eltso
16.01.2012 22:49:42
minu 60D-l on ka peegel ilusti üleval ja ei roni kuskile
| Kommentaarid: 14 loe/lisa |
14 |
Heineken
16.01.2012 23:28:54
| Matti, contrast detection jaoks ei ole see vajalik. Ainult phase detectioni jaoks. Uuematel LV'ga digipeeglitel on mõlemad valikus.
| Kommentaarid: 24 loe/lisa |
23 |
23.01.2012 01:38:35
Läheb ka Sony teemasse, aga ehk sobib ka veel siia:
http://www.dpreview.com/news/2012/01/17/Metabones_Conurus
Metabones and Conurus create Canon EF to Sony E-mount 'smart adapter'.
Vancouver, Canada, January 18, 2012 - Metabones forms a strategic partnership with Conurus of Vancouver, Canada to jointly develop, manufacture and market a new Smart Adapter(TM) series of products featuring electronic interfacing with the lens.
The partnership is shipping its first fruition of collaboration today, a Smart Adapter that integrates a Canon EF mount lens to a Sony NEX camera body. Electronic aperture is directly controlled by the camera body and all exposure modes are available. Image stabilization (if the Canon EF lens supports it) and EXIF are supported, but there is no autofocus. This new smart adapter is marketed under the Metabones brand name and may be ordered directly from conurus.com or from a Metabones distributor in Japan, the United Kingdom, Hong Kong or China for US$399.
Metabones is known for mechanical design that is already significantly ahead of the competition, as can be seen with the Contax G lens adapters for Micro 4/3 and Sony NEX with ultra-wide focusing rings and smooth manual focus action, and the ALPA lens to Leica M adapter with rangefinder coupling. Now, incorporating leading-edge electronic technology from Canada brings forth a new breed of adapters that not only truly integrates the lens with the camera body but offers the best workmanship, accuracy and reliability as well. |
_________________ HV-s ID-kaardiga autentimine
HV valuutakursid |
7 :: |
360 |
lolloom
03.02.2012 15:08:00
On keegi vaadanud shutter count'i 20D kaameral sellel viisil? Kuivõrd tõene see olla võiks?
Ühel kaameral, mille läbisõiduks (esimene) omanik ~5k väitis, oli tulemus 15k. Teisel isendil, mille lõbisõiduks väideti ~9k, kinnitas seda ka soft.
| Kommentaarid: 244 loe/lisa |
209 |
MelesMeles
04.02.2012 01:18:59
5 või 15, poogen. 50k pole ka veel mingi number, et peaks muret tundma.
_________________ Allkiri |
194 |
dud66
04.02.2012 08:39:29
MelesMeles, Kui öeldakse, et on 5 aga tegelt 15, siis minujaoks oleks see juba põhimõtteline küsimus
Soovitaksin proovida läbi kõik võimalused, mis google pakub ja kui ei saa seda 5k tulemust, siis lihtsalt küsida, millega mõõdeti enne (Kui enne polnud just kõrvaga mõõdetud)
_________________ Kommenteerige kasutajaid, siis teavad teised ka mida oodata! |
| Kommentaarid: 54 loe/lisa |
51 |
lolloom
04.02.2012 11:46:31
MelesMeles, ei tunnegi muret, huvitab hoopis selle meetodi toimivus.
_________________ One does not simply overclock Sandy Bridge with SetFSB |
209 |
Ho Ho
04.02.2012 12:23:56
60d puhul olid seal aadressil ainult nullid, ehk siis tundub, et tegu on kaameraspetsiifilise valemiga.
86 |
04.02.2012 13:13:28
| lolloom kirjutas: |
Ühel kaameral, mille läbisõiduks (esimene) omanik ~5k väitis, oli tulemus 15k. Teisel isendil, mille lõbisõiduks väideti ~9k, kinnitas seda ka soft. |
Küsi Eesti ametlikust esinduses Overallist järgi, kas seline meetod on usaldusväärne. Või Canoni enda ülemaailmsest klienditoest. Netis on sedasorti lehti mitmeid, seni pole ükski väga usaldusväärset muljet jätnud. St ametlikult pole kinnitatud, et info õige on.
147 |
guud
04.02.2012 14:27:56
| Mida arvate Phottixi akudest?
Ollaz
04.02.2012 14:42:18
| Üks on, tibake suurema mahutavusega kui Canoni originaal, kasutamise ajal erilist vahet ei märka, teenib hästi. Kotis on muidugi laetud akud alati varuks.
| Kommentaarid: 83 loe/lisa |
57 |
04.02.2012 15:04:05
| 30D'le sobiv Phottixi aku pidas sama hästi kui originaal, 5Dmk2 oma peab kehvemini (2 eksemplari olen proovinud). Mitte äärmiselt kehvasti kuid vahe on tuntav.
147 |
Jaanos
05.02.2012 15:52:13
Külmaga kindlasti Phottix akut ei soovita. Kah 5D II kogemus. Soojaga pool aastat vana isend toimetas suht võrdselt originaalidega, nii kui alla -5 läks pistab vahetult laetud aku kaamerasse sisestamisel plinkima aku hoiatuse. Seda ühtegi klõpsu tegemata. Hoiatusest hoolimata saab pildistada aga suht vähe 40-50 kaadrit, -10 ga pole isegi kaasa hakanud tassima, need mõnikümmend kaadrit ei päästa
40D ja Minoltadega on erinevaid vuffleid proovitud, kordagi ei ole sellist asja esinenud. Tea kas 5D II selline pirtsakas või on konkreetse tootja aku keemiaga viga.
| Kommentaarid: 10 loe/lisa |
10 |
busse
05.02.2012 21:48:58
mul oli 400D'ga kunagi phottixi akud, kui see tootja veel nö name oli. ei ütleks et -30ga oleks kehvem olnud kui orginaal. töötas väga edukalt. pigem vöib kala vabalt olla ka konkreetses akus.
_________________ http://foto.urmo.ee/ |
| Kommentaarid: 60 loe/lisa |
58 |
Jaanos
06.02.2012 09:35:47
| busse kirjutas: |
| pigem vöib kala vabalt olla ka konkreetses akus. |
No ma ise arvasin ka seni seda. Samas Marko sarnasest kogemusest lugedes pigem arvaks, et kala on Phottixi akudes
Ja kuna Marko on katsetanud mitte ühe vaid 2 akuga siis teoorias on variant, et äkki kolmas või neljas aku toimetab nagu peaks. Niipalju mul neid poolpiduseid eksemplare ka koguda ei ole kavas Läheb kallimaks kui originaal ja too jama juurde, et kui voolu vaja ei tea mis seisus värskelt laetud aku parajasti suvatseb olla. Adrenaliinilaksu üritaks teisiti kätte saada, mäletan küll noorusest neid autosõite pooltühja paagiga, et ei tea kas venitab välja...
10 |
06.02.2012 09:55:03
Eks alati võib juhtuda, et satub mitu ämbrit teineteise otsa, issanda teed on imelikud. AGa tõenäosus on väike.
Ega ma selle Phottixiga olen rahul - isegi kui peab kehvemini siis on selle hinna eest kvaliteeti küll ja küll. Lihtsalt konkreetset akut põhiakuna ei riski kasutada, on kas akutallas põhiakule toeks või siis varuakuna kaasas.
147 |
pohmakas,
käed värisevad
06.02.2012 19:40:20
Panen teemasse märgi maha, olen ka nüüd kohe-varsti Canoni perekonnas
| Kommentaarid: 165 loe/lisa |
137 |
Raiku
06.02.2012 20:32:35
järelikult on veel pisut-pisut aega ümber mõtelda
_________________ Честных психов можно не лечить... |
| Kommentaarid: 58 loe/lisa |
45 |
Heineken
07.02.2012 00:26:02
| Ehk oleks mõistlikum ilusate piltide teemasse märk maha panna? Või ostad kaamera selleks, et selle üle teiste HV'lastega arutleda?
23 |
elukaz
07.02.2012 03:09:16
Heineken, sa ostsid kaamera selleks et HV-sse pilte panna?
Piltidest räägitakse pildiinimestega, tehnikast tehnikafoorumis.
155 |
Heineken
07.02.2012 05:35:21
Ei, ma ostsin kaamera selleks et pilte teha.
Tegelikult, pole mõtet tähele panna, niisama õiendan veidi. Mitte pahapärast.
23 |
Jaanus
| Kommentaarid: 712 loe/lisa |
567 |
07.02.2012 09:58:29
| 24 ja 28mm fiksid on küll hea uudis. Hinna kohapealt saab muidugi näha, räägitakse 800 ja 900 dollarist. Hea, et IS on küljes kuna kulub ära... kahju, et IS on küljes kuna see lisab hinda.
147 |
dud66
07.02.2012 10:08:28
Eks tuleb 24/2,8 ja 28/2,8 hinnad ära oodata aga hea uudis igatahes
51 |
ASSAA! elektroonika
07.02.2012 11:56:03
Kaua oodatud uudis Paistab, et 24-70F2.8 on jämedamaks läinud - filtri diameetriks on näha 82mm...
106 |
