uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  LG OLED arutelu märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 24, 25, 26, 27, 28, 29  järgmine
dex
dex
sõnum 21.11.2022 09:42:08 vasta tsitaadiga
Aegajalt siin HVs ikka mõni 55-65" liigub, enamasti põhjuseks see, et ostetakse asemele veel suurem OLED icon_smile.gif
Süümi, juumi, makkami ja kui tüüle nakkami...
Kommentaarid: 97 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 86
somnambuul
sõnum 21.11.2022 10:24:49 vasta tsitaadiga
OLED telekad on piisavalt uued, tõenäoliselt jätkuvalt esimese ringi kasutuses. Ja mida sa ikka asemele ostad, kui siis suurema.
lkraav
lkraav
sõnum 21.11.2022 12:09:49 vasta tsitaadiga
Järelturu kohta on jah kõik ülaltooduga öeldud.
Aga põnev uudis FB OLED grupist
IMPORTANT: Anyone who has the LG G2 and has to press the power on button twice in order to turn their TV on: GET A TV REPLACEMENT ASAP! The LG G2/C2 83 inch has been recalled due to a badly engineered motherboard. The problem is a few compacitors on the board fail to hold power to the P3 circuit. This means if the TV sits long enough it will not have enough power to energize the relay and allow the TV to turn on properly the first time. This is why pressing power on the first time pulls energy from the wall and energizes the P3 circuit at less than half voltage and the relay does not engage to allow the TV to turn on. The second power on press will allow the TV to come on due to the strange half-volted P3 power state. This half-volted state, if persisting for a long period of time, can cause the motherboard to short to ground and cause a fire.
I’m hoping LG posts a recall shortly. I have been told they are working on drafting the recall this week.
https://www.youtube.com/shorts/E9_kSt9QFvU
TELEFON PROFIILIS :: HV-NewFavFilter - GreaseMonkey HV lemmikute filter! Kui meeldib, pane positiivne märksõnaga "HV-NewFavFilter".
Kommentaarid: 138 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 129
triu
sõnum 21.11.2022 13:10:21 vasta tsitaadiga
Tegelikult ma seda just mõtlesingi, et vahetan enda 65 tolli suuremaks ja mõtlesin, et mis vanaga teha.
Võiks ehk olla kellelgi huvi? 65" B7 toodetud aprill 2018. Ühtegi välimuse ega tehnika viga ei tea olevat.
somnambuul kirjutas:
S.I.L.L.U
sõnum 21.11.2022 13:32:46 vasta tsitaadiga
lkraav, mu CX on hakanud seda sama tegema puldiga sisse lülitades. icon_lol.gif
Arvasin, et viimane softiuuendus või äkki tühi patakas puldis.
Just järgmisel päeval sisselülitades esimest korda, kui on öö otsa seisnud.
Kommentaarid: 93 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 87
Lotharius
rallisibul
Lotharius
sõnum 21.11.2022 14:15:52 vasta tsitaadiga
ELis vist võib unistama jäädagi, et mingi tagasikutsumine tuleks...
Geek it til it MHz
Kommentaarid: 123 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 115
Dev Grex
sõnum 21.11.2022 17:09:32 vasta tsitaadiga
Veel üks huvitav OLED monitor välja antud: https://www.lg.com/us/monitors/lg-27gr95qe-b
Kommentaarid: 356 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 301
sõnum 21.11.2022 18:52:46 vasta tsitaadiga
https://www.pocket-lint.com/laptops/news/lg/162391-lg-45gr95qe-mammoth-curved-oled-monitor-for-gaming
HV valuutakalkulaator
Kommentaarid: 469 loe/lisa Kasutajad arvavad:  :: 12 :: 7 :: 359
Margo18
Margo18
sõnum 21.11.2022 21:22:42 vasta tsitaadiga
On hakanud kummitama mõte 77 tollisest c(g)2st. Nimelt on kindel plaan osta 65 tolli g2 just seinale sobivuse pärast jne. Nüüd mõte, äkki jääb 65" väheks icon_lol.gif Tuba suht väike vaatekaugus ca 2,2m, seda siis g seeria puhul. C2 77 mahuks eelarvesse, siis vaatekaugus vast mingi 2m, tundub overkill? Põhiliselt filmid, netflix vb konsool ka.
Kommentaarid: 14 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 10
dex
dex
sõnum 21.11.2022 21:46:13 vasta tsitaadiga
65" 2,2 m pealt on täitsa OK vaadata (praegu just niimoodi ees). 77" ei suuda ise visualiseerida hästi. Kui ise peaks ostma, siis valiks tänasel päeval muidugi suurema, aga mul siin ruumi tugitooliga vajadusel tahapoole ka kolida.
von Wu
von Wu
sõnum 21.11.2022 22:12:09 vasta tsitaadiga
Filmi on 2,2 m kauguselt võimalik veel 85" pealt ka napilt nii vaadata, et ei pea pead pöörama. Kui 77" füüsiliselt ära mahub ja sisu on kvaliteetne, siis miks mitte.
Telekanalite jaoks on ~2 m kauguselt 55" täpselt paras. Suuremal ekraanil oleks pilt juba liiga kole. icon_biggrin.gif
Müüa igasugu asju
Kommentaarid: 889 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 668
heretic666
heretic666
sõnum 21.11.2022 22:29:56 vasta tsitaadiga
Pole veel kuulnud et keegi kurdaks "dammit, liiga suur teler sai"
lkraav
lkraav
sõnum 21.11.2022 22:40:04 vasta tsitaadiga
Tanel kirjutas:
Ma ei tea kas sama asi, aga juhuslikult Google viskas just https://www.lg.com/uk/tvs/lgoledflex ette
Flexible Display
1 screen. 20 curves.
With LG OLED Flex, go from a flat display all the way to a spectacular 900R curve* until you find the ideal arc for total immersion. Simply press the curvature button on your remote control and explore 20 different levels of curve.
Täpselt see millest kirjutasin paar postitust tagasi - 40"+ curved on flatist palju parem UX.
https://www.lg.com/us/tvs/lg-42lx3qpua hinnasilt $2499 polegi nii kättesaamatu kui väga ja kohe tahta!
Margo18 kirjutas:
Euronics igati viisakalt pricematchis ära HV hinnaliidrid täna mulle, tundub et saan varsti loomkatsetada ja muljeid jagada.
Margo18
Margo18
sõnum 21.11.2022 23:00:05 vasta tsitaadiga
heretic666 kirjutas:
lkraav
lkraav
sõnum 22.11.2022 00:23:51 vasta tsitaadiga
Kaalun 77" wall mountiks "Vogel's Elite Fixed, 40" - 100", must - Teleri seinakinnitus" https://www.vogels.com/en/c/tvm-5605-fixed-tv-wall-mount 1,5cm seinast, ja kavalad 3 juhtmekanalit on ka raamile nikerdatud https://www.vogels.com/media/catalog/product/cache/644cc77ca34df95bb894e7e41ed8ac57/w/e/web_version-tvm5405_tvm5605_series_usp_image_pp_cable-clips_en.png
Kuidas teil kogemused, kas mingi tilt funktsioon võib olla siiski vajalik? Full motion kindlasti pole vajalik, aga vbla tulistan 100% fixed asjaga endale jalga siin?
von Wu
von Wu
sõnum 22.11.2022 02:28:42 vasta tsitaadiga
100% liikumatu külge on halb paigaldada ja kaablite vahetamiseks või isegi USB-pulga sisestamiseks võib tekkida vajadus telekas maha võtta.
Kalde reguleerimist on siis vaja, kui vahepeal märkimisväärselt madalamal istud.
Ma olen selliseid kinnitusi kasutanud: https://arvutitark.ee/est/tootekataloog/Kodu-ja-ilutooted-Televiisorid-kodukinod-TV-seinakinnitused/Maclean-TV-Bracket-37-80-must-60kg-MC-881-568423
Teler jääb küll mõni sentimeeter seinast eemale, aga väga mugav on sättida, isegi kui vaatamiseks kunagi ekraani keerata pole vaja.
Müüa igasugu asju
Wiltz
sõnum 22.11.2022 06:58:25 vasta tsitaadiga
mul on üks täpselt selline mclean bracket siin kodus pakendis kapis ka hetkel. ükspäev just võtsin välja ja uurisin pisut lähemalt, tundub päris stabiilne tükk. enda suuremat sorti telekas on hetkel ka üsna sarnase asjaga seina külge kinnitatud. aga olgem ausad eks ta liigub nende liigendite peal päris raskelt sest 65 tolline asi ikkagi üht koma teist kaalub. samas liigub, saab tõmmata seinast eemale oma 50cm ja viia seina vastu tagasi.
paigaldada ma arvan on paras tegemine nii liikumatu kui liikuva külge, ent ligipääs on tõesti palju lihtsam kui asi on natuke nihutatav
Draqula
sõnum 23.11.2022 14:41:15 vasta tsitaadiga
Vanemate inimeste puhul olen kuulnud küll sellist reaktsiooni, kuid seda vaid esimesel päeval / esimestel vaatamise tundidel.
Üsna kiirelt harjutakse ja mõte liigub edasi "paar tolli veel poleks ka paha" suunas icon_smile.gif
bpuhnja
bpuhnja
sõnum 24.11.2022 10:16:38 vasta tsitaadiga
triu kirjutas:
Kas nendel suurtel OLED telekatel üldse on mingit järelturgu? Kiirelt netis sobrades midagi eriti silma ei jäänud.
Või liigutatakse ainult kusagil tuttavatele või midagi sellist. Seda, et keegi pole enne neid müüa soovinud, hästi uskuda ei tahaks.
Kogemuse järgi selline tehnika pärandatakse suuresti ära vanematele/lastele või lihtsalt pannakse magamistuppa.
Lotharius kirjutas:
Tagasikutsumist polegi vaja. Saadavad tehniku koju sulle ja vahetavad vigase jupi (antud juhul emaplaadi siis) välja lihtsalt.
Pole mingi Apple, et ühe jupi pärast kõik kellad.
Sarnane juhus on/oli mõne vanemate OLED teleritega, toiteplokki vahetus:
https://www.lg.com/ee/toetus/teadete-uksikasjad/EENTC20201028150787
Muidugi tasub lisada juurde siia oma anektoodiline kogemus, kus originaalne toide töötas laitmatult 4a, ning siis uus väljavahetatud toide läks suitsema 6 kuuga icon_lol.gif icon_lol.gif
lkraav
lkraav
sõnum 25.11.2022 14:16:23 vasta tsitaadiga
Panin ikkagi minimaalsusele rõhudes selle liikumatu Vogels TVM-5605 seina 3 poldiga ja täitsa kobe tuli. Vogelsil on mingi AR äpp, ja see isegi aitas natuke kaasa top/center drill hole leidmisel, aga tagapaneelile mount stripid külge ja mõõdulint kindlasti abiks.
Muidugi õige - TV taha kaableid mudima minna enam asja pole, ilge keberniit, nagu oodatud. Samas kõik pordid ilusti ühe külje peale toodud, nii et 2x aastas vbla saab hakkama.
Euronicsi pricematchi protsessist sai õpitud, et
* tuleb kiiresti maksta - ma otsisin veel wall mounti ja suhtlesin tarneaadressi teemal, tulemus oli see et ülejärgmisel päeval maksevalmis olla öeldi "võrdlevat pakkumist ei ole enam" ja hind tagasi üles
* klienditeenindajad ei tohi ise konkreetset võrdlevat pakkumist valida, nii et agregaadi lingi saatmine kõikide pakkujate hindadega "orientiiriks" ei toimi
Õnneks HV-s oli veel pakkumisi reas küllalt, kuigi loomulikult 21LA vs 22LB SKU probleemid sai läbi ronitud jne.
Nagu Rifleman Creed ütles: "There are many (77" OLEDs) like it, but this one is mine". Pildil kaob mastaap ära, see ekraan on ikka päris kolakas. Täpselt 3m vaatamiskaugus nüüd on täitsa OK.
Zonerman
Zonerman
sõnum 25.11.2022 15:02:24 vasta tsitaadiga
Vabanda, ma märkasin seda lillepotti kõlari peal. Tundub, et vist pole mingid kallid kõlarid aga heli entusiastide seas on see big no no icon_biggrin.gif
Mis telekasse puutub, siis pilt vb tõesti moonutab a la lai sein aga tundub ikka päris kaugel.
Sõim ja räuskamine läheb SIIA
Kommentaarid: 66 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 65
terminator
terminator
sõnum 25.11.2022 15:08:17 vasta tsitaadiga
+1
Tundub töesti kaugel. Sobiks isegi 83" kui hinnavahe 77" nii suur poleks.
2023 QULBIX Q140MD 12kW=16hj 280Nm 72V 2160Wh 54kg 80km/h el.ratas 3999€ (poes 8500€) https://www.tori.fi/recommerce/forsale/item/25355832
2006 VOLVO V50 Sveits 2.0 100kW el. nahksisu 2999€ https://www.auto24.ee/kasutatud/auto.php?share=6753f92727c0698dd57b3bd799d69811
Kommentaarid: 494 loe/lisa Kasutajad arvavad:  :: 19 :: 6 :: 373
Zonerman
Zonerman
sõnum 25.11.2022 16:10:36 vasta tsitaadiga
Ma mõõtsin enda vaatamiskauguse ära. Täpselt 2.4m silmadest kaugus ekraanini ja 65" ja sellega pead ei pea keerama ning ka ekraan on terves ulatuses veel suht lähedal. Iga 10cm ja edasi kuni 3m mõõtsin, siis läheb väga kiirelt juba ekraan väiksemaks. Kui see on 77" ekraan pildil, siis pigem ütleks, et kaugus on pigem rohkem kui 3m. Ehk isegi 3.5m kui pilt ei peta.
Prillpapa
Aeg maha 1p
sõnum 25.11.2022 16:10:55 vasta tsitaadiga
laepaneelide järgi näha, et fotol see kalasilmaefekt, lainurk või sarnane pildi tegemisel olnud..
Zonerman
Zonerman
sõnum 25.11.2022 16:13:56 vasta tsitaadiga
Ok siis fotolt ei saa hinnata.
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  LG OLED arutelu mine lehele eelmine  1, 2, 3 ... 24, 25, 26, 27, 28, 29  järgmine
