One
29.10.2007 09:34:20
ATi RV670 aka HD3K seeria |
It has been widely rumored that the upcoming RV670 will support DX10.1. This white paper that just found its way to us from someone I'll call a "friend of TeamATI" seems to replace a lot of rumor with some actual substance.
Here's a taste-
The new ATI Radeon HD 3800 series of GPUs are the first to be designed for DirectX 10.1, as well as other cutting edge technologies, including PCI Express 2.0, Unified Video Decoder (UVD), hardware accelerated tessellation, and power efficient 55nm transistor design.
This is definitely a good read with a wealth of information about DX10.1 as well as the impact it will have on games, gamers and game developers. |
Tibake juttu tulevast RV670-st ja DX10.1-st
edit:
Diamond xDNA Allows CrossFire on Any Chipset With Any Cards
http://forums.techpowerup.com/showthread.php?t=43165
| Diamond Multimedia has made a big impact on the graphics card market with their lineup of Radeon video cards a while back and it was the first to announce the launch of Radeon HD2900XT 1GB just recently. Diamond now has plans on a new platform called xDNA. xDNA enables users to run a CrossFire setup on any chipset, and that includes NVIDIA chipsets. Users can pick almost any motherboard with any socket, fit it with two Diamond Radeon cards and run CrossFire on it using Diamond's xDNA technology. |
Kui Diamond seda teeb siis arvatavasti teevad ka teised.
ehk siis varsti saab CrossFiret jooksutada suvalise chipsetiga.
viimati muutis Winterwind 29.10.2007 09:42:48, muudetud 1 kord |
728 |
CoiL
| Kommentaarid: 95 loe/lisa |
83 |
Lotharius
rallisibul
29.10.2007 12:39:54
Kui keegi viitsib, siis seletage see free 4x MSAA värk ära (kuulduste järgi peaks see DX10.1 toetava kaardi puhul nõue olema). Et siis põhimõtteliselt suva reso mis peal on võid 4x MSAA peale lükata ja performance'ile see muutust ei avalda?
117 |
29.10.2007 13:02:24
loll jutt on see free aa.
aa toimimise reeglid on lihtsalt kindlalt paigas + developerid peavad saama aa sämpleid ise vastavalt tujule ja vajadusele sättida.
_________________ - londiste
217 |
CoiL
29.10.2007 16:51:05
Keegi oskab öelda mis RV670 hind umb. olema saab siin eestimaal? Hetkel tuli nagu isu G92 ära tellida aga ei ole kunagi nVidia eriti istunud siis kahtlen
83 |
Lotharius
rallisibul
29.10.2007 16:56:28
No 8800GT on USA hinna järgi mingi 250 doltsi kanti ja kuulduste põhjal peaks RV670 ka 250 kanti jääma, seega tuleksid nad ühte hinda umbes. Hetkel ise täpselt sama valiku ees. Ostaks Gt hea meelega ära, aga kui RV670 tuleb parem, siis nagu dumb-ass tunne kui 15 päeva ei suutnud oodata
117 |
29.10.2007 17:29:43
rv670 parem kui x2900xt?
peale 8800gt täpsema info avaldumist on rv670 kõlakad jubedalt tagasi tõmmanud.
viimati muutis londiste 29.10.2007 22:27:57, muudetud 1 kord |
217 |
excalibur
29.10.2007 17:31:12
| krt ootaks mingit poole paremat kaari vms. ei viitsi mingi 3% eest pappi välja käia metsikult.
262 |
One
29.10.2007 17:31:48
| londiste kirjutas: |
| rv670 parem kui x2900xt? |
kiirem on ta kindlasti. vähemalt see GDDR4-ga versioon.
728 |
indu
| Kommentaarid: 63 loe/lisa |
58 |
excalibur
29.10.2007 17:34:46
| kõike ei saa lihtsalt dollari kursiga korrutada. eriti eestis
262 |
One
29.10.2007 17:35:28
| excalibur kirjutas: |
| kõike ei saa lihtsalt dollari kursiga korrutada. eriti eestis |
lisaks tuleb mitu erinevat mudelit.
728 |
indu
29.10.2007 18:11:47
eino mõtlesin et ostaks mingi directx 9 kaarti 2k eest aga aru saan siis hinnalagused peaksid suured olema ja pole väitnud täpset summat vaid CA
_________________ http://www.lossirestoran.eu/ |
58 |
Ho Ho
29.10.2007 18:29:14
| Winterwind kirjutas: |
kiirem on ta kindlasti. vähemalt see GDDR4-ga versioon. |
Kas on juba mingit infot sharedite takti kohta?
87 |
G80
29.10.2007 20:15:38
| Ho Ho kirjutas: |
Kas on juba mingit infot sharedite takti kohta? |
GDDR 4 variant ehk HD 3870 peaks jooksma 825/2400MHz kelladel.
210 |
High-Q
29.10.2007 20:22:39
minu mälu järgi just rohkem rõhuti x2900 perfomance aga paremad termo/tehnilised omadused. tuleb meelde nv omaaegne ämber gf fx kus öeldi "same perfomance, better pixels" eks aeg näitab. kindlasti suudetakse 8800 seeriaga "on-par" perfomancet pakkuda, kuna x2900 ei ole ju 8800-st (näit gts640) maas vaid üsna võrdne (v.a paar eripära näit AA perfi kirves). Ja ega 8800gt pole ju imekaart. tegu on nati nõrgema kui 8800gtx-iga, seega pisku klokki siit-sealt ja nati tviikimist ja perfi mõttes on asi käes.
teine asi on aga raha: kas ati on võimeline sama rahaga sellist asja teha ja absoluutselt terve oma x2900 seeria line-upile kõrge kaarega peale kusema. ok, nv tegi gt-ga enda vanale lineupile veidi "liiga" tõesti, aga ati puhul oleks mõju kordi hullem, sest gts/gtx on vana kaart ja oma kasumi juba ära teeninud ning aeg vaikselt pensioneerida, x2900 pole aga turul väga kaua olla saanudki. sisuliselt peab ati välja tooma x2900xt-st parema pefomancega kaardi, mis võtaks vähem voolu, oleks vaiksema jahutusega ja maksaks 2x vähem (hetkel u 5500 ringis).
97 |
| Kommentaarid: 92 loe/lisa |
One
29.10.2007 21:08:17
High-Q, HD2900 tootmine on sisuliselt lõpetatud, seda tõestab ka kaartide PRO-deks ümber nimetamine ja odavalt ära müümine.
RV670 vahetab R600 täielikult välja. Shadereid on väidetavalt mõlemal 320 aga RV-l on R600 probleemid fixitud + lisatud uusi featureid.
Kiire tuleb RV670 igatahes, loodetavasti seekord kiirem kui NVIDIA vastav. ATi/AMD on väikese õnnestumise ära teeninud.
Igatahes tuleb november normaalne - RV670, Phenom, RD790, CrossFireX. Kui nüüd midagi ära ei tehta siis millal veel.
| High-Q kirjutas: |
| sisuliselt peab ati välja tooma x2900xt-st parema pefomancega kaardi, mis võtaks vähem voolu, oleks vaiksema jahutusega ja maksaks 2x vähem (hetkel u 5500 ringis). |
Ei pea olema kiirem ja 2x odavam. Tuleb mitu eri mudelit millel hinnad/jõudlus eri tasemel.
Voolutarve on igatahes väiksem ning soojaeraldus samuti.
728 |
29.10.2007 21:11:50
dollari kurss ja mitmed variandid ei puutu suurt asjasse.
kas mitte 8800gt-d ei pidada ka ametlikult miski umbes 7 varianti olema? anyway on kallim, ehk siis 512mb asi, $250 ja allapoole hinnaga. sinnapoole peab ati oma vastuse sihtima.
crossfirex on mis?
viimati muutis londiste 29.10.2007 21:12:56, muudetud 3 korda |
217 |
One
29.10.2007 21:12:42
londiste, keegi ei keela kiiremat kaarti kallimalt müümast.
| crossfirex on mis? |
trifire, quadfire, crossfire koos int videoga jne.
728 |
soodent
29.10.2007 22:21:46
Ati leeris matused?2900gt andis ju 15 minute fame...
| Kommentaarid: 822 loe/lisa |
19 :: |
6 :: |
564 |
29.10.2007 22:27:37
miks matused? eeldades et rv670 tegelikult ka parem on, siis on vastane ju täiesti olemas. küsimus on siinjuures vaid konkreetsetes omadustes, eelkõige siis voolutarve/soojuseraldus ja hind
ja eks miski poole aasta pärast majandustulemustest näha ole, kas ja kes dumpinghindadega asju müüs
217 |
G80
210 |
29.10.2007 23:05:10
bullshit pilt.
.pdf (teamati) juba oli ka siin teemas iirc.
217 |
Ho Ho
30.10.2007 08:51:48
See "global illumination" on seal tegelikult üsna räme häkk ning töötab ainult väga piiratud olukordades. Rääkimata vajatavast arvutus ja mälu ressursist. Muidugi techdemodeks kõlbab see üsna hästi
87 |
G80
210 |
One
01.11.2007 18:24:35
| RV670 võiks juba kiiremini tulla. parem on ta igatahes kui HD2600XT(millel iseenesest ka midagi viga pole)
728 |
indu
01.11.2007 18:25:25
ma pole suuremat graafikakaarti veel näinud
ja see epaks olema siis vastus 8800GT'le ?
58 |
One
01.11.2007 18:25:40
suuremat? too ju samapikk kui R600/G80
ning see 199 taalane ja gddr3-ga peaks olema vastus sellele 256mb 88GT-le.
viimati muutis Winterwind 01.11.2007 18:26:25, muudetud 1 kord |
728 |
Smoking
01.11.2007 18:26:15
Täpselt sama suured, kui eelmised kaardid, võbiolla isegi natukene lühem.
EDIT: Winter jõudis ette...
298 |
indu
58 |
Puma
01.11.2007 18:35:52
ot: kena tibi (niipalju kui teda näha on )
| Kommentaarid: 39 loe/lisa |
36 |
M8T0
02.11.2007 00:22:50
segaks vahele.
kuskil järgmistest mobile versioonidest ka juttu on ?
ilgelt ihub hinge peale uue läppari ost aga praeguse tahaks vahele jätta. HD2600 peale minek ei oleks NII suur boost (stockina 1600 vs 3200p 3dmark06s). kuid mis ja millal on järgmine ?
| Kommentaarid: 87 loe/lisa |
One
02.11.2007 19:21:01
link :: Diamond Multimedia Jumps the Gun on Radeon HD 3800
| Diamond Multimedia has "accidentally" posted the upcoming and yet unannounced Radeon HD 3800 series on its website. The three cards available are the 512MB Radeon HD 3870 and the 512 and 256MB versions of the HD 3850. Aside from the wrong box pictures and GPU names, there's some interesting information, like the changed core clock speeds of Radeon HD 3870 series which is now 775MHz and not the rumored 825MHz (the memory clock is at 1200MHz - 2400MHz DDR as expected). The rest of the specs are in line with the information already available, DirectX 10.1 support, 320 stream processors, 256-bit memory interface, and Crossfire X support. As for the HD 3850, the memory is posted as being set to 828MHz (1656MHz DDR) while the core clock is 668MHz. |
Tahaks juba ülevaateid näha..
Imelik, et pildil on HD2600PRO karp
728 |
Ho Ho
02.11.2007 19:27:44
| Aside from the wrong box pictures ... |
Muidu kahtlane et core takti madalamale lasti
87 |
02.11.2007 22:44:20
| ei oleks ju ime... palju on ATI osas arvamust avaldatud, et liialt jõuliselt üritatakse võtta tech rallis 1 kohta, samas kiipide praak kipub suur olema.
201 |
One
06.11.2007 15:22:53
link :: INQ
Pricing for both launch parts is very aggressive, and AMD claims it is all due to 55nm process working
like a clockwork and achieving excellent yields. Radeon HD 3850 should retail for between $149 to 179 (USD),
while 3870 should be between 200 to 230. This is brilliant pricing, going way below 8800GT. |
Hinnad tunduvad väga head olevat, eriti GDDR3-ga HD 3850
Mõttetu hetkel neid overpriced 88GT-sid preorder-ida kui RV670 jõuab samal ajal müüki.
728 |
06.11.2007 15:39:24
INQ on ikka usaldusväärne allikas
Seda enam, et kumba firmat rohkem usaldada AMD või NV - raske valik
See "very aggressive" on suhtkoht debiilne väide kahjumit teeniva firma kohta...55nm vs 65nm vahe on omahinnalt suht 0-0(55nm tootmise tehnoloogia on lihtsalt kallim - muidugi teenitaks kena kasumit 8800 seeria sarnase edu korral).
201 |
Ho Ho
06.11.2007 15:51:10
| Mõttetu hetkel neid overpriced 88GT-sid preorder-ida kui RV670 jõuab samal ajal müüki. |
Eks kõigepealt ootame ära RV jõudluse ja siis hakkame rääkima mis on mõttekas ja mis mitte. Mina isiklikult ei arva et RV670 miski imeloom tuleb.
87 |
HDTanel
Overclocker
06.11.2007 15:54:34
Sellest ATIAMD sigitisest pole ju ühtegi testi väljas, et jätta tellimata 8800GT
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
06.11.2007 16:19:46
way below 8800gt? edu neile sellega.
edit:
| The real truth is that AMD started running into clocking walls (with a selected heatsink-fan combo) and again decided to crash the prices instead of gunning for a better cooling setup that will enable those 800 MHz+ clocks we saw earlier in development. |
roflmao. nojah, oleks võinud siis järgmise lõigu ka pasteda
Tegin koleda tabeli ka.
RV670PRO RV670XT 8800GT
668 775 600 GPU (MHz)
- - 1500 GPU Shader (MHz)
256 512 256/512 Mem (MB)
3 4 3 GDDR?
1666 2400 1800 Mem (MHz)
10,69 12,4 - Fillrate (Gpixel/s)
- - 33,6 Peak fillrate (Gtexel/s)
52,99 76,8 57,6 Mem bandwidth (GB/s)
320 320 - Stream Processors
- - 112 Shader Processing Units
viimati muutis londiste 06.11.2007 16:33:13, muudetud 2 korda |
217 |
One
06.11.2007 16:37:19
roflmao. nojah, oleks võinud siis järgmise lõigu ka pasteda  |
mis siin naljakat on?
| PlatoonSgtElias kirjutas: |
Sellest ATIAMD sigitisest pole ju ühtegi testi väljas, et jätta tellimata 8800GT  |
kui 88GT-d reaalselt kuskilt saada ei ole ja hinda üles pushiti siis miks peaks seda preorderima?
konkurents kujundab hindu mitte monopol
728 |
eckh
06.11.2007 18:14:02
konkurents kujundab hindu mitte monopol |
Hetkel konkurentsi ei ole ja monopol kujundab hindu nii kuidas tahab Kui sul viimnegi toode laost tingimusteta ära ostetakse ja järjekord veel ukse taga on, miks siis mitte hindu tõsta ?
Kaarte pole reaalselt saada, kuna esimene batch oli suhteliselt väike ja nõudlus sellise hinna/jõudlusega kaardi järgi suur. Niikaua kuni AMD kaartide näol alternatiivi pole, lähevad 8800GT-d nagu soojad saiad.
Kui RV670-st oleks mingi tohutu püss ja 8800GT killer tulemas, oleks AMD-st igati mõistlik selle performance numbreid välja lekitada, et nVidia praegust pidu rikkuda.
103 |
06.11.2007 18:28:34
| eckh kirjutas: |
Kui RV670-st oleks mingi tohutu püss ja 8800GT killer tulemas, oleks AMD-st igati mõistlik selle performance numbreid välja lekitada, et nVidia praegust pidu rikkuda. |
Kahju jah kui sellele lihtsale äriloogikale pihta ei saada... intel lekitab vaikselt koguaeg midagi, samas kaunis arvestavate allikate kaudu ja see paneb inimesed mõtlema... NV kohta suht sama teema, kuigi pigem lihtsalt peetakse koosolekute lubatustest kinni ja kaart jõuab enam-vähem õigel hetkel letile + seni on tagatud ostjatele ATI-st parem jõudlus juba päris pikka aega.
Seda hullem on asja juures see, et AMD panustab odavale OEM hankele, samas tugeva toote puhul nad võiksid ju oluliselt kasulikumat retail kanalit tugevalt pushida nagu NV 8800 seeriaga tegi. Seega ei oota ma mitte midagi sellest RV670 juurikast.
201 |
A-Circus.
| Kommentaarid: 50 loe/lisa |
48 |
G80
210 |
Draco
07.11.2007 00:08:30
Ma loodan et Sefiir teeb mingi 512MB`se isendi, siis saab veits aega veel valetada endale. Peaasi, et kiirem on kui X1950 Pro
| Kommentaarid: 12 loe/lisa |
12 |
Syncmahv
07.11.2007 00:14:24
Ei no tglt AGP suht vähe ju kasutusel ikkagist, aga väga hea et niimodi elus hoitakse
102 |
WäntWõll
make.believe
07.11.2007 00:49:00
See AGP järelkaja ulatub aastani 2012 kindlasti aga tõsi on see et tegelikkus suri välja 2005
300 |
