Naxik
Kommentaarid: 96 loe/lisa |
87 |
ampsu
23.02.2023 13:12:00
Tore. Ei märganud, et aarch64 vaja ehk BPI M2 Zero pole sobilik...
Milliseid madala voolutarbega aarch64 plaate veel on peale RPI Zero 2W?
Kommentaarid: 109 loe/lisa |
97 |
avrn
Kommentaarid: 5 loe/lisa |
30.06.2023 21:45:58
Kommentaarid: 33 loe/lisa |
RassK
01.07.2023 00:15:20
Compute moodulid ikka otsas Tea kas jõuavad neid toota, nii et tavakasutajale ka jääb.
Kommentaarid: 116 loe/lisa |
101 |
-vodafone-
10.07.2023 12:38:40
Kui üks RPI3b kedagi huvitaks (50€) siis pange PS
Kommentaarid: 244 loe/lisa |
216 |
Rutz
28.09.2023 10:11:17
Uus Raspberry Pi 5 - Coming October 2023
https://www.raspberrypi.com/news/introducing-raspberry-pi-5/
https://www.raspberrypi.com/products/raspberry-pi-5/
tsitaat: |
Broadcom BCM2712 2.4GHz quad-core 64-bit Arm Cortex-A76 CPU, with cryptography extensions, 512KB per-core L2 caches and a 2MB shared L3 cache
VideoCore VII GPU, supporting OpenGL ES 3.1, Vulkan 1.2
Dual 4Kp60 HDMI® display output with HDR support
4Kp60 HEVC decoder
LPDDR4X-4267 SDRAM (4GB and 8GB SKUs available at launch)
Dual-band 802.11ac Wi-Fi®
Bluetooth 5.0 / Bluetooth Low Energy (BLE)
microSD card slot, with support for high-speed SDR104 mode
2 × USB 3.0 ports, supporting simultaneous 5Gbps operation
2 × USB 2.0 ports
Gigabit Ethernet, with PoE+ support (requires separate PoE+ HAT)
2 × 4-lane MIPI camera/display transceivers
PCIe 2.0 x1 interface for fast peripherals (requires separate M.2 HAT or other adapter)
5V/5A DC power via USB-C, with Power Delivery support
Raspberry Pi standard 40-pin header
Real-time clock (RTC), powered from external battery
Power button |
Kommentaarid: 402 loe/lisa |
346 |
avrn
17.05.2025 09:18:38
Kaua teil vaarika sees SD kaardid vastu peavad?
Mul on Pi-holet tegeva model 3B sees... misiganes SD kaart, ammu ostetud ning oli täitsa okei kiirustega (mälu järgi ca 40MB/s lugemist ja kirjutamist). Hiljuti märkasin, et linuxi uuendusi teeb jube kaua (stiilis 2 minuti asemel 20 minutit) ning lähemalt vaadates selgus, et kirjutamiskiirus on ca 4MB/s. Eks ma ilmselt millalgi vaatan siis uue kaardi sinna, aga ilusas teoorias on mingi imeväike miniPC ahvatlevam, kuhu M2 sisse käib. Sest kuigi vaarikale üle USB võiks ju SATA3 SSD panna, siis see tahab juba toitega HUBi pigem ning väiksest vaarikast saab tüütu juhtme- ja karbihunnik.
Kuigi ega kõnealune SD kaart on ilmselt 10 aastat vana ka, seega äkki pole põhjust kriitikaks. Äkki ongi aeg võni V30 klassi kaart asemele panna.
Kommentaarid: 182 loe/lisa |
146 |
lauri
17.05.2025 10:22:36
Mul on tehtud https://www.waveshare.com/wiki/CM4-IO-BASE-B peale RPI CM4 mooduliga (Raspberry Pi Compute Module 4 8GB RAM, Lite).
Töötab rõõmsalt, kõige keerulisem oli leida sinna pisikest m.2 ssd'd.
Kommentaarid: 90 loe/lisa |
80 |
146 |
lisa lemmikuks |
