molexi/sata lisatoidet siis lähebki tarbimine üle speci. Hetkel siis, eelneva mündikaevandaja näitel, kus kolm kaarti (võttes aluseks teadaoleva 80W üle PCIe x16 siini tarbimise) ja CPU kokku tarbisidki rohkem kui emaplaat sai turvaliselt kohale toimetada. Sellest ka väljatoodud tsitaat.
Lisaks, toiteplokk/emaplaat peaks ennast ülekoormuse korral välja lülitama, mitte juhtmetel laskma üles sulada. Kahtlustaks ka seda, et sätteid on "timmitud" sobivaks, et seda välistada.
http://www.playtool.com/pages/psuconnectors/connectors.html
Tomorrow kirjutas:
sõnum 02.07.2016 14:54:56 vasta tsitaadiga
anubis kirjutas:
Või oli lihtsalt sitt kontakt, klemmid natuke välja veninud või väsinud, hakkas lihtsalt sädelema nii suure koormuse all ja...
anubis
anubis
sõnum 02.07.2016 14:58:26 vasta tsitaadiga
Jah, kui ATX 24 korduvalt jõuga välja võtta ja tagasi suruda saavad ühendused korralikult valu.
Vael
sõnum 02.07.2016 15:13:45 vasta tsitaadiga
anubis kirjutas:
Ma arvan ka, et vähe teateid (ainult 3 siiani) RX 480 kohta, sest esiteks ülekellatud ning teiseks kehvemapoolen väikeste vigadega(kui üldse tehases testiti siis speci järgi läks üle) ning kokku ongi halb kokkulangevus. Eks vähegi korralikum emaplaat toodetakse ikka väikse varuga, aga kui on mingi silmaga nähtamatu viga, ise videokaardiga PCI-e pesa kangutanud, siis natuke suurem koormus võibki vea välja tuua...
Edit: ega emaplaatidele eraldi teemat vist polegi? võib sama hästi siia kribada siis:
anubis kirjutas:
Tomorrow kirjutas:
Ma kaldun ikkagi arvama, et 4\8pin CPU connector varustab vooluga ainult CPU-d, miks muidu P4-ajast CPU connectori nime all.
Samuti pole ülevaadetes silma jäänud riserite kasutamine 3\4 way CF\SLI puhul, eeldusel, et kaardid üle antud näitude ei lähe.
Selleks ongi spesifikatsioonid, et on rangelt paigas, mis piiridest üle ei tohi minna ja kui tavakasutaja läheb poodi ja küsib 3x Titan-X, 3-SLI sertiga emaplaadile, siis ei pea ta mingite molexi julladega enam jändama.
Minu seisukoht, seni kuni keegi ATX specist vastupidist ei tsiteeri...
viimati muutis Vael 02.07.2016 15:17:35, muudetud 1 kord
elukaz
elukaz
sõnum 02.07.2016 15:16:25 vasta tsitaadiga
Kes kaevamisega tegelenud sellele ei tule probleem üllatusena. Asi ei ole nõrgas toiteplokis või kehvas kontaktis, atx24pin kontaktid lihtsalt ei kannata ülekoormust ja põlevadki sõltumata kui hea emaplaat või toiteplokk sul on. Kui varem oli selleks vaja umbes neli lisatoiteta kaarti siis paistab et nüüd võib piisata promotud crossfire lahendusest. Või lausa ühest kaardist kui pcie pesa enda klemmid valule vastu ei pea. Prose toiteots ei mängi siin rolli, pcie-d see ei toida.
anubis
anubis
sõnum 02.07.2016 15:27:59 vasta tsitaadiga
Kuidas siis üle ATX 24pini maksimaalse 144W [12v 12A] (peak) kolm videokaarti ära toidetakse? Ikka võetakse juurde mujalt kus võimalik.
sõnum 02.07.2016 15:29:10 vasta tsitaadiga
anubis kirjutas:
võta mingi pci-e extender ligi ja tõmba sealt vajalikud otsad välja icon_smile.gif
- londiste
anubis
anubis
sõnum 02.07.2016 15:30:47 vasta tsitaadiga
Mul, kui nüüd mõelda, on 2tk pcie8x->pcie16x extendereid. Peab vaatama, kas saan hakkama. thumbs_up.gif
elukaz
elukaz
sõnum 02.07.2016 15:35:58 vasta tsitaadiga
anubis kirjutas:
Prose toide ei ole otseühenduses pcie pesaga aga atx24 on, kui toide voolu ei piira siis sealt võetaksegi nii kaua kui klemmid punased.
Võimalik et on olemas ka emaplaadid kus on võimalik voole pistikute vahel jagada aga pigem on mindud lisaühenduste teed.
anubis
anubis
sõnum 02.07.2016 16:00:33 vasta tsitaadiga
Kui oleks nii siis ei saaks üle ühe PCIe x16 pesa emaplaadile panna, minumeelest? 144W on peak.
Slazenger
Slazenger
sõnum 02.07.2016 16:24:32 vasta tsitaadiga
kuskil videos mainiti, et ühe PCI-e taluvuslävend on 300W. Kui ei eksi, siis utube-s jayztwocents mainis seda RX480 Crossfire videos.
Kommentaarid: 74 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 69
sõnum 02.07.2016 16:31:35 vasta tsitaadiga
Slazenger kirjutas:
Slazenger, pci-express kaardi spec on kuni 300w. see aga hõlmab ka 6-pin ja 8-pin otsi, vastavalt 75w ja 150w.
pci-express slotist võetakse kuni 75w (tehniliselt, 12V pealt kuni 5.5A - 66W).
- londiste
Diesel157
sõnum 02.07.2016 16:32:21 vasta tsitaadiga
2x R9 270 millel on 6pin ainult, emaplaadil CF-is(75 emaplaadilt ja 75 6pin, x2 ja ongi juba idee poolest 150W emaplaadilt + 150W otse toitest).
elukaz
elukaz
sõnum 02.07.2016 19:39:53 vasta tsitaadiga
anubis kirjutas:
Midagi võetakse 3,3V otsast kah nii et speki järgi saaks üle 150W kätte ja teoorias peaks plate kaardile ütlema kui palju ta voolu tarbida võib, kui on kolm kaarti siis ilmselt ei paku kõigile 75W. Kas seda suhtlemist reaalselt kasutatakse ei tea.
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  AMD RX400/500 "Polaris" seeria arutelu mine lehele eelmine  1, 2, 3 ... 21, 22, 23 ... 51, 52, 53  järgmine
