| Palju aega võtaks sinu steam kontol olevate mängude läbimine? |
| 1-10 tundi |
4% |
[ 21 ] |
| 10-25 tundi |
3% |
[ 18 ] |
| 25-100 tundi |
9% |
[ 43 ] |
| 100-200 tundi |
10% |
[ 48 ] |
| 200-500 tundi |
8% |
[ 39 ] |
| 500-1000 tundi |
12% |
[ 55 ] |
| Rohkem kui 1000 tundi |
50% |
[ 227 ] |
| hääli kokku : 451 |
21.12.2013 17:06:16
kaartide müümiseks on kogu aeg hea aeg
_________________ - londiste
215 |
Saabu
21.12.2013 17:12:46
| Kas oleks võimalik ka saada osa HV Steam Communityst ? ID: saabu
| Kommentaarid: 17 loe/lisa |
17 |
tanel1984
21.12.2013 18:16:09
| tanel1984 kirjutas: |
| Oracle kirjutas: |
| oleks vaja abi ja nõuannet......ostsin ghost steam aktiveerimis võtme, lisasin mängu, kuid kui panen install, siis viskab steam kinni ja midagi ei toimu ja kui proovin steami uuesti tööle panna, siis kohe sulgeb uuest. Ja seda on kõikide mu steami mängudega....kas selle vastu on mingit rohtu.....tekib juba vaikselt masendus, et ei saagi neid enam kasutada. |
Mässasin sellise jamaga mitu nädalat.
Proovi seda:
The following instructions describe how to temporarily disable applications running in the background which can cause conflicts with Steam. These instructions are for temporary, diagnostic use only and your system should not be left in this state.
Please try this:
Click the Start button, then "Run" (or Windows key + R)
Type in:
msconfig
Choose "Selective Startup"
Uncheck the box labeled "Load Startup Items".
Now, click on the "Services" tab.
Please make sure the "Hide All Microsoft Services" box *is* checked.
Then, click "Disable All".
If you are using Vista or Windows 7, please re-check the "Steam Client Service" as this is required for Steam to function on these operating systems.
Click "OK" and allow your computer to restart.
Test the issue and let us know the results. This is for diagnostic purposes only. You should not leave your computer in this state, but it may help us determine the cause of the issue.
To set the system back to normal, launch msconfig again and choose "normal startup", close the window and restart your computer.
Ning teisena võid Control panelis - Programs - Windows functions panna kõik linnukesed .Net frameworkide ette. |
kas see toimib windows 8.1 puhul ka? |
ei toimi kahjuks ükski neist variantidest minu puhul .....veel mingisuguseid ettepanekuid?
sukelduja
21.12.2013 20:17:57
| Oracle kirjutas: |
Proovi seda:
Please try this:
Type in:
msconfig
ei toimi kahjuks ükski neist variantidest minu puhul .....veel mingisuguseid ettepanekuid? |
Kas sul .net 3.5 on lubatud?
| Kommentaarid: 25 loe/lisa |
25 |
Diesel157
21.12.2013 20:41:46
Kellelgi plaan "Age of Empires II HD" 4 pack ka osta on? TK hinnaks tuleks hetkel - €3.56
viimati muutis Diesel157 21.12.2013 22:39:11, muudetud 1 kord |
| Kommentaarid: 159 loe/lisa |
144 |
Gunnar19
Kaevur
21.12.2013 21:32:55
Mis arvate kui klapiks ühe nelipaki kokku?
Buy Ace of Spades: Battle Builder 4-Pack
2.25€ tuleks per kärss.
| Kommentaarid: 42 loe/lisa |
tanel1984
21.12.2013 22:54:40
| sukelduja kirjutas: |
| Oracle kirjutas: |
Proovi seda:
Please try this:
Type in:
msconfig
Kas sul .net 3.5 on lubatud? |
kus ma seda näen, kas lubatud v mitte? ma ei ole eriti arvuti taibu nendes asjades.....vaatasin control paneli kaudu, et seal mingi kastike ees....kas need teised windows communication foundation HTTP activation ees peab ka linnuke olema?
Oracle
21.12.2013 23:02:08
| Pane kõigi .Net alammenüüde ette linnuke
| Kommentaarid: 62 loe/lisa |
59 |
tanel1984
21.12.2013 23:58:10
klge see net framework värk töötas, tänud.....mäng hakkas steamis allalaadima ja akent kinni ei visanudki
22.12.2013 20:46:15
Ollalaa, Max payne 3 suht hea hinnaga
| Kommentaarid: 39 loe/lisa |
Anna tooli
22.12.2013 22:13:20
| salatoimik kirjutas: |
Ollalaa, Max payne 3 suht hea hinnaga  |
Amazonist saab selle eest veel Rockstar Passi lisaks ning raha jääb ülegi
| Kommentaarid: 363 loe/lisa |
299 |
Leo Kalme
Reasõdur
| Kommentaarid: 23 loe/lisa |
14 |
erik111
24.12.2013 23:56:21
Kui saan kuskilt endale tasuta mängu koodi, kuhu peab steamis pannema selle sisse?
157 |
SinineSiil
25.12.2013 00:05:48
| erik111 kirjutas: |
Kui saan kuskilt endale tasuta mängu koodi, kuhu peab steamis pannema selle sisse?  |
Siia:
| Kommentaarid: 18 loe/lisa |
18 |
KaarelK
25.12.2013 00:06:38
library all on nurgas mul on + Add a game, sealt activate product on steam.
_________________ life is a bitch with 12inch strapon |
Marx112
25.12.2013 22:46:20
| Left for Dead 2 tasuta täna, aga steam on maas.
Muhekas
25.12.2013 23:33:23
Mida kuradit nad selle steamiga nüüd n*kuvad
_________________ Olenemata olukorrast, jää iseendaks ja samas lugupidavaks. |
| Kommentaarid: 20 loe/lisa |
17 |
prtv
25.12.2013 23:41:01
Rahvamass jooksis peale
_________________ |
| Kommentaarid: 82 loe/lisa |
73 |
Gap
26.12.2013 00:12:23
steam on nii läbi omadega et sisse ka ei lase logida ?
| Kommentaarid: 21 loe/lisa |
17 |
t2ring
26.12.2013 01:02:28
No suht umbes on jah Steam, ise sain Left 4 Dead 2 kätte, aega võttis aga asja sai
| Kommentaarid: 97 loe/lisa |
94 |
26.12.2013 01:56:39
steam on umbes jah, ise sain enne tormi lfd2 kätte ja praegu loadib ka pika laadimise peale lehed ära, steam store programmis sees enam ei toimi
182 |
k3rmo
26.12.2013 02:15:11
| Kes niisama ei saa, siis ava IE, paste "steam://install/550" üles lahtrisse, vajuta enter ja voilaa.
crypto
37 |
Aeron
| Kommentaarid: 72 loe/lisa |
65 |
kriist
26.12.2013 12:13:56
| Aeron, nr. 3 on vastu pakkuda, steamis: kri1st
93 |
