uus teema   vasta Hinnavaatlus »  Fotograafia »  Canoni arutelu märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 51, 52, 53 ... 77, 78, 79  järgmine
eltso
eltso
sõnum 16.01.2012 23:49:42 vasta tsitaadiga
Heineken
sõnum 17.01.2012 00:28:54 vasta tsitaadiga
Matti, contrast detection jaoks ei ole see vajalik. Ainult phase detectioni jaoks. Uuematel LV'ga digipeeglitel on mõlemad valikus.
sõnum 23.01.2012 02:38:35 vasta tsitaadiga
Läheb ka Sony teemasse, aga ehk sobib ka veel siia:
http://www.dpreview.com/news/2012/01/17/Metabones_Conurus
Metabones and Conurus create Canon EF to Sony E-mount 'smart adapter'.
Vancouver, Canada, January 18, 2012 - Metabones forms a strategic partnership with Conurus of Vancouver, Canada to jointly develop, manufacture and market a new Smart Adapter(TM) series of products featuring electronic interfacing with the lens.
The partnership is shipping its first fruition of collaboration today, a Smart Adapter that integrates a Canon EF mount lens to a Sony NEX camera body. Electronic aperture is directly controlled by the camera body and all exposure modes are available. Image stabilization (if the Canon EF lens supports it) and EXIF are supported, but there is no autofocus. This new smart adapter is marketed under the Metabones brand name and may be ordered directly from conurus.com or from a Metabones distributor in Japan, the United Kingdom, Hong Kong or China for US$399.
Metabones is known for mechanical design that is already significantly ahead of the competition, as can be seen with the Contax G lens adapters for Micro 4/3 and Sony NEX with ultra-wide focusing rings and smooth manual focus action, and the ALPA lens to Leica M adapter with rangefinder coupling. Now, incorporating leading-edge electronic technology from Canada brings forth a new breed of adapters that not only truly integrates the lens with the camera body but offers the best workmanship, accuracy and reliability as well.
HV-s ID-kaardiga autentimine
lolloom
lolloom
sõnum 03.02.2012 16:08:00 vasta tsitaadiga
On keegi vaadanud shutter count'i 20D kaameral sellel viisil? Kuivõrd tõene see olla võiks?
Ühel kaameral, mille läbisõiduks (esimene) omanik ~5k väitis, oli tulemus 15k. Teisel isendil, mille lõbisõiduks väideti ~9k, kinnitas seda ka soft.
Kommentaarid: 244 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 209
MelesMeles
sõnum 04.02.2012 02:18:59 vasta tsitaadiga
5 või 15, poogen. icon_rolleyes.gif 50k pole ka veel mingi number, et peaks muret tundma.
Allkiri
Kommentaarid: 268 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 194
dud66
dud66
sõnum 04.02.2012 09:39:29 vasta tsitaadiga
MelesMeles, Kui öeldakse, et on 5 aga tegelt 15, siis minujaoks oleks see juba põhimõtteline küsimus
Soovitaksin proovida läbi kõik võimalused, mis google pakub ja kui ei saa seda 5k tulemust, siis lihtsalt küsida, millega mõõdeti enne (Kui enne polnud just kõrvaga mõõdetud)
Kommenteerige kasutajaid, siis teavad teised ka mida oodata!
Kommentaarid: 55 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 52
lolloom
lolloom
sõnum 04.02.2012 12:46:31 vasta tsitaadiga
MelesMeles, ei tunnegi muret, huvitab hoopis selle meetodi toimivus.
One does not simply overclock Sandy Bridge with SetFSB
Ho Ho
Ho Ho
sõnum 04.02.2012 13:23:56 vasta tsitaadiga
60d puhul olid seal aadressil ainult nullid, ehk siis tundub, et tegu on kaameraspetsiifilise valemiga.
sõnum 04.02.2012 14:13:28 vasta tsitaadiga
lolloom kirjutas:
Küsi Eesti ametlikust esinduses Overallist järgi, kas seline meetod on usaldusväärne. Või Canoni enda ülemaailmsest klienditoest. Netis on sedasorti lehti mitmeid, seni pole ükski väga usaldusväärset muljet jätnud. St ametlikult pole kinnitatud, et info õige on.
guud
sõnum 04.02.2012 15:27:56 vasta tsitaadiga
Mida arvate Phottixi akudest?
Ollaz
Ollaz
sõnum 04.02.2012 15:42:18 vasta tsitaadiga
Üks on, tibake suurema mahutavusega kui Canoni originaal, kasutamise ajal erilist vahet ei märka, teenib hästi. Kotis on muidugi laetud akud alati varuks.
Kommentaarid: 83 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 57
sõnum 04.02.2012 16:04:05 vasta tsitaadiga
30D'le sobiv Phottixi aku pidas sama hästi kui originaal, 5Dmk2 oma peab kehvemini (2 eksemplari olen proovinud). Mitte äärmiselt kehvasti kuid vahe on tuntav.
Jaanos
sõnum 05.02.2012 16:52:13 vasta tsitaadiga
Külmaga kindlasti Phottix akut ei soovita. Kah 5D II kogemus. Soojaga pool aastat vana isend toimetas suht võrdselt originaalidega, nii kui alla -5 läks pistab vahetult laetud aku kaamerasse sisestamisel plinkima aku hoiatuse. Seda ühtegi klõpsu tegemata. Hoiatusest hoolimata saab pildistada aga suht vähe 40-50 kaadrit, -10 ga pole isegi kaasa hakanud tassima, need mõnikümmend kaadrit ei päästa icon_sad.gif
40D ja Minoltadega on erinevaid vuffleid proovitud, kordagi ei ole sellist asja esinenud. Tea kas 5D II selline pirtsakas või on konkreetse tootja aku keemiaga viga.
busse
sõnum 05.02.2012 22:48:58 vasta tsitaadiga
mul oli 400D'ga kunagi phottixi akud, kui see tootja veel nö name oli. ei ütleks et -30ga oleks kehvem olnud kui orginaal. töötas väga edukalt. pigem vöib kala vabalt olla ka konkreetses akus.
http://foto.urmo.ee/
Kommentaarid: 60 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 58
Jaanos
sõnum 06.02.2012 10:35:47 vasta tsitaadiga
busse kirjutas:
No ma ise arvasin ka seni seda. Samas Marko sarnasest kogemusest lugedes pigem arvaks, et kala on Phottixi akudes icon_smile.gif
Ja kuna Marko on katsetanud mitte ühe vaid 2 akuga siis teoorias on variant, et äkki kolmas või neljas aku toimetab nagu peaks. Niipalju mul neid poolpiduseid eksemplare ka koguda ei ole kavas icon_biggrin.gif Läheb kallimaks kui originaal ja too jama juurde, et kui voolu vaja ei tea mis seisus värskelt laetud aku parajasti suvatseb olla. Adrenaliinilaksu üritaks teisiti kätte saada, mäletan küll noorusest neid autosõite pooltühja paagiga, et ei tea kas venitab välja... icon_wink.gif
sõnum 06.02.2012 10:55:03 vasta tsitaadiga
Eks alati võib juhtuda, et satub mitu ämbrit teineteise otsa, issanda teed on imelikud. AGa tõenäosus on väike.
Ega ma selle Phottixiga olen rahul - isegi kui peab kehvemini siis on selle hinna eest kvaliteeti küll ja küll. Lihtsalt konkreetset akut põhiakuna ei riski kasutada, on kas akutallas põhiakule toeks või siis varuakuna kaasas.
pohmakas,
käed värisevad
pohmakas,
sõnum 06.02.2012 20:40:20 vasta tsitaadiga
Panen teemasse märgi maha, olen ka nüüd kohe-varsti Canoni perekonnas icon_smile.gif
Kommentaarid: 166 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 137
Raiku
Raiku
sõnum 06.02.2012 21:32:35 vasta tsitaadiga
Heineken
sõnum 07.02.2012 01:26:02 vasta tsitaadiga
Ehk oleks mõistlikum ilusate piltide teemasse märk maha panna? Või ostad kaamera selleks, et selle üle teiste HV'lastega arutleda?
elukaz
elukaz
sõnum 07.02.2012 04:09:16 vasta tsitaadiga
Heineken, sa ostsid kaamera selleks et HV-sse pilte panna?
Piltidest räägitakse pildiinimestega, tehnikast tehnikafoorumis.
Heineken
sõnum 07.02.2012 06:35:21 vasta tsitaadiga
Ei, ma ostsin kaamera selleks et pilte teha.
Tegelikult, pole mõtet tähele panna, niisama õiendan veidi. Mitte pahapärast. icon_razz.gif
Jaanus
Jaanus
sõnum 07.02.2012 10:25:47 vasta tsitaadiga
Canonile on ka lõpuks väljas kauaoodatud normaalzoomi uuendus 24-70mm f2.8 II thumbs_up.gif
http://www.dpreview.com/news/2012/02/07/Canon_24-70mm_F2p8_II_24mm_f2p8_IS_28mm_f2p8_IS
Kommentaarid: 717 loe/lisa Kasutajad arvavad:  :: 0 :: 4 :: 571
sõnum 07.02.2012 10:58:29 vasta tsitaadiga
24 ja 28mm fiksid on küll hea uudis. Hinna kohapealt saab muidugi näha, räägitakse 800 ja 900 dollarist. Hea, et IS on küljes kuna kulub ära... kahju, et IS on küljes kuna see lisab hinda.
dud66
dud66
sõnum 07.02.2012 11:08:28 vasta tsitaadiga
Eks tuleb 24/2,8 ja 28/2,8 hinnad ära oodata aga hea uudis igatahes thumbs_up.gif
ASSAA! elektroonika
sõnum 07.02.2012 12:56:03 vasta tsitaadiga
Kaua oodatud uudis icon_smile.gif Paistab, et 24-70F2.8 on jämedamaks läinud - filtri diameetriks on näha 82mm...
Kommentaarid: 116 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 106
busse
sõnum 07.02.2012 13:23:52 vasta tsitaadiga
mulle ka sobib see uudis. pikemas perspektiivis tähendab, et uued IS'ga L torude vanem pölvkond muutub taaskord soodsamaks.
Heineken
sõnum 07.02.2012 17:07:36 vasta tsitaadiga
Eh... tore oleks kui tol 24-70mm'l oleks IS... pohh sellest kaalust. icon_biggrin.gif
Iseenesest stabikaga mitte-telefiksid on vägagi teretulnud, kahju ainult et ava suhteliselt väike, muidu võiks isegi väikese uuenduse peale mõelda(oleks ava seal F1.8...F2 kanti).
busse
sõnum 10.02.2012 12:29:27 vasta tsitaadiga
ehk siis unustage ülessehaibitud kvaliteettorud, uus viis kuidas saab soodsalt hea objektiivi http://www.petapixel.com/2012/02/09/how-to-increase-the-performance-of-your-canon-kit-lens/
hemmar
sõnum 10.02.2012 12:47:26 vasta tsitaadiga
Mul sigma 70-300mm objel õnneks juba tehasest punane triip kaasas.
High-Q
High-Q
sõnum 10.02.2012 13:26:05 vasta tsitaadiga
kõvemad mehed värvivad pikad teletorud must-helehall triibuliseks, et ikka pro ka kaugelt paistaks icon_wink.gif
teitur
teitur
sõnum 10.02.2012 13:32:27 vasta tsitaadiga
busse kirjutas:
Pildikvaliteet võib ju olla rahuldav aga kasutusmugavuse poolest ei anna neid võrrelda. Jah, pühapäevased pildid lastest ja kassist saab tehtud aga pikemaajalisemaks kasutuseks ei ole need kitid eriti head. Seda enam, et tänapäeval kasutatakse peegelkaameraid filmimiseks ja see tähendab tihtipeale manuaalset fokuseerimist. Näitena 18-55 ja 50mm fix mis on oma pildikvaliteedilt head aga manuaalne fokusseerimine on tõeline nikedamine ja ka automaatse fokusseerimisega jäävad väga häirivad krägina helid video peale. Lisaks veel puudulik tolmu ja niiskuskindlus, aeglasem/ebatäpsem fookus.
Ehk kokkuvõtvalt, hea objektiivi saamiseks ei piisa ainult heast pildikvaliteedist.
dud66
dud66
sõnum 10.02.2012 14:01:47 vasta tsitaadiga
teitur, Kõik uued torud on suunitlusega kiire AF peale ja seetõttu lühikese käiguga, seetõttu ka filmimiseks mitte kõige paremad k.a L
Ja miks peaks üldse filmimisel AF-i kasutama icon_rolleyes.gif ?
High-Q
High-Q
sõnum 10.02.2012 14:12:03 vasta tsitaadiga
dud66 kirjutas:
ei tegelt, filmimisel on valgusjõudu veel enam vaja kui pildil. õhtul linnas teed sa IS-iga ilusti käest pilti ka 1/5-1/10 sekundiga, vähemalt lainurgas kindlasti. 30fps video aga tähendab igaljuhul vähemalt 1/30s säriaega. hämaras pole seda aga alati võtta, seega ainsad opsioonid on valgusjõuline lääts või kõrge iso. isot kõrgele ajada tähendab paratamatu pildikvaliteedikadu, valgusjõuline lääts suure avaga tähendab aga väiksemat teravussügavust.
lihtsalt proovi 50mm EFL >=2.8 avaga 1,5 cropi kaameraga mõne meetri pealt liikuvat inimest filmida, siis saad aru, miks kiire autofookus nii oluline on. käsi ei jõua lihtsalt järgi. võibolla uhkete rullikute ja spets raamiga, aga tavalist suumiringiga jääd kiiresti jänni.
teitur
teitur
sõnum 10.02.2012 18:44:25 vasta tsitaadiga
dud66 kirjutas:
Käib võib lühike olla aga kallimatel objektiividel on inimlik teravustamisrõngas, mis on ühtlase käiguga ja ei tekita üleliia palju heli. Minu toodud näidetel võib öelda, et teravustamisrõngas puudub. Võimalus on aga see on ju sisuliselt esiläätse keeramine ja varjukit kasutades väga ebapraktiline.
Sheffnaste
sõnum 10.02.2012 20:33:53 vasta tsitaadiga
DSLRiga filmides ei kasutata AF. Vähemalt senised Canoni peegelkaameratega mitte. Ja AF kasutamine on suht kasutu, sest ta otsib ikka päris kaua kuni jõuab fookusesse ja kui otsustada kaameraga või kaamera peal oleva suunamikriga heli võtta, siis objega täristamine jääb ilusti peale, mis ei ole samuti päris see, mida oodata. Kui rääkida objektiivist, siis ühest küljest on vaja valgusjõulist obje, mis võimaldaks f/1.4-2'ga lasta, aga siis tuleb muidugi arvestada ka sellega, et olenevalt obje pikkusest võib DoF olla vägagi hõre. Palju lihtsam on võtta mingi enamvähem valgusjõuline lainurk (kuskil 20mm ümber) ja sellega lähedale minna ning DoF on juba märgatavalt kasutatavam.
Väga kasulik vidin filmimisel on follow focus, mis käitub sisuliselt kui käigukast. Sellega on fookust juba üsna lihtne paika saada ning ka hoida, kuna väikseid adjustmente on üpris lihtne teha, rääkimata focus pullidest. Samas kui rääkida headest teravustamisrõngastest filmimisel, siis tasub vaadata Zeissi toodete poole. Üldiselt on nad suure avaga, optiliselt väga kvaliteetsed ning üldjuhul ca 270 kraadise jooksuga MFDst lõpmatuseni.
Muidugi valgusel on kaks külge - kas objektiiv, mis laseb palju valgust sisse, aga samas pead arvestama sellega, et DoF on olenevalt obje pikkusest ja avast 1-20cm või siis investeerida lisavalgustusse. Mu enda kogemus on näidanud, et odavam on võtta mingisugune B.I.G firma valgustus koos vihmavarjude, hajutite, barn doorside või filtritega kui suhteliselt kallis objektiiv, mis laseb palju valgust sisse. Sellises olukorras saab juba vabalt f4-f5.6 filmida, mispuhul on DoF palju laiem. Muidugi siis peab arvestama sellega, et ajakulu on suurem, kuna valgusega tuleb palju mõllata ning lokatsioon peab suhteliselt staatiline olema.
Ollaz
Ollaz
sõnum 10.02.2012 21:25:14 vasta tsitaadiga
Sony uuematel (pool läbipaistev peegel) DSLR-idel on olemas live AF ja seda ilma mingisuguse väristamise ja asjadeta ja väga mõistlik on. Tavalise peegliga aparaatide puhul ei ole jah teda inimlikul moel olemas, D3100 vist omas ka seda võimalust.
High-Q
High-Q
sõnum 10.02.2012 21:46:06 vasta tsitaadiga
nikoni dlsrid (ja ka sony SLT mudelid) suudavad küll live view-s autofookust teha, aga teevad seda väga aeglaselt ehk siis ikkagi kasutu. hetkel peale m43 (ja eelkõige panasonicu GH mudelite) video pidev-AF-i pole mõtet kasutada. uus oly OM-D EM-5 pidi küll päris hea olema ja GH2 live view continuous AF-is troonilt lükkama. m43 AF töö on 100% optimeeritud sensoripõhise CDAF-ile (nii sensor, AF algoritm, läätsed, CPU jne) ja eks nad seda pika puuga kõige paremini ka oskavad, kuid siiski on arenguruumi küllaga (C-AF vigu on ikka liiga palju, single AF on juba päris tip-top).
eks igal süsteemil on omad eelised.
teitur
teitur
sõnum 11.02.2012 23:57:05 vasta tsitaadiga
kellelgi on aimu kust saada 550D tarbeks 12v vooluadapterit? 220v omasid on küllaga aga oleks vaja 12v, timelapse jms. asjade tarvis.
sõnum 12.02.2012 12:28:06 vasta tsitaadiga
teitur, tahad autost voolu võtta? osta 220V inverter vahele.
teitur
teitur
sõnum 12.02.2012 15:57:00 vasta tsitaadiga
Ei taha autost võtta. Tahaks võtta 12v geelaku pealt ja inventer on mõtetult suur sinna vahele panna. Peaks vist otsima otsa mis käib kaamerasse ja siis mingi pingemuunduri, et saaks 7.2v sealt.
Mobileman
sõnum 13.02.2012 00:31:59 vasta tsitaadiga
Mark0 kirjutas:
Nii lühikese toru, millel on pealegi nii suur ava, IS-i mõttekusest ei saa ma hästi aru.
Säriaeg peab ikka megapikaks kiskuma kui 28 mm juures 2,8 ava kasutades ilma värinata pilti tehtud ei saaks. Nii pika säriajaga liikuvast objektist ega arvatavasti ka inimesest (kui ta just teadlikult kramplikult liikumatuna ei püüa olla) pilti ei tee. Kui objekt eest ära ei jookse, siis väga pikaks kiskuva säriaja puhul aitab statiiv. Ei saaks ju IS-i mõne-"stopisele" abile lootma jääda kui ikka tähtis on pilt saada, arvatavasti sellisel puhul niikuinii statiiv kaasas.
17-40 omanikuna ei mäleta küll siiani ühtegi juhust kus oleks stabikast puudust tundnud või veelgi hullem, oleks mõni tähtis pilt selle pärast tegemata jäänud. Looduses loomade-lindude pildistamisel kasutan 300 mm stabikata toru. Nii pika toru korral juba mõnikord tunnen stabikast puudust, kuigi reeglina saab ka ilma hakkama. Hämaras paigal seisvast loomast peaks üsnagi pika säriajaga saama veel hea pildi, võibolla isegi pikema kui 1/30 s, aga jah ilma stabikata sellisel juhul eriti pole lootust teravat pilti saada. Mul jookseb see piir kusagil 1/60-1/125 vahel, tähendab et reeglina 300 mm toruga (poolkaadri ees) saab käest püsti seistes 1/125-ga normaalse pildi tehtud ja kui saab hästi toetada, siis on võimalik ka 1/60, aga mõni nädal tagasi õnnestus hämaras teha ilvesest ilma nähtavate värisemise jälgedeta pilt 1/60 s-ga ning seda käest, püsti seistes, eks oli hea juhus, igal korral see kindlasti ei õnnestuks. Kui oleks hunt olnud (või veelgi hullem- karu, kuigi tegelikult nad magavad talveund veel), siis võibolla poleks ilma värinata hakkama saanud. icon_lol.gif Muidugi ISO oli laes (3200) ja seega ka müra üsna tugev (tuleb välja just hämaras, päeval ISO3200 pole üldse halb), stabikaga oleks saanud vist ISO 800-ga teha ja müra oleks olnud veidi talutavam.
viimati muutis Mobileman 13.02.2012 00:34:51, muudetud 1 kord
Kommentaarid: 45 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 41
Ho Ho
Ho Ho
sõnum 13.02.2012 00:34:35 vasta tsitaadiga
Mobileman, sealt see asi tulebki, et aeg-ajalt on vaja pilti teha üsnagi hämaras icon_smile.gif
Mobileman
sõnum 13.02.2012 00:38:14 vasta tsitaadiga
Sellest saan aru, aga mida sellest lõigust arvad: "Nii pika säriajaga liikuvast objektist ega arvatavasti ka inimesest (kui ta just teadlikult kramplikult liikumatuna ei püüa olla) pilti ei tee. Kui objekt eest ära ei jookse, siis väga pikaks kiskuva säriaja puhul aitab statiiv. Ei saaks ju IS-i mõne-"stopisele" abile lootma jääda kui ikka tähtis on pilt saada, arvatavasti sellisel puhul niikuinii statiiv kaasas."
elukaz
elukaz
sõnum 13.02.2012 00:38:31 vasta tsitaadiga
Mobileman, käest võetud videole on is väga vajalik ka lainurgal ja eredas valguses.
Ho Ho
Ho Ho
sõnum 13.02.2012 00:41:39 vasta tsitaadiga
Mobileman, ütleks niipalju, et igasugu "oleks kolmjalg poleks vaja" ongi pahatihti "oleks", mitte "on" icon_smile.gif
Linnas ringi kolades on tihtipeale fotokas kotis aga jalgu küll ei viitsi sarnaselt kaasa tarida. Kui IS'i lisamine ei pane hinnale mitusada euri otsa siis võiks see u olemas olla, ega ta miskit halba küll ei tee.
sõnum 13.02.2012 00:53:19 vasta tsitaadiga
Ho Ho, IS lisab Canoni puhul julgelt kolmandiku hinda (vaata näiteks 70-200 tavaliste ja stabikaga versioonide hindu).
Mobileman, kaasaegsed stabikad annavad 3-4 EV'd mänguruumi juurde. Muidugi liikuvate objektiivide puhul on teine lugu kuid vähegi staatilisemate hetkede puhul ilma stabikata objektiiviga kasutad ISO 3200, stabikaga ISO200 - vähe on märkimisväärne. Või veel hullem - ISO 6400 versus 400. Või ajame asja täitsa kosmoseks - ISO 12800 versus 800.
Kui sa 17-40 jutuks tõid - mul oli aasta tagasi kogemus Lapimaal polaaröös sama objektiiviga, kus ka "valgel" ajal valgust nappis. Maastiku pildistamisel oli ava kusagil 9-10 kandis, säriaeg 1/25 ning ISO 2000 kuni 3200. Ja no ei riskinud käest pildistades säriaega pikemaks panna kuna niigi oli segavaid faktoreid piisavalt. Hiljem kodus oli natukene nukker vaadata mõnda hetke kuna veebi jaoks oli tulemus igati OK aga natukenegi sisse zoomides või siis seina peale 40x60cm pilti valides - no maastikufoto puhul kuidagi ei tundunud asi õige.
Mobileman
sõnum 13.02.2012 01:01:55 vasta tsitaadiga
elukaz, võimalik, video teemal ei julge kaasa rääkida, sest ei oma kogemust.
Ho Ho, ega arvatavasti siis nö. linnas ringi kolades sa väga ei looda midagi eriliselt head pildile püüda ka, vastasel juhul ei tahaks midagi juhuse hoolde jätta ja kannaksid statiivi ikkagi igaks juhuks kaasas. Näiteks kui ma läheksin IS-ga lainurka omades hommikul enne päikesetõusu kusagile metsa või rabasse hämarast maastikust pilte tegema, siis ei jääks kindlasti lootma, et IS aitab. Võibolla aitab, aga võib juhtuda ka, et jääb elu parim pilt saamata. icon_confused.gif
Mark0 , osadel vist annab jah stabikas 3-4 stopi juurde, aga 300 F4-l peaks vist 2 olema.
Kui juba statiivi mainisin, siis võiks ka küsida, et miks siis mina oma 300 mm puhul IS-st vahel puudust tunnen (aga samas lainurga puhul ei tunne), saaks ju ka statiivi kasutada, näiteks mainitud ilvese pildistamise puhul? Kahjuks on asi nii, tihti on kohtumine mõne loomaga nii ootamatu ja kiire, et on aega ainult klõps või paar teha, statiivi üles sättimine oleks täiesti välistatud.
viimati muutis Mobileman 13.02.2012 01:03:44, muudetud 2 korda
sõnum 13.02.2012 01:02:25 vasta tsitaadiga
Mobileman, 300/4 IS USM stabikas on jah vanem, tean endal praktikas, et 1-2 EV mänguruumi on maksimum. Nood 24 ja 28mm uued fiksid võiksid aga pigem tulla kaasaegse tehnoloogiaga stabikaga.
Mobileman
sõnum 13.02.2012 01:14:29 vasta tsitaadiga
Mark0 kirjutas:
Jah, aga siiski kui tahaks nö. kindla peale välja minna, ei jääks ikkagi lootma, et isegi 4-st stopist piisab ja võtaks igaks juhuks statiivi kaasa. Näiteks kui sa uuesti läheksid lapimaale polaaröö ajal pildistama ning isegi omades stabikaga lainurka, sa ju ei jätaks enam statiivi koju? icon_biggrin.gif Võibolla tõesti kohapeal selgub, et polegi vaja seda kotist välja võtta, see siis olekski ainuke pluss stabikaga lainurga juures? icon_razz1.gif
Seda vist ei tasu jah loota, et stabikas tublisti hinda ei tõsta. Kui ei tõstaks, siis muidugi jah ega ta nö. leiba ei küsiks kui igaks juhuks olemas on. Samas olen kuulnud ka (kuulu?)jutte, et kui võtta 2 ühesugust toru, 1 stabikaga ja teine stabikata, siis ilma stabikata toru joonistab veidi teravamalt/kontrastsemalt vms kuna stabikaga torul on mitu lisaläätse sees ja eks iga lääts mingil määral takistab vms. icon_rolleyes.gif
viimati muutis Mobileman 13.02.2012 01:19:40, muudetud 1 kord
Ho Ho
Ho Ho
sõnum 13.02.2012 01:18:30 vasta tsitaadiga
Kui stabikas annab näiteks 2EV'd ning kolmjalg veel teised 2 (reaalselt küll kõvasti enam sõltuvalt olukorrast) siis on muidugi ideaalne. Samas kui pole kumbag jääd ilma 4 EV'st, kui on vähemalt üks noist siis ainult 2'st icon_smile.gif Plus muidugi seesama mainitud lühike ettevalmistusperiood kus ei jõua kolmjalaga möllama hakata.
Ehk siis ainus probleem on hind, iga muu kandi pealt oleks IS igati kasuks.
uus teema   vasta Hinnavaatlus »  Fotograafia »  Canoni arutelu mine lehele eelmine  1, 2, 3 ... 51, 52, 53 ... 77, 78, 79  järgmine
