eltso
16.01.2012 23:49:42
minu 60D-l on ka peegel ilusti üleval ja ei roni kuskile
| Kommentaarid: 14 loe/lisa |
14 |
Heineken
17.01.2012 00:28:54
| Matti, contrast detection jaoks ei ole see vajalik. Ainult phase detectioni jaoks. Uuematel LV'ga digipeeglitel on mõlemad valikus.
| Kommentaarid: 24 loe/lisa |
23 |
23.01.2012 02:38:35
Läheb ka Sony teemasse, aga ehk sobib ka veel siia:
http://www.dpreview.com/news/2012/01/17/Metabones_Conurus
Metabones and Conurus create Canon EF to Sony E-mount 'smart adapter'.
Vancouver, Canada, January 18, 2012 - Metabones forms a strategic partnership with Conurus of Vancouver, Canada to jointly develop, manufacture and market a new Smart Adapter(TM) series of products featuring electronic interfacing with the lens.
The partnership is shipping its first fruition of collaboration today, a Smart Adapter that integrates a Canon EF mount lens to a Sony NEX camera body. Electronic aperture is directly controlled by the camera body and all exposure modes are available. Image stabilization (if the Canon EF lens supports it) and EXIF are supported, but there is no autofocus. This new smart adapter is marketed under the Metabones brand name and may be ordered directly from conurus.com or from a Metabones distributor in Japan, the United Kingdom, Hong Kong or China for US$399.
Metabones is known for mechanical design that is already significantly ahead of the competition, as can be seen with the Contax G lens adapters for Micro 4/3 and Sony NEX with ultra-wide focusing rings and smooth manual focus action, and the ALPA lens to Leica M adapter with rangefinder coupling. Now, incorporating leading-edge electronic technology from Canada brings forth a new breed of adapters that not only truly integrates the lens with the camera body but offers the best workmanship, accuracy and reliability as well. |
7 :: |
364 |
lolloom
03.02.2012 16:08:00
On keegi vaadanud shutter count'i 20D kaameral sellel viisil? Kuivõrd tõene see olla võiks?
Ühel kaameral, mille läbisõiduks (esimene) omanik ~5k väitis, oli tulemus 15k. Teisel isendil, mille lõbisõiduks väideti ~9k, kinnitas seda ka soft.
| Kommentaarid: 244 loe/lisa |
209 |
MelesMeles
04.02.2012 02:18:59
5 või 15, poogen. 50k pole ka veel mingi number, et peaks muret tundma.
_________________ Allkiri |
194 |
dud66
04.02.2012 09:39:29
MelesMeles, Kui öeldakse, et on 5 aga tegelt 15, siis minujaoks oleks see juba põhimõtteline küsimus
Soovitaksin proovida läbi kõik võimalused, mis google pakub ja kui ei saa seda 5k tulemust, siis lihtsalt küsida, millega mõõdeti enne (Kui enne polnud just kõrvaga mõõdetud)
_________________ Kommenteerige kasutajaid, siis teavad teised ka mida oodata! |
| Kommentaarid: 55 loe/lisa |
52 |
lolloom
04.02.2012 12:46:31
MelesMeles, ei tunnegi muret, huvitab hoopis selle meetodi toimivus.
_________________ One does not simply overclock Sandy Bridge with SetFSB |
209 |
Ho Ho
04.02.2012 13:23:56
60d puhul olid seal aadressil ainult nullid, ehk siis tundub, et tegu on kaameraspetsiifilise valemiga.
87 |
04.02.2012 14:13:28
| lolloom kirjutas: |
Ühel kaameral, mille läbisõiduks (esimene) omanik ~5k väitis, oli tulemus 15k. Teisel isendil, mille lõbisõiduks väideti ~9k, kinnitas seda ka soft. |
Küsi Eesti ametlikust esinduses Overallist järgi, kas seline meetod on usaldusväärne. Või Canoni enda ülemaailmsest klienditoest. Netis on sedasorti lehti mitmeid, seni pole ükski väga usaldusväärset muljet jätnud. St ametlikult pole kinnitatud, et info õige on.
147 |
guud
04.02.2012 15:27:56
| Mida arvate Phottixi akudest?
Ollaz
04.02.2012 15:42:18
| Üks on, tibake suurema mahutavusega kui Canoni originaal, kasutamise ajal erilist vahet ei märka, teenib hästi. Kotis on muidugi laetud akud alati varuks.
| Kommentaarid: 83 loe/lisa |
57 |
04.02.2012 16:04:05
| 30D'le sobiv Phottixi aku pidas sama hästi kui originaal, 5Dmk2 oma peab kehvemini (2 eksemplari olen proovinud). Mitte äärmiselt kehvasti kuid vahe on tuntav.
147 |
Jaanos
05.02.2012 16:52:13
Külmaga kindlasti Phottix akut ei soovita. Kah 5D II kogemus. Soojaga pool aastat vana isend toimetas suht võrdselt originaalidega, nii kui alla -5 läks pistab vahetult laetud aku kaamerasse sisestamisel plinkima aku hoiatuse. Seda ühtegi klõpsu tegemata. Hoiatusest hoolimata saab pildistada aga suht vähe 40-50 kaadrit, -10 ga pole isegi kaasa hakanud tassima, need mõnikümmend kaadrit ei päästa
40D ja Minoltadega on erinevaid vuffleid proovitud, kordagi ei ole sellist asja esinenud. Tea kas 5D II selline pirtsakas või on konkreetse tootja aku keemiaga viga.
| Kommentaarid: 10 loe/lisa |
10 |
busse
05.02.2012 22:48:58
mul oli 400D'ga kunagi phottixi akud, kui see tootja veel nö name oli. ei ütleks et -30ga oleks kehvem olnud kui orginaal. töötas väga edukalt. pigem vöib kala vabalt olla ka konkreetses akus.
_________________ http://foto.urmo.ee/ |
| Kommentaarid: 60 loe/lisa |
58 |
Jaanos
06.02.2012 10:35:47
| busse kirjutas: |
| pigem vöib kala vabalt olla ka konkreetses akus. |
No ma ise arvasin ka seni seda. Samas Marko sarnasest kogemusest lugedes pigem arvaks, et kala on Phottixi akudes
Ja kuna Marko on katsetanud mitte ühe vaid 2 akuga siis teoorias on variant, et äkki kolmas või neljas aku toimetab nagu peaks. Niipalju mul neid poolpiduseid eksemplare ka koguda ei ole kavas Läheb kallimaks kui originaal ja too jama juurde, et kui voolu vaja ei tea mis seisus värskelt laetud aku parajasti suvatseb olla. Adrenaliinilaksu üritaks teisiti kätte saada, mäletan küll noorusest neid autosõite pooltühja paagiga, et ei tea kas venitab välja...
10 |
06.02.2012 10:55:03
Eks alati võib juhtuda, et satub mitu ämbrit teineteise otsa, issanda teed on imelikud. AGa tõenäosus on väike.
Ega ma selle Phottixiga olen rahul - isegi kui peab kehvemini siis on selle hinna eest kvaliteeti küll ja küll. Lihtsalt konkreetset akut põhiakuna ei riski kasutada, on kas akutallas põhiakule toeks või siis varuakuna kaasas.
147 |
pohmakas,
käed värisevad
06.02.2012 20:40:20
Panen teemasse märgi maha, olen ka nüüd kohe-varsti Canoni perekonnas
| Kommentaarid: 167 loe/lisa |
138 |
Raiku
06.02.2012 21:32:35
järelikult on veel pisut-pisut aega ümber mõtelda
_________________ Честных психов можно не лечить... |
| Kommentaarid: 58 loe/lisa |
45 |
Heineken
07.02.2012 01:26:02
| Ehk oleks mõistlikum ilusate piltide teemasse märk maha panna? Või ostad kaamera selleks, et selle üle teiste HV'lastega arutleda?
23 |
elukaz
07.02.2012 04:09:16
Heineken, sa ostsid kaamera selleks et HV-sse pilte panna?
Piltidest räägitakse pildiinimestega, tehnikast tehnikafoorumis.
158 |
Heineken
07.02.2012 06:35:21
Ei, ma ostsin kaamera selleks et pilte teha.
Tegelikult, pole mõtet tähele panna, niisama õiendan veidi. Mitte pahapärast.
23 |
Jaanus
| Kommentaarid: 720 loe/lisa |
573 |
07.02.2012 10:58:29
| 24 ja 28mm fiksid on küll hea uudis. Hinna kohapealt saab muidugi näha, räägitakse 800 ja 900 dollarist. Hea, et IS on küljes kuna kulub ära... kahju, et IS on küljes kuna see lisab hinda.
147 |
dud66
07.02.2012 11:08:28
Eks tuleb 24/2,8 ja 28/2,8 hinnad ära oodata aga hea uudis igatahes
52 |
ASSAA! elektroonika
07.02.2012 12:56:03
Kaua oodatud uudis Paistab, et 24-70F2.8 on jämedamaks läinud - filtri diameetriks on näha 82mm...
106 |
busse
07.02.2012 13:23:52
mulle ka sobib see uudis. pikemas perspektiivis tähendab, et uued IS'ga L torude vanem pölvkond muutub taaskord soodsamaks.
58 |
Heineken
07.02.2012 17:07:36
Eh... tore oleks kui tol 24-70mm'l oleks IS... pohh sellest kaalust.
Iseenesest stabikaga mitte-telefiksid on vägagi teretulnud, kahju ainult et ava suhteliselt väike, muidu võiks isegi väikese uuenduse peale mõelda(oleks ava seal F1.8...F2 kanti).
23 |
busse
58 |
hemmar
10.02.2012 12:47:26
| Mul sigma 70-300mm objel õnneks juba tehasest punane triip kaasas.
| Kommentaarid: 11 loe/lisa |
High-Q
10.02.2012 13:26:05
kõvemad mehed värvivad pikad teletorud must-helehall triibuliseks, et ikka pro ka kaugelt paistaks
97 |
teitur
10.02.2012 13:32:27
Pildikvaliteet võib ju olla rahuldav aga kasutusmugavuse poolest ei anna neid võrrelda. Jah, pühapäevased pildid lastest ja kassist saab tehtud aga pikemaajalisemaks kasutuseks ei ole need kitid eriti head. Seda enam, et tänapäeval kasutatakse peegelkaameraid filmimiseks ja see tähendab tihtipeale manuaalset fokuseerimist. Näitena 18-55 ja 50mm fix mis on oma pildikvaliteedilt head aga manuaalne fokusseerimine on tõeline nikedamine ja ka automaatse fokusseerimisega jäävad väga häirivad krägina helid video peale. Lisaks veel puudulik tolmu ja niiskuskindlus, aeglasem/ebatäpsem fookus.
Ehk kokkuvõtvalt, hea objektiivi saamiseks ei piisa ainult heast pildikvaliteedist.
| Kommentaarid: 42 loe/lisa |
37 |
dud66
10.02.2012 14:01:47
teitur, Kõik uued torud on suunitlusega kiire AF peale ja seetõttu lühikese käiguga, seetõttu ka filmimiseks mitte kõige paremad k.a L
Ja miks peaks üldse filmimisel AF-i kasutama ?
52 |
High-Q
10.02.2012 14:12:03
| dud66 kirjutas: |
Ja miks peaks üldse filmimisel AF-i kasutama ? |
ef objekt püsiks fookuses?
ei tegelt, filmimisel on valgusjõudu veel enam vaja kui pildil. õhtul linnas teed sa IS-iga ilusti käest pilti ka 1/5-1/10 sekundiga, vähemalt lainurgas kindlasti. 30fps video aga tähendab igaljuhul vähemalt 1/30s säriaega. hämaras pole seda aga alati võtta, seega ainsad opsioonid on valgusjõuline lääts või kõrge iso. isot kõrgele ajada tähendab paratamatu pildikvaliteedikadu, valgusjõuline lääts suure avaga tähendab aga väiksemat teravussügavust.
lihtsalt proovi 50mm EFL >=2.8 avaga 1,5 cropi kaameraga mõne meetri pealt liikuvat inimest filmida, siis saad aru, miks kiire autofookus nii oluline on. käsi ei jõua lihtsalt järgi. võibolla uhkete rullikute ja spets raamiga, aga tavalist suumiringiga jääd kiiresti jänni.
97 |
teitur
10.02.2012 18:44:25
| dud66 kirjutas: |
Käib võib lühike olla aga kallimatel objektiividel on inimlik teravustamisrõngas, mis on ühtlase käiguga ja ei tekita üleliia palju heli. Minu toodud näidetel võib öelda, et teravustamisrõngas puudub. Võimalus on aga see on ju sisuliselt esiläätse keeramine ja varjukit kasutades väga ebapraktiline.
37 |
Sheffnaste
10.02.2012 20:33:53
DSLRiga filmides ei kasutata AF. Vähemalt senised Canoni peegelkaameratega mitte. Ja AF kasutamine on suht kasutu, sest ta otsib ikka päris kaua kuni jõuab fookusesse ja kui otsustada kaameraga või kaamera peal oleva suunamikriga heli võtta, siis objega täristamine jääb ilusti peale, mis ei ole samuti päris see, mida oodata. Kui rääkida objektiivist, siis ühest küljest on vaja valgusjõulist obje, mis võimaldaks f/1.4-2'ga lasta, aga siis tuleb muidugi arvestada ka sellega, et olenevalt obje pikkusest võib DoF olla vägagi hõre. Palju lihtsam on võtta mingi enamvähem valgusjõuline lainurk (kuskil 20mm ümber) ja sellega lähedale minna ning DoF on juba märgatavalt kasutatavam.
Väga kasulik vidin filmimisel on follow focus, mis käitub sisuliselt kui käigukast. Sellega on fookust juba üsna lihtne paika saada ning ka hoida, kuna väikseid adjustmente on üpris lihtne teha, rääkimata focus pullidest. Samas kui rääkida headest teravustamisrõngastest filmimisel, siis tasub vaadata Zeissi toodete poole. Üldiselt on nad suure avaga, optiliselt väga kvaliteetsed ning üldjuhul ca 270 kraadise jooksuga MFDst lõpmatuseni.
Muidugi valgusel on kaks külge - kas objektiiv, mis laseb palju valgust sisse, aga samas pead arvestama sellega, et DoF on olenevalt obje pikkusest ja avast 1-20cm või siis investeerida lisavalgustusse. Mu enda kogemus on näidanud, et odavam on võtta mingisugune B.I.G firma valgustus koos vihmavarjude, hajutite, barn doorside või filtritega kui suhteliselt kallis objektiiv, mis laseb palju valgust sisse. Sellises olukorras saab juba vabalt f4-f5.6 filmida, mispuhul on DoF palju laiem. Muidugi siis peab arvestama sellega, et ajakulu on suurem, kuna valgusega tuleb palju mõllata ning lokatsioon peab suhteliselt staatiline olema.
Ollaz
10.02.2012 21:25:14
| Sony uuematel (pool läbipaistev peegel) DSLR-idel on olemas live AF ja seda ilma mingisuguse väristamise ja asjadeta ja väga mõistlik on. Tavalise peegliga aparaatide puhul ei ole jah teda inimlikul moel olemas, D3100 vist omas ka seda võimalust.
57 |
High-Q
10.02.2012 21:46:06
nikoni dlsrid (ja ka sony SLT mudelid) suudavad küll live view-s autofookust teha, aga teevad seda väga aeglaselt ehk siis ikkagi kasutu. hetkel peale m43 (ja eelkõige panasonicu GH mudelite) video pidev-AF-i pole mõtet kasutada. uus oly OM-D EM-5 pidi küll päris hea olema ja GH2 live view continuous AF-is troonilt lükkama. m43 AF töö on 100% optimeeritud sensoripõhise CDAF-ile (nii sensor, AF algoritm, läätsed, CPU jne) ja eks nad seda pika puuga kõige paremini ka oskavad, kuid siiski on arenguruumi küllaga (C-AF vigu on ikka liiga palju, single AF on juba päris tip-top).
eks igal süsteemil on omad eelised.
97 |
teitur
11.02.2012 23:57:05
| kellelgi on aimu kust saada 550D tarbeks 12v vooluadapterit? 220v omasid on küllaga aga oleks vaja 12v, timelapse jms. asjade tarvis.
37 |
12.02.2012 12:28:06
teitur, tahad autost voolu võtta? osta 220V inverter vahele.
| Kommentaarid: 95 loe/lisa |
teitur
12.02.2012 15:57:00
| Ei taha autost võtta. Tahaks võtta 12v geelaku pealt ja inventer on mõtetult suur sinna vahele panna. Peaks vist otsima otsa mis käib kaamerasse ja siis mingi pingemuunduri, et saaks 7.2v sealt.
37 |
Mobileman
13.02.2012 00:31:59
| Mark0 kirjutas: |
| 24 ja 28mm fiksid on küll hea uudis. Hinna kohapealt saab muidugi näha, räägitakse 800 ja 900 dollarist. Hea, et IS on küljes kuna kulub ära... kahju, et IS on küljes kuna see lisab hinda. |
Nii lühikese toru, millel on pealegi nii suur ava, IS-i mõttekusest ei saa ma hästi aru.
Säriaeg peab ikka megapikaks kiskuma kui 28 mm juures 2,8 ava kasutades ilma värinata pilti tehtud ei saaks. Nii pika säriajaga liikuvast objektist ega arvatavasti ka inimesest (kui ta just teadlikult kramplikult liikumatuna ei püüa olla) pilti ei tee. Kui objekt eest ära ei jookse, siis väga pikaks kiskuva säriaja puhul aitab statiiv. Ei saaks ju IS-i mõne-"stopisele" abile lootma jääda kui ikka tähtis on pilt saada, arvatavasti sellisel puhul niikuinii statiiv kaasas.
17-40 omanikuna ei mäleta küll siiani ühtegi juhust kus oleks stabikast puudust tundnud või veelgi hullem, oleks mõni tähtis pilt selle pärast tegemata jäänud. Looduses loomade-lindude pildistamisel kasutan 300 mm stabikata toru. Nii pika toru korral juba mõnikord tunnen stabikast puudust, kuigi reeglina saab ka ilma hakkama. Hämaras paigal seisvast loomast peaks üsnagi pika säriajaga saama veel hea pildi, võibolla isegi pikema kui 1/30 s, aga jah ilma stabikata sellisel juhul eriti pole lootust teravat pilti saada. Mul jookseb see piir kusagil 1/60-1/125 vahel, tähendab et reeglina 300 mm toruga (poolkaadri ees) saab käest püsti seistes 1/125-ga normaalse pildi tehtud ja kui saab hästi toetada, siis on võimalik ka 1/60, aga mõni nädal tagasi õnnestus hämaras teha ilvesest ilma nähtavate värisemise jälgedeta pilt 1/60 s-ga ning seda käest, püsti seistes, eks oli hea juhus, igal korral see kindlasti ei õnnestuks. Kui oleks hunt olnud (või veelgi hullem- karu, kuigi tegelikult nad magavad talveund veel), siis võibolla poleks ilma värinata hakkama saanud. Muidugi ISO oli laes (3200) ja seega ka müra üsna tugev (tuleb välja just hämaras, päeval ISO3200 pole üldse halb), stabikaga oleks saanud vist ISO 800-ga teha ja müra oleks olnud veidi talutavam.
viimati muutis Mobileman 13.02.2012 00:34:51, muudetud 1 kord |
| Kommentaarid: 45 loe/lisa |
41 |
Ho Ho
13.02.2012 00:34:35
Mobileman, sealt see asi tulebki, et aeg-ajalt on vaja pilti teha üsnagi hämaras
87 |
Mobileman
13.02.2012 00:38:14
| Sellest saan aru, aga mida sellest lõigust arvad: "Nii pika säriajaga liikuvast objektist ega arvatavasti ka inimesest (kui ta just teadlikult kramplikult liikumatuna ei püüa olla) pilti ei tee. Kui objekt eest ära ei jookse, siis väga pikaks kiskuva säriaja puhul aitab statiiv. Ei saaks ju IS-i mõne-"stopisele" abile lootma jääda kui ikka tähtis on pilt saada, arvatavasti sellisel puhul niikuinii statiiv kaasas."
41 |
elukaz
13.02.2012 00:38:31
Mobileman, käest võetud videole on is väga vajalik ka lainurgal ja eredas valguses.
158 |
Ho Ho
13.02.2012 00:41:39
Mobileman, ütleks niipalju, et igasugu "oleks kolmjalg poleks vaja" ongi pahatihti "oleks", mitte "on"
Linnas ringi kolades on tihtipeale fotokas kotis aga jalgu küll ei viitsi sarnaselt kaasa tarida. Kui IS'i lisamine ei pane hinnale mitusada euri otsa siis võiks see u olemas olla, ega ta miskit halba küll ei tee.
87 |
13.02.2012 00:53:19
Ho Ho, IS lisab Canoni puhul julgelt kolmandiku hinda (vaata näiteks 70-200 tavaliste ja stabikaga versioonide hindu).
Mobileman, kaasaegsed stabikad annavad 3-4 EV'd mänguruumi juurde. Muidugi liikuvate objektiivide puhul on teine lugu kuid vähegi staatilisemate hetkede puhul ilma stabikata objektiiviga kasutad ISO 3200, stabikaga ISO200 - vähe on märkimisväärne. Või veel hullem - ISO 6400 versus 400. Või ajame asja täitsa kosmoseks - ISO 12800 versus 800.
Kui sa 17-40 jutuks tõid - mul oli aasta tagasi kogemus Lapimaal polaaröös sama objektiiviga, kus ka "valgel" ajal valgust nappis. Maastiku pildistamisel oli ava kusagil 9-10 kandis, säriaeg 1/25 ning ISO 2000 kuni 3200. Ja no ei riskinud käest pildistades säriaega pikemaks panna kuna niigi oli segavaid faktoreid piisavalt. Hiljem kodus oli natukene nukker vaadata mõnda hetke kuna veebi jaoks oli tulemus igati OK aga natukenegi sisse zoomides või siis seina peale 40x60cm pilti valides - no maastikufoto puhul kuidagi ei tundunud asi õige.
147 |
Mobileman
13.02.2012 01:01:55
elukaz, võimalik, video teemal ei julge kaasa rääkida, sest ei oma kogemust.
Ho Ho, ega arvatavasti siis nö. linnas ringi kolades sa väga ei looda midagi eriliselt head pildile püüda ka, vastasel juhul ei tahaks midagi juhuse hoolde jätta ja kannaksid statiivi ikkagi igaks juhuks kaasas. Näiteks kui ma läheksin IS-ga lainurka omades hommikul enne päikesetõusu kusagile metsa või rabasse hämarast maastikust pilte tegema, siis ei jääks kindlasti lootma, et IS aitab. Võibolla aitab, aga võib juhtuda ka, et jääb elu parim pilt saamata.
Mark0 , osadel vist annab jah stabikas 3-4 stopi juurde, aga 300 F4-l peaks vist 2 olema.
Kui juba statiivi mainisin, siis võiks ka küsida, et miks siis mina oma 300 mm puhul IS-st vahel puudust tunnen (aga samas lainurga puhul ei tunne), saaks ju ka statiivi kasutada, näiteks mainitud ilvese pildistamise puhul? Kahjuks on asi nii, tihti on kohtumine mõne loomaga nii ootamatu ja kiire, et on aega ainult klõps või paar teha, statiivi üles sättimine oleks täiesti välistatud.
viimati muutis Mobileman 13.02.2012 01:03:44, muudetud 2 korda |
41 |
13.02.2012 01:02:25
| Mobileman, 300/4 IS USM stabikas on jah vanem, tean endal praktikas, et 1-2 EV mänguruumi on maksimum. Nood 24 ja 28mm uued fiksid võiksid aga pigem tulla kaasaegse tehnoloogiaga stabikaga.
147 |
Mobileman
13.02.2012 01:14:29
| Mark0 kirjutas: |
| Mobileman, 300/4 IS USM stabikas on jah vanem, tean endal praktikas, et 1-2 EV mänguruumi on maksimum. Nood 24 ja 28mm uued fiksid võiksid aga pigem tulla kaasaegse tehnoloogiaga stabikaga. |
Jah, aga siiski kui tahaks nö. kindla peale välja minna, ei jääks ikkagi lootma, et isegi 4-st stopist piisab ja võtaks igaks juhuks statiivi kaasa. Näiteks kui sa uuesti läheksid lapimaale polaaröö ajal pildistama ning isegi omades stabikaga lainurka, sa ju ei jätaks enam statiivi koju? Võibolla tõesti kohapeal selgub, et polegi vaja seda kotist välja võtta, see siis olekski ainuke pluss stabikaga lainurga juures?
Seda vist ei tasu jah loota, et stabikas tublisti hinda ei tõsta. Kui ei tõstaks, siis muidugi jah ega ta nö. leiba ei küsiks kui igaks juhuks olemas on. Samas olen kuulnud ka (kuulu?)jutte, et kui võtta 2 ühesugust toru, 1 stabikaga ja teine stabikata, siis ilma stabikata toru joonistab veidi teravamalt/kontrastsemalt vms kuna stabikaga torul on mitu lisaläätse sees ja eks iga lääts mingil määral takistab vms.
viimati muutis Mobileman 13.02.2012 01:19:40, muudetud 1 kord |
41 |
Ho Ho
13.02.2012 01:18:30
Kui stabikas annab näiteks 2EV'd ning kolmjalg veel teised 2 (reaalselt küll kõvasti enam sõltuvalt olukorrast) siis on muidugi ideaalne. Samas kui pole kumbag jääd ilma 4 EV'st, kui on vähemalt üks noist siis ainult 2'st Plus muidugi seesama mainitud lühike ettevalmistusperiood kus ei jõua kolmjalaga möllama hakata.
Ehk siis ainus probleem on hind, iga muu kandi pealt oleks IS igati kasuks.
87 |
