gemini
04.05.2004 19:41:05
FX6 seeria voolutarbimisest:
As theorized in our 6800 Ultra preview article, the system ran flawlessly with this setup. 3DMark 03, Call of Duty, and UT 2004 all ran with complete stability on a 350-watt power supply with GeForce 6800 Ultra. Clearly, NVIDIAs 480-watt PSU recommendation errs on the side of extreme caution, as a high quality sub-$50 350W PSU like the Enermax EG365P-VE can be used with no problems.
| Kommentaarid: 75 loe/lisa |
61 |
sant
04.05.2004 20:23:19
Tsitaat from FiringSguad:
NVIDIA felt 480 watts was a good cutoff point for both generic and high-grade power supply units, but there are a number of high quality power supplies that provide adequate power on the 12V rail that are in the 350-430 watt range.
Just avoid the generic brands, and as we mentioned in Alan’s power supply guide, always check the figures on the 12V rail.
Mida nad selle generic brandi all mõtlevad? Kas see tähendab odavaid firmasid?
_________________ So, at the end of the day, after I have butchered all the nvidiots all around me, standing alone in a pool of blood surrounded by the corpses of my victims, a horrible truth reveals itself to me: I am an amd\ati fänboy...and I must do my dark masters bidding, for I am damned for all eternity... |
| Kommentaarid: 67 loe/lisa |
60 |
High-Q
04.05.2004 20:27:02
| generic on jah need el cheapo või miskid noname variandid
97 |
04.05.2004 22:09:25
| AMD puhul pole väga hull asi see 12V nõrkus... endal on koormatud kusagil 2-3Amprit, samas P4 puhul langeb enamus koormusest just 12V peale... nii et idee poolest võivad need nn "noname" brandid ka ilusti ära toita.
201 |
Scart
05.05.2004 10:07:35
naised saunas rääkisid 6800 variandist, millel vesijahutus by default ja kellad nii 550/1300- 1400
101 |
erick
05.05.2004 14:38:10
Naised saunas ehk tõesti rääkisid sellest, aga fakt on, et naised saunas ei saa seda kunagi oma masinates nägema
Ega ka ükskõik millist muud kaarti 6800 seeriast, for that matter
Millest on tõesti kahju, sest hea meelega oleks 6800 GT-d suures volüümis näinud. Kaart on ju võimekas iseenesest, ja pealekauba oleks säärase kaardi hulgitootmine algatanud ilusa pisikese hinnasõja... mis nüüd jääb kahjuks olemata, ja ATI saab oma kaartide eest küsida mis hinda ise tahab
96 |
05.05.2004 15:09:53
jah nii see kahjuks on
201 |
Zajats
05.05.2004 16:45:08
| Ahh, ei ole see kogus nii väike midagi. Pigem püütakse kuumaks ajada et siis kõik rabaksid. Firma on ju ameeriklased, need teevad sellist nalja. Ati omad on canadalased, vähe tagasihoidlikumad. Tasa sõuad kaugele jõuad. Kaks-kolm aastat tagasi oleks naerdud selle peale et Ati kõige kõvem tegija graafika vallas on...
| Kommentaarid: 16 loe/lisa |
15 |
tomz
| Kommentaarid: 68 loe/lisa |
hmagi
05.05.2004 23:18:48
| not again
| Kommentaarid: 24 loe/lisa |
23 |
High-Q
05.05.2004 23:38:12
tomz, su postitus võinuks ka olemata olla.. paistab et sina hoopis fanATIc. tõsiselt, pistnuks sa selle posti parem x800 teemasse, sinna see sobib way paremini. mine arene. Ime et sa veel ei kirjtuanud "ati rulz forever, nv sux", see oli sinu postitusel tõsiselt puudu. Tee endale "Powered By Ati" tattoo kah kuskile, siis on täislaks.
Mõlemal, nii Atil kui NV-l kasutati BETA draivereid, mis enamikes mängudes annab küll tõetruu pildi, kuid võis teatud mängudes ka bugisid ette tuua. Jah, näiteks uuemal 61.xx draiveril oli mingis mängus trilinear filteringu probleem, et see sisse ei lülitunud ja seepärast kasutasid osad saidid vanemaid 60.xx draivereid, mis aga NV ja xbit poiste sõnade järgi on kohati ca 5-10% aeglasemad kui uued 61.xx-d
me siin spekuleerime, kas ja millal võiks eestis uusi NV kaarte näha, mis toide oleks piisav jne, ei nuta ega hala.
Miks mina valisin NV: oli mul valida, kas R9700 Pro (sapphire kaart) või 5900XT PNY oma. Defaultis on too 9700 kiirem, hands down. Aga juhuslikult Ati samsungi 2,8ns mälud suutsid vaid alla 680mhz välja anda ja ega coregi üle 360-ne ei elanud (default 325/620). Mina aga oma 5900XT 2,8ns hynixi mäludega suutsin 900mhz välja pigistada (ja piiri pole veel kätte saanud). Ja kiirustega 460/900 (kuigi 24/7 kasutan igaks juhuks 430/840, kuid seegi on sivam) on 5900xt ikka julgelt sivam, kui 9700pro. Lisaks need igivanad tarkvaraprobleemid catalystidega, võibolla mul lihtsalt ei vea Ati kaartidega.
ahjaa, tomz, ära nüüd tule ütlema, et on alati teinud optimiseerimata ja täitsa ausaid draivereid. Kõik teevad optimiseeringuid.
Hell, imelik, et kui source-code kompileerimises loetakse optimiseerimist AINULT heaks, et saaks kiiremini koodi kätte saada, siis mängus arvatakse, et see on väga paha.
Kui tahad kõrgeid benche, siis pole ime, et MIPMAP level aetakse madalaimaks, kõik high perfomance, kõikvõimalikud jurad lülitatakse välja. Sama hea, kui kasutaja teeb seda manuaalselt 3rd party tweakidega (et petta ära, et tegelt kasutab õigeid draivereid), võiks seda juba nende benchide jaoks ka draiver ise teha. 3dmark on paras ussipesa, kõige hullem cheatimine käibki seal ja seda mitte kaartide tootjate ega draiverite kirjutajate, vaid seda tahtlikult tegevate kasutajate poolt.
Mina pean kõige adekvaatsemaks ja targemateks testijateks Xbitlabsi (ehk siis ixbt.com) kutte (tõsiselt asjalikud vene tüübid), kui nemad midagi valesti ei leidnud, siis võib ka nende juttu uskuda ja kõik on ok.
97 |
tomz
06.05.2004 00:07:47
| milleks selline närvilisus. mulle ei meeldi lihtsalt nvidia värk, suure hurraaga ja pärast pole muhvigi (fx seeria) ja siis veel see chiitimine (mis oli fx seeriaga). geforce4 oli hea ja parem kui ati r8500, kas siis ati chiitis?
High-Q
06.05.2004 00:28:38
| gf4 võitis 8500-t sellepärast, et oli sootuks teise põlvkonna kaart, ei maksa unustada. 8500 oli siiski mõeldud gf3 killeriks (mida ta ka põmst oli). sama hea, mis tegi r9500/r9700 gf4 seeriaga. Sinu toodud kaarte ei anna võrrelda.
97 |
HDTanel
Overclocker
06.05.2004 00:33:40
| High-Q kirjutas: |
Mina pean kõige adekvaatsemaks ja targemateks testijateks Xbitlabsi (ehk siis ixbt.com) kutte (tõsiselt asjalikud vene tüübid), kui nemad midagi valesti ei leidnud, siis võib ka nende juttu uskuda ja kõik on ok. |
irw `MHz suht igal kaardil erinevad ja nende järgi küll ma kaarti ei ostaks sinu loogika järgi peab siis 9600PRO olema veidi aeglasem kui 9800XT
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
High-Q
06.05.2004 00:40:47
ma ikka mõtlesin nende kahe kaartide vahel, mis mõlemad oleks 256bit mälu ja 8 pixel pipeline'ga, õigemini mida võiks arvata samal "tasemel". selge see et 9600 sinna ei kuulu. No ma vähemalt ei ole nii peetikukkunud, et oma videokaardiga magaks.
platoon, sa koli x800 teemasse, koht!
viimati muutis High-Q 06.05.2004 00:43:57, muudetud 1 kord |
97 |
HDTanel
Overclocker
06.05.2004 00:43:15
5900XT 9700PROst kohe kuidagi kiirem pole ju nii defaultis kui OC-tult... või tahad öelda et tegid 3dmarkis üle 20100p?
edit: Miks ma sinna tagasi minema pean? ega ma ei poolda ei ATI-t ega Nvidiat hetkel
496 |
High-Q
06.05.2004 00:54:03
mina ei teind, mu CPU ei lähe enam kui 2135mhz minu neetud wr4 jahutusega. Kinnine barton, lisa ainult volte, aga 1,85 peal teeb shut-downi suht kiiresti.
ja 2001 on niikuinii praeguste high-end kaartide juures rohkem CPU/FSB dependent. Kui ma saaks kah 235FSB-d kuidagi kätte, siis võistleks sinuga hea meelega, praeguse näruse 190-ga pole eriti midagi teha. Kui ma vahetaks oma bartoni juustu näiteks miski vingema a64 vastu, siis 5000 punni oleks laksust juures, masin niivõrd pidurdab maha, praegu närused 16.5K. Isegi tõestus: FSB185-t tõstmine 192-le andis pea 500 punni juurde, samas kui 450/850 clock 425/820 asemel sama fsb-ga miski närused 70 punni.
näiteks 2003-s, mis rohkem praegustes oludes videokaardist rohkem sõltuv, sain ma üle 6000 punni (vist miski 6010 kanti, napilt igatahes üle 6k), kuigi masin sinust märksa lahjem ja arvestades, et mina kasutasin kõige uuemaid nv draivereid (mitte neid 44.xx omasid), sinul aga need pole isegi futuremark approved mitte.
tra, fururemark leht nii pidur
97 |
HDTanel
Overclocker
06.05.2004 01:21:07
ma peaks tegema ka 4.4 catakatega... see annab ju kiirust juurde just 2003-s nii, et see 6145 pole üldse rekord mul... mingi 6300saaks ära. 9700radeoniga siis. Ok aitab OT nüüd... kui soovid saada priva.
496 |
Le Inc
06.05.2004 08:15:00
| 3DMarkxxxx on üsna mõttetu programmike millega graafikakaartide võimu kontrollida. Loevad ikkagi "päris" mängud. Eks nii ATI kui nVidia töötavad selle nimel et viimanegi piisk 3DMark'ist välja pigistada. Aga jah, kahju on sellest 6800 GT, mis paistab, et klokkub väga hästi (pea Ultra tasemele) ning läheks kindlasti kaubaks (a la 5900XT).
| Kommentaarid: 56 loe/lisa |
54 |
One
06.05.2004 09:02:40
High-Q ära sa siin hüple miskit ja väida, et nvidia fx kiirem on... tuleb mängu jälle see asi, et võtame
näiteks väga hea pela nagu Call of Duty nVIDIA 5900 EPV kaart, millele ma 5950 ULTRA biosi
peale lasin vedas seda mängu tegelikult sedasi, et ei saanud üldse
mängida ja niimoodi multiplayeri mängus, resoks 1024 x 768 ja setingud mediumi peal
väike stiilinäide siis selgitamaks:
Nvidia max fps oli oma 100 laksu suurem kui praeguse ATI r9800PRO oma, aga näiteks põõsastes
tõmbas ta samal setingul 2x aeglasemaks kui Ati kaardil (Nvidia kaardil siis <60 ja Atil tublilt >120 fps)
ja kujuta ette, missugune hakkimine toimub, kui veel sõda käima hakkab. Fps kukub lagedal platsil 400
ringist 30 (atil 100 kanti) peale ja kui järgmine hetk uuesti 400 peale lajatab on vahepeal selline
quantum leap tehtud, et jube. Nvidia tehnika FX'i puhul oligi see, et nad oskasid ära kasutada benchide
suurimat viga, nimelt selle arvestamist, et kellel on suurem keskmine fps, tegelikkuses on kiirem kaart
siiski see, millel low fps on kõrgem. Lisaks veel 3d mark 2001se'st, ära sa ennast mitte mõtlegi sellega
julgustada, et sa 20k kätte saad selle fx'iga esiteks nõudis 20k ületamine 2.8ghzist amd proset ja
kellasi corele üle 500 ja memile kah 1000 ja hetke seisuga olen mina hetkel ainuke 20k ületaja GF FX'iga
meie kallil maarjamaal (mul ei ole selle üle hea meel )
kui teinekord aktsiooni satud, siis kiida ikkagi uut nvidia kaarti, mitte ära räägi laus lollust, sest fx seeria
on minu silmis oma 2x aeglasem kui radeon r3xx corega kaardid , sest otsustavatel hetkedel on fps 2x
väiksem ja see on fakt, mitte miski fanATIcu seisukoht
Ahjaa, 6800 Ultrast ära küll ei ütleks 8)
728 |
06.05.2004 09:19:59
jah kõik see väga õige... pelasin sõbra arvuti peal FX 5700-ga ja see fps'i mitmekordne kukkumine häiris tõsiselt
201 |
High-Q
06.05.2004 09:52:59
mina sain sellised slow-downid suurest klokkimisest, täitsa ausalt. Default või siis sutsukene kõrgemal nominaalist polnud selliseid asju küll märgata. Fraps töötas.
Mängisin näiteks kokku ca 8h Manhunti (1024x768, max, 4xAA, 8xAF), sama lugu oli näiteks isegi farcry'ga (1024x768 very high, ilma aa/af-ita). FPS küll kõikus, aga mõistlikes piirides.
2001-s sul kõige rohkem loeb masin, mitte enam videokaart. 20K pole korralike kaartidega (9700, 9800, 5900 või sinna kanti) mingi mure kätte saada, kui omad tõsiselt kiiret masinat. >3,5Ghz P4-ga pole selline saavutus MITTE mingi probleem, isegi suurt tviikimist ei vaja. 3dmark2001 on praegu juba suht obsolete bench videokaardite perfomance arvutamiseks. Sellest ei viitsi enam eriti rääkidagi.
97 |
Zonerman
06.05.2004 10:44:27
Äkki jääks ikka teemasse? Ja see nvidia cheat värk on juba ära tüüdanud - aitab ok? Pole veel official draivereidki. Ja need futuremark lingid on bullshit, ATI mehed üritavad iga hinna eest jälle nvidiat materdada, kuigi FM aproved 60.72 drivers...
_________________ Sõim ja räuskamine läheb SIIA |
67 |
Le Inc
06.05.2004 11:36:05
| High-Q kirjutas: |
Jep, sama prose (siin on lahjem ) aga Far Cry 1024x768, high detail, 4xAA, 4xAF ja madalaim fps 30 kandis. Niipalju on R9700 parem. 2x täitsa mõsitlik pakkumine!
54 |
Elof
06.05.2004 13:16:31
High-Q, kui sa tähele ei pannud oli tomz'i antud lingil tehtud teste nii, et oli vaid "farcry.exe" nimetatud "fartcry.exe"'ks ... vaevalt, et siin loeb kas draiverid on beetastaadiumis.
Faili ümbernimetamine ei tohiks muuta jõudlust !
175 |
Scart
06.05.2004 13:41:37
link :: loe siit
päris hea graafik 8)
minu ainuke kysimus oleks, kas seal on vastamisi 6800ultra + 800tx või 6800ultra + 800pe .... 800tx skoore oli yleeile netis ikka väga vähe
viimati muutis Scart 06.05.2004 15:07:51, muudetud 1 kord |
101 |
gemini
06.05.2004 14:59:28
29:35 Nvidia kahjuks
61 |
Subu
06.05.2004 16:31:22
| gemini kirjutas: |
29:35 Nvidia kahjuks  |
Pole häda, need tulemused olid non overclocked ultraga.
| Kommentaarid: 60 loe/lisa |
56 |
06.05.2004 16:43:29
| Subu kirjutas: |
| gemini kirjutas: |
Pole häda, need tulemused olid non overclocked ultraga. |
sama ju atide kohta
201 |
Subu
06.05.2004 16:52:02
| Magic kirjutas: |
| Subu kirjutas: |
sama ju atide kohta  |
Nvidial olid kaardid juba testijatele laiali jaotatud kui nad ütlesid et ATI kellade tõstmise peale oma kaartidel ka default clokke nac nihutavad
Aga vahet pole, tähtsam on hoopis mis hinnaga ja milline kaart eesti turule tekib
56 |
06.05.2004 19:28:18
jah hind tähtis
201 |
razor
120 |
Plin500
HV piljardihai
| Kommentaarid: 79 loe/lisa |
77 |
MatrixMan
07.05.2004 00:45:07
Kahtlaselt vastuollu on need kaks viimast artiklit sattunud
| Kommentaarid: 35 loe/lisa |
sant
07.05.2004 04:23:50
Ei ütleks et vastuolus,ma vaatasin,et neil on erinevad konfid ja erinevad driveri versioonid-kuigi vahed on küll kahtlaselt suured.
60 |
razor
07.05.2004 14:03:05
see xbiti oma on 400mhz corega 6800l tehtud pealegi, tasub alati lugeda commenteid
4. This is the most bias review ever. It's simply anti-nvidia bullshit.
Whenever Nvidia wins by around 10fps you claim that it's a tie between the 2 cards but when they come within 3fps of each other you claim that the "RADEON X800 XT manages to strongly outperform the rivaling NVIDIA GeForce 6800 Ultra. "
This is simply bullshit as the 2 cards are within 3fps of each other.
5. I'm going to kind of nod @ comment #4...
ATI is using 24 bit color downcoloring 32bit mode. Coming from the users who do digital photography on the side, that's not a limitation I'd think is acceptable anymore.
And the BIG thing is, back when you were touting the 9700/9800, you claimed that PS 2.0 was great because you were ready for the next big thing. Now PS 3.0 is in hardware, it makes programmers lives easier with even bigger effects and "ATI works just great with games you can play right now"?
This article is unusual for Xbit, and it is an article of convenience, catering to the ATI side of the fence while highlighting none of the sacrifices you have to accept in going to that side of the fence.
I like both, and I happily applaud good performance numbers, but at least highlight the serious compromises that ATI made to make these performance figures happen. I think your readers ought to be aware that ATI is banking on selling you a $500 card now and then another $500 card in a year to make up for all the things the NV card can do right now.
Its a poor financial choice and you are hiding that fact behind performance numbers, imo. That is NOT a service to your readers.
120 |
erick
08.05.2004 11:15:50
Ma ei viitsi ise seda xbitlabsi reviewd läbi lugema hakata, aga mõned mõtted selle eelpoolmainitud asja kohta.
Esiteks, mõnes testis võib 3 fpsi olla tunduvalt suurem vahe kui 10 fpsi mõnes teises. Ma ei tea kindlalt, kas ka seekord juhtus nii, aga põhimõtteliselt on 3 fpsine vahe mõnes väga keerulises testis, kus keskmine fps on näiteks 30, väärt 10%. Kui sinna vaadata kõrvale näiteks Q3-e teste, kus freimreit on 400, ja vahe kahe kaardi vahel on näiteks 20 fpsi, siis protsentuaalselt on tegu siiski 5% vahega. Põmst loetaksegi 10% vahet juba märkimisväärseks, iseasi, kas see lubab väita, et üks kaart 'strongly overperformed the other'.
Mis puudutab PS 2.0 vs PS3.0 probleemi... Esiteks, PS 2.0 oli tõeline HÜPE võrreldes PS 1.1-ga näiteks. nVidia enda marketingiosakond kandis selle eest hoolt, et kõik teaksid kui suur see vahe on, avaldades mõned teatud pildid. Nad võisid küll enda väitel kasutada PS 3.0-i, aga põhimõtteliselt ei tohiks PS 2.0 ja 3.0-i vahel suurt graafilist erinevust veel olla. Selge see, et mängude jooksutamise kiiruse koha pealt PS 3.0 ilmselt tõestab oma väärtust, aga puhtalt graafika arengu seisukohalt pole see suurem asi hüpe. Ja see on õige, mida xbitlabs kirjutas - ATI töötabki väga hästi mängudega, mis on hetkel olemas või kohe-kohe välja tulemas. Tegelikult arvan, et PS 3.0 nägemisega tõelises A-klassi tiitlis, kuhu ta on sisse progetud kõiki selle võimalusi ära kasutades, läheb veel aastake aega ehk. Nii et pole põhjust paanikat tekitada. Võib vabalt juhtuda, muide, et selle aja peale, kui PS 3.0 tiitlid juba tavalised on, ei ole 6800 seeria enam võimeline muude parameetrite nõrkuse tõttu neid mänge isegi full detailis jooksutama. Kui see on nii, siis mis kasu on 6800 kaardi ostmisest futureproofingu eesmärgil?? Mängid kahe-kolme aasta pärast uusi mänge 640x480 resol, tekstuurid allakeeratud, aga PS 3.0 uhkelt peal???
Nojah, see on minu subjektiivne arvamus, nii et ärge südamesse võtke
96 |
razor
08.05.2004 12:34:27
erick, mängud ei arene nüüd nii kohutavalt kiiresti, et kaardid aeguksid "kahe kolme aastaga". mina mängin siiamaani halot ja Wtar Wars : KoTOR'i GTSi peal, kotori veel 1280 resoga ja detailid põhjas. ja jookseb täitsa sujuvalt... ja TI4200 on kah juba imo pea 2 aastat vana kaart, kuid siiamaani võimeline jooksutama uusi mänge. pigem on GF6800 plussiks ati ees see, et kui mõlemad jooksutavad veel aasta-kahe pärast mänge, siis GF6800 jooksutab neid paremini ja kenama graafikaga
120 |
Auron
08.05.2004 12:35:53
| erick kirjutas: |
| Ja see on õige, mida xbitlabs kirjutas - ATI töötabki väga hästi mängudega, mis on hetkel olemas või kohe-kohe välja tulemas. Tegelikult arvan, et PS 3.0 nägemisega tõelises A-klassi tiitlis, kuhu ta on sisse progetud kõiki selle võimalusi ära kasutades, läheb veel aastake aega ehk. Nii et pole põhjust paanikat tekitada. Võib vabalt juhtuda, muide, et selle aja peale, kui PS 3.0 tiitlid juba tavalised on, ei ole 6800 seeria enam võimeline muude parameetrite nõrkuse tõttu neid mänge isegi full detailis jooksutama. Kui see on nii, siis mis kasu on 6800 kaardi ostmisest futureproofingu eesmärgil?? Mängid kahe-kolme aasta pärast uusi mänge 640x480 resol, tekstuurid allakeeratud, aga PS 3.0 uhkelt peal??? |
Nujah aga praeguste väljas olevate ja kohe kohe tulevate mängudega töötavad ka eelmised high end kaardid hästi.Milleks osta sigakallis kaart, kui teda pole otseselt vaja praeguste mängude jaoks ja tal pole mõtet PS3.0 kasutavate tuleviku mängude jaoks?Ehk ainult selleks,et kuskil kekata oma freimratega või 3Dmark skooriga.Seda millal PS3.0 tavaliseks muutub tegelt ju ei tea.Võib juhtuda ,et hommepäev avastab miski tegelane kuda seda palju etemini ära kasutada, kui siiani teati ja siis võtab see väga kiirelt tuult tiibadesse.Samas võib tõesti tükk maad aega minna aga kardan ,et ikkagi mitte piisavalt ,et sellepärast praegu miski 10 tonni magama panna.Siis nVidial hea tituleerida,et best performance ja looks ainult nende kaartidega.Seda nüüd hästi ei usu ,et aastakese või nii pärast miski 6800UE peal mängud enam ei jookse parema reso kui 640x480.See tähendaks seda ,et sellised kaardid nagu 9800pro ja 5900U ei jooksuta selliseid asju enam üldse või siis kõige juustumate detailidega.Ehk siis ärge samuti keegi sellest postist tuld võtke .Lihtsalt enda seisukoht kui mitte miljonäril on see,et parem ootan ära mis sel ajal toimub kui R500 välja tuleb.Pole ju seda probleemi,et praegu miski asi ilusana mängimatta jääks.
133 |
08.05.2004 13:23:04
pole tegelikult midagi suurt arutada. nagu eelminte seeriatega, kipub ka seekord nvidia lööma featuuride ja ati puhtalt jõuga. mõlemal probleemid siis oma 'paremuse' tõestamisega.
pigem vaadake techjuttu ja ati kõva tekstuurimisosa, mis anisotroopiat rõõmsaˇlt kiiresti teha suudab ja nvidia z-value vms mis seal oli osa, mis varjude jms juures väga abiks on. ehk siis hl2 vs d3 kui nii tahta võrrelda
üldiselt olen minga totaalne nvidioot. aga hetkel ausalt öeldes tunduvad juba pikemat aega mõlema tegija gpud üüüüsna võrdsed olevat.
_________________ - londiste
217 |
Aser
08.05.2004 22:26:00
| Kas see RAdeoni kaart mis välja tuleb (ilma PS3-ta) on samuti "fully programmable" nagu nvidia oma millel on PS3 olemas
Le Inc
10.05.2004 08:39:52
link :: NV40/R420 Face-Off
Firingsquad.com kaks EIC's (Editor-in-Chiefs) vaidlevad kumb chip' on parem - kas NV40/R420.
Tegemist on mõnusa väitlusega ja huvitava lugemisega. Soovitan.
54 |
DigeBeni
10.05.2004 09:11:25
... kui mina PS 3-2 vahest rääkisin, siis pidasin silmas vaid seda, mida see vahe minu, kui tarbija jaoks tähendab. Esmalt, oleks hüpe 9700Pro'lt emba kumba kiibitootja kaardile juba niigi suur, et mingi PS versiooni pärast, mis võib vaid marginaalse kiiruselisa anda, ma nutma ei hakkaks. Liiatigi on siiamaani ATI kiip suutnud oma PS2 toega ka PS3 testides piisavalt hästi hakkama saada, et ma ei näe enda jaoks küll PS3 toes piisavat müügiargumenti. Mina tahan vaid mänge mängida ja saada sealt kõik, mida saada on ja 5% kiiruselisa ei paku veel midagi sellist, millest puudust tunneks, sest robustset jõudlust on mõlema kiibitootja kaartidel praeguste ja teadaolevate tulevaste mängude jaoks niigi piisavalt. Liiga kaugele pole mõtet kah mõelda, kuna tehnika reaalne areng on mõneti niivõrd ettearvamatu, et nagu erick ka üldjoones mainis - hommepäev võib tulla mõni otsustav pööre, kuid samas, seda ei pruugi tulla ka veel aasta/paari pärast. Mina valin selle, mis saab olema reaalselt saadaval ja mille hinnas on kõige vähem õhku, nii lihtne see ongi ...
163 |
stepzter
10.05.2004 11:48:15
Kuna ATI ei toeta PS3'e ja praegu on kasutusel sigapalju kaarte, mis on PS2 toega, siis ei ole niipea oodata, et ükski mäng arhitekteeritakse PS3'le orienteeritult. Kuna PS3 sisuliselt midagi paremat ei saa teha, kui PS2'ga, siis ilma PS3 toeta kaardiga ei jää ilmselt eriti millestki ilma.
Küll aga üks asi, mida ma ei pannudki alguses tähele ja mis mulle NV40 juures sigameeldis. NV40 toetab floatingpoint tekstuuridest bilineaarse filtriga sämplimist ja floating point rendertargetisse blendimist. Need on asjad, mis on ATI R420'l ja eelmisel põlvkonnal (NV30/R300) puudu. Samas ilma nendeta ei ole floating point renderdamisest üldse väga palju kasu. See küll ei ole põhjus mängurile ATI kaart ostmata jätta, sest kui pooled uutest kaartidest seda ei toeta, siis seda ka ei kasutata. Aga arengule paneb see küll paraja põntsu. Blendimine juurde panna oleks suhteliselt odav, 4*4 = 16 32bitist ujukoma summaatorit, mis on võrreldes pixelsahderis ja vertexshaderis olevate 16*4*2 + 6*5 = 158'ga võrreldes suhteliselt köömes. Ujukoma filterdamine on arvatavasti põhjus, miks ATI suudab teha 2*4 floating point op'i + tekstuuri, NVidia aga 2*4 või 1*4 + tekstuur. Filterdamiseks on vaja 4 multiplikaatorit ja 3 summaatorit. ATIl on need fikskoma, NVidia kasutab pixelshaderi ujukoma omasid.
| Kommentaarid: 26 loe/lisa |
26 |
DigeBeni
10.05.2004 15:22:20
| stepzter kirjutas: |
Küll aga üks asi, mida ma ei pannudki alguses tähele ja mis mulle NV40 juures sigameeldis. NV40 toetab floatingpoint tekstuuridest bilineaarse filtriga sämplimist ja floating point rendertargetisse blendimist. Need on asjad, mis on ATI R420'l ja eelmisel põlvkonnal (NV30/R300) puudu. Samas ilma nendeta ei ole floating point renderdamisest üldse väga palju kasu. See küll ei ole põhjus mängurile ATI kaart ostmata jätta, sest kui pooled uutest kaartidest seda ei toeta, siis seda ka ei kasutata. Aga arengule paneb see küll paraja põntsu. Blendimine juurde panna oleks suhteliselt odav, 4*4 = 16 32bitist ujukoma summaatorit, mis on võrreldes pixelsahderis ja vertexshaderis olevate 16*4*2 + 6*5 = 158'ga võrreldes suhteliselt köömes. Ujukoma filterdamine on arvatavasti põhjus, miks ATI suudab teha 2*4 floating point op'i + tekstuuri, NVidia aga 2*4 või 1*4 + tekstuur. Filterdamiseks on vaja 4 multiplikaatorit ja 3 summaatorit. ATIl on need fikskoma, NVidia kasutab pixelshaderi ujukoma omasid. |
... kahjuks ei oska tavaline inimene, kelleks ka mina ennast pean, sellise tarkusega midagi peale hakata. Samas, omadest kogemustest, niipaljukest kui mul neid on, ütleks, et tihtilugu polegi piduriks kaugeltki ilmselged puudujäägid tehnoloogias, vaid olemasoleva korralikult funktsioneerima saamine. Antud hetkel tundub mulle, et nVidia püüab iga hinna eest funktsionaalsuses esirinnas olla arvestamata, kas neist "über" lisadest, kiibi tegelikule tarbijale, ka reaalset kasu on. IMHO oleks kiibitootjatel mõistlik lasta graafikaprogejate tarvis välja eraldi prototüüpe (mingil kujul seda tehaksegi, kuid mitte päris selle loogika alusel, mida mina silmas pean), mille peal siis igat sorti katseid saaks teha, ning hiljem alles rahvale mõistlik tükk rauda kokku klopsida, et me ei peaks pidevalt maksma funktsioonide eest, mis on mõeldud vaid suht kitsale ringile ...
163 |
reso
10.05.2004 15:28:33
ja nende suht kitsale ringile mõeldud funktsioonidega nad püüavad lihtinimesi ostma meelitada(pole ju vaja seda funkt.-i mingil momendil või siis ei vääri oma hinda). tavaliselt inimesed ei osta näiteks graafikakaardi sellepärast, et tal ps3 on ja tulevikus lähevad mängud sellele üle, vaid ostetakse siis kui juba häda käes.
täitsa õige jutt DiqeBeni poolt
Auron
10.05.2004 15:44:23
Mnjah ühesõnaga nagu ma DigeBeni jutust aru saan ,siis see PS3.0 on sama mis 2.0 ainult selle eelisega ,et seda kasutades on jõudlus kuskil 5% suurem aga mingit visuaalset vahet pole(pean silmas midagi sellelaadset kus näiteks DX8.1 kaardiga ei ole mängudes selliseid efekte nagu DX 9 kaardiga mis seda toetab) Ei tahaks ju sellisesse olukorda sattuda nagu eelmine aasta umbes samal ajal mil oleks äärepealt võtnud Radeon 9700 asemel GeForce 4 Ti
133 |
DigeBeni
10.05.2004 15:56:40
stepzter, võib teid üksikasjades valgustada, kuid DX9 ja 8 vahega võrrelda PS3 ja 2 on vist ikka kohatu ...
163 |
razor
10.05.2004 15:58:57
nagu keegi juba eespool välja tõi, on PS3 jaoks effektide kirjutamine progejatele kergem. seega, kuna Nvidia kaart on ainuke mis seda hetkel toetab, siis kasutatakse testimisel just nimelt nvidia kaarte. seega ka kerge optimiseerimine nvidiale
120 |
stepzter
10.05.2004 19:02:34
PS3 lisafunktsionaalsus iseenesest ei olegi niiväga pisikene samm PS2'st edasi. Aga selle lisafunktsionaalsusega millegi eriti effektse tegemiseks peab mängu miinimum spec olema PS3. Sellega läheb aga vähemalt paar-kolm aastat aega. Praegu saab seda siin seal ära kasutada, et võibolla natukene kiiremaks teha. Kuna mängud on niikuinii niimoodi tehtud, et nad ilma PS3'ta adekvaatse kiirusega töötaks, siis see vahe ei saa eriti suur olla.
| reso kirjutas: |
Ja mängud ei lähe sellele enne üle kui see piisavalt paljudel inimestel on. Muna-kana probleem. Praeguseni ei tehta pixel-shaderile orienteeritud mänge, kuna GF MX kasutajaid on nii palju. Seega minult poolt tehnoloogilisele arengule.
26 |
