soulshaker
01.09.2011 00:41:52
vortex, kumma poolelt siis kvalitatiivne eelis on? Eeldan et kui passiiv 3D on odavam, siis prillidega aktiiv on parema pildiga.
Sony 55" 3D telekat sai Playstatoini mingi mängu peal testitud, siis see oli küll muljetavaldab. Solarise Sony Centeris ca. 1,5m pealt sai vaadatud. Väga viis oli. Passiivi pole oma silmaga näinud.
Kommentaarid: 243 loe/lisa |
219 |
Le Inc
01.09.2011 20:35:59
Ausalt öeldes ma pole väga kursis kuidas tänapäeval aktiivne 3D telekates pilti näitab. Ülevaateid sirvides jääb kõlama ikkagi see et plasma olla parem 3D jaoks kui LCD, eriti head pidavat olema panasonicu omad (VT30). Aga jah seal on see aktiivne,
Prill oli küll mõnusalt kerge,
Kommentaarid: 56 loe/lisa |
54 |
02.09.2011 09:18:04
Panasonicu kohta veel üks hea uudis: http://www.broadbandtvnews.com/2011/09/01/panasonic-integrates-hbbtv-in-its-tv-sets/
tsitaat: |
IFA 2011 – BERLIN. Panasonic has announced it is adding HbbTV functionality to its VT-30 TV sets. The CE manufacturer has also said it will update its 2011 and most of its 2010 models with the Viera Connect and Viera Connect Market services.
With the addition of HbbTV on some of its TV sets, Panasonic falls in line with other CE manufacturers, who also are incorporating the new hybrid standard into their devices.
Meanwhile, Panasonic is also extending its own connected services under the Viera brand. The manufacturer has added an app market, called Viera Connect Market. There will be free apps as well as paid-for applications in the shop including games.
Panasonic has also added Twitter and Skype apps to its connected TV functions. Viewers can also use the market the buy accessories, such as 3D glasses, for their TV sets.
The app market is available on all new sets, TV and Blu-ray, as well as Home Cinema sets, and a firmware upgrade will be released for its 2010 models. This inlcues TV sets, Bluray players, Bluray recorder and Home Cinema systems. |
Kommentaarid: 142 loe/lisa |
127 |
aise
Kommentaarid: 189 loe/lisa |
172 |
02.09.2011 21:12:53
Tühja sellest Toshibast, LG on kontoritesse tahvlite, paberpoognate jm. joonistamiskohtade asemele toomas midagi uut.
Ka koju joonistamishimulistele lastele sobib selline asi. Ja eriti hea veel, kui näidatav pilt ei meeldi, joonistad ise hoopis..
LG PenTouch PZ850T Lets You Draw On Your TV
tsitaat: |
IFA, Berlin:Remember the amount of times you’ve been sitting at home and wished you could get up and draw something on your 60in plasma 3D TV? No, us neither but it seems as if LG thinks it's a great idea.
The LG PenTouch PZ850T TV will allow owners to use a stylus to draw smiley faces on their 50in or 60in 3D Cinema plasma screens. The LG PZ850T plasmas have been around for a while now but LG has decided that what was missing from the high-end sets was the ability to put your own personal touch on them. |
127 |
tulema
Kommentaarid: 67 loe/lisa |
60 |
iguaan
04.09.2011 14:10:47
jägaja ja siis paari nädala pärast nutad rikutud tv (ekraani) pildi pärast...
Kommentaarid: 82 loe/lisa |
iir
Kommentaarid: 90 loe/lisa |
04.09.2011 17:27:06
iguaan kirjutas: |
jägaja ja siis paari nädala pärast nutad rikutud tv (ekraani) pildi pärast... |
no kindlasti, kui sul on oidu suvalise naelaga seda ekraanipilti joonistama minna .
127 |
iguaan
04.09.2011 17:59:52
ei ütlegi, et sina seda teeksid, selle jaoks on lapsed
xxlmaster
Kommentaarid: 83 loe/lisa |
77 |
ents75
04.09.2011 19:52:53
Kas keegi tark suudab mulle selgitada mis vahe on LG mudelitel LG 55LW750S ja LG 55LW650S? Esimesena mainitud on millegipärast odavam (kuigi täpselt samasuguste näitajatega) ja ka LG kodulehel pole sellest 750S mudelist sõnagi ja ka guugeldades ei anna viimase kohta peale Eesti poelinkide mingit infot...
soulshaker kirjutas: |
Sony 55" 3D telekat sai Playstatoini mingi mängu peal testitud, siis see oli küll muljetavaldab. Solarise Sony Centeris ca. 1,5m pealt sai vaadatud. Väga viis oli. Passiivi pole oma silmaga näinud. |
Mina olen sellest just niipidi aru saanud, et just passiivprillidega LG on parema 3D pildiga - selgem, suurema vaatenurgaga jms. Lisaks veel prillidega seotud plussid. 2D pilt seevastu on suht sama - pigem mõnel LG konkurendil veidi parem.
Kommentaarid: 10 loe/lisa |
10 |
mk1985
06.09.2011 09:40:50
Küsimus kas keegi teab kudas saaks finlux'i service menüüsse. Teadmatu on ka vist see kes seda tänapäeval üldse toodab.
Kommentaarid: 5 loe/lisa |
06.09.2011 09:56:31
LG tõi turule just sellel eesmärgil passiivprillide tehnoloogia, et see on odav (prillid on odavad).
Asja mõte on, et noid prille võid kasvõi toidupoest osta, on juba kaasas miski 3D filmiga. Aktiivprillid aga on kallid ja pasiivtehnoloogia süsteemiga ei tööta.
Kui tahad aga poest osta miskeid samasuguseid prille, siis kallimad on nad ilmselt just disaini tõttu. Mõeldagse miski tuntud moebrändi nimi juurdre ja hind on kohe vastav. Pildikvaliteeti see aga ei mõjuta.
mk1985 kirjutas: |
Küsimus kas keegi teab kudas saaks finlux'i service menüüsse. Teadmatu on ka vist see kes seda tänapäeval üldse toodab. |
Toodavad türklased (Vestel) aga infot on ilmselt ainult võimalik leida veebist.
http://en.wikipedia.org/wiki/Finlux
127 |
[Pec]
Kommentaarid: 19 loe/lisa |
18 |
pots4t4j4
06.09.2011 21:17:53
oleks soov vana 32" Fusi myrica välja vahetada, ainuke otstarve on arvuti järel filme mängida , on kellelgi ehk miskit mõistliku soovitada ? 46"+ mitte plasma, oleks tore sinnamaani võib ka suurem olla kui hind väga ebanormaalseks ei muutu
Kommentaarid: 490 loe/lisa |
398 |
jax
Kommentaarid: 53 loe/lisa |
53 |
iir
07.09.2011 22:33:34
Ei tea kui tõsiseltvõetav leht on, aga tulemused on väga head, mängimiseks ja pildi kvaliteedilt peaks väga hea olema.
http://www.digitalversus.com/philips-40pfl8605h-p364_10007_53.html
Muidugi ka ambilight
aise
08.09.2011 15:30:06
olge ettevaatlikud
172 |
iir
08.09.2011 15:36:09
3D porn? On olemas? 3D telekate uus maailm, magamistoas seina suurune ekraan.
puujuur
09.09.2011 20:48:36
hmm sony uued 3d prillid 750 tolllli!
Kommentaarid: 39 loe/lisa |
39 |
exciter
10.09.2011 12:47:25
Ameerikas on kõik võimalik.
PeTzZz
10.09.2011 13:29:02
Kas LG kaitseb ka salvestatud saated DRM'iga, nagu Samsung, nii, et neid on hiljem võimalik vaid sama telekaga vaadata?
Lugesin veebist üht vanemat foorumiteemat, kus märgiti, et kui Samsungil elektroonilise telekava (EPG) järgi salvestama panna, siis ta salvestab täpselt kava järgi, lisaaega ei ole võimalik panna. Kas see on ka nüüd nii? Saated tikuvad üle aja minema. Kas saab ka täpse ajavahemiku ette anda? Kuidas on lood LG'ga?
Kas riiulis 5cm külgedelt ja 2cm ülevalt vaba ruumi on ok (LED LCD telekas)?
9 |
ents75
10.09.2011 14:46:58
ents75 kirjutas: |
Kas keegi tark suudab mulle selgitada mis vahe on LG mudelitel LG 55LW750S ja LG 55LW650S? Esimesena mainitud on millegipärast odavam (kuigi täpselt samasuguste näitajatega) ja ka LG kodulehel pole sellest 750S mudelist sõnagi ja ka guugeldades ei anna viimase kohta peale Eesti poelinkide mingit infot... |
oskab ehk keegi öelda mis vahe neil on?
PS. LG "toetus" vastab eestikeelsele küsimusele vene keeles mingi jogaga. Kui toote enda tugi on sama siis LG-le tuli siit esimene miinuspunkt [/quote]
10 |
virx
10.09.2011 15:03:58
Soomes praegu pakutakse neid telekaid üsna soodsalt (PFL8605), 40" 799 ja 52" 999eur.
Kommentaarid: 356 loe/lisa |
301 |
