| Palju aega võtaks sinu steam kontol olevate mängude läbimine? |
| 1-10 tundi |
4% |
[ 21 ] |
| 10-25 tundi |
3% |
[ 18 ] |
| 25-100 tundi |
9% |
[ 43 ] |
| 100-200 tundi |
10% |
[ 48 ] |
| 200-500 tundi |
8% |
[ 39 ] |
| 500-1000 tundi |
12% |
[ 55 ] |
| Rohkem kui 1000 tundi |
50% |
[ 228 ] |
| hääli kokku : 452 |
21.12.2013 18:06:16
kaartide müümiseks on kogu aeg hea aeg
_________________ - londiste
217 |
Saabu
21.12.2013 18:12:46
| Kas oleks võimalik ka saada osa HV Steam Communityst ? ID: saabu
| Kommentaarid: 17 loe/lisa |
17 |
tanel1984
21.12.2013 19:16:09
| tanel1984 kirjutas: |
| Oracle kirjutas: |
| oleks vaja abi ja nõuannet......ostsin ghost steam aktiveerimis võtme, lisasin mängu, kuid kui panen install, siis viskab steam kinni ja midagi ei toimu ja kui proovin steami uuesti tööle panna, siis kohe sulgeb uuest. Ja seda on kõikide mu steami mängudega....kas selle vastu on mingit rohtu.....tekib juba vaikselt masendus, et ei saagi neid enam kasutada. |
Mässasin sellise jamaga mitu nädalat.
Proovi seda:
The following instructions describe how to temporarily disable applications running in the background which can cause conflicts with Steam. These instructions are for temporary, diagnostic use only and your system should not be left in this state.
Please try this:
Click the Start button, then "Run" (or Windows key + R)
Type in:
msconfig
Choose "Selective Startup"
Uncheck the box labeled "Load Startup Items".
Now, click on the "Services" tab.
Please make sure the "Hide All Microsoft Services" box *is* checked.
Then, click "Disable All".
If you are using Vista or Windows 7, please re-check the "Steam Client Service" as this is required for Steam to function on these operating systems.
Click "OK" and allow your computer to restart.
Test the issue and let us know the results. This is for diagnostic purposes only. You should not leave your computer in this state, but it may help us determine the cause of the issue.
To set the system back to normal, launch msconfig again and choose "normal startup", close the window and restart your computer.
Ning teisena võid Control panelis - Programs - Windows functions panna kõik linnukesed .Net frameworkide ette. |
kas see toimib windows 8.1 puhul ka? |
ei toimi kahjuks ükski neist variantidest minu puhul .....veel mingisuguseid ettepanekuid?
sukelduja
21.12.2013 21:17:57
| Oracle kirjutas: |
Proovi seda:
Please try this:
Type in:
msconfig
ei toimi kahjuks ükski neist variantidest minu puhul .....veel mingisuguseid ettepanekuid? |
Kas sul .net 3.5 on lubatud?
| Kommentaarid: 25 loe/lisa |
25 |
Diesel157
21.12.2013 21:41:46
Kellelgi plaan "Age of Empires II HD" 4 pack ka osta on? TK hinnaks tuleks hetkel - €3.56
viimati muutis Diesel157 21.12.2013 23:39:11, muudetud 1 kord |
| Kommentaarid: 162 loe/lisa |
146 |
Gunnar19
Kaevur
21.12.2013 22:32:55
Mis arvate kui klapiks ühe nelipaki kokku?
Buy Ace of Spades: Battle Builder 4-Pack
2.25€ tuleks per kärss.
| Kommentaarid: 42 loe/lisa |
tanel1984
21.12.2013 23:54:40
| sukelduja kirjutas: |
| Oracle kirjutas: |
Proovi seda:
Please try this:
Type in:
msconfig
Kas sul .net 3.5 on lubatud? |
kus ma seda näen, kas lubatud v mitte? ma ei ole eriti arvuti taibu nendes asjades.....vaatasin control paneli kaudu, et seal mingi kastike ees....kas need teised windows communication foundation HTTP activation ees peab ka linnuke olema?
Oracle
22.12.2013 00:02:08
| Pane kõigi .Net alammenüüde ette linnuke
| Kommentaarid: 62 loe/lisa |
59 |
tanel1984
22.12.2013 00:58:10
klge see net framework värk töötas, tänud.....mäng hakkas steamis allalaadima ja akent kinni ei visanudki
22.12.2013 21:46:15
Ollalaa, Max payne 3 suht hea hinnaga
| Kommentaarid: 39 loe/lisa |
Anna tooli
22.12.2013 23:13:20
| salatoimik kirjutas: |
Ollalaa, Max payne 3 suht hea hinnaga  |
Amazonist saab selle eest veel Rockstar Passi lisaks ning raha jääb ülegi
300 |
Leo Kalme
Reasõdur
| Kommentaarid: 23 loe/lisa |
14 |
erik111
25.12.2013 00:56:21
Kui saan kuskilt endale tasuta mängu koodi, kuhu peab steamis pannema selle sisse?
157 |
SinineSiil
25.12.2013 01:05:48
| erik111 kirjutas: |
Kui saan kuskilt endale tasuta mängu koodi, kuhu peab steamis pannema selle sisse?  |
Siia:
| Kommentaarid: 20 loe/lisa |
19 |
KaarelK
25.12.2013 01:06:38
library all on nurgas mul on + Add a game, sealt activate product on steam.
_________________ life is a bitch with 12inch strapon |
Marx112
25.12.2013 23:46:20
| Left for Dead 2 tasuta täna, aga steam on maas.
Muhekas
26.12.2013 00:33:23
Mida kuradit nad selle steamiga nüüd n*kuvad
17 |
prtv
26.12.2013 00:41:01
Rahvamass jooksis peale
_________________ |
| Kommentaarid: 82 loe/lisa |
73 |
Gap
26.12.2013 01:12:23
steam on nii läbi omadega et sisse ka ei lase logida ?
| Kommentaarid: 21 loe/lisa |
17 |
t2ring
26.12.2013 02:02:28
No suht umbes on jah Steam, ise sain Left 4 Dead 2 kätte, aega võttis aga asja sai
| Kommentaarid: 97 loe/lisa |
94 |
26.12.2013 02:56:39
steam on umbes jah, ise sain enne tormi lfd2 kätte ja praegu loadib ka pika laadimise peale lehed ära, steam store programmis sees enam ei toimi
182 |
k3rmo
26.12.2013 03:15:11
| Kes niisama ei saa, siis ava IE, paste "steam://install/550" üles lahtrisse, vajuta enter ja voilaa.
crypto
37 |
Aeron
| Kommentaarid: 72 loe/lisa |
65 |
kriist
26.12.2013 13:13:56
| Aeron, nr. 3 on vastu pakkuda, steamis: kri1st
93 |
Marx112
26.12.2013 13:37:50
Panin hommikul kell 5 äratuse, et siis äkki toimib see steam juba ja oligi. Sain left for deadi 2 kätte ja tagasi magama
madness
26.12.2013 14:25:52
Praegugi ju veel tasuta saadaval
| Kommentaarid: 13 loe/lisa |
Anna tooli
300 |
KrisVr
28.12.2013 01:14:43
Tasuta Left 4 Dead 2 tulemus!
Uus rekord, 7,505,314 kasutajat samaegselt Steamis sees. Kuu alguses kusjuures alles ületati 7 millioni piir!
Ja muidugi ribalaiuse kasutus, rohkem kui 4 Terabiti sekundis.
Enne kõike seda oli maximum kõvasti alla 2 Tb/s. Pole ime, et Steam maas oli!
| Kommentaarid: 30 loe/lisa |
Hardi
28.12.2013 02:09:51
Ma juba seeaeg tirisin õnneks, kui maha kukkuma steam hakkas selle tasuta L4D2 ajal
_________________ ツ |
| Kommentaarid: 84 loe/lisa |
NNk2
| Kommentaarid: 208 loe/lisa |
173 |
UB
29.12.2013 14:16:02
| DefXtreme kirjutas: |
Enne kõike seda oli maximum kõvasti alla 2 Tb/s. Pole ime, et Steam maas oli! |
Euroopa tegi USAle nii kõvasti ära
| Kommentaarid: 45 loe/lisa |
39 |
rainisk
29.12.2013 14:28:30
Kuna see Left4Dead 2 jälle tasuta on steamis?
_________________ ( -_・) ︻デ═一 ▸ |
18 |
Timberg
ööKARU
29.12.2013 14:45:13
| rainisk kirjutas: |
| Kuna see Left4Dead 2 jälle tasuta on steamis? |
Ennustame
No... ma pakun, et mitte kunagi või mõne järgneva aasta jooksul
272 |
R3negadeX
29.12.2013 15:21:53
| Praegu 50% hind maas, samas eelmine aasta sai L4D ja L4D2 väga väikse kopika eest, siis ostsin ka endale.
| Kommentaarid: 8 loe/lisa |
KurjaJuur
29.12.2013 17:24:05
On väike võimalus, et... tulevikus.
_________________ Steam|Last.fm| |
| Kommentaarid: 7 loe/lisa |
Aeron
29.12.2013 17:47:25
| UB kirjutas: |
Euroopa tegi USAle nii kõvasti ära  |
Kus juures see on huvitav tähelepanek.
Seni maani enamik on arvanud, et usa turg suurem või vähemalt kasumilikum.
Antud näide natuke illustreerib vähemalt mastaabi mõttes EU potentsiaali... vist?
_________________ Võib öelda, et ma olen liigselt enesekeskne, aga mind see ei häiri
Tulge kõik HV rahvaga jalkat mängima!| |
65 |
29.12.2013 18:17:42
näitab lihtsalt seda, et euroopas on pc-l mängimine suhtena konsoolidel mängimisse suurem.
217 |
EvilKatarn
diivanilill
29.12.2013 23:14:57
| Või siis seda, et USA-s ei kaota võrdne hulk inimesi pead tasuta mängu tõttu.
81 |
Aeron
65 |
devilman
30.12.2013 17:10:06
| londiste kirjutas: |
| näitab lihtsalt seda, et euroopas on pc-l mängimine suhtena konsoolidel mängimisse suurem. |
täpselt nii
| Kommentaarid: 19 loe/lisa |
19 |
Muhekas
30.12.2013 23:27:45
Et sai siis steami poes tehtud 2x-dne ost. Krediitkaardilt raha pole maha võetud. Samas esimese korraga ma ei märganud seda infot " Notice: We are currently out of keys for this title. We've requested more from the publisher and will have those soon. Should you purchase this title, your key will be delivered as soon as we receive it. " Küsimus siis, et kuidas ma saan teda alla laadida kui pole võtmeid ning miks krediitkaardilt pole raha võetud?
17 |
kaurrrr
30.12.2013 23:41:41
Sellepärast, et neil on võtmed poest otsas Kui võti tuleb poodi siis saad kätte.
| Kommentaarid: 36 loe/lisa |
Muhekas
30.12.2013 23:48:13
| kaurrrr kirjutas: |
Sellepärast, et neil on võtmed poest otsas Kui võti tuleb poodi siis saad kätte. |
Ta on mul ju käes, laeb alla hetkel. Kuid raha pole ikka maha võetud, selles on uba.
17 |
NATAS999
31.12.2013 00:16:59
El-Fuego, niikaua kuni on võetud vähem või üldse mitte võetud, niikaua hoia suu kinni ja naudi lihtsat elu. kisa tõstetakse ja küsimusi küsitakse siis, kui on võetud rohkem või kui on võetud ja pole asja kätte saand
| Kommentaarid: 41 loe/lisa |
39 |
SirVorkars
31.12.2013 01:18:11
Kreda pealt võibki see alles hiljem näha olla,et on võetud. Teinekord näed kohe, teinekord alles mingi aeg hiljem, oleneb kuidas neil pankadega arvledus/arvete esitamise süsteem üles seatud on ja millisele päevale ostu tegemine joppab...
Kui pidid maksma siis tasuta ei anna nad midagi ja raha broneeritud on kuni arvelduse täideviimiseni
56 |
kjaups
MeesKesTuliMetsast
142 |
DanelM
31.12.2013 15:38:21
| Sooviks kutset HV gruppi. Link
88 |
Diesel157
31.12.2013 17:06:49
Tänud!
viimati muutis Diesel157 31.12.2013 19:44:07, muudetud 1 kord |
146 |
heretic666
02.01.2014 04:20:33
| Steamis mingi konkreetne üleujutus Indie mängudest, küsitakse röögatuid 45 euriseid hindasid ka veel nende eest... mis toimub?
| Kommentaarid: 73 loe/lisa |
