uus teema   vasta Tarkvara »  Arvutimängude foorum »  DayZ (arma 2 mod) märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 36, 37, 38 ... 239, 240, 241  järgmine
sõnum 24.07.2012 16:03:12 vasta tsitaadiga
Praegu olime vist viiekesi korraga... leidsin ka lõpuks seltskonna üles icon_biggrin.gif
allavett
allavett
sõnum 24.07.2012 16:44:50 vasta tsitaadiga
Paari päeva tagune PvP Chernos:
Twitch.tv/allavett
Kommentaarid: 49 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 46
KrisVr
sõnum 24.07.2012 18:12:22 vasta tsitaadiga
ARMA 2: Combined Operations / Operation Arrowhead / Reinforcements Patch 1.62
ArmA2
As part of our continuous support, we released a new patch for the award-winning tactical military shooter, Arma 2. Patch 1.62 brings a lot of fixes to multiplayer, which – aside for the large scale military battles – will also make zombie hunts much less prone to crashes and should improve server stability. The other highlights of version 1.62 are:
    • Multiplayer optimizations, security and server improvements
    • Overall stability was improved with numerous tweaks and fixes
    • Added new video options (Post-Process Anti-Aliasing, Alpha To Coverage)
    • Additional AI improvements and numerous bug fixes
    • Resolved issues with several training missions
    • Added a lot of new script commands for content makers
For the full list of fixes, be sure to check out 1.62’s README file, which is provided together with the .exe file.
The new update is available for immediate download here.
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 27
DeTHiCa.
DeTHiCa.
sõnum 24.07.2012 18:14:49 vasta tsitaadiga
Kommentaarid: 144 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 136
rene p
sõnum 24.07.2012 19:42:37 vasta tsitaadiga
Day Z Mod To Go Stand-Alone This Year
http://www.techpowerup.com/169466/Day-Z-Mod-To-Go-Stand-Alone-This-Year.html
Kommentaarid: 71 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 68
_joonas
sõnum 24.07.2012 22:41:42 vasta tsitaadiga
Ma ilmselt olen ainus kel ühtegi serverit Rocket launcheris pole? Mängust sisenedes räägib hooldustöödest.
DeTHiCa.
DeTHiCa.
sõnum 24.07.2012 22:50:01 vasta tsitaadiga
ei tea kas on siit läbi käinud, kindlasti paljud pole näinud.
omaenda statse saab varsti igaüks näha.
Voyage
sõnum 24.07.2012 23:08:35 vasta tsitaadiga
nonii poisid, tunnistage üles kes mu telgist AK ja muu kraami pihta pani?
Kommentaarid: 800 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 633
pots4t4j4
sõnum 24.07.2012 23:23:24 vasta tsitaadiga
chesm6mmi
chesm6mmi
sõnum 24.07.2012 23:29:42 vasta tsitaadiga
kas sa mõtled sealt baasist mis elekro kohal? võimalik et mina võtsin, üks ak cobra sai sealt võetud küll, kahjuks ei teadnud et see kellegi oma spetsiaalselt on, ja keegi ei hoiatanud kah =)
Kommentaarid: 107 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 102
karvane
sõnum 24.07.2012 23:54:24 vasta tsitaadiga
Anyhuu, kõik see nänn telkides on meile kõigile + ma ei imesta kui mõni teine sealt ka käib korjamas stuffi. Eriti kui veel peale igat restarti see stuff on tagasi, kuna telke oli süsteemis üle miljoni ja nad lõhkusid ära mingi rocketi loogika (viimane kord see jama juhtus miljoni kasutaja ID'ga)
Üldiselt võiks seal telgis olla lihtsalt n00bi varustust ja mitte hi end gear, kuna siis ta ei ole nii ahvatlev võõrastele playeritele.
robertzon
sõnum 25.07.2012 00:27:47 vasta tsitaadiga
Hetkel kuskil Bor'i lähedal 1,7k bloodiga, suht mõnna.
pots4t4j4
sõnum 25.07.2012 00:30:45 vasta tsitaadiga
DeTHiCa.
DeTHiCa.
sõnum 25.07.2012 00:35:53 vasta tsitaadiga
kui server IP teada siis saab connectida käsurea või six updater abil.
dohc-48v12
Aeg maha 1p
dohc-48v12
sõnum 25.07.2012 00:57:47 vasta tsitaadiga
six loendis pole ka ühtegi serverit. ja endal ip-ga ei hakkagi ühendama.
Miks ADMIN Anti112 ambusib mind? andis 1p cooldowni aga ma ei saa peale selle enam mitteühtegi postitust teha! üks päev ei kuid!
Kommentaarid: 112 loe/lisa Kasutajad arvavad:  :: 6 :: 0 :: 85
DeTHiCa.
DeTHiCa.
sõnum 25.07.2012 01:00:33 vasta tsitaadiga
niimoodi sain mina eilse maintenance ajal sisse:
Tonsor
Tonsor
sõnum 25.07.2012 03:09:54 vasta tsitaadiga
L85A2 AWS käes, M107 kotis, Ghillie ka olemas, ainult Rangefinder heast setist puudu. Feels good.
Kommentaarid: 36 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 32
sõnum 25.07.2012 08:07:09 vasta tsitaadiga
Kui ma disconnectisin eile kui me kambaga seal "punases majas" ootasime kedagi, kas ma uuesti mängu alustades alustan sealt olemasoleva varustusega või jälle kuskil lambi kohas rannikul tühjade kätega?
_joonas
sõnum 25.07.2012 08:15:29 vasta tsitaadiga
Kui sa elus olid, siis ikka jätkad sealt majast.
Voyage
sõnum 25.07.2012 08:53:00 vasta tsitaadiga
chesm6mmi kirjutas:
HaXoR
sõnum 25.07.2012 10:21:47 vasta tsitaadiga
tiido kirjutas:
http://www.gametracker.com/server_info/94.242.227.34:2362/top_players/?query=[HV]&Search=Search&searchipp=50&sort=minutes&order=DESC
Kommentaarid: 52 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 44
karvane
sõnum 25.07.2012 11:08:28 vasta tsitaadiga
Tonsor kirjutas:
Kui sa regularis, siis rangefinder on lihtsalt see eelviimane linnuke (radio on viimane) mis ära checkida, kuna kaugust saad ka niisama teada. HC servus jah rangefinder juba väga practiline icon_smile.gif
AWSiga pole väga mõtet siis üle 300m lasta, sniperile aga spottimis tooliks päris asendamatu icon_smile.gif
tiido
484
tiido
sõnum 25.07.2012 12:04:24 vasta tsitaadiga
Kasulik informatsioon relvade kohta => http://i.imgur.com/ntfgw.jpg
Kommentaarid: 139 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 130
allavett
allavett
sõnum 25.07.2012 12:16:03 vasta tsitaadiga
tiido kirjutas:
Läks esimesse posti.
Kui keegi veel miskit kasuliku teab, mis võiks olla esimeses postis, andku teada.
Voyage
sõnum 25.07.2012 12:32:25 vasta tsitaadiga
Mul kaardiga mingi kala. enne näitas, kus ma kaardil asun kuid enam mitte. Kas ma olen mingit nuppu vajutanud, et minu asukohta ei kuvataks?
uus teema   vasta Tarkvara »  Arvutimängude foorum »  DayZ (arma 2 mod) mine lehele eelmine  1, 2, 3 ... 36, 37, 38 ... 239, 240, 241  järgmine
