uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  ATi RV670 aka HD3K seeria märgi kõik teemad loetuks
mine lehele 1, 2, 3 ... 52, 53, 54  järgmine
One
sõnum 29.10.2007 10:34:20 ATi RV670 aka HD3K seeria vasta tsitaadiga
It has been widely rumored that the upcoming RV670 will support DX10.1. This white paper that just found its way to us from someone I'll call a "friend of TeamATI" seems to replace a lot of rumor with some actual substance.
Here's a taste-
The new ATI Radeon HD 3800 series of GPUs are the first to be designed for DirectX 10.1, as well as other cutting edge technologies, including PCI Express 2.0, Unified Video Decoder (UVD), hardware accelerated tessellation, and power efficient 55nm transistor design.
This is definitely a good read with a wealth of information about DX10.1 as well as the impact it will have on games, gamers and game developers.
Tibake juttu tulevast RV670-st ja DX10.1-st
edit:
Diamond xDNA Allows CrossFire on Any Chipset With Any Cards
http://forums.techpowerup.com/showthread.php?t=43165
Diamond Multimedia has made a big impact on the graphics card market with their lineup of Radeon video cards a while back and it was the first to announce the launch of Radeon HD2900XT 1GB just recently. Diamond now has plans on a new platform called xDNA. xDNA enables users to run a CrossFire setup on any chipset, and that includes NVIDIA chipsets. Users can pick almost any motherboard with any socket, fit it with two Diamond Radeon cards and run CrossFire on it using Diamond's xDNA technology.
Kui Diamond seda teeb siis arvatavasti teevad ka teised.
ehk siis varsti saab CrossFiret jooksutada suvalise chipsetiga.
viimati muutis Winterwind 29.10.2007 10:42:48, muudetud 1 kord
CoiL
CoiL
sõnum 29.10.2007 11:08:58 vasta tsitaadiga
Laiskadele otselink AMD pdf`le ka: http://www.teamati.com/DirectX%2010_1%20White%20Paper%20v0.4.pdf
Kuigi kas see kõik ikka tõele vastab? icon_rolleyes.gif Kui see jutt õige siis loodan, et uuest seeriast tuleb hea paugupill icon_smile.gif
E: ei tea kas see juba olnud siin aga ka sama jutt: http://www.tomshardware.com/2007/10/29/amd_hd_3800_to_support_dx_10/
Kommentaarid: 95 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 83
Lotharius
rallisibul
Lotharius
sõnum 29.10.2007 13:39:54 vasta tsitaadiga
Kui keegi viitsib, siis seletage see free 4x MSAA värk ära (kuulduste järgi peaks see DX10.1 toetava kaardi puhul nõue olema). Et siis põhimõtteliselt suva reso mis peal on võid 4x MSAA peale lükata ja performance'ile see muutust ei avalda?
Geek it til it MHz
Kommentaarid: 125 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 117
sõnum 29.10.2007 14:02:24 vasta tsitaadiga
loll jutt on see free aa.
aa toimimise reeglid on lihtsalt kindlalt paigas + developerid peavad saama aa sämpleid ise vastavalt tujule ja vajadusele sättida.
- londiste
CoiL
CoiL
sõnum 29.10.2007 17:51:05 vasta tsitaadiga
Keegi oskab öelda mis RV670 hind umb. olema saab siin eestimaal? Hetkel tuli nagu isu G92 ära tellida aga ei ole kunagi nVidia eriti istunud siis kahtlen icon_rolleyes.gif
Lotharius
rallisibul
Lotharius
sõnum 29.10.2007 17:56:28 vasta tsitaadiga
No 8800GT on USA hinna järgi mingi 250 doltsi kanti ja kuulduste põhjal peaks RV670 ka 250 kanti jääma, seega tuleksid nad ühte hinda umbes. Hetkel ise täpselt sama valiku ees. Ostaks Gt hea meelega ära, aga kui RV670 tuleb parem, siis nagu dumb-ass tunne kui 15 päeva ei suutnud oodata icon_confused.gif
Geek it til it MHz
sõnum 29.10.2007 18:29:43 vasta tsitaadiga
rv670 parem kui x2900xt?
peale 8800gt täpsema info avaldumist on rv670 kõlakad jubedalt tagasi tõmmanud.
- londiste
viimati muutis londiste 29.10.2007 23:27:57, muudetud 1 kord
excalibur
sõnum 29.10.2007 18:31:12 vasta tsitaadiga
krt ootaks mingit poole paremat kaari vms. ei viitsi mingi 3% eest pappi välja käia metsikult.
Kommentaarid: 316 loe/lisa Kasutajad arvavad:  :: 5 :: 4 :: 262
One
sõnum 29.10.2007 18:31:48 vasta tsitaadiga
londiste kirjutas:
kiirem on ta kindlasti. vähemalt see GDDR4-ga versioon.
indu
indu
sõnum 29.10.2007 18:32:22 vasta tsitaadiga
kas siis saab hind olema ca 3000 ?
http://www.lossirestoran.eu/
Kommentaarid: 63 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 58
excalibur
sõnum 29.10.2007 18:34:46 vasta tsitaadiga
kõike ei saa lihtsalt dollari kursiga korrutada. eriti eestis
One
sõnum 29.10.2007 18:35:28 vasta tsitaadiga
excalibur kirjutas:
lisaks tuleb mitu erinevat mudelit.
indu
indu
sõnum 29.10.2007 19:11:47 vasta tsitaadiga
eino mõtlesin et ostaks mingi directx 9 kaarti 2k eest aga aru saan siis hinnalagused peaksid suured olema ja pole väitnud täpset summat vaid CA
Ho Ho
Ho Ho
sõnum 29.10.2007 19:29:14 vasta tsitaadiga
Winterwind kirjutas:
londiste kirjutas:
Kas on juba mingit infot sharedite takti kohta?
G80
G80
sõnum 29.10.2007 21:15:38 vasta tsitaadiga
Ho Ho kirjutas:
londiste kirjutas:
GDDR 4 variant ehk HD 3870 peaks jooksma 825/2400MHz kelladel. icon_razz1.gif
Ära siia kliki
Kommentaarid: 256 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 210
High-Q
High-Q
sõnum 29.10.2007 21:22:39 vasta tsitaadiga
minu mälu järgi just rohkem rõhuti x2900 perfomance aga paremad termo/tehnilised omadused. tuleb meelde nv omaaegne ämber gf fx kus öeldi "same perfomance, better pixels" icon_biggrin.gif eks aeg näitab. kindlasti suudetakse 8800 seeriaga "on-par" perfomancet pakkuda, kuna x2900 ei ole ju 8800-st (näit gts640) maas vaid üsna võrdne (v.a paar eripära näit AA perfi kirves). Ja ega 8800gt pole ju imekaart. tegu on nati nõrgema kui 8800gtx-iga, seega pisku klokki siit-sealt ja nati tviikimist ja perfi mõttes on asi käes.
teine asi on aga raha: kas ati on võimeline sama rahaga sellist asja teha ja absoluutselt terve oma x2900 seeria line-upile kõrge kaarega peale kusema. ok, nv tegi gt-ga enda vanale lineupile veidi "liiga" tõesti, aga ati puhul oleks mõju kordi hullem, sest gts/gtx on vana kaart ja oma kasumi juba ära teeninud ning aeg vaikselt pensioneerida, x2900 pole aga turul väga kaua olla saanudki. sisuliselt peab ati välja tooma x2900xt-st parema pefomancega kaardi, mis võtaks vähem voolu, oleks vaiksema jahutusega ja maksaks 2x vähem (hetkel u 5500 ringis).
sõnum 29.10.2007 21:58:28 vasta tsitaadiga
EDIT:Nevermind icon_lol.gif
One
sõnum 29.10.2007 22:08:17 vasta tsitaadiga
High-Q, HD2900 tootmine on sisuliselt lõpetatud, seda tõestab ka kaartide PRO-deks ümber nimetamine ja odavalt ära müümine.
RV670 vahetab R600 täielikult välja. Shadereid on väidetavalt mõlemal 320 aga RV-l on R600 probleemid fixitud + lisatud uusi featureid.
Kiire tuleb RV670 igatahes, loodetavasti seekord kiirem kui NVIDIA vastav. ATi/AMD on väikese õnnestumise ära teeninud.
Igatahes tuleb november normaalne - RV670, Phenom, RD790, CrossFireX. Kui nüüd midagi ära ei tehta siis millal veel.
High-Q kirjutas:
Ei pea olema kiirem ja 2x odavam. Tuleb mitu eri mudelit millel hinnad/jõudlus eri tasemel.
Voolutarve on igatahes väiksem ning soojaeraldus samuti.
sõnum 29.10.2007 22:11:50 vasta tsitaadiga
dollari kurss ja mitmed variandid ei puutu suurt asjasse.
kas mitte 8800gt-d ei pidada ka ametlikult miski umbes 7 varianti olema? anyway on kallim, ehk siis 512mb asi, $250 ja allapoole hinnaga. sinnapoole peab ati oma vastuse sihtima.
crossfirex on mis?
- londiste
viimati muutis londiste 29.10.2007 22:12:56, muudetud 3 korda
One
sõnum 29.10.2007 22:12:42 vasta tsitaadiga
londiste, keegi ei keela kiiremat kaarti kallimalt müümast.
londiste kirjutas:
crossfirex on mis?
trifire, quadfire, crossfire koos int videoga jne.
soodent
sõnum 29.10.2007 23:21:46 vasta tsitaadiga
Ati leeris matused?2900gt andis ju 15 minute fame...
Kommentaarid: 822 loe/lisa Kasutajad arvavad:  :: 19 :: 6 :: 564
sõnum 29.10.2007 23:27:37 vasta tsitaadiga
miks matused? eeldades et rv670 tegelikult ka parem on, siis on vastane ju täiesti olemas. küsimus on siinjuures vaid konkreetsetes omadustes, eelkõige siis voolutarve/soojuseraldus ja hind icon_smile.gif
ja eks miski poole aasta pärast majandustulemustest näha ole, kas ja kes dumpinghindadega asju müüs icon_biggrin.gif
- londiste
G80
G80
sõnum 29.10.2007 23:50:08 vasta tsitaadiga
Uutest kaartidest juttu ja DX10.1-st.
http://forums.vr-zone.com/showthread.php?t=199296
Ära siia kliki
sõnum 30.10.2007 00:05:10 vasta tsitaadiga
bullshit pilt.
.pdf (teamati) juba oli ka siin teemas iirc.
- londiste
sõnum 30.10.2007 00:14:39 vasta tsitaadiga
Hehe hea pilt.Et siis nagu nvidia sellid saavad ATI logo pihta pallikesi pilduda vms? icon_razz.gif icon_lol.gif .
Ho Ho
Ho Ho
sõnum 30.10.2007 09:51:48 vasta tsitaadiga
See "global illumination" on seal tegelikult üsna räme häkk ning töötab ainult väga piiratud olukordades. Rääkimata vajatavast arvutus ja mälu ressursist. Muidugi techdemodeks kõlbab see üsna hästi icon_smile.gif
G80
G80
sõnum 01.11.2007 19:12:37 vasta tsitaadiga
Yeston Radeon HD 3850 ready to roll
http://www.tcmagazine.com/comments.php?shownews=16640&catid=2
8)
Ära siia kliki
One
sõnum 01.11.2007 19:24:35 vasta tsitaadiga
RV670 võiks juba kiiremini tulla. parem on ta igatahes kui HD2600XT(millel iseenesest ka midagi viga pole)
indu
indu
sõnum 01.11.2007 19:25:25 vasta tsitaadiga
G80 kirjutas:
8)
ja see epaks olema siis vastus 8800GT'le ?
One
sõnum 01.11.2007 19:25:40 vasta tsitaadiga
suuremat? too ju samapikk kui R600/G80
ning see 199 taalane ja gddr3-ga peaks olema vastus sellele 256mb 88GT-le.
viimati muutis Winterwind 01.11.2007 19:26:25, muudetud 1 kord
Smoking
Smoking
sõnum 01.11.2007 19:26:15 vasta tsitaadiga
Täpselt sama suured, kui eelmised kaardid, võbiolla isegi natukene lühem. icon_rolleyes.gif
EDIT: Winter jõudis ette...
Kommentaarid: 360 loe/lisa Kasutajad arvavad:  :: 2 :: 1 :: 298
indu
indu
sõnum 01.11.2007 19:27:30 vasta tsitaadiga
Puma
sõnum 01.11.2007 19:35:52 vasta tsitaadiga
ot: kena tibi icon_smile.gif (niipalju kui teda näha on icon_lol.gif )
Kommentaarid: 39 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 36
M8T0
sõnum 02.11.2007 01:22:50 vasta tsitaadiga
segaks vahele.
kuskil järgmistest mobile versioonidest ka juttu on ?
ilgelt ihub hinge peale uue läppari ost aga praeguse tahaks vahele jätta. HD2600 peale minek ei oleks NII suur boost (stockina 1600 vs 3200p 3dmark06s). kuid mis ja millal on järgmine ?
One
sõnum 02.11.2007 20:21:01 vasta tsitaadiga
link :: Diamond Multimedia Jumps the Gun on Radeon HD 3800
Diamond Multimedia has "accidentally" posted the upcoming and yet unannounced Radeon HD 3800 series on its website. The three cards available are the 512MB Radeon HD 3870 and the 512 and 256MB versions of the HD 3850. Aside from the wrong box pictures and GPU names, there's some interesting information, like the changed core clock speeds of Radeon HD 3870 series which is now 775MHz and not the rumored 825MHz (the memory clock is at 1200MHz - 2400MHz DDR as expected). The rest of the specs are in line with the information already available, DirectX 10.1 support, 320 stream processors, 256-bit memory interface, and Crossfire X support. As for the HD 3850, the memory is posted as being set to 828MHz (1656MHz DDR) while the core clock is 668MHz.
Tahaks juba ülevaateid näha..
Ho Ho
Ho Ho
sõnum 02.11.2007 20:27:44 vasta tsitaadiga
Aside from the wrong box pictures ...
Muidu kahtlane et core takti madalamale lasti
sõnum 02.11.2007 23:44:20 vasta tsitaadiga
ei oleks ju ime... palju on ATI osas arvamust avaldatud, et liialt jõuliselt üritatakse võtta tech rallis 1 kohta, samas kiipide praak kipub suur olema.
One
sõnum 06.11.2007 16:22:53 vasta tsitaadiga
link :: INQ
Pricing for both launch parts is very aggressive, and AMD claims it is all due to 55nm process working
like a clockwork and achieving excellent yields. Radeon HD 3850 should retail for between $149 to 179 (USD),
while 3870 should be between 200 to 230. This is brilliant pricing, going way below 8800GT.
Mõttetu hetkel neid overpriced 88GT-sid preorder-ida kui RV670 jõuab samal ajal müüki.
sõnum 06.11.2007 16:39:24 vasta tsitaadiga
Seda enam, et kumba firmat rohkem usaldada AMD või NV - raske valik icon_razz.gif
See "very aggressive" on suhtkoht debiilne väide kahjumit teeniva firma kohta...55nm vs 65nm vahe on omahinnalt suht 0-0(55nm tootmise tehnoloogia on lihtsalt kallim - muidugi teenitaks kena kasumit 8800 seeria sarnase edu korral).
Ho Ho
Ho Ho
sõnum 06.11.2007 16:51:10 vasta tsitaadiga
Eks kõigepealt ootame ära RV jõudluse ja siis hakkame rääkima mis on mõttekas ja mis mitte. Mina isiklikult ei arva et RV670 miski imeloom tuleb.
HDTanel
Overclocker
HDTanel
sõnum 06.11.2007 16:54:34 vasta tsitaadiga
Sellest ATIAMD sigitisest pole ju ühtegi testi väljas, et jätta tellimata 8800GT thumbs_down.gif icon_rolleyes.gif
Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
sõnum 06.11.2007 17:19:46 vasta tsitaadiga
way below 8800gt? edu neile sellega.
edit:
The real truth is that AMD started running into clocking walls (with a selected heatsink-fan combo) and again decided to crash the prices instead of gunning for a better cooling setup that will enable those 800 MHz+ clocks we saw earlier in development.
Tegin koleda tabeli ka.
RV670PRO RV670XT 8800GT
668      775     600     GPU (MHz)
-        -       1500    GPU Shader (MHz)
256      512     256/512 Mem (MB)
3        4       3       GDDR?
1666     2400    1800    Mem (MHz)
10,69    12,4    -       Fillrate (Gpixel/s)
-        -       33,6    Peak fillrate (Gtexel/s)
52,99    76,8    57,6    Mem bandwidth (GB/s)
320      320     -       Stream Processors
-        -       112     Shader Processing Units
- londiste
viimati muutis londiste 06.11.2007 17:33:13, muudetud 2 korda
One
sõnum 06.11.2007 17:37:19 vasta tsitaadiga
londiste kirjutas:
mis siin naljakat on?
PlatoonSgtElias kirjutas:
kui 88GT-d reaalselt kuskilt saada ei ole ja hinda üles pushiti siis miks peaks seda preorderima?
konkurents kujundab hindu mitte monopol
eckh
sõnum 06.11.2007 19:14:02 vasta tsitaadiga
Hetkel konkurentsi ei ole ja monopol kujundab hindu nii kuidas tahab icon_rolleyes.gif Kui sul viimnegi toode laost tingimusteta ära ostetakse ja järjekord veel ukse taga on, miks siis mitte hindu tõsta ?
Kaarte pole reaalselt saada, kuna esimene batch oli suhteliselt väike ja nõudlus sellise hinna/jõudlusega kaardi järgi suur. Niikaua kuni AMD kaartide näol alternatiivi pole, lähevad 8800GT-d nagu soojad saiad.
Kui RV670-st oleks mingi tohutu püss ja 8800GT killer tulemas, oleks AMD-st igati mõistlik selle performance numbreid välja lekitada, et nVidia praegust pidu rikkuda.
Kommentaarid: 108 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 103
sõnum 06.11.2007 19:28:34 vasta tsitaadiga
eckh kirjutas:
Kahju jah kui sellele lihtsale äriloogikale pihta ei saada... intel lekitab vaikselt koguaeg midagi, samas kaunis arvestavate allikate kaudu ja see paneb inimesed mõtlema... NV kohta suht sama teema, kuigi pigem lihtsalt peetakse koosolekute lubatustest kinni ja kaart jõuab enam-vähem õigel hetkel letile + seni on tagatud ostjatele ATI-st parem jõudlus juba päris pikka aega.
Seda hullem on asja juures see, et AMD panustab odavale OEM hankele, samas tugeva toote puhul nad võiksid ju oluliselt kasulikumat retail kanalit tugevalt pushida nagu NV 8800 seeriaga tegi. Seega ei oota ma mitte midagi sellest RV670 juurikast.
A-Circus.
A-Circus.
sõnum 06.11.2007 20:48:35 vasta tsitaadiga
X-Bit lab'is mingi huvitav joonis.
Link:
http://www.xbitlabs.com/news/video/display/20071105054143_ATI_Readies_Ultra_High_End__R680__Graphics_Solution__Presentation_Slide.html
Samuti siin veel üks oletus (tõestus), miks RV679't on odavam toota: RV670=180mm2 vs R600=420mm2; samuti siis pidavat transistorite arv paarikümne miljoni võrra vähenenud olema.
http://www.theinquirer.net/gb/inquirer/news/2007/11/06/number-beast-hd3800
Ehk kui mõlemad allikad peaks õigeks osutuma, siis on RV670'l nii hinna kui ka jõudluse graafikud tsipakene madalamad kui 8800GT'l
G80
G80
sõnum 07.11.2007 00:50:28 vasta tsitaadiga
AMD prepares DX10.1 part for AGP computers
AGP ei suregi ära vist,einoh tegelt,kui ostjaid on siis miks mitte.
http://forums.vr-zone.com/showthread.php?t=201732
Ära siia kliki
Draco
Draco
sõnum 07.11.2007 01:08:30 vasta tsitaadiga
G80 kirjutas:
Ma loodan et Sefiir teeb mingi 512MB`se isendi, siis saab veits aega veel valetada endale. Peaasi, et kiirem on kui X1950 Pro
Syncmahv
Syncmahv
sõnum 07.11.2007 01:14:24 vasta tsitaadiga
Ei no tglt AGP suht vähe ju kasutusel ikkagist, aga väga hea et niimodi elus hoitakse thumbs_up.gif
WäntWõll
make.believe
WäntWõll
sõnum 07.11.2007 01:49:00 vasta tsitaadiga
See AGP järelkaja ulatub aastani 2012 kindlasti aga tõsi on see et tegelikkus suri välja 2005 icon_idea.gif
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  ATi RV670 aka HD3K seeria mine lehele 1, 2, 3 ... 52, 53, 54  järgmine
