firemark
13.11.2016 12:22:16
| Tänu sellele HDRile mis peab olema spets versioon ja PS4Prole läks teleka valimine palju keerulisemaks.
92 |
sulomile
13.11.2016 13:31:49
"LG ole UHD. Neil iga kümnes pixel lihtsalt valget värvi, selline jokk variant."
Nii selgitas asja üks Samsungiga seotud sugulane- insener. Tema palk ei sõltu müükidest, nii et pole põhjust kahelda
_________________ Oleks mina näinud, kuis sind tehti, oleks öelnud: ärge tehke. |
13.11.2016 13:36:46
on küll põhjust kahelda.
kui ei ole jama jutt, siis on sellest seletusest midagi olulist kaduma läinud.
_________________ - londiste
215 |
anubis
| Kommentaarid: 336 loe/lisa |
283 |
13.11.2016 14:24:55
anubise lingilt:
White Sub-pixels
Every pixel on the LG OLED TV also has a 4th independent pure White sub-pixel in addition to the standard Red, Green and Blue sub-pixels found on other displays – that’s an extra 2.1 million sub-pixels, bringing the total up to 8.3 million. In principle, they aren’t necessary because White can be produced by the other sub-pixels, but White sub-pixels provide a number of key advantages: they improve color management that allows the Color Gamut to be easily adjusted, they improve the color balance of the White Point, particularly for the crucial Color Tracking accuracy of the gray scale, and they significantly improve the power efficiency of the display because a single sub-pixel is needed to make the underlying gray component of every pixel instead of powering three Red, Green and Blue sub-pixels to do the same job. Other displays also have White sub-pixels, but they are always used to boost brightness at the expense of color saturation and accuracy – LG is the first manufacturer I am aware of to use White sub-pixels to improve color accuracy rather than decrease it… |
215 |
13.11.2016 14:57:59
Sama ka Sharp'i telerites RGBY paneelides, ehk siis piksleid pole mitte vähem, vaid rohkem.
128 |
anubis
13.11.2016 15:06:43
| Piksleid ikka sama palju, subpiksleid per piksel lihtsalt üks rohkem.
283 |
13.11.2016 15:09:35
jägaja, täpsustuseks - subpiksleid.
teleka üks piksel koosneb väiksematest osadest, traditsiooniliselt rgb, ehk punane, roheline ja sinine.
läbi lcd (ja nüüd oled) ekraanide ajaloo on mängitud nende komponentide suuruse ja asetusega, optimeerimaks mingi kindla asja peale. kvaliteet, vastupidavus, loetavus jms.
sharpi rgby tähendab siis, et lisaks traditsioonilisele kolmele on seal ka kollane komponent.
too lg oledi wrgb (ja nagu lingil räägitud, siis ka mitmed lcd-d) on saanud lisaks valge komponendi. sama lisandi eesmärk on seejuures olnud erinev. sellega on välditud valge valguse läbi filtrite minemist.
lg oledi puhul paistab eesmärgiks olema puhas valge, lcd-de puhul ereduse lisamine (kuna filtri läbimine tahes-tahtmata võtab heledust maha).
215 |
firemark
13.11.2016 15:28:09
| kas see on õige fakt mida kuulsin,et kas teleka pilt näiteks Telia teenust kasutades on palju kehvem suurel 4K telkal võrreldes odava väikse resoga telekal? Kuna see upscale pidi muutma pildi väga kuubikuliseks.
92 |
13.11.2016 15:29:29
ei.
see sõltub pigem ekraani suurusest kui resost/upscalest.
nii halva upscaleriga telekat sa ilmselt täna enam poest ei leia, mis sellist jama upscale tõttu tekitaks.
215 |
sooty
13.11.2016 15:29:36
| Sõltub telekast. Kallimatel on säästukatest oluliselt parem upscale.
| Kommentaarid: 12 loe/lisa |
12 |
anubis
13.11.2016 15:44:36
| S*tt läbi suurendusklaasi paistab suurem/koledam . Suuremal paneelil paistavad signaali vead paremini välja.
283 |
firemark
13.11.2016 15:50:14
| keegi võiks hea foto teha 4K teleka pildist kasutades Telia televisiooniteenust näiteks mingit eesti kanalit vaadates
92 |
13.11.2016 15:51:17
| firemark kirjutas: |
| keegi võiks hea foto teha 4K teleka pildist kasutades Telia televisiooniteenust näiteks mingit eesti kanalit vaadates |
Milleks?
firemark
13.11.2016 15:56:16
| tahaks lihtsalt näha kuidas välja näeb pilt suurelt ja uhkelt 4K telekast, kuna kasutan Teliat ja plaanin telekat vahetama hakata. Aga ilmselt on Telia esinduses ka pilti võimalik näha nendest telekatest mis seinte peal on.
92 |
von Wu
13.11.2016 16:00:26
Foto tuleb alati kehvem. Video on parem. Kõige parem on ikkagi oma silmaga vaadata.
_________________ Osta auto ära
Müüa naastrehvid |
| Kommentaarid: 890 loe/lisa |
669 |
13.11.2016 16:08:01
Telia on viimane asi mille pärast telekat vahetada
anubis
13.11.2016 16:09:01
Mul on kõik pildiparandused välja lülitatud, ehk et ETV HD on normaalne, SD üsna udune.
Teen hiljem video.
283 |
firemark
13.11.2016 16:13:09
| Need pildiparandused sisse lülitades muudavad pildi veel hullemaks?
92 |
sooty
13.11.2016 16:29:11
Mul on pildiparandused ainult filmide sisendil välja lükatud. Teevad ilusa pildi udusemaks või liiga teravaks.
Telial aitavad kindlasti.
12 |
RandomHero
14.11.2016 10:49:42
4K telekaga eesti telekanaleid vaadata on sama tunne, mis mul oli esimeste -4,5 ujumisprillidega basseini minnes - ma olin õnnelikum, kui ma vähem asju nägin. Usun, et 40+ tolli peal näeb nii HD kui UHD, tõenäoliselt isegi 720p paneeliga kogu telelevi ikka üsna kole välja. Eriti mingid kohalikud uudistesaated jne.
Lisaks, ma usun et ei maksa seda upscale teemat niiväga karta. Ma usun, et peamine hirm on tulnud 480 -> 720 ja 720>1080 upscale'ist, mis on komadega arvutamine. Kui nüüd lihtsustada, siis 1080 -> UHD upscale'i matemaatika on kõvasti lihtsam, sama suure paneeli puhul kuvatakse 1080p puhul 1 piksel, UHD puhul 4 pikslit. Kuna PPI erinevus on 4x, siis lõpptulemuseks on, et nii HD kui UHD peal on valgusruut sama, ühel lihtsalt ühest, teisel neljast pikslist koosnev. Eks kõiksugu nutikad algoritmid annavad endast parimat, et natuke detaili lisada, aga asi pole võrreldav jpeg faili 1,5 korda suuremaks tegemisega, kus asi läheb a) jõnksuliseks b) uduseks.
nüüd aga küsimus-mure. Nimelt ei suuda mu arvuti 4k pilti toota väga hästi. Youtube, MPC ja VLC kõik veidi jõnksutavad. Mis võiks põhjuseks olla? HD7850'l peaks veel piisavalt jõudu olema, pigem tundub mingi confi viga olevat. Või on mõttekas arvutist 1080p signaal peale anda, ning jätta upscale teleka hooleks?
_________________ Kui sa ei kirjelda, mida sa müüd, kus sa asud või palju sa selle eest raha tahad, siis jätan endale õiguse pakkuda kauba eest 3 kummikana ja eeldan, et sa tood mulle kauba koju ära ka. |
| Kommentaarid: 134 loe/lisa |
126 |
von Wu
14.11.2016 10:54:07
| RandomHero kirjutas: |
| Usun, et 40+ tolli peal näeb nii HD kui UHD, tõenäoliselt isegi 720p paneeliga kogu telelevi ikka üsna kole välja. Eriti mingid kohalikud uudistesaated jne. |
Oma kogemusest väidan, et LG 6. seeria 42" FHD ja 43" UHD ekraanidel näevad isegi kohalikud saated head välja.
Müüa naastrehvid |
669 |
ihvike
14.11.2016 16:20:30
Oleneb, mida SD kanalitesse lastakse ka. Mõned filmid näevad TV3, Kanal 2 ja muu taolise peal üsna rahuldavad välja. Põhiline viga, mida telekad (sisemise tuuneriga) tihti SD kanalite puhul teevad on overscan - selle asemel et näidata 100% signaalis olevast pildist, suurendatakse pildi servad välja. See rikub pildi küll väga jamaks ära. Kui overscani õnnestub vältida, on SD kanalite pilt nii ja naa - osad asjad on koledad, osad on rahuldava kvaliteediga, arvestades füüsilist reaalsust. Küll aga on see jutt kehvast pildist suurema (ja suurema pikslite arvuga) teleka peal laiemas plaanis mõttetu teema. Väikese teleka peal on pilt üsna samasugune - mine lähemale, vaata...
Teisalt - kui teleka ainuke eesmärk on kodumaist SD-d näidata, siis soovitan soojalt see raha kasvõi maha juua - oluliselt tulemuslikum "investeering".
12 |
14.11.2016 16:39:05
ihvike, kõik on ju õige, et väiksema ekraani peal on pilt ilusam. Lähedalt ei vaata ju enamus telerit ja kaugemalt, loe mõistlikult vaatamiskauguselt, sulanduvad need ruudueffektid juba ühtseks massiks.
128 |
inca
14.11.2016 18:18:26
nüüd aga küsimus-mure. Nimelt ei suuda mu arvuti 4k pilti toota väga hästi. Youtube, MPC ja VLC kõik veidi jõnksutavad. Mis võiks põhjuseks olla? HD7850'l peaks veel piisavalt jõudu olema, pigem tundub mingi confi viga olevat. Või on mõttekas arvutist 1080p signaal peale anda, ning jätta upscale teleka hooleks? |
Nii huvi pärast uuriks, kas videokaart arvutab lennult youtube'i ilma mingeid trikke tegemata? VLC-s oli vanasti vaja kuskil sätetes surada, kui tahtsid videorauaga asju ajada.
Ma eeldan, et see pentium võib küll 4k pildiga hätta jääda.
_________________ KASS |
158 |
