Rebel_
03.09.2010 12:39:02
| Renka kirjutas: |
Ei ole rake uskuda - lihtsalt info on väga vastukäiv olnud algusest peale
1. Boot to Windows in Boot Camp
2. Right click on My Computer and select Manage
3. Check the display drivers installed
4. Right click on that and choose to update driver
5. When the wizard comes up let it search for the drivers first
6. If it is not finding the appropriate drivers repeat the steps and choose to install from the disk
7. Insert the Boot Camp driver disk (i.e. Mac OS X install disk) and try to update the driver. |
see on tehtud? |
selles ongi asi et peale driveite installi jookeb kokku.
praegu kasutan ilma video driveriteta ja töötab kuidagi.
| Kommentaarid: 10 loe/lisa |
10 |
fedja
03.09.2010 12:41:29
Kontrollige oma faktid üle, enne kui siin kedagi skisofreenikuks tembeldate, nii 20" kui ka 24" iMac-i on toodetud 9400M videokaartiga, eMac on ilmselt lihtsalt inimlik kirjaviga.
iMac 24" (Early 2009)
116 |
Rebel_
03.09.2010 12:58:05
fedja
ära pane tähele inimesel on see põhimõtte küsimus.
kahju, et ei ole fotokat käepärast teeks selles paradoksist pilti.
http://support.apple.com/kb/HT3246
Products with the NVIDIA 9400M include:
MacBook (13-inch, Aluminum, Late 2008)
MacBook (13-inch, Early 2009)
MacBook (13-inch, Mid 2009)
MacBook (13-inch Late 2009)
MacBook Air (Late 2008)
MacBook Pro (15-inch, Late 2008) when "Better battery life" is enabled
MacBook Pro (17-inch, Early 2009) when "Better battery life" is enabled
Mac mini (Early 2009)
iMac (20-inch, Early 2009)
iMac (24-inch, Early 2009) with 2.66GHz Intel Core Duo processor
iMac (21.5-inch, Late 2009)
MacBook Pro (13-inch, Mid 2009)
MacBook Pro (15-inch, 2.53 GHz, Mid 2009)
MacBook Pro (15-inch, Mid 2009) when "Better battery life" is enabled
MacBook Pro (17-inch, Mid 2009) when "Better battery life" is enabled
viimati muutis Rebel_ 07.09.2010 10:26:30, muudetud 1 kord |
10 |
beastbeats
03.09.2010 13:19:19
OT:
fedja, kasutaja Rebel_ oleks 2,5 sisutühja postituse asemel kohe võinud masina spec'id kirja panna
Peace
M: Uus/pakendis Fjern Fjork Titanium Forked Spoon - 10€ |
281 |
Cemtey
26.01.2013 10:26:55
.. kustutatud .. |
.. kustutatud ..
viimati muutis Cemtey 23.04.2014 00:56:21, muudetud 1 kord |
| Kommentaarid: 18 loe/lisa |
17 |
flake
26.01.2013 20:52:31
Kindel et iOS? OS X'ga sassi ei aja?
_________________ ..||.. |
| Kommentaarid: 63 loe/lisa |
60 |
Renka
28.01.2013 04:44:47
Parallels Desktop on siiani parim virtualiseerimise soft mis Macile leidnud olen, kasuta seda http://www.parallels.com/products/desktop/
BootCamp ei ole aga virtualiseerimistarkvara ja sa ei saa korraga mõlemat OSi jooksutada.
61 |
rocki
28.01.2013 09:10:54
Bootcamp on bootloader nagu lilo või grub linuxil, kus valid, mida jooksutad. Renkaga nõus, parallels on päris hea jah. kui tahad, et mõlemad samaaegselt jooksevad/on integreeritud.
_________________ Asju saab kah teisiti teha! |
| Kommentaarid: 7 loe/lisa |
Cemtey
30.01.2013 09:50:09
.. kustutatud ..
viimati muutis Cemtey 04.05.2014 16:10:41, muudetud 3 korda |
17 |
Renka
30.01.2013 14:13:12
Boot Camp ei ole virtualiseerimistarkvara ju.
Parallels on tasuline jah - aga vastutasuks saad parima toote ka mis hetkel turul on.
61 |
vipu
07.04.2014 11:15:52
| Küsimus Boot Campi kohta. Tiksub arvutis kenasti, aga kui ma tahan osta juurde ühe usb välise kõvaketta, siis millist failisüsteemi ma peaks kettal kasutama nii, et win7 kui ka mac seda lugeda oskaks?
flake
07.04.2014 12:27:45
mac oskab windowsi failisüsteemidest aru saada, vastupidi mitte. Seega ntfs või fat32 peaks täiesti pädema
60 |
vipu
07.04.2014 12:37:21
| ntfs mälupulgaga oli jama, fat32 sobis. vist formaadin fat32.
Alari A.
07.04.2014 12:47:03
iMac millel 10.9.2 peal ning bootcampiga W7 64 bit, loeb HFS+ välist ketast ilusasti. Kirjutamist ei ole proovinud
| Kommentaarid: 662 loe/lisa |
543 |
Renka
07.04.2014 12:51:49
| vipu kirjutas: |
| ntfs mälupulgaga oli jama, fat32 sobis. vist formaadin fat32. |
ntfs jakos on vaja vastavat driverit. Ostad mõne välise ketta siis peaks tasuta kaasa saama. Seagate toodete puhul vähemalt on siiani saanud.
61 |
vipu
07.04.2014 14:14:47
| Selge, ostan ketta ja uurin driverit kui kaasas ei ole.
Renka
61 |
Forss
07.04.2014 15:10:00
Ise ostsin just WD My Passport Ultra 1TB
Leidsin, et parim lahendus on teha kaks partitsiooni kettale: 500GB HFS+ ja 500GB NTFS.
Saab teiste windowsi masinatega ligi asjadele NTFSilt ja TimeMachine saab oma backupid HFS partitsioonile.
Paragoni NTFS driveriga saab macis kirjutada ka faile.
vipu
07.04.2014 15:57:37
| Ostsin mingi Toshiba 1TB ja tegin ketta samuti kaheks. USB3 kärab päris hästi, mul polegi varem ühtegi välist ketast olnud. Küsimus Boot campi kohta, kuidas arvuti alglaadimisele selle valiku saaks nagu windowsil on? Praegu tuleb õigel ajal ALT all hoida, aga valik võiks kohe ette ise tulla.
Alari A.
543 |
mathiasm
08.04.2014 09:06:19
| vipu kirjutas: |
| Küsimus Boot Campi kohta. Tiksub arvutis kenasti, aga kui ma tahan osta juurde ühe usb välise kõvaketta, siis millist failisüsteemi ma peaks kettal kasutama nii, et win7 kui ka mac seda lugeda oskaks? |
Kui FAT32 puhul hakkab failisuuruse piirang häirima, siis vorminda exFATiks
HDvurle
HV pensionär
10.04.2014 21:54:17
Kui soov NTFS-ile kirjutada kasuta Tuxera NTFS-i. On küll tasuline, kuid töötab ilusti.
_________________ Teie küsimused on vastatavad, kuid meie vastused on küsitavad.
IT uudissõnad. Pihuarvuti - pihkar, pihuarvuti kasutaja - pihkur. |
| Kommentaarid: 21 loe/lisa |
16 |
seeMees
30.07.2014 07:53:08
Soovitan exFAT'i nii väliste ketaste kui igasugu pulkade formaadiks.
Ise kasutan ja pole probleemi ei lugemise ega kirjutamisega nii Win PC kui Mac'ide puhul.
Mac toetab exFAT'i alates OS X versioonist 10.6.5.
mighty
14.06.2017 16:08:55
Kuidas installeerida Windows 7 - Macbook early 2008 10.7.5 peale ilma cd seadmeta |
Googlist ei leidnud õpetust kahjuks.
USB pealt olen proovinud windows 7 64&32bit installeerida - tulutult. Ka xp-d.
Bootcamp lihtsalt ei toimi.
Olen ka teinud eraldi partitsiooni ja sinna tõstnud windowsi installeerimiseks failid.
Äkki on keegi sellega mingil viisil hakkama saanud.
| Kommentaarid: 140 loe/lisa |
123 |
Alari A.
14.06.2017 22:27:00
| Installid plaadilt ? Sellisel juhul tasub suvalist välist USB DVDRW proovida.
543 |
