uus teema   vasta Tarkvara »  Arvutimängude foorum »  Starfield märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... , 16, 17, 18  järgmine
Esmamulje Starfieldist:
Väga viis
11%
 11%  [ 9 ]
Hea
25%
 25%  [ 20 ]
Käib kah
18%
 18%  [ 15 ]
Alla keskmise
30%
 30%  [ 24 ]
Täielik käkk
13%
 13%  [ 11 ]
hääli kokku : 79
1dumbpcuser
sõnum 10.10.2024 15:02:42 vasta tsitaadiga
With The Elder Scrolls 6 and Fallout 5 still on the distant horizon, Bethesda's plans for Starfield to join its "big 3" seem like a pipe dream
https://www.gamesradar.com/games/rpg/with-the-elder-scrolls-6-and-fallout-5-still-on-the-distant-horizon-bethesdas-plans-for-starfield-to-join-its-big-3-seem-like-a-pipe-dream/
M:
Kommentaarid: 102 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 97
486
sõnum 10.10.2024 18:12:20 vasta tsitaadiga
Selles expansionis uusi kolle ka lisati mida ma oma hiigel arsenaliga pommitada saaks?
zero
sõnum 10.10.2024 18:56:50 vasta tsitaadiga
486, Väidetavalt vanade vaenlaste reskinnid. Eriti uusi relvi ega midagi ei pidavat olevat.
sõnum 10.10.2024 21:50:32 vasta tsitaadiga
486 kirjutas:
phantom, vortex horror, redeemed.
va'ruun spetsiifilised relvad ja armorid lisandusid ka.
- londiste
sõnum 11.10.2024 14:18:53 vasta tsitaadiga
Link
1dumbpcuser
sõnum 11.10.2024 21:27:26 vasta tsitaadiga
Skyrim lead designer says Bethesda can't just switch engines because the current one is "perfectly tuned" to make the studio's RPGs
https://www.gamesradar.com/games/the-elder-scrolls/skyrim-lead-designer-says-bethesda-cant-just-switch-engines-because-the-current-one-is-perfectly-tuned-to-make-the-studios-rpgs/
While Bethesda's engine has been used to create what are arguably many of the best RPGs of all time, it's also ever-evolving - what started as the company's version of Gamebryo, a now long-defunct engine, gradually blossomed into the Creation Engine. "Gamebryo is no longer a business, it hasn't been for a while. But that engine has been constantly tweaked, updated, and refined," continues Nesmith.
M:
labidas
labidas
sõnum 11.10.2024 21:38:42 vasta tsitaadiga
Nad jäävad selle arvamuse juurde kuni praegune ärimudel toimib. Starfield üsna tõenäoliselt teenib oma raha tagasi.
Aga trend on allamäge ja kui ES6 ning Fallout5 on samasugused käkid, siis tuleb neil lõpuks ka muutuda.
1dumbpcuser
sõnum 11.10.2024 22:05:50 vasta tsitaadiga
labidas kirjutas:
Mingite raportite alusel teenis starfield juba 2023 aastaga 657-miljon dollarit
https://gamerant.com/starfield-success-sales-bestselling-games-2023-failure-critical-reception/
M:
labidas
labidas
sõnum 11.10.2024 23:13:39 vasta tsitaadiga
1dumbpcuser, see on kui palju mäng teenis kokku kõigile. Bethesda kasumi jaoks pead nüüd asju maha lahutama hakkama. Arendus 400M$, reklaam, Steam 20%, muud seotud ettevõtted, maksud jne. Aga ega müüs hästi küll ja müüb vaikselt edasi. Võibki juba kasumis olla.
sõnum 11.10.2024 23:46:36 vasta tsitaadiga
Eks näis kaua seda edasi kasutatakse. Näiteks 343 Industries (Halo seeria) läks UE5 peale üle just selle väitega, et neil kulus rohkem aega ja raha oma enda mootori haldamise ja arendamise peale, kui reaalselt mängude tegemise peale.
Vaevalt Bethesdas teisiti on. Probleem on ka inimeste palkamisega. Iga uus arendaja kes palgatakse peab kõigepealt mootorit hakkama õppima. UE5'ga seda probleemi poleks.
Samas UE5 toob kaasa omad probleemid. Mod support kindlasti kannatab selle all. Jõudlus lõppkasutajatel võib samuti kõvasti kannatada kui arendaja ei optimeeri mängu korralikult. Me oleme näinud mitmeid mänge millel #StutterStruggle jne.
Starfieldil oli neil juba oma mootoril jõudluseprobleemid alguses. UE5'ga oleks need potentsiaalselt veel suuremad olnud.
1dumbpcuser
sõnum 12.10.2024 00:06:12 vasta tsitaadiga
labidas kirjutas:
Vaevalt SS müügile kuidagi positiivselt mõjub...
M:
SirAskAlot
sõnum 12.10.2024 11:12:47 vasta tsitaadiga
Bethesda pole ammu enam tootja, kes teeb mänge mängude tegemise pärast. Ots-otsaga kokkutulek on investorite jaoks läbikukkumine. Eeldatakse , et mäng toodab ikka kasumit.
Mängumootiriga on ka ikka nii, et see peaks graafiliselt ja tehniliselt konkurentidega lähedasel tasemel olema. Võtame näiteks Starfieldi alade vahetamiseks kuluvad lugemis ajad. Võrdleme neid nüüd näiteks UE-l tehtud Throne&Libertyga. Ei kannata vist võrrelda.
Sul võib ju RPG-de jaoks hea mängumootor olla,aga kui see jääb teistes elementides konkurentidele valgusaastatega alla ja sa ei suuda seda piisavalt kiirelt uuendada, siis on mõistlikum midagi muud kasutada. See ei olnud ju kellelegi üllatus, mis tasemel UE5-ga tehtud mängud tulevad. Control on juba aastaid väljas olnud. Kui sa 5 aastaga ei suuda oma mängumootorit konkurentsi võimeliseks teha, siis ära kasuta seda.
UE-ga modimine jääb ilmselt litsentsi lepingute taha. Ma eeldan , et ka modide tegemiseks saab UE-d ennast kasutada ja see on kordades parem kui kõik teised modimiseks kasutatavad vahendid. Wukongi jaoks on näiteks nexuses praegu 500+ modi. Kui ma olen valesti arusaanud, siis võite mind parandada.
Larian ei plaaninud ju ka oma mod toolsiga BG3-le kõigele juurdepääsu anda. See häkiti lihsalt ära. Seega on see ikka pigem tootja otsustada palju modijad teha saavad.
sõnum 12.10.2024 11:59:45 vasta tsitaadiga
ue vist ei ole tänaseni openworld rpgdele keskendunud. seda küll kasutatakse aga seal on kõigil omajagu ise tehtud asju selleks peal.
su näidetest on ju enamik asjad kodukootud mootoritel, rõhuga kas storytelling või rpgdel. control on northlighti peal, mida remedy kasutab alates quantum breakist. bg3 on divinity engine, mille juured on original sinis.
modide lugu ei tasu ka alahinnata. gamebryo/creation engine on modimise jaoks väga tuntud suurus ja robustsete tööriistadega.
mitte, et bethesda ei peaks mänge vähe paremini tegema aga mootori vahetus sellise projekti juures on väga suur ettevõtmine.
pealegi, kas bethesda või konkreetsel juhul starfieldi puudujäägid on üldse seotud kasutatava mängumootoriga?
- londiste
1dumbpcuser
sõnum 12.10.2024 12:07:20 vasta tsitaadiga
Kas ma kujutan ette, et alguses päris paljud modderid kirusid starfieldi mootorit modimise koha pealt?
ma mäletan kunagist Toddi ütlust, et nad enne ei hakka tes6-ga tegelema kui tehnoloogia on piisavalt edasi arenenud ja millegi varasemalt võimatuna näiva olnud aspekti lahendanud. Ma ei usu, et see praegune mootor kuidagi sellele tingimusele vastaks, isegi raytracingut ei toetata icon_rolleyes.gif
M:
viimati muutis 1dumbpcuser 12.10.2024 12:13:52, muudetud 1 kord
labidas
labidas
sõnum 12.10.2024 12:10:48 vasta tsitaadiga
Link
Eks see on juba vana teema, aga jah... mootor ei pruugi midagi muuta.
SirAskAlot
sõnum 12.10.2024 12:16:53 vasta tsitaadiga
londiste kirjutas:
CDprojekt poleks ilmselt UE-5 kasutusele võtnud kui see story põhise avatud maailmaga RPG kasutamise jaoks ei sobi. Ma muidugi ei eeldagi , et keset mängu tootmist hakataske sellist asja muutma. Järgmise mängu jaoks võiks seda siiski teha. Tänaseks on vist selge , et nad ei suuda ise korraliku mootorit üleval hoida.
Redfall oli muide UE5-l tehtud. See seda mängu ei päästnud. Seega jagan arvamust, et viga pole mängu mootoris.
viimati muutis SirAskAlot 12.10.2024 14:31:07, muudetud 1 kord
sõnum 12.10.2024 13:38:23 vasta tsitaadiga
Olen nõus sellega, et mootor ei ole süüdi kõigis hädades. Mootori valik ei takista kirjutamast paremat stoorit ja ja tegema paremaid queste koos unikaalsema lootiga, mis motiveeriks inimesi maailma avastama. Protseduuriliselt genereeritud asjad on oma kohal, aga mitte siis kui seda on kasutatud copy-paste kõige jaoks alates maastikust kuni lootini.
TES taolises mängus ei ole üldiselt ka palju laadimisekraane v.a fast travel tehes või suurtesse linnadesse ja majadesse sisenedes. Need viimased võiks küll ära kaotada. Open cities jms on modderite abiga tõestanud, et saab rohkem mällu laadida olemasoleva mootoriga.
Fast travel loading on ja jääb aga usun, et sellega lepivad kõik. Nn realm loading (a'la sovngarde, oblivion) on samuti mõistetav.
1dumbpcuser
sõnum 14.10.2024 14:57:49 vasta tsitaadiga
Link
M:
Vael
sõnum 14.10.2024 16:01:16 vasta tsitaadiga
Intelit prosad ja nvidia draiverid panevad villast ja siis inimesed hädaldavad mingi stutterstruggle pärast.
6800xt ja 5800x3d tegin Wu Kong läbi, 0 probleemi va. 1 kindel koht kus oli korra väike nõks laadimisega. Ja öelge nüüd et ühelgi teisel mootoril 1te jõnksu ka ei esine.
Pealegi on UE5 mängud CGI tasemel, seega ei maks segi ajada tõsiasja, et hetkel ei leidu rauda mis UE5 Cinematic seadetel välja veaks(ja RT olukord 35% gen perf tõusuga peaks nüüdseks igaüks aduma) ja puhast SS olukorda.
sõnum 14.10.2024 16:05:45 vasta tsitaadiga
#stutterstruggle ei ole prosede ega gpu draiverite probleem. see on täiesti konkreetne tehniline probleem, mis ei ole tihti kas korralikult lahendatud või ei pöörata sellele tähelepanu. asjaolu, et konsoole see samal kujul ei mõjuta, ei aita muidugi ka kaasa.
- londiste
Vael
sõnum 15.10.2024 17:58:33 vasta tsitaadiga
londiste kirjutas:
Ja huvitav kuidas kõik kes RT välja lükkavad ning draiverid ära vahetavad sellest lahti saavad?
Samuti kui Inteli prosad ei saa shader compiga hakkam, siis jääbki sul arvuti cräshima ja läögima.
Samuti ei suuda inimesed leppida, et nende 2k kaart ei suuda 4k kõik seaded põhjas mängida, lükka seaded madalamaks ja on ok jälle.
RT gen jõudlusekasv on 35%, samas palju arvutusjõudlust nõuab? Stutteri igas mängus on lahendanud RT kiirte pooleks lõikamine...
Mul oli 0 probleemi 100h AMD vanal süsteemil, 7900 amd gpu lõpetas ka kräshimise draiveri uuendusega=draivu probleem.
Kui klikbait YT videosid uskuda tahta, siis keegi ei keela.
Samuti võib öelda, et Crysis oli halvasti optimeeritud, samas on tegu siiani kohati parima grasfikaga, seda ei saagi ilma rauast viimast pigistamata.
sõnum 15.10.2024 18:28:32 vasta tsitaadiga
Vael, Shader Compilation stutter ei ole RT seotud. See esineb sõltumata sellest kas mäng üldse RT kasutab. Mina arvan, et see on paljuski arendajate kiirustamise tulemus. See on tarkvaraliselt täiesti lahendatav, aga on arendajaid kes ei viitsi seda optimeerida.
On neid kes süüdistavad UE5 mootorit selles aga see on vale. Vajalikud tööriistad selle lahendamiseks on mootoris olemas.
See on probleem mis aja jooksul saab lahenduse ainult kas siis kui arendaja selle ära paikab või uus kiirem raud välja tuleb mis brute force meetodiga selle mängitavaks muudab.
Crysis probleem oli see, et see oli optimeeritud Inteli arhitektuurile, kuna väljatuleku hetkel oli Intel kaugel ees ja teine probleem oli selles, et see nõudis väga head CPU ST jõudlust.
Remasteri jaoks kasutati põhjana konsooliporti mis oli rohkem CPU optimeeritud jooksma rohkematel tuumadel aga see tõi kaasa teised probleemid ja mina seda OG PC versioonist paremaks ei loe.
Võibolla kunagi saame ground up remake.
RedFusion
RedFusion
sõnum 17.10.2024 10:58:52 vasta tsitaadiga
Tomorrow kirjutas:
londiste, Starfield ei ole mingi cult classic mis 10 aasta pärast avastatakse ja taevani kiidetakse.
Sinu pidev jutt, et seda "pekstakse" on naeruväärne. Tegu on lihtsalt väga igava ja keskpärase mänguga. Kamaluga otsa veel tehnilisi puudujääke.
Nõus. Ma aasta tagasi kurtsin, et mäng ei jookse üldse, oli ainult slideshow. Siis SSD peal lõpuks sain normilt tööle asja, pole küll väga hea fps, aga enam-vähem sujuv. Olgugi et pilt on suht meh. Aga siis hakkas iga ca 10-15 min tagant mäng lampi crashima. Teistes mängudes pole olnud sellist asja, wtf? Pole mingi pira versioon vms ka, otse Steamist ostetud. Natuke guugeldasin, muutsin mingeid settinguid süsteemis ja kettal ning sain paremaks - nüüd crashib korra tunnis vms, vahel harvem. Sellega leppisin, sest ei osanud rohkem midagi teha. Võimalik, et nüüd aasta hiljem seda enam pole, ma ei ole vahepeal mänginud...
Jõudsin muidu peaaegu lõppu, 1-2 main story questi jäi veel teha. Siis tulid küll muud asjad vahele, aga ega ei tõmmanud ka hirmsasti mängu lõpetama. Juba nende tehniliste jamade pärast võtaks vähemalt 1/10 hindest maha. Tegelt okei, osa main storyst oli täitsa põnev ja mingid side questid ka (osad vist veel tegemata), planeetide avastamine ja maailm olid huvitavad (kuigi veidi liiga tühi kõik). Laevaehitus oli ka päris tore, aga seda alles siis, kui asjast aru said. Oleks võinud lihtsalt mingi tutorial või abistav UI olla. Seal on üsna palju võimalusi ja ma tükk aega ei saanud aru, kuhu mingeid tükke lisada saab ja kuidas üldse asi töötab. Siis videote ja proovimise põhjal lõpuks sai aru, aga no wtf, selgitage mängus seda. Questid on nii ja naa - vahepeal läks jah suht igavaks, sest liiga palju on samasugust "mine too see asi" sisu. Nõus, et esemed on liiga generic ja oleks tahtnud legendary vastaseid ja looti nagu FO-s varem.
Kokkuvõttes ma arvan, et Steami "mixed reviews" on suht aus. Võib-olla teen lõpuks läbi ning avastan veidi rohkem maailma ka, aga kas uuesti mängiks kunagi? Kindlasti mitte.
sõnum 17.10.2024 13:05:59 vasta tsitaadiga
ma loodan, et sa profiiliarvutiga ei mänginud seda. starfieldi nõuded süsteemile ei ole just tagasihoidlikud.
sealhulgas ssd on täiesti nõutud ja ka minimaalsetes kirjas. see oli avaldamise hetkel jutuaineks ning ilmselt põhiliseks põhjuseks miks starfieldi ei üritatud eelmisele konsoolipõlvkonnale müüa.
https://help.bethesda.net/#en/answer/60442 kirjutas:
Minimum
OS: Windows 10 version 21H1 (10.0.19043)
Processor: AMD Ryzen 5 2600X, Intel Core i7-6800K
Memory: 16 GB RAM
Graphics: AMD Radeon RX 5700, NVIDIA GeForce 1070 Ti
DirectX: Version 12
Storage: 125 GB available space
Additional Notes: SSD Required(Solid-state Drive)
- londiste
RedFusion
RedFusion
sõnum 17.10.2024 14:16:14 vasta tsitaadiga
londiste kirjutas:
Minimum
Memory: 16 GB RAM
DirectX: Version 12
Mängisin ja nagu mainisin, siis SSD-ga oli suht okei fps, täiesti mängitav. Oleks saanud isegi madalamaks keerata settinguid, aga polnud põhjust (proovisin igat pidi, crashide vastu ei aidanud). Asi ju selles ongi, et need nõuded süsteemile on debiilsed, sest see pilt pole nii hea. Olen paar aastat vanu AAA mänge high peal jooksutanud 50-60+ fps, kenam graafika, madalamad nõuded. Crashimist see ka ei põhjenda, ma lugesin päris palju kurtmist high-end PC-de omanikelt, et samamoodi crashib. See on lihtsalt mingi ülihalvasti optimeeritud port...
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Starfield mine lehele eelmine  1, 2, 3 ... , 16, 17, 18  järgmine
