uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  DirectX 10 märgi kõik teemad loetuks
mine lehele eelmine  1, 2
sõnum 05.09.2005 12:18:41 vasta tsitaadiga
üks asi mis ma ei taipa, et te halate (vähemasti winter) et praeguse videokaardiga ei saa näiteks vistas (DX10 siis) tegutseda
kuid saab ju ka näiteks ülivana S3'e kaardiga softis DX9't jooksutada, riistvaraliselt ei pea ju toetama, vaja on vaid draivereid, mis oleks compatibled selle uue DX10'ga
One
sõnum 05.09.2005 15:05:16 vasta tsitaadiga
link :: New DirectX 9 is almost ready to go
edit:
SM4 lubatakse juba enne DX10-t ehk siis järg aasta keskpaigaks..
taifunk
taifunk
sõnum 18.09.2005 10:39:55 vasta tsitaadiga
link :: DirectX 9.0L is the next Direct X
WE ALREADY reported here that Microsoft plans to introduce a new DirectX 9.0 version. This time we managed to get the name and the company plans to call it DirectX 9.0L.
You will remember that Nvidia was pressing Microsoft to call its last revision of DirectX, DirectX 9.1 but Vole decided to simply add a letter C to its existing DirectX 9.0 name. This currently available DirectX 9.0c features support for Shader model 3.0 and Nvidia though that upgrade from Shader model 2.0 would deserve at least 9.1 prefix.
Now the Vole plans to do the same thing. It will call its next generation DirectX featuring Shader model 4.0, DirectX 9.0L.
We don't know when the company plans to make this new marchitecture available but we expect that this will happen sometimes trough 2006. It's still too early to shift to Shader Model 4.0 as Nvidia and ATI won't have Shader model 4.0 hardware until middle of 2006.
It's interesting that ATI has to upgrade to Shader model 3.0 in a few weeks time and Shader Model 4.0 within a year from R520 aka Radeon X1800 RV530 aka Radeon X1600 and RV515 aka Radeon X1300
Remember this day, men, for it will be yours for all time.
Kommentaarid: 45 loe/lisa Kasutajad arvavad:  :: 3 :: 5 :: 36
tumbuser
sõnum 19.09.2005 19:49:00 vasta tsitaadiga
Ho Ho kirjutas:
OpenGL tuli välja tüki maad varem kui DX ning viimane muutus tõeliselt kasutuskõlblikuks alles umbes 6-7 versioonist. Tuletage ise meelde mis oli esimesed korralikud DX mängud icon_smile.gif
OpenGL'i arhitektuur on üsnagi erinev DX'i omast ning selle uuendamine on teistsugune. Minu teada tulevad DX'i uued
Veidi küll teemaväline, aga ehk andestatakse. Ostsin samsung 959 NF, millega sain kaasa OpenGL-i. Arvutis oli enne DX 9. Kas need ei hakka üksteist segama kui mõnda uuemat mängu jooksutada? (enne uue kuvari installi mäng töötas, uue kuvariga näitab vaid intro ära ja siis viskab mängust välja). Või on mingi muu põhjus?
"The computer says I need to upgrade my brain to be compatible with the new software."
angel
angel
sõnum 19.09.2005 20:45:24 vasta tsitaadiga
tumbuser kirjutas:
Ho Ho kirjutas:
Kuda sa siis 959NF moluga äkki openGL kaasa said? Endal sama monitor. Ning kui mängur oled ja uuemad driverid peal siis on sul OpenGL juba peal. Paljud mängud vajavad OpenGL töötamiseks seega see peab peal olema ning sellist asja et DX ja OpenGL ei suuda koos eksisteerida kuulen esimest korda.
Seega see et OpenGL ja DX9 on koos masinas on täitsa tavaline ja nii peabki (linux i peal ainult DX ei ole).
Pane oma Hz ja resod paika ning mängi rahus. Endal on kogemus: viskab mängust välja juhtumitega selline et lihtsalt mängule ei meeldinud mu default reso ja Hz.
Pealegi paha ei teeks kui sa ütled mis mängud jamavad.
cbr
cbr
sõnum 19.09.2005 22:45:28 vasta tsitaadiga
Kuna OpenGL on avatud litsentsiga, peaks see olema kaasatud kiibitootja driverites. Ja monitoriga sa kohe PÄRIS KINDLASTI ei saanud OpenGL'i kaasa.
Kommentaarid: 48 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 39
HDTanel
Overclocker
HDTanel
sõnum 20.09.2005 00:58:52 vasta tsitaadiga
Ohsakrt icon_eek.gif FarCry2???
Anyway DirectX10 powered tech demo ja väga FarCry moodi kuna Cryteki tech video...
http://www.gamershell.com/download_10801.shtml
Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
hobihall
sõnum 20.09.2005 08:39:01 vasta tsitaadiga
https://foorum.hinnavaatlus.ee/viewtopic.php?t=202783&postdays=0&postorder=asc&start=0
Nu
Nu
sõnum 20.09.2005 09:03:11 vasta tsitaadiga
Platoon, sa peaks vist oma uudiste allikat vahetama. Muidugi eilseid uudiseid on ka vahel hea lugeda.
https://foorum.hinnavaatlus.ee/viewtopic.php?t=194813 icon_lol.gif
DO you want it.. And if you had it would you flaunt it...
ss
Kommentaarid: 177 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 157
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  DirectX 10 mine lehele eelmine  1, 2
