According to a lengthy blog post the outlet published, most if not all RTX 50-series AIB partner cards are allegedly prone to high-temperature hotspots in the power delivery area, which could potentially damage these graphics cards after extended heavy use.
The problem lies in the construction of power delivery systems for the affected graphics cards. Igor's Lab states that several components that make up the power delivery system, such as the FETs, coils, drivers, and traces connecting everything together, are grouped too close together, creating temperatures that can potentially deteriorate the power delivery system over the course of a card's life, potentially killing the card after just a few years of use.
Another issue Igor's Lab highlights are flaws in Nvidia's Thermal Design Guide. This guide is a document made for all Nvidia add-in board partners that serves as a thermal planning document for Nvidia's reference PCB designs, aimed at helping AIB's create properly cooled Nvidia graphics cards. Igor's Lab highlighted flaws in Nvidia's RTX 40-series guide, revealing that many of the document's parameters are specified under ideal environmental conditions, rather than being optimized for a worst-case scenario. _________________ M: MSI B660M MORTAR
Kokkuhoiu koht, eriti odavamate kaartide puhul. Nagu artiklis kirjas, kuigipalju leevendatav termopatjade ladumisega backplate ja kaardi vahele, korpuse hea õhuvool ka alati abiks, tüüpiline kasti tagumine vent teeb enamus tööd ära.
Ilmselt topin enda 5080 ventusele kah ühelt maalt vahele. Backplate läheb ikka päris kuumaks juba praegu, mingi ülekanne nagu toimuks, aga ruumi optimeerimiseks. _________________ Terrorists have two eyes, pandas have two eyes. Coincidence? I think not!
backplate suudab reaalse jahutuse mõttes teha mitte nii palju. mõned termopadjad ja läheb soojus backplatesse küll aga backplatel ei ole ei massi ega pinda olulise jahutamise jaoks. midagi annab aga mitte väga palju.
palju huvitavamad olid loos kommentaarid pigem kaardi enda jahutuse koha pealt. tundub, et sama vrm juures kust hotspot alguse saab, on ka pealpool kaarti jahutus kehvasti tehtud. _________________ - londiste
Ma kahtlen, et backplate vahele patjade panemine asja väärt on... vbl paar kraadi võidad, aga kütad ka ülemist m.2 SSD oluliselt rohkem(vähemalt klassikalise korpuse ja GPU asetusega).
Mul 990 Pro(SSD) läks 10C kuumemaks 7900XT-ga, mis küll keskmiselt tarbis ka rohkem kui 5080, aga teiste komponentide temp jäi umbes samaks.
Ja selle pärast ei usaldagi neid odavama otsa kaarte osta, millel jahutusega ko8nerdatud(testides VRAM juba 6c kõrgem, VRM pole nii jälginud).
Endal ka kast kehva õhuvooluga ka veel, mesh kastis võiks suht ok olla, kus 2x140st pealt kuuma õhu välja tõmbavad kohe.(saab kohe aru kui kasti tagumist nurka katsuda, kas kuum õhk koguneb või mitte).
tpu vaidluses - arutelus toodi välja, et 3gb ddr7 kivid on täitsa olemas-tulemas. rtx pro seeria ja mobile 5090 kasutavad. 5090 mobile oli veebruari algusest saadaval (mingil määral). rtx pro kuulutati välja märtsi lõpus ja nüüd vist hakkab shippima.
tundub ikkagi, et saadavus piiratud. 5090 mobile jaoks leiti mingi hulk. nüüd siis rtx pro jaoks läheb lademes. _________________ - londiste
Aga gddr6/x 3gb kivid? Kui siin nagunii pci3x8 on siis pole nendest gddr7 ka kasu madalama otsa kaartidel?
5090l nagunii piisavalt Vrammu juba, see et nvidia .50$ PCB tinutamiselt kokku saab hoida väga lõpptarbijat ei mõjuta ju?
gddr6/x ajal oli juttu suurema mahuga kividest aga ei ole neid ei standardis ega tootmises olnud.
pcie ei mängi mälu kiiruse osas mingit rolli. mida rohkem gpu kõrval oleval mälul läbilaset on, seda parem. _________________ - londiste
Kuidas ei mängi? Kui sul on VRAM nagunii täis pidevalt siis ega sealt üle cpu pci3.0 ja edasi pci3.0x8 juurde andmeid ei pumpa ju? Eriti veel suurte avatud maailmade puhul. Parem oleks suurem maht aga ohverdada madalam kiiruse pealt?
Need 5060ti 8GB testid tehti pci 5.0ga, ega need kaardid lähevad põhiliselt vanemate platvormide peale ja pcie 4.0/3.0 olukord paremaks enam lähe...
AMDl on üldse 9070 peal gddr6, isegi mitte x ja toimetab ka(ok ue5 mängudes jääb läbilaskest puudu, aga gddr6x oleks piisanud)...
128-bit gddr7 läbilase on 448GB/s. täna parimal võimalikul variandil ehk pci-e 5.0 x16 läbilase on 63GB/s. kui üle pci-e süsteemimällu kobama lähed, on asjad juba tuksis niikuinii. _________________ - londiste
Keegi teab miks 4080 kaardid nii hälve kalliks läksid? M6ned kuud tagasi sai Superi 1000€ eest, nüüd alatas 1600 ja isegi 3000 wtf? _________________ zero
kas on mingi hea põhjus, miks täna uuena 5080 asemel 4080/4080s osta?
Ilmselt enamus nii ei m6tle, muidu oleks 4080 hinnad madalamad ja ka saadavus oleks parem. Nagu 4060 ja 4070-ki. 5k seeria tarbib liiga palju voolu ja veel fakeframed kah _________________ zero
Recent reports suggest that Nvidia has halted production for most RTX 4000 GPUs, with only the AD107 chip—used in the RTX 4060 desktop and laptop cards and the mobile RTX 4050—still in production.
Ja see oli juba eelmise aasta novembris
Kuidas nii labaseid vigu ei suudeta lahendada? Tehnoloogilise tipp-toote juures ei suudeta aru saada palju mingi kaabli/connectori ristlõikest on võimalik ohutult ampreid läbi lasta?
oluline punkt, mis ei ole siiani vastust saanud on, et kes peaks tegelema selle per juhe läbi mineva vooluhulga piiramisega. _________________ - londiste
Parandage, kui eksin, aga minu teada on nVidia vist keelanud vanade, töötavate 8-piniste pistikute kasutamise ja lubab ainult nende uute, vigaste kasutamist, seega on see puhtalt nVidia mure see asi korda teha _________________ M: MSI B660M MORTAR
* Muutis uue pistiku tüübi kasutamise kohustuslikuks
* Lõdvendas pistiku ja kaardi võimsuse kontrolle iga pinni kohta (nende endi nuditud PCB on üks hullemaid)
* Pole siiani omalt poolt ametlikult midagi vastanud, vaid lihtsalt vaatab pealt
PSU tootjad ja adapteri müüjad ning AIB partnerid:
* Tehke midagi aga teil pole õigust muuta PCB's oluliselt seda disaini osa
Nagu mida me arutame üldse _________________ Sõim ja räuskamine läheb SIIA
