uus teema   vasta Tarkvara »  Arvutimängude foorum »  DayZ (arma 2 mod) märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 18, 19, 20 ... 119, 120, 121  järgmine
sõnum 24.07.2012 17:03:12 vasta tsitaadiga
Praegu olime vist viiekesi korraga... leidsin ka lõpuks seltskonna üles icon_biggrin.gif
allavett
allavett
sõnum 24.07.2012 17:44:50 vasta tsitaadiga
Paari päeva tagune PvP Chernos:
Twitch.tv/allavett
Kommentaarid: 50 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 47
KrisVr
sõnum 24.07.2012 19:12:22 vasta tsitaadiga
ARMA 2: Combined Operations / Operation Arrowhead / Reinforcements Patch 1.62
ArmA2
As part of our continuous support, we released a new patch for the award-winning tactical military shooter, Arma 2. Patch 1.62 brings a lot of fixes to multiplayer, which – aside for the large scale military battles – will also make zombie hunts much less prone to crashes and should improve server stability. The other highlights of version 1.62 are:
    • Multiplayer optimizations, security and server improvements
    • Overall stability was improved with numerous tweaks and fixes
    • Added new video options (Post-Process Anti-Aliasing, Alpha To Coverage)
    • Additional AI improvements and numerous bug fixes
    • Resolved issues with several training missions
    • Added a lot of new script commands for content makers
For the full list of fixes, be sure to check out 1.62’s README file, which is provided together with the .exe file.
The new update is available for immediate download here.
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 27
DeTHiCa.
DeTHiCa.
sõnum 24.07.2012 19:14:49 vasta tsitaadiga
rene p
sõnum 24.07.2012 20:42:37 vasta tsitaadiga
Day Z Mod To Go Stand-Alone This Year
http://www.techpowerup.com/169466/Day-Z-Mod-To-Go-Stand-Alone-This-Year.html
Kommentaarid: 71 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 68
_joonas
sõnum 24.07.2012 23:41:42 vasta tsitaadiga
Ma ilmselt olen ainus kel ühtegi serverit Rocket launcheris pole? Mängust sisenedes räägib hooldustöödest.
DeTHiCa.
DeTHiCa.
sõnum 24.07.2012 23:50:01 vasta tsitaadiga
ei tea kas on siit läbi käinud, kindlasti paljud pole näinud.
omaenda statse saab varsti igaüks näha.
Voyage
sõnum 25.07.2012 00:08:35 vasta tsitaadiga
nonii poisid, tunnistage üles kes mu telgist AK ja muu kraami pihta pani?
Kommentaarid: 830 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 658
pots4t4j4
sõnum 25.07.2012 00:23:24 vasta tsitaadiga
chesm6mmi
chesm6mmi
sõnum 25.07.2012 00:29:42 vasta tsitaadiga
kas sa mõtled sealt baasist mis elekro kohal? võimalik et mina võtsin, üks ak cobra sai sealt võetud küll, kahjuks ei teadnud et see kellegi oma spetsiaalselt on, ja keegi ei hoiatanud kah =)
Kommentaarid: 110 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 105
karvane
sõnum 25.07.2012 00:54:24 vasta tsitaadiga
Anyhuu, kõik see nänn telkides on meile kõigile + ma ei imesta kui mõni teine sealt ka käib korjamas stuffi. Eriti kui veel peale igat restarti see stuff on tagasi, kuna telke oli süsteemis üle miljoni ja nad lõhkusid ära mingi rocketi loogika (viimane kord see jama juhtus miljoni kasutaja ID'ga)
Üldiselt võiks seal telgis olla lihtsalt n00bi varustust ja mitte hi end gear, kuna siis ta ei ole nii ahvatlev võõrastele playeritele.
robertzon
sõnum 25.07.2012 01:27:47 vasta tsitaadiga
Hetkel kuskil Bor'i lähedal 1,7k bloodiga, suht mõnna.
pots4t4j4
sõnum 25.07.2012 01:30:45 vasta tsitaadiga
DeTHiCa.
DeTHiCa.
sõnum 25.07.2012 01:35:53 vasta tsitaadiga
kui server IP teada siis saab connectida käsurea või six updater abil.
dohc-48v12
Aeg maha 1p
dohc-48v12
sõnum 25.07.2012 01:57:47 vasta tsitaadiga
six loendis pole ka ühtegi serverit. ja endal ip-ga ei hakkagi ühendama.
Miks ADMIN Anti112 ambusib mind? andis 1p cooldowni aga ma ei saa peale selle enam mitteühtegi postitust teha! üks päev ei kuid!
Kommentaarid: 112 loe/lisa Kasutajad arvavad:  :: 6 :: 0 :: 85
DeTHiCa.
DeTHiCa.
sõnum 25.07.2012 02:00:33 vasta tsitaadiga
niimoodi sain mina eilse maintenance ajal sisse:
Tonsor
Tonsor
sõnum 25.07.2012 04:09:54 vasta tsitaadiga
L85A2 AWS käes, M107 kotis, Ghillie ka olemas, ainult Rangefinder heast setist puudu. Feels good.
Kommentaarid: 36 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 32
sõnum 25.07.2012 09:07:09 vasta tsitaadiga
Kui ma disconnectisin eile kui me kambaga seal "punases majas" ootasime kedagi, kas ma uuesti mängu alustades alustan sealt olemasoleva varustusega või jälle kuskil lambi kohas rannikul tühjade kätega?
_joonas
sõnum 25.07.2012 09:15:29 vasta tsitaadiga
Kui sa elus olid, siis ikka jätkad sealt majast.
Voyage
sõnum 25.07.2012 09:53:00 vasta tsitaadiga
chesm6mmi kirjutas:
HaXoR
sõnum 25.07.2012 11:21:47 vasta tsitaadiga
tiido kirjutas:
http://www.gametracker.com/server_info/94.242.227.34:2362/top_players/?query=[HV]&Search=Search&searchipp=50&sort=minutes&order=DESC
Kommentaarid: 52 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 44
karvane
sõnum 25.07.2012 12:08:28 vasta tsitaadiga
Tonsor kirjutas:
Kui sa regularis, siis rangefinder on lihtsalt see eelviimane linnuke (radio on viimane) mis ära checkida, kuna kaugust saad ka niisama teada. HC servus jah rangefinder juba väga practiline icon_smile.gif
AWSiga pole väga mõtet siis üle 300m lasta, sniperile aga spottimis tooliks päris asendamatu icon_smile.gif
tiido
484
tiido
sõnum 25.07.2012 13:04:24 vasta tsitaadiga
Kasulik informatsioon relvade kohta => http://i.imgur.com/ntfgw.jpg
Kommentaarid: 140 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 131
allavett
allavett
sõnum 25.07.2012 13:16:03 vasta tsitaadiga
tiido kirjutas:
Läks esimesse posti.
Kui keegi veel miskit kasuliku teab, mis võiks olla esimeses postis, andku teada.
Voyage
sõnum 25.07.2012 13:32:25 vasta tsitaadiga
Mul kaardiga mingi kala. enne näitas, kus ma kaardil asun kuid enam mitte. Kas ma olen mingit nuppu vajutanud, et minu asukohta ei kuvataks?
allavett
allavett
sõnum 25.07.2012 13:35:08 vasta tsitaadiga
Voyage kirjutas:
Oli sul GPS? Sest ma kuulen esimest korda, et DayZ'is on võimalik oma asukohta kaardil näha. icon_rolleyes.gif
Venturi
Venturi
sõnum 25.07.2012 13:37:37 vasta tsitaadiga
Ja GPS'iga näeb vaid cordse kus asud. Kui just seda tillukest GPSi display siin ei mõelda.
Voyage
sõnum 25.07.2012 13:39:48 vasta tsitaadiga
allavett kirjutas:
Voyage kirjutas:
kusjuures ei olnud ja pole ka nüüd icon_smile.gif Et see oli mingi bug? icon_smile.gif
Oli nii, et avasin enda kaardi siis kuvas minu asukohta kaardil (punase täpina) ja ka suunda (väike kriips tähistas suunda).
Lisaks nägin veel mõnda playerit sellega.
Ja see ei olnud ainult ühel päeval nii. Võimalik, et ei olnud LU15 server vaid miski muu
ollari
ollari
sõnum 25.07.2012 13:59:17 vasta tsitaadiga
Mul ka nii olnud ükskord, kui mapi avasin siis näitas ilusti asukohta ja kriipsuga suuna.
Kujundpudrutaja
Kommentaarid: 90 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 77
Sarin
Sarin
sõnum 25.07.2012 14:02:53 vasta tsitaadiga
Mis kell LU15 serveris päike paistma hakkab ?
Ärge mind tapke, olen healoomulik.
nimi: [hv]Sarin
Kommentaarid: 7 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 7
karvane
sõnum 25.07.2012 14:09:28 vasta tsitaadiga
allavett kirjutas:
Voyage kirjutas:
See on minu teada serveri seadistustes kinni. Mõnes serveris ta näitab sulle täpselt ära kus sa oled ja kui sul on line of sight mõte teise mängija suhtes, siis näitab ka selle ära märkega "Man".
Kunagi leidsin sedasi ATV metsast, juhuslikult ilmus see ikoon kaardile minu lähedal. Samamoodi mingid servud võimaldavad sul ka waypointe kaardile panna ja neid siis lihtsalt järgida.
LU15 ei tohiks seda võimaldada ning seal piirdub GPSi eripära minikaardiga + koordinaatidega, et kus asud ja vaatad siis ise suurema kaardi pealt, kus paikned.
Venturi
Venturi
sõnum 25.07.2012 14:09:53 vasta tsitaadiga
Sarin kirjutas:
nimi: [hv]Sarin
Vist mingi kolme, nelja paiku meie aja järgi. Päris täpselt ei tea. Alati kui viiest sisse loginud olen on igatahes täiesti valge olnud. Samas praegu juba 10/50 ja 3,4 HV'st ka näha, ehk nad oskavad öelda. Vaata siit serveri seisu - http://www.gametracker.com/server_info/94.242.227.34:2362/
LKits
LKits
sõnum 25.07.2012 14:10:14 vasta tsitaadiga
Kaardil enda asukoht on ainult nähtav "regular" serverites.
Veteranis ei näita.
parm
sõnum 25.07.2012 14:19:06 vasta tsitaadiga
Sain eile Armory Co-OP 8 playeri jaoks tööle.
Kui kedagi huvitab siis aegajatl jooksutan seda, hetkel ka, lisainfo mumbles (serveri ip, port ja parool)
Armory multiplayer siis NWAF-il kus kõik kola tankid, kopterid, autod, relvad jne on katsetamiseks. Eile kahekesi sai juba nalja meeletult seal icon_biggrin.gif
Kommentaarid: 57 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 56
Lovvi
Lovvi
sõnum 25.07.2012 15:16:15 vasta tsitaadiga
parm kirjutas:
Kuidas seal masinad respawnida ilma mapi restartita? Muidu tore map jah, saab niisama lollitada
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 58
karvane
sõnum 25.07.2012 15:28:22 vasta tsitaadiga
Ma sain sellise teate DayZ foorumis ühe teise pisi "klanni" poolt.
Hi, I heard you are from HV? I want to ask u, if u are more like a bandit clan, or more like a friendly one? We are 2 Medics on LU15 and we could operate together if u want.
Just massage me
Oleme vist ikka bandiidid rohkem?
ZuluXE
ZuluXE
sõnum 25.07.2012 15:36:56 vasta tsitaadiga
karvane, vasta, et pooled on friendlyd.
Vaata asukohta
Kommentaarid: 102 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 87
karvane
sõnum 25.07.2012 15:41:27 vasta tsitaadiga
See nii keeruline öelda, et pooled on friendlyd. Vahepeal on olnud momente, kus mul endal ka hea tuju, et näe, n00b jookseb ja ma ei lase maha teda, ainult et 10 sekka hiljem kuulen laske ja ikka jäi mõnele meie hv'lasele hambusse.
Ei saa lihtsalt garanteerida, et tal tuleb positiivne kogemus meiega olema.
sõnum 25.07.2012 15:43:14 vasta tsitaadiga
Mina pole bandiit siiamaani veel olnud, ei tahakski tegelt... mulle meeldiks see mod ikkagi rohkem co-op kui pvp stiilis icon_smile.gif
allavett
allavett
sõnum 25.07.2012 15:44:45 vasta tsitaadiga
ZuluXE kirjutas:
karvane
sõnum 25.07.2012 15:54:34 vasta tsitaadiga
carlking kirjutas:
Saad vabalt co-opida teistes servudes, LU15 on lihtsalt co-op voicecommiga ja eestlastega icon_biggrin.gif
sõnum 25.07.2012 15:58:29 vasta tsitaadiga
karvane kirjutas:
carlking kirjutas:
Eks tuleb siis lähiajal headset osta... igapäev kahjuks nagunii mängima ei jõua
chesm6mmi
chesm6mmi
sõnum 25.07.2012 16:15:35 vasta tsitaadiga
karvane kirjutas:
Just massage me
noo mul poleks küll miskit vastu koostööle, aga võid öelda jah et tihti on nii et kui keegi kaasa jooksub siis pärast lööb nö noa selga, a kui normaalsed kutid ja tõesti tahavad koostööd teha siis pigem ikka friendlid thumbs_up.gif
Qufi
sõnum 25.07.2012 16:48:47 vasta tsitaadiga
http://www.dayzblog.com/dayz-real-chernarus/
Origin: Qufi
pots4t4j4
sõnum 25.07.2012 17:34:24 vasta tsitaadiga
Link
piraat262
piraat262
sõnum 25.07.2012 18:17:30 vasta tsitaadiga
karvane kirjutas:
Just massage me
Kommentaarid: 75 loe/lisa Kasutajad arvavad:  :: 1 :: 3 :: 69
Venturi
Venturi
sõnum 25.07.2012 18:43:10 vasta tsitaadiga
karvane kirjutas:
Just massage me
Kui HV tagi pole ja käsklustele ei allu saab tina, "meedik" või mitte "meedik"
Velociraptor
Velociraptor
sõnum 25.07.2012 20:12:14 vasta tsitaadiga
Kas nime saab muuta üldse või ? Ei saanud nagu seal player profile all
Kommentaarid: 32 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 30
chesm6mmi
chesm6mmi
sõnum 25.07.2012 20:14:30 vasta tsitaadiga
tee uus lihtsalt, kõik muu jääb alles nagu...
pots4t4j4
sõnum 25.07.2012 20:27:29 vasta tsitaadiga
kas ainult mul või ka teistel graafika täiega glitchib dayz mängides ? mujal seda nagu täheldanud ei ole ja vahel ei glitchi mitu päeva?
uus teema   vasta Tarkvara »  Arvutimängude foorum »  DayZ (arma 2 mod) mine lehele eelmine  1, 2, 3 ... 18, 19, 20 ... 119, 120, 121  järgmine
