soulshaker
01.09.2011 00:41:52
vortex, kumma poolelt siis kvalitatiivne eelis on? Eeldan et kui passiiv 3D on odavam, siis prillidega aktiiv on parema pildiga.
Sony 55" 3D telekat sai Playstatoini mingi mängu peal testitud, siis see oli küll muljetavaldab. Solarise Sony Centeris ca. 1,5m pealt sai vaadatud. Väga viis oli. Passiivi pole oma silmaga näinud.
219 |
Le Inc
01.09.2011 20:35:59
Ausalt öeldes ma pole väga kursis kuidas tänapäeval aktiivne 3D telekates pilti näitab. Ülevaateid sirvides jääb kõlama ikkagi see et plasma olla parem 3D jaoks kui LCD, eriti head pidavat olema panasonicu omad (VT30). Aga jah seal on see aktiivne,
Prill oli küll mõnusalt kerge,
| Kommentaarid: 56 loe/lisa |
54 |
02.09.2011 09:18:04
Panasonicu kohta veel üks hea uudis: http://www.broadbandtvnews.com/2011/09/01/panasonic-integrates-hbbtv-in-its-tv-sets/
IFA 2011 – BERLIN. Panasonic has announced it is adding HbbTV functionality to its VT-30 TV sets. The CE manufacturer has also said it will update its 2011 and most of its 2010 models with the Viera Connect and Viera Connect Market services.
With the addition of HbbTV on some of its TV sets, Panasonic falls in line with other CE manufacturers, who also are incorporating the new hybrid standard into their devices.
Meanwhile, Panasonic is also extending its own connected services under the Viera brand. The manufacturer has added an app market, called Viera Connect Market. There will be free apps as well as paid-for applications in the shop including games.
Panasonic has also added Twitter and Skype apps to its connected TV functions. Viewers can also use the market the buy accessories, such as 3D glasses, for their TV sets.
The app market is available on all new sets, TV and Blu-ray, as well as Home Cinema sets, and a firmware upgrade will be released for its 2010 models. This inlcues TV sets, Bluray players, Bluray recorder and Home Cinema systems. |
131 |
aise
| Kommentaarid: 189 loe/lisa |
172 |
02.09.2011 21:12:53
Tühja sellest Toshibast, LG on kontoritesse tahvlite, paberpoognate jm. joonistamiskohtade asemele toomas midagi uut.
Ka koju joonistamishimulistele lastele sobib selline asi. Ja eriti hea veel, kui näidatav pilt ei meeldi, joonistad ise hoopis..
LG PenTouch PZ850T Lets You Draw On Your TV
IFA, Berlin:Remember the amount of times you’ve been sitting at home and wished you could get up and draw something on your 60in plasma 3D TV? No, us neither but it seems as if LG thinks it's a great idea.
The LG PenTouch PZ850T TV will allow owners to use a stylus to draw smiley faces on their 50in or 60in 3D Cinema plasma screens. The LG PZ850T plasmas have been around for a while now but LG has decided that what was missing from the high-end sets was the ability to put your own personal touch on them. |
131 |
tulema
| Kommentaarid: 76 loe/lisa |
69 |
iguaan
04.09.2011 14:10:47
| jägaja ja siis paari nädala pärast nutad rikutud tv (ekraani) pildi pärast...
| Kommentaarid: 84 loe/lisa |
72 |
iir
| Kommentaarid: 90 loe/lisa |
04.09.2011 17:27:06
| iguaan kirjutas: |
| jägaja ja siis paari nädala pärast nutad rikutud tv (ekraani) pildi pärast... |
no kindlasti, kui sul on oidu suvalise naelaga seda ekraanipilti joonistama minna .
131 |
iguaan
04.09.2011 17:59:52
ei ütlegi, et sina seda teeksid, selle jaoks on lapsed
72 |
xxlmaster
| Kommentaarid: 83 loe/lisa |
77 |
ents75
04.09.2011 19:52:53
Kas keegi tark suudab mulle selgitada mis vahe on LG mudelitel LG 55LW750S ja LG 55LW650S? Esimesena mainitud on millegipärast odavam (kuigi täpselt samasuguste näitajatega) ja ka LG kodulehel pole sellest 750S mudelist sõnagi ja ka guugeldades ei anna viimase kohta peale Eesti poelinkide mingit infot...
| soulshaker kirjutas: |
Sony 55" 3D telekat sai Playstatoini mingi mängu peal testitud, siis see oli küll muljetavaldab. Solarise Sony Centeris ca. 1,5m pealt sai vaadatud. Väga viis oli. Passiivi pole oma silmaga näinud. |
Mina olen sellest just niipidi aru saanud, et just passiivprillidega LG on parema 3D pildiga - selgem, suurema vaatenurgaga jms. Lisaks veel prillidega seotud plussid. 2D pilt seevastu on suht sama - pigem mõnel LG konkurendil veidi parem.
| Kommentaarid: 11 loe/lisa |
mk1985
06.09.2011 09:40:50
| Küsimus kas keegi teab kudas saaks finlux'i service menüüsse. Teadmatu on ka vist see kes seda tänapäeval üldse toodab.
06.09.2011 09:56:31
LG tõi turule just sellel eesmärgil passiivprillide tehnoloogia, et see on odav (prillid on odavad).
Asja mõte on, et noid prille võid kasvõi toidupoest osta, on juba kaasas miski 3D filmiga. Aktiivprillid aga on kallid ja pasiivtehnoloogia süsteemiga ei tööta.
Kui tahad aga poest osta miskeid samasuguseid prille, siis kallimad on nad ilmselt just disaini tõttu. Mõeldagse miski tuntud moebrändi nimi juurdre ja hind on kohe vastav. Pildikvaliteeti see aga ei mõjuta.
| mk1985 kirjutas: |
| Küsimus kas keegi teab kudas saaks finlux'i service menüüsse. Teadmatu on ka vist see kes seda tänapäeval üldse toodab. |
Toodavad türklased (Vestel) aga infot on ilmselt ainult võimalik leida veebist.
http://en.wikipedia.org/wiki/Finlux
131 |
[Pec]
| Kommentaarid: 19 loe/lisa |
18 |
pots4t4j4
06.09.2011 21:17:53
oleks soov vana 32" Fusi myrica välja vahetada, ainuke otstarve on arvuti järel filme mängida , on kellelgi ehk miskit mõistliku soovitada ? 46"+ mitte plasma, oleks tore sinnamaani võib ka suurem olla kui hind väga ebanormaalseks ei muutu
401 |
jax
| Kommentaarid: 53 loe/lisa |
53 |
iir
07.09.2011 22:33:34
Ei tea kui tõsiseltvõetav leht on, aga tulemused on väga head, mängimiseks ja pildi kvaliteedilt peaks väga hea olema.
http://www.digitalversus.com/philips-40pfl8605h-p364_10007_53.html
Muidugi ka ambilight
aise
08.09.2011 15:30:06
olge ettevaatlikud
172 |
iir
08.09.2011 15:36:09
3D porn? On olemas? 3D telekate uus maailm, magamistoas seina suurune ekraan.
puujuur
09.09.2011 20:48:36
hmm sony uued 3d prillid 750 tolllli!
| Kommentaarid: 39 loe/lisa |
39 |
exciter
10.09.2011 12:47:25
Ameerikas on kõik võimalik.
PeTzZz
10.09.2011 13:29:02
Kas LG kaitseb ka salvestatud saated DRM'iga, nagu Samsung, nii, et neid on hiljem võimalik vaid sama telekaga vaadata?
Lugesin veebist üht vanemat foorumiteemat, kus märgiti, et kui Samsungil elektroonilise telekava (EPG) järgi salvestama panna, siis ta salvestab täpselt kava järgi, lisaaega ei ole võimalik panna. Kas see on ka nüüd nii? Saated tikuvad üle aja minema. Kas saab ka täpse ajavahemiku ette anda? Kuidas on lood LG'ga?
Kas riiulis 5cm külgedelt ja 2cm ülevalt vaba ruumi on ok (LED LCD telekas)?
| Kommentaarid: 10 loe/lisa |
9 |
ents75
10.09.2011 14:46:58
| ents75 kirjutas: |
Kas keegi tark suudab mulle selgitada mis vahe on LG mudelitel LG 55LW750S ja LG 55LW650S? Esimesena mainitud on millegipärast odavam (kuigi täpselt samasuguste näitajatega) ja ka LG kodulehel pole sellest 750S mudelist sõnagi ja ka guugeldades ei anna viimase kohta peale Eesti poelinkide mingit infot... |
oskab ehk keegi öelda mis vahe neil on?
PS. LG "toetus" vastab eestikeelsele küsimusele vene keeles mingi jogaga. Kui toote enda tugi on sama siis LG-le tuli siit esimene miinuspunkt [/quote]
virx
10.09.2011 15:03:58
Soomes praegu pakutakse neid telekaid üsna soodsalt (PFL8605), 40" 799 ja 52" 999eur.
309 |
exciter
10.09.2011 19:57:16
Milline on hetke parim SOny telekas? Mingid nuti tv'sid ei kasuta,oluline pole isegi interneti(wifi) võimalus jne, rääkimata skype'st ja muudest võimalustest. 3D'd ka ei taha.
Tahan lihtsat telekat põhiliselt TV vaatamiseks, internetti kasutan arvutiga ning rääkimiseks kasutan telefoni. Põhiline on , et pilt oleks kvaliteetne.
Six
10.09.2011 20:47:32
Karta on, et hetke parimal Sony telekal on kõik need vidinad olemas – tahad sa või ei taha.
Iseasi, kas sa ka neid kasutad.
| exciter kirjutas: |
Tahan lihtsat telekat põhiliselt TV vaatamiseks, internetti kasutan arvutiga ning rääkimiseks kasutan telefoni. Põhiline on , et pilt oleks kvaliteetne. |
| Kommentaarid: 40 loe/lisa |
39 |
Shelby-SV
Jõulud On Läbi!
11.09.2011 11:18:59
Sony Centeris on 46CX520 hind jälle langenud. eelmine kuu oli 599, nüüd 549 ja lisaks antakse wireless kõrvaklapid kaasa. Paistab, et CCFL ja natuke iganenud disain ei müü eriti
| Kommentaarid: 63 loe/lisa |
55 |
WerteX
11.09.2011 13:14:34
| Shelby-SV, ei saa öelda. Tavalisi LCD ostetakse hetkel veel kindlasti rohkem kui LED'e.
306 |
Pimp
11.09.2011 13:20:40
| Shelby-SV kirjutas: |
Sony Centeris on 46CX520 hind jälle langenud. eelmine kuu oli 599, nüüd 549 ja lisaks antakse wireless kõrvaklapid kaasa. Paistab, et CCFL ja natuke iganenud disain ei müü eriti  |
40" mudelit pidasid silmas?
E: konkreetsel mudelil just ei ole clouding probleemi kui siit lugeda http://www.digitalversus.com/sony-bravia-kdl-46cx520-p364_10822_16.html
_________________ PSN Taffinaff
viimati muutis Pimp 11.09.2011 21:48:11, muudetud 1 kord |
| Kommentaarid: 49 loe/lisa |
48 |
iir
11.09.2011 19:16:22
CCFL pidi parem olema, sony LEDidel on probleeme cloudinguga, ebaühtlaselt valgustab, nagu keegi näitaks taskulambiga valgust paneeli taha. samas on see enamuse uute telekate probleem...
http://www.digitalversus.com/sony-bravia-kdl-40ex523-p364_10744_16.html
Shelby-SV
Jõulud On Läbi!
11.09.2011 19:37:46
| Pimp kirjutas: |
40" mudelit pidasid silmas? |
õigus, ongi 40".
eelmine kuu oli 46" ka odav
55 |
iguaan
12.09.2011 07:53:50
samad probleemid on ka CCFL'ga. parim lahendus ongi vb see full led
72 |
12.09.2011 08:34:40
ideaalset lahendust ei ole, ka full led võib olla samamoodi ebaühtlane.
eks see sõltub pigem tootmise kvaliteedist.
_________________ - londiste
217 |
kembadesig
| Kommentaarid: 73 loe/lisa |
65 |
7 :: |
362 |
kembadesig
12.09.2011 11:15:08
_________________ Sounds?... |
65 |
loox
12.09.2011 11:52:28
| iir kirjutas: |
Väljamaa foorumites soovitatakse neid "valgusvihke" kergelt patsutada. Mõned soovitavad ka tagant korpuse kruvisid nõrgemaks lasta.
iir
12.09.2011 12:02:03
Huvitav igatahes Kas mõjub paneelile ka kuidagi kui koguaeg koputada? No kui nõrgemaks lasta kruvisi, siis järeldaks, et ledid kaugenevad paneelist? Samas väheneb ka efektiivsus, samas peaks aitama nende väljalülitamine, siis jälle on pilt tume... äh, kõige parem on vist plasma telku...
RaidoR
12.09.2011 19:39:41
Kas see või see?
Põhiliseks kasutusalaks on arvutist filmide ja dvb-t vaatamine. Väiksema mudeli kasuks räägib 100Hz ja LED, kuid kui suur vahe on 42" mudeliga võrreldes? Endale tundub, et sama raha eest saab päris mitu tolli suurema tv
| Kommentaarid: 52 loe/lisa |
50 |
pots4t4j4
12.09.2011 19:44:50
ei oska küll nende mudelite vahet valikut teha aga olenemata vaatekaugusest on 32" liigagi lukuauk
401 |
iguaan
12.09.2011 20:22:34
| pots4t4j4 kirjutas: |
ei oska küll nende mudelite vahet valikut teha aga olenemata vaatekaugusest on 32" liigagi lukuauk  |
2-3m kauguselt on vägagi paras. otse vaatega saad korraliku ülevaate kõiges toimuvast(ei pea pead trükimasinana kasutama)
72 |
RaidoR
12.09.2011 20:28:19
| Kuna tuba suht pisike, siis vaatamiskaugus jääkski minupuhul 2,5-3,5m kaugusele.
50 |
mesikas
pwnage
12.09.2011 20:42:12
| RaidoR kirjutas: |
| Kuna tuba suht pisike, siis vaatamiskaugus jääkski minupuhul 2,5-3,5m kaugusele. |
Ise võtaks 3m pealt vaatamiseks 50-60", eriti arvutist HD vaatamiseks.
Praegu 40" jätab küll lukuaugu mulje.
Mida suurem, seda parem.
| Kommentaarid: 50 loe/lisa |
50 |
WAV
12.09.2011 20:52:09
| pwnage kirjutas: |
Mida suurem, seda parem. |
Kas ikka on nii? Resolutsioon on ju kõigil max 1920x1080. Vaadates 3m kauguselt on 60" peale laialivenitatuna selline resolutsioon ikka väga häirivalt ruuduline (või siis udune) näha.
| Kommentaarid: 7 loe/lisa |
iguaan
12.09.2011 21:06:35
| ot: |
| pwnage, kinos käid filme ka esireas vaatamas? |
72 |
7 :: |
362 |
crp
12.09.2011 21:42:51
Sai ostetud omale 32PFL5405H ning nüüd säärane jama, et kui ühendan arvuti telekaga ja panen resoks 1920x1080 siis pilt hakkab nagu virvendama vms, nagu ei joonista pilti ilusti(glitching). Samas kui panen resoks 1380x720 siis on piltt ideaalne. Proovisin driverite uninstalli aga ikka sama jama. Ehk keegi targem oskab aidata natuke? os on Xp ning videokaart on gf mx440(tean mitte kõige parem ). Samas kui googlist uurisin siis paljudel oli veel sama probleem, aga kahjuks vastust kuidas parandada seda ei leidnud :/.
7 :: |
362 |
