uus teema   vasta Hinnavaatlus »  Fotograafia »  Canoni arutelu märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 102, 103, 104 ... 155, 156, 157  järgmine
eltso
eltso
sõnum 16.01.2012 22:49:42 vasta tsitaadiga
Heineken
sõnum 16.01.2012 23:28:54 vasta tsitaadiga
Matti, contrast detection jaoks ei ole see vajalik. Ainult phase detectioni jaoks. Uuematel LV'ga digipeeglitel on mõlemad valikus.
sõnum 23.01.2012 01:38:35 vasta tsitaadiga
Läheb ka Sony teemasse, aga ehk sobib ka veel siia:
http://www.dpreview.com/news/2012/01/17/Metabones_Conurus
Metabones and Conurus create Canon EF to Sony E-mount 'smart adapter'.
Vancouver, Canada, January 18, 2012 - Metabones forms a strategic partnership with Conurus of Vancouver, Canada to jointly develop, manufacture and market a new Smart Adapter(TM) series of products featuring electronic interfacing with the lens.
The partnership is shipping its first fruition of collaboration today, a Smart Adapter that integrates a Canon EF mount lens to a Sony NEX camera body. Electronic aperture is directly controlled by the camera body and all exposure modes are available. Image stabilization (if the Canon EF lens supports it) and EXIF are supported, but there is no autofocus. This new smart adapter is marketed under the Metabones brand name and may be ordered directly from conurus.com or from a Metabones distributor in Japan, the United Kingdom, Hong Kong or China for US$399.
Metabones is known for mechanical design that is already significantly ahead of the competition, as can be seen with the Contax G lens adapters for Micro 4/3 and Sony NEX with ultra-wide focusing rings and smooth manual focus action, and the ALPA lens to Leica M adapter with rangefinder coupling. Now, incorporating leading-edge electronic technology from Canada brings forth a new breed of adapters that not only truly integrates the lens with the camera body but offers the best workmanship, accuracy and reliability as well.
HV valuutakalkulaator
Kommentaarid: 472 loe/lisa Kasutajad arvavad:  :: 13 :: 7 :: 359
lolloom
lolloom
sõnum 03.02.2012 15:08:00 vasta tsitaadiga
On keegi vaadanud shutter count'i 20D kaameral sellel viisil? Kuivõrd tõene see olla võiks?
Ühel kaameral, mille läbisõiduks (esimene) omanik ~5k väitis, oli tulemus 15k. Teisel isendil, mille lõbisõiduks väideti ~9k, kinnitas seda ka soft.
Kommentaarid: 244 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 209
MelesMeles
sõnum 04.02.2012 01:18:59 vasta tsitaadiga
5 või 15, poogen. icon_rolleyes.gif 50k pole ka veel mingi number, et peaks muret tundma.
Allkiri
Kommentaarid: 268 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 194
dud66
dud66
sõnum 04.02.2012 08:39:29 vasta tsitaadiga
MelesMeles, Kui öeldakse, et on 5 aga tegelt 15, siis minujaoks oleks see juba põhimõtteline küsimus
Soovitaksin proovida läbi kõik võimalused, mis google pakub ja kui ei saa seda 5k tulemust, siis lihtsalt küsida, millega mõõdeti enne (Kui enne polnud just kõrvaga mõõdetud)
Kommenteerige kasutajaid, siis teavad teised ka mida oodata!
lolloom
lolloom
sõnum 04.02.2012 11:46:31 vasta tsitaadiga
MelesMeles, ei tunnegi muret, huvitab hoopis selle meetodi toimivus.
One does not simply overclock Sandy Bridge with SetFSB
Ho Ho
Ho Ho
sõnum 04.02.2012 12:23:56 vasta tsitaadiga
60d puhul olid seal aadressil ainult nullid, ehk siis tundub, et tegu on kaameraspetsiifilise valemiga.
sõnum 04.02.2012 13:13:28 vasta tsitaadiga
lolloom kirjutas:
Küsi Eesti ametlikust esinduses Overallist järgi, kas seline meetod on usaldusväärne. Või Canoni enda ülemaailmsest klienditoest. Netis on sedasorti lehti mitmeid, seni pole ükski väga usaldusväärset muljet jätnud. St ametlikult pole kinnitatud, et info õige on.
Kommentaarid: 182 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 146
guud
sõnum 04.02.2012 14:27:56 vasta tsitaadiga
Mida arvate Phottixi akudest?
Ollaz
Ollaz
sõnum 04.02.2012 14:42:18 vasta tsitaadiga
Üks on, tibake suurema mahutavusega kui Canoni originaal, kasutamise ajal erilist vahet ei märka, teenib hästi. Kotis on muidugi laetud akud alati varuks.
Kommentaarid: 83 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 57
sõnum 04.02.2012 15:04:05 vasta tsitaadiga
30D'le sobiv Phottixi aku pidas sama hästi kui originaal, 5Dmk2 oma peab kehvemini (2 eksemplari olen proovinud). Mitte äärmiselt kehvasti kuid vahe on tuntav.
Jaanos
sõnum 05.02.2012 15:52:13 vasta tsitaadiga
Külmaga kindlasti Phottix akut ei soovita. Kah 5D II kogemus. Soojaga pool aastat vana isend toimetas suht võrdselt originaalidega, nii kui alla -5 läks pistab vahetult laetud aku kaamerasse sisestamisel plinkima aku hoiatuse. Seda ühtegi klõpsu tegemata. Hoiatusest hoolimata saab pildistada aga suht vähe 40-50 kaadrit, -10 ga pole isegi kaasa hakanud tassima, need mõnikümmend kaadrit ei päästa icon_sad.gif
40D ja Minoltadega on erinevaid vuffleid proovitud, kordagi ei ole sellist asja esinenud. Tea kas 5D II selline pirtsakas või on konkreetse tootja aku keemiaga viga.
busse
sõnum 05.02.2012 21:48:58 vasta tsitaadiga
mul oli 400D'ga kunagi phottixi akud, kui see tootja veel nö name oli. ei ütleks et -30ga oleks kehvem olnud kui orginaal. töötas väga edukalt. pigem vöib kala vabalt olla ka konkreetses akus.
http://foto.urmo.ee/
Kommentaarid: 60 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 58
Jaanos
sõnum 06.02.2012 09:35:47 vasta tsitaadiga
busse kirjutas:
No ma ise arvasin ka seni seda. Samas Marko sarnasest kogemusest lugedes pigem arvaks, et kala on Phottixi akudes icon_smile.gif
Ja kuna Marko on katsetanud mitte ühe vaid 2 akuga siis teoorias on variant, et äkki kolmas või neljas aku toimetab nagu peaks. Niipalju mul neid poolpiduseid eksemplare ka koguda ei ole kavas icon_biggrin.gif Läheb kallimaks kui originaal ja too jama juurde, et kui voolu vaja ei tea mis seisus värskelt laetud aku parajasti suvatseb olla. Adrenaliinilaksu üritaks teisiti kätte saada, mäletan küll noorusest neid autosõite pooltühja paagiga, et ei tea kas venitab välja... icon_wink.gif
sõnum 06.02.2012 09:55:03 vasta tsitaadiga
Eks alati võib juhtuda, et satub mitu ämbrit teineteise otsa, issanda teed on imelikud. AGa tõenäosus on väike.
Ega ma selle Phottixiga olen rahul - isegi kui peab kehvemini siis on selle hinna eest kvaliteeti küll ja küll. Lihtsalt konkreetset akut põhiakuna ei riski kasutada, on kas akutallas põhiakule toeks või siis varuakuna kaasas.
pohmakas,
käed värisevad
pohmakas,
sõnum 06.02.2012 19:40:20 vasta tsitaadiga
Panen teemasse märgi maha, olen ka nüüd kohe-varsti Canoni perekonnas icon_smile.gif
Kommentaarid: 164 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 136
Raiku
Raiku
sõnum 06.02.2012 20:32:35 vasta tsitaadiga
Heineken
sõnum 07.02.2012 00:26:02 vasta tsitaadiga
Ehk oleks mõistlikum ilusate piltide teemasse märk maha panna? Või ostad kaamera selleks, et selle üle teiste HV'lastega arutleda?
elukaz
elukaz
sõnum 07.02.2012 03:09:16 vasta tsitaadiga
Heineken, sa ostsid kaamera selleks et HV-sse pilte panna?
Piltidest räägitakse pildiinimestega, tehnikast tehnikafoorumis.
Kommentaarid: 190 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 153
Heineken
sõnum 07.02.2012 05:35:21 vasta tsitaadiga
Ei, ma ostsin kaamera selleks et pilte teha.
Tegelikult, pole mõtet tähele panna, niisama õiendan veidi. Mitte pahapärast. icon_razz.gif
Jaanus
Jaanus
sõnum 07.02.2012 09:25:47 vasta tsitaadiga
Canonile on ka lõpuks väljas kauaoodatud normaalzoomi uuendus 24-70mm f2.8 II thumbs_up.gif
http://www.dpreview.com/news/2012/02/07/Canon_24-70mm_F2p8_II_24mm_f2p8_IS_28mm_f2p8_IS
Kommentaarid: 712 loe/lisa Kasutajad arvavad:  :: 0 :: 4 :: 567
sõnum 07.02.2012 09:58:29 vasta tsitaadiga
24 ja 28mm fiksid on küll hea uudis. Hinna kohapealt saab muidugi näha, räägitakse 800 ja 900 dollarist. Hea, et IS on küljes kuna kulub ära... kahju, et IS on küljes kuna see lisab hinda.
dud66
dud66
sõnum 07.02.2012 10:08:28 vasta tsitaadiga
Eks tuleb 24/2,8 ja 28/2,8 hinnad ära oodata aga hea uudis igatahes thumbs_up.gif
ASSAA! elektroonika
sõnum 07.02.2012 11:56:03 vasta tsitaadiga
Kaua oodatud uudis icon_smile.gif Paistab, et 24-70F2.8 on jämedamaks läinud - filtri diameetriks on näha 82mm...
Kommentaarid: 116 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 106
uus teema   vasta Hinnavaatlus »  Fotograafia »  Canoni arutelu mine lehele eelmine  1, 2, 3 ... 102, 103, 104 ... 155, 156, 157  järgmine
