One
29.10.2007 09:34:20
ATi RV670 aka HD3K seeria |
It has been widely rumored that the upcoming RV670 will support DX10.1. This white paper that just found its way to us from someone I'll call a "friend of TeamATI" seems to replace a lot of rumor with some actual substance.
Here's a taste-
The new ATI Radeon HD 3800 series of GPUs are the first to be designed for DirectX 10.1, as well as other cutting edge technologies, including PCI Express 2.0, Unified Video Decoder (UVD), hardware accelerated tessellation, and power efficient 55nm transistor design.
This is definitely a good read with a wealth of information about DX10.1 as well as the impact it will have on games, gamers and game developers. |
Tibake juttu tulevast RV670-st ja DX10.1-st
edit:
Diamond xDNA Allows CrossFire on Any Chipset With Any Cards
http://forums.techpowerup.com/showthread.php?t=43165
| Diamond Multimedia has made a big impact on the graphics card market with their lineup of Radeon video cards a while back and it was the first to announce the launch of Radeon HD2900XT 1GB just recently. Diamond now has plans on a new platform called xDNA. xDNA enables users to run a CrossFire setup on any chipset, and that includes NVIDIA chipsets. Users can pick almost any motherboard with any socket, fit it with two Diamond Radeon cards and run CrossFire on it using Diamond's xDNA technology. |
Kui Diamond seda teeb siis arvatavasti teevad ka teised.
ehk siis varsti saab CrossFiret jooksutada suvalise chipsetiga.
viimati muutis Winterwind 29.10.2007 09:42:48, muudetud 1 kord |
728 |
CoiL
| Kommentaarid: 95 loe/lisa |
83 |
Lotharius
rallisibul
29.10.2007 12:39:54
Kui keegi viitsib, siis seletage see free 4x MSAA värk ära (kuulduste järgi peaks see DX10.1 toetava kaardi puhul nõue olema). Et siis põhimõtteliselt suva reso mis peal on võid 4x MSAA peale lükata ja performance'ile see muutust ei avalda?
117 |
29.10.2007 13:02:24
loll jutt on see free aa.
aa toimimise reeglid on lihtsalt kindlalt paigas + developerid peavad saama aa sämpleid ise vastavalt tujule ja vajadusele sättida.
_________________ - londiste
215 |
CoiL
29.10.2007 16:51:05
Keegi oskab öelda mis RV670 hind umb. olema saab siin eestimaal? Hetkel tuli nagu isu G92 ära tellida aga ei ole kunagi nVidia eriti istunud siis kahtlen
83 |
Lotharius
rallisibul
29.10.2007 16:56:28
No 8800GT on USA hinna järgi mingi 250 doltsi kanti ja kuulduste põhjal peaks RV670 ka 250 kanti jääma, seega tuleksid nad ühte hinda umbes. Hetkel ise täpselt sama valiku ees. Ostaks Gt hea meelega ära, aga kui RV670 tuleb parem, siis nagu dumb-ass tunne kui 15 päeva ei suutnud oodata
117 |
29.10.2007 17:29:43
rv670 parem kui x2900xt?
peale 8800gt täpsema info avaldumist on rv670 kõlakad jubedalt tagasi tõmmanud.
viimati muutis londiste 29.10.2007 22:27:57, muudetud 1 kord |
215 |
excalibur
29.10.2007 17:31:12
| krt ootaks mingit poole paremat kaari vms. ei viitsi mingi 3% eest pappi välja käia metsikult.
262 |
One
29.10.2007 17:31:48
| londiste kirjutas: |
| rv670 parem kui x2900xt? |
kiirem on ta kindlasti. vähemalt see GDDR4-ga versioon.
728 |
indu
| Kommentaarid: 63 loe/lisa |
58 |
excalibur
29.10.2007 17:34:46
| kõike ei saa lihtsalt dollari kursiga korrutada. eriti eestis
262 |
One
29.10.2007 17:35:28
| excalibur kirjutas: |
| kõike ei saa lihtsalt dollari kursiga korrutada. eriti eestis |
lisaks tuleb mitu erinevat mudelit.
728 |
indu
29.10.2007 18:11:47
eino mõtlesin et ostaks mingi directx 9 kaarti 2k eest aga aru saan siis hinnalagused peaksid suured olema ja pole väitnud täpset summat vaid CA
_________________ http://www.lossirestoran.eu/ |
58 |
Ho Ho
29.10.2007 18:29:14
| Winterwind kirjutas: |
kiirem on ta kindlasti. vähemalt see GDDR4-ga versioon. |
Kas on juba mingit infot sharedite takti kohta?
86 |
G80
29.10.2007 20:15:38
| Ho Ho kirjutas: |
Kas on juba mingit infot sharedite takti kohta? |
GDDR 4 variant ehk HD 3870 peaks jooksma 825/2400MHz kelladel.
210 |
High-Q
29.10.2007 20:22:39
minu mälu järgi just rohkem rõhuti x2900 perfomance aga paremad termo/tehnilised omadused. tuleb meelde nv omaaegne ämber gf fx kus öeldi "same perfomance, better pixels" eks aeg näitab. kindlasti suudetakse 8800 seeriaga "on-par" perfomancet pakkuda, kuna x2900 ei ole ju 8800-st (näit gts640) maas vaid üsna võrdne (v.a paar eripära näit AA perfi kirves). Ja ega 8800gt pole ju imekaart. tegu on nati nõrgema kui 8800gtx-iga, seega pisku klokki siit-sealt ja nati tviikimist ja perfi mõttes on asi käes.
teine asi on aga raha: kas ati on võimeline sama rahaga sellist asja teha ja absoluutselt terve oma x2900 seeria line-upile kõrge kaarega peale kusema. ok, nv tegi gt-ga enda vanale lineupile veidi "liiga" tõesti, aga ati puhul oleks mõju kordi hullem, sest gts/gtx on vana kaart ja oma kasumi juba ära teeninud ning aeg vaikselt pensioneerida, x2900 pole aga turul väga kaua olla saanudki. sisuliselt peab ati välja tooma x2900xt-st parema pefomancega kaardi, mis võtaks vähem voolu, oleks vaiksema jahutusega ja maksaks 2x vähem (hetkel u 5500 ringis).
97 |
29.10.2007 20:58:28
r970??
EDIT:Nevermind
| Kommentaarid: 92 loe/lisa |
One
29.10.2007 21:08:17
High-Q, HD2900 tootmine on sisuliselt lõpetatud, seda tõestab ka kaartide PRO-deks ümber nimetamine ja odavalt ära müümine.
RV670 vahetab R600 täielikult välja. Shadereid on väidetavalt mõlemal 320 aga RV-l on R600 probleemid fixitud + lisatud uusi featureid.
Kiire tuleb RV670 igatahes, loodetavasti seekord kiirem kui NVIDIA vastav. ATi/AMD on väikese õnnestumise ära teeninud.
Igatahes tuleb november normaalne - RV670, Phenom, RD790, CrossFireX. Kui nüüd midagi ära ei tehta siis millal veel.
| High-Q kirjutas: |
| sisuliselt peab ati välja tooma x2900xt-st parema pefomancega kaardi, mis võtaks vähem voolu, oleks vaiksema jahutusega ja maksaks 2x vähem (hetkel u 5500 ringis). |
Ei pea olema kiirem ja 2x odavam. Tuleb mitu eri mudelit millel hinnad/jõudlus eri tasemel.
Voolutarve on igatahes väiksem ning soojaeraldus samuti.
728 |
29.10.2007 21:11:50
dollari kurss ja mitmed variandid ei puutu suurt asjasse.
kas mitte 8800gt-d ei pidada ka ametlikult miski umbes 7 varianti olema? anyway on kallim, ehk siis 512mb asi, $250 ja allapoole hinnaga. sinnapoole peab ati oma vastuse sihtima.
crossfirex on mis?
viimati muutis londiste 29.10.2007 21:12:56, muudetud 3 korda |
215 |
One
29.10.2007 21:12:42
londiste, keegi ei keela kiiremat kaarti kallimalt müümast.
| crossfirex on mis? |
trifire, quadfire, crossfire koos int videoga jne.
728 |
soodent
29.10.2007 22:21:46
Ati leeris matused?2900gt andis ju 15 minute fame...
| Kommentaarid: 822 loe/lisa |
19 :: |
6 :: |
564 |
29.10.2007 22:27:37
miks matused? eeldades et rv670 tegelikult ka parem on, siis on vastane ju täiesti olemas. küsimus on siinjuures vaid konkreetsetes omadustes, eelkõige siis voolutarve/soojuseraldus ja hind
ja eks miski poole aasta pärast majandustulemustest näha ole, kas ja kes dumpinghindadega asju müüs
215 |
G80
210 |
29.10.2007 23:05:10
bullshit pilt.
.pdf (teamati) juba oli ka siin teemas iirc.
215 |
29.10.2007 23:14:39
Hehe hea pilt.Et siis nagu nvidia sellid saavad ATI logo pihta pallikesi pilduda vms? .
