dex
21.11.2022 09:42:08
Aegajalt siin HVs ikka mõni 55-65" liigub, enamasti põhjuseks see, et ostetakse asemele veel suurem OLED
_________________ Süümi, juumi, makkami ja kui tüüle nakkami... |
Kommentaarid: 97 loe/lisa |
86 |
somnambuul
21.11.2022 10:24:49
OLED telekad on piisavalt uued, tõenäoliselt jätkuvalt esimese ringi kasutuses. Ja mida sa ikka asemele ostad, kui siis suurema.
Kommentaarid: 60 loe/lisa |
54 |
lkraav
21.11.2022 12:09:49
Järelturu kohta on jah kõik ülaltooduga öeldud.
Aga põnev uudis FB OLED grupist
tsitaat: |
IMPORTANT: Anyone who has the LG G2 and has to press the power on button twice in order to turn their TV on: GET A TV REPLACEMENT ASAP! The LG G2/C2 83 inch has been recalled due to a badly engineered motherboard. The problem is a few compacitors on the board fail to hold power to the P3 circuit. This means if the TV sits long enough it will not have enough power to energize the relay and allow the TV to turn on properly the first time. This is why pressing power on the first time pulls energy from the wall and energizes the P3 circuit at less than half voltage and the relay does not engage to allow the TV to turn on. The second power on press will allow the TV to come on due to the strange half-volted P3 power state. This half-volted state, if persisting for a long period of time, can cause the motherboard to short to ground and cause a fire. |
tsitaat: |
I’m hoping LG posts a recall shortly. I have been told they are working on drafting the recall this week. |
https://www.youtube.com/shorts/E9_kSt9QFvU
_________________ TELEFON PROFIILIS :: HV-NewFavFilter - GreaseMonkey HV lemmikute filter! Kui meeldib, pane positiivne märksõnaga "HV-NewFavFilter". |
Kommentaarid: 138 loe/lisa |
129 |
triu
21.11.2022 13:10:21
Tegelikult ma seda just mõtlesingi, et vahetan enda 65 tolli suuremaks ja mõtlesin, et mis vanaga teha.
Võiks ehk olla kellelgi huvi? 65" B7 toodetud aprill 2018. Ühtegi välimuse ega tehnika viga ei tea olevat.
somnambuul kirjutas: |
OLED telekad on piisavalt uued, tõenäoliselt jätkuvalt esimese ringi kasutuses. Ja mida sa ikka asemele ostad, kui siis suurema. |
S.I.L.L.U
21.11.2022 13:32:46
lkraav, mu CX on hakanud seda sama tegema puldiga sisse lülitades.
Arvasin, et viimane softiuuendus või äkki tühi patakas puldis.
Just järgmisel päeval sisselülitades esimest korda, kui on öö otsa seisnud.
Kommentaarid: 93 loe/lisa |
87 |
Lotharius
rallisibul
21.11.2022 14:15:52
ELis vist võib unistama jäädagi, et mingi tagasikutsumine tuleks...
Kommentaarid: 123 loe/lisa |
115 |
Dev Grex
Kommentaarid: 355 loe/lisa |
301 |
Kommentaarid: 468 loe/lisa |
12 :: |
7 :: |
359 |
Margo18
21.11.2022 21:22:42
On hakanud kummitama mõte 77 tollisest c(g)2st. Nimelt on kindel plaan osta 65 tolli g2 just seinale sobivuse pärast jne. Nüüd mõte, äkki jääb 65" väheks Tuba suht väike vaatekaugus ca 2,2m, seda siis g seeria puhul. C2 77 mahuks eelarvesse, siis vaatekaugus vast mingi 2m, tundub overkill? Põhiliselt filmid, netflix vb konsool ka.
Kommentaarid: 13 loe/lisa |
10 |
dex
21.11.2022 21:46:13
65" 2,2 m pealt on täitsa OK vaadata (praegu just niimoodi ees). 77" ei suuda ise visualiseerida hästi. Kui ise peaks ostma, siis valiks tänasel päeval muidugi suurema, aga mul siin ruumi tugitooliga vajadusel tahapoole ka kolida.
86 |
von Wu
21.11.2022 22:12:09
Filmi on 2,2 m kauguselt võimalik veel 85" pealt ka napilt nii vaadata, et ei pea pead pöörama. Kui 77" füüsiliselt ära mahub ja sisu on kvaliteetne, siis miks mitte.
Telekanalite jaoks on ~2 m kauguselt 55" täpselt paras. Suuremal ekraanil oleks pilt juba liiga kole.
_________________ Müüa igasugu asju
Saab 9-3 10-sendise alghinnaga oksjonil
Müüa LPG-seadmega Subaru |
Kommentaarid: 889 loe/lisa |
668 |
heretic666
21.11.2022 22:29:56
Pole veel kuulnud et keegi kurdaks "dammit, liiga suur teler sai"
Kommentaarid: 72 loe/lisa |
lkraav
21.11.2022 22:40:04
Ma ei tea kas sama asi, aga juhuslikult Google viskas just https://www.lg.com/uk/tvs/lgoledflex ette
Flexible Display
1 screen. 20 curves.
With LG OLED Flex, go from a flat display all the way to a spectacular 900R curve* until you find the ideal arc for total immersion. Simply press the curvature button on your remote control and explore 20 different levels of curve.
Täpselt see millest kirjutasin paar postitust tagasi - 40"+ curved on flatist palju parem UX.
https://www.lg.com/us/tvs/lg-42lx3qpua hinnasilt $2499 polegi nii kättesaamatu kui väga ja kohe tahta!
Dünaamilise raadiusega monitor on ikka next level
Margo18 kirjutas: |
On hakanud kummitama mõte 77 tollisest c(g)2st. Nimelt on kindel plaan osta 65 tolli g2 just seinale sobivuse pärast jne. Nüüd mõte, äkki jääb 65" väheks Tuba suht väike vaatekaugus ca 2,2m, seda siis g seeria puhul. C2 77 mahuks eelarvesse, siis vaatekaugus vast mingi 2m, tundub overkill? Põhiliselt filmid, netflix vb konsool ka. |
Euronics igati viisakalt pricematchis ära HV hinnaliidrid täna mulle, tundub et saan varsti loomkatsetada ja muljeid jagada.
129 |
Margo18
21.11.2022 23:00:05
heretic666 kirjutas: |
Pole veel kuulnud et keegi kurdaks "dammit, liiga suur teler sai" |
Naised kah vist ei kurda, kui suurem sai
10 |
lkraav
129 |
von Wu
668 |
Wiltz
22.11.2022 06:58:25
mul on üks täpselt selline mclean bracket siin kodus pakendis kapis ka hetkel. ükspäev just võtsin välja ja uurisin pisut lähemalt, tundub päris stabiilne tükk. enda suuremat sorti telekas on hetkel ka üsna sarnase asjaga seina külge kinnitatud. aga olgem ausad eks ta liigub nende liigendite peal päris raskelt sest 65 tolline asi ikkagi üht koma teist kaalub. samas liigub, saab tõmmata seinast eemale oma 50cm ja viia seina vastu tagasi.
paigaldada ma arvan on paras tegemine nii liikumatu kui liikuva külge, ent ligipääs on tõesti palju lihtsam kui asi on natuke nihutatav
Kommentaarid: 275 loe/lisa |
9 :: |
226 |
Draqula
23.11.2022 14:41:15
Vanemate inimeste puhul olen kuulnud küll sellist reaktsiooni, kuid seda vaid esimesel päeval / esimestel vaatamise tundidel.
Üsna kiirelt harjutakse ja mõte liigub edasi "paar tolli veel poleks ka paha" suunas
Kommentaarid: 42 loe/lisa |
34 |
bpuhnja
24.11.2022 10:16:38
triu kirjutas: |
Kas nendel suurtel OLED telekatel üldse on mingit järelturgu? Kiirelt netis sobrades midagi eriti silma ei jäänud.
Või liigutatakse ainult kusagil tuttavatele või midagi sellist. Seda, et keegi pole enne neid müüa soovinud, hästi uskuda ei tahaks. |
Kogemuse järgi selline tehnika pärandatakse suuresti ära vanematele/lastele või lihtsalt pannakse magamistuppa.
Lotharius kirjutas: |
ELis vist võib unistama jäädagi, et mingi tagasikutsumine tuleks... |
Tagasikutsumist polegi vaja. Saadavad tehniku koju sulle ja vahetavad vigase jupi (antud juhul emaplaadi siis) välja lihtsalt.
Pole mingi Apple, et ühe jupi pärast kõik kellad.
Sarnane juhus on/oli mõne vanemate OLED teleritega, toiteplokki vahetus:
https://www.lg.com/ee/toetus/teadete-uksikasjad/EENTC20201028150787
Muidugi tasub lisada juurde siia oma anektoodiline kogemus, kus originaalne toide töötas laitmatult 4a, ning siis uus väljavahetatud toide läks suitsema 6 kuuga
Kommentaarid: 26 loe/lisa |
25 |
lkraav
25.11.2022 14:16:23
tsitaat: |
100% liikumatu külge on halb paigaldada ja kaablite vahetamiseks või isegi USB-pulga sisestamiseks võib tekkida vajadus telekas maha võtta. |
Panin ikkagi minimaalsusele rõhudes selle liikumatu Vogels TVM-5605 seina 3 poldiga ja täitsa kobe tuli. Vogelsil on mingi AR äpp, ja see isegi aitas natuke kaasa top/center drill hole leidmisel, aga tagapaneelile mount stripid külge ja mõõdulint kindlasti abiks.
Muidugi õige - TV taha kaableid mudima minna enam asja pole, ilge keberniit, nagu oodatud. Samas kõik pordid ilusti ühe külje peale toodud, nii et 2x aastas vbla saab hakkama.
tsitaat: |
Euronics igati viisakalt pricematchis ära HV hinnaliidrid täna mulle, tundub et saan varsti loomkatsetada ja muljeid jagada. |
Euronicsi pricematchi protsessist sai õpitud, et
* tuleb kiiresti maksta - ma otsisin veel wall mounti ja suhtlesin tarneaadressi teemal, tulemus oli see et ülejärgmisel päeval maksevalmis olla öeldi "võrdlevat pakkumist ei ole enam" ja hind tagasi üles
* klienditeenindajad ei tohi ise konkreetset võrdlevat pakkumist valida, nii et agregaadi lingi saatmine kõikide pakkujate hindadega "orientiiriks" ei toimi
Õnneks HV-s oli veel pakkumisi reas küllalt, kuigi loomulikult 21LA vs 22LB SKU probleemid sai läbi ronitud jne.
Nagu Rifleman Creed ütles: "There are many (77" OLEDs) like it, but this one is mine". Pildil kaob mastaap ära, see ekraan on ikka päris kolakas. Täpselt 3m vaatamiskaugus nüüd on täitsa OK.
129 |
Zonerman
25.11.2022 15:02:24
Vabanda, ma märkasin seda lillepotti kõlari peal. Tundub, et vist pole mingid kallid kõlarid aga heli entusiastide seas on see big no no
Mis telekasse puutub, siis pilt vb tõesti moonutab a la lai sein aga tundub ikka päris kaugel.
_________________ Sõim ja räuskamine läheb SIIA |
Kommentaarid: 66 loe/lisa |
65 |
terminator
Kommentaarid: 494 loe/lisa |
19 :: |
6 :: |
373 |
Zonerman
25.11.2022 16:10:36
Ma mõõtsin enda vaatamiskauguse ära. Täpselt 2.4m silmadest kaugus ekraanini ja 65" ja sellega pead ei pea keerama ning ka ekraan on terves ulatuses veel suht lähedal. Iga 10cm ja edasi kuni 3m mõõtsin, siis läheb väga kiirelt juba ekraan väiksemaks. Kui see on 77" ekraan pildil, siis pigem ütleks, et kaugus on pigem rohkem kui 3m. Ehk isegi 3.5m kui pilt ei peta.
65 |
Prillpapa
25.11.2022 16:10:55
laepaneelide järgi näha, et fotol see kalasilmaefekt, lainurk või sarnane pildi tegemisel olnud..
_________________ --- |
Kommentaarid: 20 loe/lisa |
20 |
Zonerman
25.11.2022 16:13:56
Ok siis fotolt ei saa hinnata.
65 |
