24.07.2012 16:03:12
Praegu olime vist viiekesi korraga... leidsin ka lõpuks seltskonna üles
| Kommentaarid: 92 loe/lisa |
79 |
allavett
24.07.2012 16:44:50
Paari päeva tagune PvP Chernos:
_________________ Twitch.tv/allavett |
| Kommentaarid: 49 loe/lisa |
46 |
KrisVr
24.07.2012 18:12:22
ARMA 2: Combined Operations / Operation Arrowhead / Reinforcements Patch 1.62
ArmA2
As part of our continuous support, we released a new patch for the award-winning tactical military shooter, Arma 2. Patch 1.62 brings a lot of fixes to multiplayer, which – aside for the large scale military battles – will also make zombie hunts much less prone to crashes and should improve server stability. The other highlights of version 1.62 are:
• Multiplayer optimizations, security and server improvements
• Overall stability was improved with numerous tweaks and fixes
• Added new video options (Post-Process Anti-Aliasing, Alpha To Coverage)
• Additional AI improvements and numerous bug fixes
• Resolved issues with several training missions
• Added a lot of new script commands for content makers
For the full list of fixes, be sure to check out 1.62’s README file, which is provided together with the .exe file.
The new update is available for immediate download here. |
| Kommentaarid: 30 loe/lisa |
DeTHiCa.
24.07.2012 18:14:49
oppaa
136 |
rene p
68 |
_joonas
24.07.2012 22:41:42
| Ma ilmselt olen ainus kel ühtegi serverit Rocket launcheris pole? Mängust sisenedes räägib hooldustöödest.
DeTHiCa.
24.07.2012 22:50:01
ei tea kas on siit läbi käinud, kindlasti paljud pole näinud.
omaenda statse saab varsti igaüks näha.
136 |
Voyage
24.07.2012 23:08:35
| nonii poisid, tunnistage üles kes mu telgist AK ja muu kraami pihta pani?
| Kommentaarid: 806 loe/lisa |
638 |
pots4t4j4
24.07.2012 23:23:24
milline see sinu telk on nimega kohe ?
401 |
chesm6mmi
24.07.2012 23:29:42
| kas sa mõtled sealt baasist mis elekro kohal? võimalik et mina võtsin, üks ak cobra sai sealt võetud küll, kahjuks ei teadnud et see kellegi oma spetsiaalselt on, ja keegi ei hoiatanud kah =)
102 |
karvane
24.07.2012 23:54:24
Anyhuu, kõik see nänn telkides on meile kõigile + ma ei imesta kui mõni teine sealt ka käib korjamas stuffi. Eriti kui veel peale igat restarti see stuff on tagasi, kuna telke oli süsteemis üle miljoni ja nad lõhkusid ära mingi rocketi loogika (viimane kord see jama juhtus miljoni kasutaja ID'ga)
Üldiselt võiks seal telgis olla lihtsalt n00bi varustust ja mitte hi end gear, kuna siis ta ei ole nii ahvatlev võõrastele playeritele.
robertzon
25.07.2012 00:27:47
| Hetkel kuskil Bor'i lähedal 1,7k bloodiga, suht mõnna.
pots4t4j4
25.07.2012 00:30:45
hetkel ju maintenance kuidas sa siis mängid ?
401 |
DeTHiCa.
25.07.2012 00:35:53
| kui server IP teada siis saab connectida käsurea või six updater abil.
136 |
dohc-48v12
Aeg maha 1p
25.07.2012 00:57:47
six loendis pole ka ühtegi serverit. ja endal ip-ga ei hakkagi ühendama.
_________________ Ime tala, Nagu ime kepike.
Miks ADMIN Anti112 ambusib mind? andis 1p cooldowni aga ma ei saa peale selle enam mitteühtegi postitust teha! üks päev ei kuid! |
6 :: |
85 |
DeTHiCa.
25.07.2012 01:00:33
niimoodi sain mina eilse maintenance ajal sisse:
136 |
Tonsor
25.07.2012 03:09:54
| L85A2 AWS käes, M107 kotis, Ghillie ka olemas, ainult Rangefinder heast setist puudu. Feels good.
| Kommentaarid: 36 loe/lisa |
25.07.2012 08:07:09
Kui ma disconnectisin eile kui me kambaga seal "punases majas" ootasime kedagi, kas ma uuesti mängu alustades alustan sealt olemasoleva varustusega või jälle kuskil lambi kohas rannikul tühjade kätega?
79 |
_joonas
25.07.2012 08:15:29
| Kui sa elus olid, siis ikka jätkad sealt majast.
Voyage
25.07.2012 08:53:00
| chesm6mmi kirjutas: |
| kas sa mõtled sealt baasist mis elekro kohal? võimalik et mina võtsin, üks ak cobra sai sealt võetud küll, kahjuks ei teadnud et see kellegi oma spetsiaalselt on, ja keegi ei hoiatanud kah =) |
ei, telk ei ole baasis metsas on
tegelt ma ei teagi, kus HV baas on
638 |
HaXoR
25.07.2012 10:21:47
See CMG mis meid lubas hävitada, palju õnne neile.
| Kommentaarid: 52 loe/lisa |
44 |
karvane
25.07.2012 11:08:28
| Tonsor kirjutas: |
| L85A2 AWS käes, M107 kotis, Ghillie ka olemas, ainult Rangefinder heast setist puudu. Feels good. |
Kui sa regularis, siis rangefinder on lihtsalt see eelviimane linnuke (radio on viimane) mis ära checkida, kuna kaugust saad ka niisama teada. HC servus jah rangefinder juba väga practiline
AWSiga pole väga mõtet siis üle 300m lasta, sniperile aga spottimis tooliks päris asendamatu
tiido
484
| Kommentaarid: 139 loe/lisa |
130 |
allavett
25.07.2012 12:16:03
Läks esimesse posti.
Kui keegi veel miskit kasuliku teab, mis võiks olla esimeses postis, andku teada.
46 |
Voyage
25.07.2012 12:32:25
| Mul kaardiga mingi kala. enne näitas, kus ma kaardil asun kuid enam mitte. Kas ma olen mingit nuppu vajutanud, et minu asukohta ei kuvataks?
638 |
