uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  AMD RX400/500 "Polaris" seeria arutelu märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 42, 43, 44 ... 103, 104, 105  järgmine
Kristoferr
Kristoferr
sõnum 02.07.2016 08:52:29 vasta tsitaadiga
Nahu näha, siis PCI voolutarve on rohkem pseudoprobleem. Küll aga pole seda TDP ületamine.
Liitu Binance'ga
Liitu Honey'ga
Kommentaarid: 259 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 210
sõnum 02.07.2016 09:12:54 vasta tsitaadiga
sõnum 02.07.2016 10:08:43 vasta tsitaadiga
sannukas00 kirjutas:
http://www.pcper.com/reviews/Graphics-Cards/Power-Consumption-Concerns-Radeon-RX-480/Evaluating-ASUS-GTX-960-Strix
- londiste
anubis
anubis
sõnum 02.07.2016 10:38:15 vasta tsitaadiga
http://www.tomshardware.com/reviews/geforce-gtx-750-ti-review,3750-20.html
http://www.tomshardware.com/reviews/amd-radeon-rx-480-polaris-10,4616-9.html
GTX750Ti'd peaks järelikult samamoodi emaplaate põletama, pole kuulnud. Torm veeklaasis?
Kommentaarid: 326 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 277
sõnum 02.07.2016 10:40:14 vasta tsitaadiga
anubis, 62w ja 64w? in spec.
http://www.pcper.com/reviews/Graphics-Cards/Power-Consumption-Concerns-Radeon-RX-480/Evaluating-ASUS-GTX-960-Strix kirjutas:
One interesting note on our data compared to what Tom’s Hardware presents – we are using a second order low pass filter to smooth out the data to make it more readable and more indicative of how power draw is handled by the components on the PCB. Tom’s story reported “maximum” power draw at 300 watts for the RX 480 and while that is technically accurate, those figures represent instantaneous power draw. That is interesting data in some circumstances, and may actually indicate other potential issues with excessively noisy power circuitry, but to us, it makes more sense to sample data at a high rate (10 kHz) but to filter it and present it more readable way that better meshes with the continuous power delivery capabilities of the system.
Some gamers have expressed concern over that “maximum” power draw of 300 watts on the RX 480 that Tom’s Hardware reported. While that power measurement is technically accurate, it doesn’t represent the continuous power draw of the hardware. Instead, that measure is a result of a high frequency data acquisition system that may take a reading at the exact moment that a power phase on the card switches. Any DC switching power supply that is riding close to a certain power level is going to exceed that on the leading edges of phase switches for some minute amount of time. This is another reason why our low pass filter on power data can help represent real-world power consumption accurately. That doesn’t mean the spikes they measure are not a potential cause for concern, that’s just not what we are focused on with our testing.
- londiste
anubis
anubis
sõnum 02.07.2016 10:44:54 vasta tsitaadiga
Seda mõtlesin.
Vondur
Vondur
sõnum 02.07.2016 10:49:33 vasta tsitaadiga
londiste kirjutas:
http://www.tomshardware.com/reviews/nvidia-geforce-gtx-960,4038-8.html
Aga siis ma küll ei näinud, et sa hädakella oleksid löönud ja "epic fail" igasse ilmakaarde hõiganud... icon_biggrin.gif
Kaua selle pcper artikli otsas veel ratsutada saab? Kus on teised? Kus on kõik need miljonid maha põlenud emaplaadid?
anubis
anubis
sõnum 02.07.2016 10:57:10 vasta tsitaadiga
Midagi ilusat hetkelandmetel, jah, ei paista. Samas midagi eriti koledat ka mitte.
Niiumbes viie päeva pärast saan ise testida, kahju, et korralikku varustust pole voolutarbe täpseks mõõtmiseks icon_sad.gif
hondaa
hondaa
sõnum 02.07.2016 10:58:38 vasta tsitaadiga
kogu probleem oleneb selles, et tomshw mõõdetud hetkeline voolutarve läheb üle 150w? päris paljud kaardid tõmbavad hetkeliselt nende testis korralikke numbreid, mingi hetk keegi tahtis isegi suuremaid 600-700w toiteid soovitada nende mõõtmiste pärast. Pole kuulnud, et 400w toited kõik maha põleks, niiet see mõõtmise metood on üsnagi küsitav. Aga nagu ikka peab custom versioonid ära ootama. Hetkel minu jaoks pettumus, 980 võinuks kiirem olla. eks custom versioonid ja uued driverid võivad asja leevendada, aga eks ole näha, hetkel jääb 1060 ootama.
elukaz
elukaz
sõnum 02.07.2016 11:16:51 vasta tsitaadiga
Paistab et läheb ikka päris koledaks mida rohkem tagasikutsumisega oodatakse. Kui vähegi crossfire kasutada nagu kogu aeg on rõhutatud siis hakkab plaate minema nagu leiba.
6 tundi kaevandamist mahakellatud kaartidega: https://bitcointalk.org/index.php?topic=1433925.msg15438988#msg15438988
Kommentaarid: 188 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 152
kaspar737
sõnum 02.07.2016 11:17:56 vasta tsitaadiga
anubis kirjutas:
Seda mõtlesin.
Peak ei ole probleem, see kui kaardi keskmine voolutarve on 10W üle speci on probleem.
Timoo87
Timoo87
sõnum 02.07.2016 11:23:23 vasta tsitaadiga
rx 480 laseb pidevalt üle pcie speci, need mõned nvidia kaardid ainult peak-ivad sellest üle.
selline quote ka pcper artiklist:
With our ability to measure voltage and current, we return back to Metro: Last Light at 4K to find that amperage draw over the motherboard's +12V line stays right at 2.5A. That is a drastic difference compared to the RX 480 hitting more than 7A over the same line, especially considering the 5.5A limit from the PCI Express specification.
anubis
anubis
sõnum 02.07.2016 11:39:08 vasta tsitaadiga
elukaz kirjutas:
https://bitcointalk.org/index.php?topic=1433925.msg15439621#msg15439621
wrong he was using unpowered ribbon risers , recipe for disaster long term
Timoo87 kirjutas:
Nägin nüüd, jep. 62-65W avg 750Ti vs 80W avg RX 480.
BIOSi uuendusest peaks piisama, et muuta vahekord 1/3 PEG 2/3 PCIe 6p.
viimati muutis anubis 02.07.2016 11:39:45, muudetud 1 kord
elukaz
elukaz
sõnum 02.07.2016 11:39:11 vasta tsitaadiga
anubis kirjutas:
elukaz kirjutas:
See ongi sama kui sa ühendad kaardi otse emaplaadile, mängurid ju ei kasuta risereid. Kuigi nüüd peaks hakkama, AMD võiks pakki juurde visata 16>16 power riseri icon_biggrin.gif
anubis
anubis
sõnum 02.07.2016 11:41:11 vasta tsitaadiga
Mängimine ei tekita kunagi sellist koormust nagu kaevandamine.
Ja toome mängu selle toreda fakti, et ükski tavakasutajadetail ei ole mõeldud töötama 24/7 täiskoormusel. Out-of-spec töökoormus. Omal vastutusel.
elukaz
elukaz
sõnum 02.07.2016 11:44:16 vasta tsitaadiga
Misasi on out of spec? Kas furmarkiga võib kaardi stabiilsust testida? Kui kaua? Mitu tükki korraga? Kas Metro Last Night võib 4x crossfires mängida? Kui kaua?
Timoo87
Timoo87
sõnum 02.07.2016 11:53:21 vasta tsitaadiga
elukaz kirjutas:
pcie slotist ei tohiks üle 75W tõmmata, kui tõmbab rohkem vatte siis võib pahasti minna. seda ilma spets tehnikata mõõta ei saa. crossfire kohta jään vastuse võlgu. jutt oli muidu 4K resolutsioonist, mitte crossfirest.
viimati muutis Timoo87 02.07.2016 11:56:03, muudetud 1 kord
anubis
anubis
sõnum 02.07.2016 12:12:10 vasta tsitaadiga
24/7 arvutuskoormuse jaoks on sertifitseeritud Teslad. Lisaks on sertifitseeritud platvorm kus need kaardid paiknema saavad (toiteplokid, emaplaat, õhuvool, temperatuur õhu sissevõtu poolel jne)
Kui sa jooksutad furmarki üle tunni siis sa otsid probleeme, mitte ei testi kaarti.
edit: lisaks, 3 v 4x Crossfire võimaldavad emaplaadid peaksid omama lisatoidet PEG siinidele (molexi vms ühendusege) ja olema EPS12 emaplaadi lisatoite pistikuga, mitte ATX 4pin.
Timoo87
Timoo87
sõnum 02.07.2016 12:14:44 vasta tsitaadiga
https://www.techpowerup.com/223833/official-statement-from-amd-on-the-pci-express-overcurrent-issue
fix tuleb
Le Inc
Le Inc
sõnum 02.07.2016 12:18:24 vasta tsitaadiga
Vaadates RX480 CrossFire kooslust siis on selle võimsus enam-vähem ühe GTX1070 kanti, seda siis ainult neis mängudes kus kahe videokaardi tugi on toetatud. Arvestades et kahe RX480 hind on enam-vähem samasse auku (teoorias võiks olla) 1070, siis on nVidia lahendus igati pidi mõistlikum. Lisaks saab 1070 korralikumalt kellata.
Huvitav on see et keskeltläbi on RX480 3..5% kiirem kui GTX970, seda eriti üle FHD resolutsioonil (ilmselt tänu 8 GB mälule).
Kaart oleks võinud välja tulla koos 970, siis oleks asjal pointi olnud. thumbs_up.gif
viimati muutis Le Inc 02.07.2016 12:19:09, muudetud 1 kord
Timoo87
Timoo87
Le Inc kirjutas:
See kaart oleks võinud välja tulla koos 970, siis oleks asjal pointi olnud. thumbs_up.gif
970 tuli 199$ välja?
Evil14
Evil14
sõnum 02.07.2016 12:19:58 vasta tsitaadiga
Timoo87 kirjutas:
Le Inc kirjutas:
viimati muutis Evil14 02.07.2016 12:20:16, muudetud 1 kord
Kommentaarid: 222 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 194
Le Inc
Le Inc
sõnum 02.07.2016 12:20:45 vasta tsitaadiga
Timoo87 kirjutas:
Le Inc kirjutas:
Ma ei räägi hinnast, vaid võimsusest. Siis oleks AMD võinud ka 2x rohkem raha küsida. Aga noh mis teha kui oled sammukese teisest maas. Asi ikka. icon_biggrin.gif
Timoo87
Timoo87
sõnum 02.07.2016 12:24:18 vasta tsitaadiga
Le Inc kirjutas:
See kaart millest sa räägid kõlab nagu r 390.
elukaz
elukaz
sõnum 02.07.2016 12:28:49 vasta tsitaadiga
anubis, kas tegu on siis selle konkreetse kaardi jaoks välja mõeldud vandenõuga ja tegelikult probleemi polegi?
Aeg on näidanud et atx 24pin 12V otsad ei talu eriti voolu, ise sellega rohkem kui korra kokku puutunud. Kui masina tervist hinnatakse tavaliselt prose ja videokaardi temperatuuride järgi siis kahjuks ei saa juhtmeühenduste tempi lihtsate meetoditega mõõta. Ja nii võidki vaadata et oh mul kena stabiilne masin ja tempid kontrolli all, aga mingi hetk hakkavad lambi restardid, kindel märk on see kui masin kohe käima ei lähe vaid 10 minutit jahtuda tahab.
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  AMD RX400/500 "Polaris" seeria arutelu mine lehele eelmine  1, 2, 3 ... 42, 43, 44 ... 103, 104, 105  järgmine
