uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  nVidia Blackwell (GB202/GB203/GB205/GB206/GB207) märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 53, 54, 55 ... 59, 60, 61  järgmine
1dumbpcuser
sõnum 23.04.2025 07:08:19 vasta tsitaadiga
Igor's Lab uncovers 'hotspot issue' affecting all RTX 50-series GPUs — says it could compromise graphics card longevity
https://www.tomshardware.com/pc-components/gpus/igors-lab-uncovers-hotspot-issue-affecting-all-rtx-50-series-gpus-says-it-could-compromise-graphics-card-longevity
According to a lengthy blog post the outlet published, most if not all RTX 50-series AIB partner cards are allegedly prone to high-temperature hotspots in the power delivery area, which could potentially damage these graphics cards after extended heavy use.
The problem lies in the construction of power delivery systems for the affected graphics cards. Igor's Lab states that several components that make up the power delivery system, such as the FETs, coils, drivers, and traces connecting everything together, are grouped too close together, creating temperatures that can potentially deteriorate the power delivery system over the course of a card's life, potentially killing the card after just a few years of use.
Another issue Igor's Lab highlights are flaws in Nvidia's Thermal Design Guide. This guide is a document made for all Nvidia add-in board partners that serves as a thermal planning document for Nvidia's reference PCB designs, aimed at helping AIB's create properly cooled Nvidia graphics cards. Igor's Lab highlighted flaws in Nvidia's RTX 40-series guide, revealing that many of the document's parameters are specified under ideal environmental conditions, rather than being optimized for a worst-case scenario.
M:
Kommentaarid: 100 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 95
Mirage
sõnum 23.04.2025 08:08:33 vasta tsitaadiga
Kokkuhoiu koht, eriti odavamate kaartide puhul. Nagu artiklis kirjas, kuigipalju leevendatav termopatjade ladumisega backplate ja kaardi vahele, korpuse hea õhuvool ka alati abiks, tüüpiline kasti tagumine vent teeb enamus tööd ära.
Ilmselt topin enda 5080 ventusele kah ühelt maalt vahele. Backplate läheb ikka päris kuumaks juba praegu, mingi ülekanne nagu toimuks, aga ruumi optimeerimiseks.
Terrorists have two eyes, pandas have two eyes. Coincidence? I think not!
Kommentaarid: 80 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 74
sõnum 23.04.2025 08:41:13 vasta tsitaadiga
backplate suudab reaalse jahutuse mõttes teha mitte nii palju. mõned termopadjad ja läheb soojus backplatesse küll aga backplatel ei ole ei massi ega pinda olulise jahutamise jaoks. midagi annab aga mitte väga palju.
palju huvitavamad olid loos kommentaarid pigem kaardi enda jahutuse koha pealt. tundub, et sama vrm juures kust hotspot alguse saab, on ka pealpool kaarti jahutus kehvasti tehtud.
- londiste
Arx07
Arx07
sõnum 23.04.2025 09:55:10 vasta tsitaadiga
Ma kahtlen, et backplate vahele patjade panemine asja väärt on... vbl paar kraadi võidad, aga kütad ka ülemist m.2 SSD oluliselt rohkem(vähemalt klassikalise korpuse ja GPU asetusega).
Mul 990 Pro(SSD) läks 10C kuumemaks 7900XT-ga, mis küll keskmiselt tarbis ka rohkem kui 5080, aga teiste komponentide temp jäi umbes samaks.
busta
sõnum 23.04.2025 10:31:45 vasta tsitaadiga
Kasutagem jahutamiseks vett. Saab vaikse kone.
1dumbpcuser
sõnum 23.04.2025 10:44:17 vasta tsitaadiga
busta kirjutas:
M:
Vael
sõnum 23.04.2025 17:17:50 vasta tsitaadiga
Ja selle pärast ei usaldagi neid odavama otsa kaarte osta, millel jahutusega ko8nerdatud(testides VRAM juba 6c kõrgem, VRM pole nii jälginud).
Endal ka kast kehva õhuvooluga ka veel, mesh kastis võiks suht ok olla, kus 2x140st pealt kuuma õhu välja tõmbavad kohe.(saab kohe aru kui kasti tagumist nurka katsuda, kas kuum õhk koguneb või mitte).
EDIT
Tomorrow kirjutas:
Link
Halenaljakas on see et paljulubatud Fake Frames lisab gigabaite veel juurdegi ja muudab 4k Very High seadetel mängitava mängu desktopile pangestuma...
sõnum 24.04.2025 08:35:28 vasta tsitaadiga
tpu vaidluses - arutelus toodi välja, et 3gb ddr7 kivid on täitsa olemas-tulemas. rtx pro seeria ja mobile 5090 kasutavad. 5090 mobile oli veebruari algusest saadaval (mingil määral). rtx pro kuulutati välja märtsi lõpus ja nüüd vist hakkab shippima.
tundub ikkagi, et saadavus piiratud. 5090 mobile jaoks leiti mingi hulk. nüüd siis rtx pro jaoks läheb lademes.
- londiste
Vael
sõnum 24.04.2025 19:36:56 vasta tsitaadiga
Aga gddr6/x 3gb kivid? Kui siin nagunii pci3x8 on siis pole nendest gddr7 ka kasu madalama otsa kaartidel?
5090l nagunii piisavalt Vrammu juba, see et nvidia .50$ PCB tinutamiselt kokku saab hoida väga lõpptarbijat ei mõjuta ju?
1dumbpcuser
sõnum 24.04.2025 19:51:26 vasta tsitaadiga
Neid pole vist tootmises ja pole enam mõtet ka tootma hakata icon_rolleyes.gif
M:
sõnum 24.04.2025 20:05:35 vasta tsitaadiga
Vael kirjutas:
gddr6/x ajal oli juttu suurema mahuga kividest aga ei ole neid ei standardis ega tootmises olnud.
pcie ei mängi mälu kiiruse osas mingit rolli. mida rohkem gpu kõrval oleval mälul läbilaset on, seda parem.
- londiste
Vael
sõnum 25.04.2025 10:18:51 vasta tsitaadiga
londiste kirjutas:
Vael kirjutas:
Kuidas ei mängi? Kui sul on VRAM nagunii täis pidevalt siis ega sealt üle cpu pci3.0 ja edasi pci3.0x8 juurde andmeid ei pumpa ju? Eriti veel suurte avatud maailmade puhul. Parem oleks suurem maht aga ohverdada madalam kiiruse pealt?
Need 5060ti 8GB testid tehti pci 5.0ga, ega need kaardid lähevad põhiliselt vanemate platvormide peale ja pcie 4.0/3.0 olukord paremaks enam lähe...
AMDl on üldse 9070 peal gddr6, isegi mitte x ja toimetab ka(ok ue5 mängudes jääb läbilaskest puudu, aga gddr6x oleks piisanud)...
sõnum 25.04.2025 11:19:21 vasta tsitaadiga
128-bit gddr7 läbilase on 448GB/s. täna parimal võimalikul variandil ehk pci-e 5.0 x16 läbilase on 63GB/s. kui üle pci-e süsteemimällu kobama lähed, on asjad juba tuksis niikuinii.
- londiste
486
sõnum 25.04.2025 11:24:21 vasta tsitaadiga
Keegi teab miks 4080 kaardid nii hälve kalliks läksid? M6ned kuud tagasi sai Superi 1000€ eest, nüüd alatas 1600 ja isegi 3000 wtf?
zero
1dumbpcuser
sõnum 25.04.2025 11:32:34 vasta tsitaadiga
Ja võrdluseks veel - see pci-e 5x16 läbilase 63GB on sama, mis ühel Harju keskmisel gddr6 mälukiibil (@32bit laius).
486 kirjutas:
https://foorum.hinnavaatlus.ee/viewtopic.php?t=860004&highlight=
M:
sõnum 25.04.2025 11:58:33 vasta tsitaadiga
1dumbpcuser kirjutas:
486 kirjutas:
kas on mingi hea põhjus, miks täna uuena 5080 asemel 4080/4080s osta? icon_smile.gif
- londiste
486
sõnum 25.04.2025 13:10:35 vasta tsitaadiga
londiste kirjutas:
486 kirjutas:
Ilmselt enamus nii ei m6tle, muidu oleks 4080 hinnad madalamad ja ka saadavus oleks parem. Nagu 4060 ja 4070-ki. 5k seeria tarbib liiga palju voolu ja veel fakeframed kah thumbs_down.gif
zero
1dumbpcuser
sõnum 25.04.2025 13:24:46 vasta tsitaadiga
edit:
Ja näiteks HWU 5080 launch videos tarbis 5080 mängides õige natuke vähem voolu kui 4080S - https://www.youtube.com/watch?v=sEu6k-MdZgc&t=793s icon_rolleyes.gif
M:
Snaxez
Snaxez
sõnum 25.04.2025 14:19:14 vasta tsitaadiga
486 kirjutas:
londiste kirjutas:
486 kirjutas:
Recent reports suggest that Nvidia has halted production for most RTX 4000 GPUs, with only the AD107 chip—used in the RTX 4060 desktop and laptop cards and the mobile RTX 4050—still in production.
Ja see oli juba eelmise aasta novembris
1440p avg power usage:
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 54
1dumbpcuser
sõnum 29.04.2025 21:12:22 vasta tsitaadiga
MSI’s yellow 12V-2×6 power connector turns black after burning on GeForce RTX 5090 graphics card
https://videocardz.com/newz/msis-yellow-12v-2x6-power-connector-turns-black-after-burning-on-geforce-rtx-5090-graphics-card
Edit: pilt spoilerdatud
M:
viimati muutis 1dumbpcuser 30.04.2025 08:42:46, muudetud 1 kord
sõnum 30.04.2025 07:00:12 vasta tsitaadiga
1dumbpcuser, Pilt tsipa suur. Võiks spoileris olla.
Mis puutub high failiure rate connectorit, siis see jätkab sulamist, kuni ei lahendada fundamentaalseid probleeme selle ja kaartide enda disainis.
Der8auer ütles seda juba eelmine aasta ja tal oli õigus.
-Koppel-
-Koppel-
sõnum 30.04.2025 08:14:01 vasta tsitaadiga
Kuidas nii labaseid vigu ei suudeta lahendada? Tehnoloogilise tipp-toote juures ei suudeta aru saada palju mingi kaabli/connectori ristlõikest on võimalik ohutult ampreid läbi lasta?
sõnum 30.04.2025 09:10:05 vasta tsitaadiga
-Koppel- kirjutas:
oluline punkt, mis ei ole siiani vastust saanud on, et kes peaks tegelema selle per juhe läbi mineva vooluhulga piiramisega.
- londiste
1dumbpcuser
sõnum 30.04.2025 09:39:40 vasta tsitaadiga
londiste kirjutas:
-Koppel- kirjutas:
Parandage, kui eksin, aga minu teada on nVidia vist keelanud vanade, töötavate 8-piniste pistikute kasutamise ja lubab ainult nende uute, vigaste kasutamist, seega on see puhtalt nVidia mure see asi korda teha icon_rolleyes.gif
M:
Zonerman
Zonerman
sõnum 30.04.2025 11:50:26 vasta tsitaadiga
Nvidia:
* Muutis uue pistiku tüübi kasutamise kohustuslikuks
* Lõdvendas pistiku ja kaardi võimsuse kontrolle iga pinni kohta (nende endi nuditud PCB on üks hullemaid)
* Pole siiani omalt poolt ametlikult midagi vastanud, vaid lihtsalt vaatab pealt
PSU tootjad ja adapteri müüjad ning AIB partnerid:
* Tehke midagi aga teil pole õigust muuta PCB's oluliselt seda disaini osa icon_biggrin.gif
Sõim ja räuskamine läheb SIIA
Kommentaarid: 67 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 66
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  nVidia Blackwell (GB202/GB203/GB205/GB206/GB207) mine lehele eelmine  1, 2, 3 ... 53, 54, 55 ... 59, 60, 61  järgmine
