Scart
09.12.2014 09:16:42
| Tomorrow kirjutas: |
Ja VSR on suurepärane lisa, et mängida vanemaid mänge ilma sakkideta |
Nope!
Currently this will work on AMD Radeon R9 295X2, R9 290X, R9 290 and R9 285 only. This also works on single-GPU and multi-GPU configurations of those GPUs.
If you have a 1080p display you can run at 2560x1440 VSR or 3200x1800 VSR and 3840x2160 VSR but only on R9 285. So that means 4K VSR only works on the R9 285, which as you will recall is the latest iteration of GCN known as Tonga. That means hardware has a lot to do with VSR support, and only the latest GCN iteration can support 4K VSR. The second iteration, Hawaii, R9 290/290X can only do 3200x1800 VSR max on a 1080p display. So there are limitations based on hardware.
If you have a 1200p display you can run at 2048x1536, 2560x1600 and 3840x2400 VSR but only on R9 285. If have a 1440p display you can run at 3200x1800 on each GPU. If you have a 120Hz 1080p display you can run only at 1920x1200 120Hz or 2048x1536 120Hz.
http://hardocp.com/article/2014/12/08/introducing_new_amd_catalyst_omega_driver/2#.VIaTlMkQMV8
101 |
09.12.2014 09:28:13
Scart, Always finding the negative?
Märkasin seda isegi. Kahju, aga las ta siis olla. Vähemalt hea teada, et AMD mingil määral toetab downsamplingut. Muidugi kui nad oma draiverites selle jälle lubaks, siis saaks ka vanemate kaartide omanikud selle vajadusel tööle häkkida. Olen seda vanemate 12.11 draiveritega proovinud ja kuigi see kõigis mängudes ei toiminud oli pilt superilus.
| Kommentaarid: 92 loe/lisa |
Scart
09.12.2014 09:32:22
Scart, Always finding the negative? |
Eih, ma olen lihtsalt harjunud AMDi tavapäraste but-situatsioonidega.
101 |
Draco
09.12.2014 09:33:48
Ei tule uusi drivereid, on paha. Tuleb suuremat sorti uuendus, ikka paha Raske lapsepõlv?
_________________ Purgatory Judgement |
| Kommentaarid: 12 loe/lisa |
12 |
A-Circus.
09.12.2014 13:32:27
| Ramones kirjutas: |
AMD pole endiselt sleepist väljatuleku bugi parandada suutnud? Endiselt peale sleepist väljumist lülitub ekraani taustavalgus sisse ja pilt jääb mustaks. Aitab arvuti uuesti sleepi panek (klaviatuuril on vastav nupp õnneks olemas) ja äratamine 280x + Win8.1 + viimane beta driver. |
Nüüd tundub olema korras sellega, minu kaart tuleb uute driveritega ilusti sleepist välja.
| Kommentaarid: 50 loe/lisa |
48 |
Draco
09.12.2014 13:40:22
| A-Circus. kirjutas: |
| Ramones kirjutas: |
Nüüd tundub olema korras sellega, minu kaart tuleb uute driveritega ilusti sleepist välja. |
Lähiajal kolmes masinas olnud kus on AMD kaart ja Win 8.1 64 PRO millel pole sleepist välja tulekuga probleeme olnud. Mõnes muus asjas probleem ehk ?
12 |
A-Circus.
09.12.2014 14:27:39
| Draco kirjutas: |
| Ramones kirjutas: |
Lähiajal kolmes masinas olnud kus on AMD kaart ja Win 8.1 64 PRO millel pole sleepist välja tulekuga probleeme olnud. Mõnes muus asjas probleem ehk ? |
Mul kahes täiesti erinevas masinas erinevate kaartidega olnud see jama. Praegusega algusest peale ja HD 7850'l tekkis see peale mõnekuulist kasutamist. Otsisin internetist abi, aga mingit lahendust ei leidnud. Omega bug fixide listis selle probleemi kõrvaldamine igatahes kirjas ja minul peale nende driverite paigaldamist seda jama ei ole(spetsiaalselt katsetasin). Ju siis on ikkagi driveritega kuidagi seotud, seda miks osadel kaartidel seda probleemi esineb ja teistel mitte ei oska öelda.
48 |
bitCON
09.12.2014 15:09:44
| Draco kirjutas: |
| Ramones kirjutas: |
Mul pole ka see probleem ära kadunud. ptui-ptui-ptui
infect
09.12.2014 19:46:56
Hmm, kas neid on mõttekas 6000 seriale ka panna või pigem järgida motot, et kui vana töötab, siis pole vaja torkida ?
| Kommentaarid: 25 loe/lisa |
25 |
Scart
101 |
Aah
09.12.2014 23:55:20
| Scart kirjutas: |
Eih, ma olen lihtsalt harjunud AMDi tavapäraste but-situatsioonidega. |
Meenub viimati kasutuses olnud NVIDIA vga situatsiooniga kus nad ei suutnud pea aasta draiverite installikat korda saada. Õnneks polnud muid probleeme nagu teistel oli. Läks õnneks et mitte kokku puutuda NVIDIA- but-situatsioonidega.
| Kommentaarid: 21 loe/lisa |
21 |
Vael
10.12.2014 06:40:14
Proovisin järgi, Watch Dogsis küll midagi paremuse poole ei liikunud.
infect, ma muidu ka sama meelt, et kui töötab siis pole mõtet surkida.
Nüüd tuleb ainult 5k monitor freesync toega soetada, et draivust kasu oleks;)
| Kommentaarid: 17 loe/lisa |
16 |
infect
10.12.2014 12:04:45
| Seda black screen bugi mul hetkel esineb küll. Aga nii minuti jooksul ärkab ikka üles.
25 |
busta
10.12.2014 14:14:33
| Amd vennad jauravad ikka mingisuguste läbi mõtlemata lahenduste kallal, mis on neile kiiruga maha parseldatud. Vasekestest hakkab vahest päris kahju, õige raja ära tundmisel on rõõm jällegi suur.
| Kommentaarid: 16 loe/lisa |
14 |
10.12.2014 14:49:39
busta, aitäh selle sisutu, teemat risustava, postituse eest. vajalik
182 |
Draco
10.12.2014 16:20:14
| busta kirjutas: |
| Amd vennad jauravad ikka mingisuguste läbi mõtlemata lahenduste kallal, mis on neile kiiruga maha parseldatud. Vasekestest hakkab vahest päris kahju, õige raja ära tundmisel on rõõm jällegi suur. |
Ajuvähi algstaadium ?
12 |
Lovvi
10.12.2014 19:21:39
Kas kellegi jääb samamoodi toppama? ca 5 minutit nii juba.
| Kommentaarid: 60 loe/lisa |
57 |
bitCON
10.12.2014 20:53:36
| lase DDU-ga draiverid maha ja proovi uuesti
WäntWõll
make.believe
10.12.2014 20:58:33
| No niipalju on ikka kasu, et top 10 bugi väidetavalt fixiti ära k.a nn black screen bug kus monitor ei ärka timeoutist (mitte ajada segi kogu arvuti sleepist ärkamise blackscreeniga mis ei pruugi üldse amd viga olla - nagu minu arvutil esines see varem ka nvidia kaardiga). |
Win-i + mõne tootja uefi/biose häda.
Töökaaslasel sama asi Lenovo miski süle pilliga ja sama tragöödia.
Osad on saanud mobo uefi/biose uuendusega lahti.
Teemasse tagasi, siis ma parem ei kommentaari seda draiveri asja
300 |
Lovvi
10.12.2014 22:30:48
| Lovvi, Ei. Vanad lasid maha? |
Control Panelist lasin vanad maha. Kustutasin C:\AMD kausta ära, siis läks peale.
57 |
Aah
11.12.2014 13:11:17
| Draco kirjutas: |
| busta kirjutas: |
Ajuvähi algstaadium ?  |
Loe ridade vahelt mis ta öelda tahtis. Nvidia 9xx seeria Coil Whine probleemid kuni toiteploki vahamiseni. Nvidia mängu Far Cry 4 roheliste probleemid kuni klassialise "nvidia display driver stopped responding and has recovered" probleemini
21 |
bitCON
11.12.2014 16:45:54
tra uute draiveritega juba 3. freeze BF:BC2 mängimise ajal aitab ainult restart
Vael
11.12.2014 17:55:03
| bitCON kirjutas: |
tra uute draiveritega juba 3. freeze BF:BC2 mängimise ajal aitab ainult restart |
Kui töötab, siis ära uuenda;)
Mitu korda peale lasid drivereid? NetFW 4.5 ka kaasas, kahtlustan, et esimese korraga ei pruugigi täppi minna...
16 |
