LightsabeR
Kommentaarid: 14 loe/lisa |
14 |
Scart
15.03.2013 15:49:37
LightsabeR kirjutas: |
Samas ametlikult pole EA midagi öelnud. |
Mitteametlikult bännib EA esindaja sõnul EA kõik modijad
Kommentaarid: 119 loe/lisa |
101 |
15.03.2013 16:44:27
Eks kui midagi liikuma hakkab, siis tuleb testida enda Ungari versiooniga
Kommentaarid: 234 loe/lisa |
200 |
MatchMaker
Kommentaarid: 2 loe/lisa |
limp
15.03.2013 17:43:45
Küsiks, kust hetkel kõige odavamalt seda saaks?
greenmangamingust igatahes ütleb order not complete. erineva pankade krediitkaartidega nii + paypal ka sama teema...
_________________ Ärgake lapsed, maailm on hädaohus
Windows keskkond on nagu li*s - kõik teda ke*ivad aga keegi teda ei armasta! |
Kommentaarid: 56 loe/lisa |
52 |
MaxEvil
15.03.2013 18:05:16
Kui hetkel ostetud ei ole, siis tasub oodata, mäng eriti täis hinda hetkel väärt ei ole, samas USAs Target on karbi versioonilt -20$ juba
Kommentaarid: 11 loe/lisa |
LightsabeR
15.03.2013 18:16:37
Mõned tsitaadid AzzerUK postitusest EA foorumis, mis praeguseks on juba kustutatud. Nendele, kes kogu teksti ei viitsi lugeda:
http://pastie.org/6505519
tsitaat: |
I edited quite a few function calls to make this work reliably, including disabling UI elements so I had no disconnect warnings on my screen while I played. The simulation runs just fine. You can even trade with other cities in the region to an extent, and get service trucks from their cities, AS LONG AS you already had the region loaded in before disconnecting. |
tsitaat: |
It doesn't let you play DRM free - the city you want to play in still has to be loaded from the server. There is also no way of saving that city to hard-disk to load while still offline later. However, it does prove that EA's servers are not processing the stuff in a city at all. Your PC can handle your entire city simulation without any help from the internet or EA's servers. |
tsitaat: |
City size limits are artificially restricted, and can be increased by EA/Maxis with absolute ease. Obviously - the more your PC is processing, the slower it will get, but the current city sizes are far too small for anything other than extremely old, basic setups. |
14 |
15.03.2013 19:31:26
Ei tea... eks tuleb oodata mingit juhendit kuidas mängu õieti mängida, sest "nearest" loogika on küll ikka mage
teenuste fiximise kohta pole mingit infot st. kuna need politsei ja muud teenused korda saavad?
Pole viitsinud pea 2 päeva mängida...
200 |
MatchMaker
16.03.2013 02:23:43
link :: EA Admits That SimCity Could Have Been Offline
Following the recent discovery that SimCity can function without an internet connection, Maxis general manager Lucy Bradshaw admits that they could have created an offline mode for the game.
"We did not focus on the 'single city in isolation' that we have delivered in past [SimCity games]. We recognize that there are fans -- people who love the original SimCity -- who want that. But we're also hearing from thousands of people who are playing across regions, trading, communicating and loving the Always-Connected functionality."
http://www.ea.com/news/simcity-update-straight-answers-from-lucy
Goon
16.03.2013 02:31:33
MatchMaker kirjutas: |
See mees on pilves ve? mitte keegi peale EA enda pole öelnud, et nad tahavad Always-Connected functionality´t
XATM092
16.03.2013 02:38:21
Tõesti usute, et mitte kellelegi ei võiks meeldida (M?)MO Simcity?
Kommentaarid: 40 loe/lisa |
37 |
indu
16.03.2013 02:52:15
Kas see on mingi bug et tööstus ja ka vahest kommerts röögib tööliste järele ?
Elanikke nagu on tööstust ka väheke aga ikka pole kunagi piisav.
Vahet pole kui hea on haridussüsteem. Ikka pole kunagi piisav.
_________________ http://www.lossirestoran.eu/ |
Kommentaarid: 63 loe/lisa |
58 |
16.03.2013 08:44:18
Bug on ka hariduses...mul piisavalt ressurssi, aga kooli lähedal karjutakse ei saa harida... mingid pisiasjad on katki, mis rikuvad mängu ära, eriti kui proovid seda mõistliku loogika järgi mängida.
200 |
Scart
16.03.2013 10:20:37
Goon kirjutas: |
See mees on pilves ve? mitte keegi peale EA enda pole öelnud, et nad tahavad Always-Connected functionality´t |
Miks ei peaks tahtma? Simcity töötab MPs vägagi hästi (kui mäng parajasti töötada otsustab).
101 |
greencow
16.03.2013 12:35:54
Minu jaoks on SimCity olnud selline mäng, mida on väga mõnus mängida kohtades, kus ei ole interneedust.
Kommentaarid: 13 loe/lisa |
12 |
Mafia
16.03.2013 14:50:08
Kas Great Works tegemine on bugine või kuidas see käib? Mitu korda on nii juhtunud, et kui materialid on täis saanud siis järsku on pooled kadunud ja veel vaja. Kui keegi on GW valmis saanud siis ehk seletab?
_________________ Bawse |
Kommentaarid: 19 loe/lisa |
17 |
DigeBeni
16.03.2013 15:43:35
... krt, kui linnades juba 200-300k inimest, siis muutub regiooni üksinda majandamine ikka päris haiglaselt keeruliseks sest kuna salvestada ei saa, siis suuri vigu teha ei tohi ja alternatiivsete strateegiate katsetamine on äärmiselt vaevaline. Pole nii palju aega kah mängimiseks, et pidevalt uuesti alustada või n+1 erinevat regiooni vaheldumisi arendada. Lisades siia veel teada olevad anomaaliad ja olukorrad, millest on raske aru saada, kas ma teen ise midagi valesti või on see jällegi mingi kala on see mäng muutumas vaikselt äärmiselt frustreerivaks
Kommentaarid: 194 loe/lisa |
160 |
16.03.2013 15:46:45
280 pealt saab kukkuda väga kiiresti 160K linnaks
Hetekel ei viitsi pead vaevata... parandagu enne vead ära.
200 |
DigeBeni
16.03.2013 17:02:19
... jah, parim näide, elektrijaamale ei toodud õli, ma pidin ennast lolliks nuputama, et miks ometi, autod sõitsid jaama eest kenasti läbi ja tee näis ühendatud aga tegelikult polnud, pidin ümbruskaudsed teed maha lammutama ja uuesti ehitama. Selle jama käigus kaotasin ~300k raha ja ~150k inimest
160 |
LightsabeR
16.03.2013 17:17:54
Jube hea artikkel RPS'is: http://www.rockpapershotgun.com/2013/03/16/simcity-bosss-straight-answers-seem-pretty-wiggly/
See Bradshaw jutt ajab ikka tõesti kurjaks. EA lihtsalt valetab rahuliku südamega edasi.
tsitaat: |
Things then take a turn for the darned strange when Bradshaw adds,
“The game we launched is only the beginning for us – it’s not final and it never will be. In many ways, we built an MMO.”
In almost no ways have they built an MMO. The first M rather puts pay to that suggestion, with minimal numbers of players interacting, and even then interacting through relatively remote systems. Let alone that it’s a management game that previously functioned perfectly well without the addition of social aspects – which is what makes it so mystifying that apparently adding something has caused so much more to be taken away. But the association with an “MMO” is an essential part of the vocabulary Maxis and EA want us to use, to reinforce the notion that this hasn’t been about piracy, preventing solo-play cheating, and controlling players’ experiences. “Oh, MMOs,” we’re supposed to say. “Yeah, good point, because you couldn’t play World Of Warcraft offline, could you? So this must be the same.” We’re asked to ignore that SimCity looks, feels and plays like a single-player game with some multiplayer functionality, and instead conflate it with an entirely different type of game. It’s a blatantly fallacious stance, but one that’s unfortunately perpetuating. (Check out many other sites’ coverage of Bradshaw’s statements this evening.) Bradshaw then says. |
14 |
ottf
Kommentaarid: 6 loe/lisa |
Genobe222
16.03.2013 20:21:07
tsitaat: |
IMPORTANT NOTE: I have NOT enabled syncing of data for this. All cities you see in this video remain UNHARMED - nothing got synced to server. |
Päris hea uudis. Raske on video descriptioni esimest lauset lugeda.
Kommentaarid: 1 loe/lisa |
Kristoferr
16.03.2013 20:34:26
Kui ta oleks sünkinud, siis oleks need linnad katki. või vähemalt tekitaks out of sünk errori ja rollbacki?
Kommentaarid: 257 loe/lisa |
209 |
16.03.2013 20:46:45
jah. häkk tekitab rollbacki nagunii..iseasi kui seda tõlgendada mänguri teadliku käitumisena, siis seda ei toimu ja rollback on võimatu st. seda ei eksisteeri enam.
Neil hea huumor mängus:
Harsh Realty
Panin mängu sente koguma ja lähen poodi...
aap14 kirjutas: |
Ma panen siia märgi maha, et valmis olla selleks kui ükskord bugid ära parandatakse ja kõik mängu taevani kiidavad (enne pole vist mõtet proovidagi). |
Neid buge omajagu veel üleval jah. St mida nad kavandasid ei tööta ilusti. Modimisega saab varsti enamiku kitsaskohti kõrvaldada ja kui põhiteenused jookseksid vastavalt reaalsele panusele, siis oleks tegelikult mäng korras.
Aga muidu jääb teemaks traffic... hetkel töötavad hästi bussid ja rongid.
Laevad lähevad lolliks ja sama kehtib ka trammide kohta. Lisaks koolibussid on samuti lollid.
Poleks orikana ostetud mängult sellist jama tegelikult eeldanud. Enamik auru on läinud selle DRM toe püsti hoidmisele st. et raha jookseks sisse.
Muude vigadega ikka vähe tegeldud.
edit: 1 buss lasi linna umbe...geniaalne
viimati muutis Magic 16.03.2013 21:14:00, muudetud 3 korda |
200 |
aap14
16.03.2013 20:47:03
_________________ Slow is smooth and smooth is fast |
Kommentaarid: 41 loe/lisa |
38 |
