Ertai
27.02.2011 14:59:10
väike vahekokkuvõte |
väike vahekokkuvõte siis, mis hetkel teada on
* Your character will learn the acient language of the dragons. The phrases can include up to three words and are mostly found inscribed on dungeon walls. The phrases will allow you to do certain things such as slow down time, knock back foes, and more.
* The phrases are mapped to the right bumper/R1 and you'll learn one word at a time for each phrase. Learning more words within the phrase will allow the spell to be either more powerful or longer.
* Finishing moves will be available for your characters in battle. The article describes a finishing move where you plunge "your saber through a foe's chest".
* Telekinesis will be an available spell, allowing those of you who are rather lazy the ability to pick up items or objects to launch at your enemies.
* Runes can be cast and used as traps. The article describes a situation where you can throw a frost rune to the ground, and if an enemy walks across it, pieces of ice will impale them.
* A perk is available that gives your enemies deeper cuts. A strategy talked about is simply hitting your opponent with a solid strike, then hiding as they slowly bleed to death.
* Around 80 different spells will be featured in the game.
* If you find yourself below average at using weapons, you should still be able to survive in combat using offensive and defensive magic.'
* The two handed mechanic Bethesda introduces in Skyrim for fighting will remind a ton of gamers of the BioShock series.
* If you happen to scale one of the many peaks in Skyrim, all of the snow you see is totally dynamic.
* All of the established Elder Scrolls races will return in Skyrim.
* The race you pick in the beginning will only effect your baseline stats, as what you actually do in the world with your combat, magic, and stealth will help shape your character instead.
* The "perks" system will still allow you to make more direct changes to your character as well. As opposed to Fallout, perks in Skyrim are on a much smaller scale.
* Graphics engine for Elder Scrolls V: Skyrim is "all but written from scratch".
* Cities in Skyrim will all be unique, shying away from the reusing of assets we popularly saw in Oblivion.
* There are 120 dungeons, with each one typically having its own feel. Far more traps and puzzles are featured in them too.
* While you may be able to avoid them at some points in your journey, you're going to have to take dragons down at some point, and it won't be an easy task.
* Dragons aren't scripted, they'll cruise the entire world and occassionally land on different objects or areas. Make one mad and it'll swoop down to take you on.
* New to Skyrim also is the "Radiant Story system". An example listed in the article is, "If you discard a weapon on the ground to free up inventory space, you might find that a nearby character approaches you. If they like you, they might offer the sword back to you in case you dropped it by accident; if they're neutral toward you, they might ask if they can have it; and if they dislike you, they might simply nab the weapon and take off. Kill that character and the Radiant Story system will search for his or her relatives, and may even send one of them in pursuit of you to avenge the murder."
draakonite puhul ma loodan, et nad ei oleks väga nõrgad.. nii esimesed 15-20 levelit üritaks igal võimalusel nende eest minema joosta
Selline overpowered dragonslayer olla mingi level 5 juba on suht igav.
Muidugi draakonid võiksid ja ilmselt ongi erineva tugevusega ka
| Kommentaarid: 52 loe/lisa |
47 |
Dude .
27.02.2011 15:42:19
Ertai, millegi pärast arvan ma, et mäng hakkabki pihta draakoni tapmisega.
_________________ TALUSILDID |
| Kommentaarid: 16 loe/lisa |
16 |
Ertai
27.02.2011 16:12:02
| Dude . kirjutas: |
| Ertai, millegi pärast arvan ma, et mäng hakkabki pihta draakoni tapmisega. |
See oleks paras bollocks küll
Aga spekuleerin, et oled vang - nagu eelmises kahes mängus (traditsioon )
siis ehk ronid Greybeardide juurde kuhugi mäe otsa (vennad, kes jagavad Dragon Shoutite värki ja teavad Dragonbornidest üht-teist)
Samas sain aru, et lubatakse rohkem vabadust - et mainquestiga ei peaks tegelema koguaeg ja see ei käi pinda (nagu oblivionis)
Morrowindist võetakse ka kõvasti eeskuju, mis mulle sobib. (graafikapoole pealt peaks olema oblivion+ )
Tore oleks, et oled kuskil mingi suvavend töötaja (rassist olenemata) ja asi hakkab hargnema.
Aga aega on sinna kõvasti veel ja ilmselt enne E3 (juunikuus) ei saa midagi rohkem väga teada, vähemalt gameplay poole pealt, eks veidi infot ikka tilgutatakse..
ise hakkasin Morrowindi nüüd uuesti klõbistama ja jätsin DA:O ja ME2 (mõlemad 2nd playthrough) pooleni.
47 |
madness
27.02.2011 16:15:45
Re: väike vahekokkuvõte |
| Ertai kirjutas: |
palju Oblivionis oli ?
| Kommentaarid: 13 loe/lisa |
Dude .
27.02.2011 16:29:14
Ertai, see vangi asi pidi olema juba kinnitatud.
Aga jamh, mäng tuleb ikkagi pauguga avada ning nagu ma aru sain, siis tegelane ise alguses ei tea, et ta dragonborn on. Parim viis teada saamiseks olekski kui mingisugune draakon ründab vms. Aga toh, see niisama spekulatsioon Kuigi kuskil Todd rääkis ka veel mängu alguse kohta, et kuidas suht suur osa inimesi juba plaadi sisse pannes teavad, et nende tegelane on dragonborn vms.
16 |
kakuke
27.02.2011 17:19:22
| Dude . kirjutas: |
| Ertai Kuigi kuskil Todd rääkis ka veel mängu alguse kohta, et kuidas suht suur osa inimesi juba plaadi sisse pannes teavad, et nende tegelane on dragonborn vms. |
Ma arvan, et see on parem variant, kui et poes on n+1 ühesugust halli karpi lihtsa times new roman font kirjaga Mäng ja arvutisse sisestades saad alles teada, kas seekord mängid Morrowindi või Barbie ja Keni uusi seiklusi.
| Kommentaarid: 18 loe/lisa |
14 |
Dude .
27.02.2011 18:26:12
kakuke, wah?
Mul ei ole selle vastu mitte midagi, et mängjad teavad midagi mängust eelnevalt. Ma lihtsalt mainisin, et Todd rääkis mängu algusest ühes videos. Et kuidas pole mõtet story suhtes selle dragonborn asjaga venitada, kuna paljud juba teavad.
16 |
Araablane
27.02.2011 23:48:39
Fuck me, kui see ainult korralikult töötaks ka, ennemgi selliseid asju lubatud
| Kommentaarid: 30 loe/lisa |
28 |
Ertai
47 |
veso
28.02.2011 11:19:46
Awesome
LightsabeR
| Kommentaarid: 14 loe/lisa |
14 |
Paganarh
02.03.2011 09:57:23
good1 kindel GOTY
| Kommentaarid: 15 loe/lisa |
Araablane
02.03.2011 12:04:34
Väga hea
28 |
Tonsor
02.03.2011 13:06:50
| Oblivion, Fallout, Neverwinter Nights ja muud taolised on mind siiani külmaks jätnud, aga sellest tundub küll tulevat üks pükse märgav mäng.
| Kommentaarid: 36 loe/lisa |
Auron
02.03.2011 13:16:23
Oot kas mingit ametlikku sneak peek või mingit trailerit ei pidand nüüd äsja tulema
133 |
Midigi
34 |
Cb4
06.03.2011 23:57:33
Jälle põnev
_________________ Ma ei ole agressiivne juht, olen lihtsalt võistlushimuline.
Did i ever tell you the definition of "Insanity"? |
| Kommentaarid: 113 loe/lisa |
95 |
denis28
07.03.2011 18:27:10
krt juutuub on aeglaseks jäänud
| Kommentaarid: 67 loe/lisa |
07.03.2011 18:47:07
| denis28 kirjutas: |
krt juutuub on aeglaseks jäänud  |
| ot: |
Flash 10.2 mitmed kaeblevad probleemide üle.Pigem selles asi ma arvan |
| Kommentaarid: 92 loe/lisa |
madfury
| Kommentaarid: 28 loe/lisa |
28 |
Auron
19.03.2011 09:36:20
| Heh mul see PC geimer täitsa olemas. Enivei üks mõnusamaid asju mida on tehtud on see, et enam pole major ja minor skill süsteemi kus expi annnavad ainult valitud skillid vaid expi annab kõik mida kasutad.
133 |
19.03.2011 09:54:41
| Auron kirjutas: |
| Heh mul see PC geimer täitsa olemas. Enivei üks mõnusamaid asju mida on tehtud on see, et enam pole major ja minor skill süsteemi kus expi annnavad ainult valitud skillid vaid expi annab kõik mida kasutad. |
Jah see on tõesti hea, et ei pea mängu alustades valima, et vot ma tahan nüüd vibumees olla.Pärast tuleb välja, et ei meeldigi see üldse
madfury
19.03.2011 11:43:10
Ehh, ma eelistaks traditsioonilist arendust pigem, kuid seda on vanillast palju tahta. Usun, et see moditakse kiiresti ära. Ma näen siin probleemi selles, et oletame teed melee tüüpi, leiad mingi rämedalt hea kirve ja siis kukud sellega äsama, axe läheb üles ja mingi ajapärast on kirves kergelt vananenud, kuid jube hea mõõk jäi teele. Nüüd enne, kui mõõka normaalselt kasutada saab, tuleb spämmida kuskil seda. Reeglina RPG-des ma üritan hoida 2te relva/loitsu maksimumi lähedal juhuks kui peaks mõni resisti tüüp teele tekkima (slash vs pierce või fire vs cold). Kui kõik munandid ühte korvi panna, siis korralikult disainitud RPG-s tõmmatakse sulle mingis punktis kott pähe
Ja no ei meeldi mulle level scaling, isegi FO-s ei meeldinud. Nii FO3 kui FO:NV olid mid-game kaklused juba täielikud teerullid ja seda ilma maximise karakterita. Eks siis ole asi ka raskusastme implementeerimise taga, kuid FO lõppu mängisin pigem story ja exploration põrast, kui combati pärast...
_________________ Avatar by Flacko |
28 |
Markxy10
28.03.2011 01:06:23
PC gamerist
| you can no longer run backwards to get away from a fight while still defending yourself. Your reverse movement is much slower, so you have to decide: stay and fight, or turn and flee? |
oblivionis oli see minu kõige parem viis vaenlasi tappa, vibuga, selg ees joostes. athletics oli vist 98 ja marksman 103 vms (koos ülikonnaga) kui ma mängu lõpetasin. Keegi ei saanud mulle midagi teha
| Bethesda are considering adding an ability to combine different spells to make new ones. |
...pls make it happen. Ise asi kui hästi välja tuleb.
| Kommentaarid: 11 loe/lisa |
EvilKatarn
diivanilill
28.03.2011 06:46:51
| Markxy10 kirjutas: |
PC gamerist
oblivionis oli see minu kõige parem viis vaenlasi tappa, vibuga, selg ees joostes. athletics oli vist 98 ja marksman 103 vms (koos ülikonnaga) kui ma mängu lõpetasin. Keegi ei saanud mulle midagi teha  |
Lihtne võis olla, aga kindlasti on see ka liiga gamey tegevus. Päriselt oleks sellist jebimist üpris naljakas vaadata.
Hea, et ära muudavad.
81 |
Auron
28.03.2011 12:44:26
Jah see on hea, et selgees liikudes samakiire pole kui niisama joostes. Jällegi peaks mainima kui eduline DMoMM oli oma käitumiselt- suurepäraselt oli tehtud see kus kuigi mäng FPS siis nö. Oli tunda, et tegelasel on ka reaalselt nigu mingisugune raam olemas mitte tegelane ei koosne keset ekraani rippuvast crosshairist. Teisisõnu kiiresti liigutades nö. vaade liikus kätest eraldi mitte ei liikund kõik robotlikult ja jäigalt kaasa, kõiksugused liikumised omasid sellist fluid motionit jne. Võtta see asi ja teha paremaks annaks fantast asja teha.
Aga üldiselt ei kurda sellepõhjal mida praegu nähtud ja kuuldud. Küsimus on pigem selles kas selles ilusas maailmas piisavalt inteaktiivsust on ja kas piisavalt erinevaid asju teha on. Näiteks selle viimase kohapealt oblivion võrreldes morrowindiga oli ilka suht feil, eriti mis puudutas seda, et kõik unikaalsed jubinad said shrine questidest ja kuskilt kivialt polnud lootust midagi vägaspetsi leida, rääkimata sellest, et varakult ei andnud kuskilt mõnda kõrgema astmega relva saada (morrowindis võisid kohe alguses omale ebony või daedric seti kokku korjata kui teadsid khu minna).
133 |
Ertai
28.03.2011 14:29:14
Eks nad on vaikselt ikka vihjanud, et kiikavad sinna Morrowindi poole tagasi. Mängu graafika peaks tulema küll Oblivion+, see on täiesti piisav ka. Aga mängu art uniqueness võiks tõesti olla Morrowindi pühendumise pealt õpitud.
Kõige suurem hirm on need Radiant questid jne., et päris palju queste arvuti ju chari järgi kohandab.. loodetavasti asi töötab, et basic peaks juba paigas olema, aga veidi siis nipet-näpet. Random queste ei tahaks küll, et tekitataks, võib maailma üsna untsu keerata.
Igatahes hopes are high
47 |
flameas
28.03.2011 15:08:14
Seda on nii kaua tehtud, et poolik vms nagu Dragon age II ei saa see olla Usun et pikalt tehtud kaunikene. Huvitav kas ülikoolist õppepuhkust saab novembris
| Kommentaarid: 91 loe/lisa |
81 |
Markxy10
28.03.2011 18:40:17
Üks asi mis mind Oblivionis häiris oli see, et vibuga laskmine oli liiga täpne, üliinimlik. See täpsus võiks oleneda ikka Marksman skillist. Oblivionis lasin ühe lasuga banditi max distance pealt maha, mis on seal mingi 400+ meetrit äkki.
Skyrim-is tulevad ikka vibud ?
madfury
28.03.2011 19:55:30
Markxy10, Tulevad. Soovitan natuke lugeda selle kohta, kui vibutamine huvitab. Lühidalt siis on muutus päris radikaalne - vibutamine on tegelt isegi tugevam, kui Oblivionis, kuid rate of fire on väga kõvasti maha keeratud. Ehk siis bow on kas kuskilt mättalt snipemiseks või kakluse alustamiseks, seda selg ees jooksmist + valang-valang-valang värki enam olla ei tohiks. Ma arvan, et sihtimine, võnkumine jne. sõltuvad skillist, aga see on minu arvamus.
28 |
Archangel
28.03.2011 20:23:10
Nii nagu peaks. Vanillas oli vibu küll paras nali Oblivionis. Muidugi ei tea üldse kedagi, kes Vanillat enam mängida tahaks... ever.
Praegu toksin veidi OOO mod'i ja Qarl texture packiga. Silmailu tonnide viisi, jookseb nagu siidi ning raske nagu vana põrgu. Mingi 3h mängitud ning siiani ei saa kellegist peale mõne roti jagu. - Läbi häda suutsin midme potioniga ühe skeletoni maha virutada. Vist mingi lvl 3 juba aga vähe kasu... Ehk nagu öö ja päev võrreldes Vanillaga kus võisid mängu alguses juba suhtkoht ülbitseda...
Vibu peakski ikka selline olema, mis enamik tavalisi inimesi paarist paugust teise ilma saadab kui õigesse kohta pihta saad ning vastasel vaid light armor peal. Oleks ülikõva kui nõrgemad vibud vs Steel armoriga vastased ei teekski midagi. Plönn vastu armorit nooled puruks ja kõik.
Kujutan ette, et vibumehe mängimine peakski olema selline, et hiilid ringi ja siis kuskilt metsatuka vahelt, puu tagant keerad vastasele noole kuklasse sujuvalt. Kena critical niigi võimsa damage otsa ning peakski kogu moos olema. Vbl vastane kergelt stunnitud alguses sellest rünnakust ning siis lased järgmise otse silmade vahele näiteks. Oleks ikka realistlikum küll kui lennata mingile bandiitide cambile peale ning kütta nooli vasakule ja paremale ning siis selg ees minema joosta ja veel tulistada nii, et kõik kohad pärast nooli täis...
Kindlasti peaksid mingit statid kogu seda laskmist muutma, kuid mitte ka oluliselt palju. Muidu tekib lihtsalt tobe tunne, kus sihid jumalasta täpselt, kuid ei tee mingit dämmi. A'la strenght võiks piirata seda kui kaugele jõuad vibu pingutada. Madal strenght ning lihtsalt dämm väike. Madal dex ning sihik veidi kõigub. Muud nagu väga polegi.
Saan aru küll, et RPG ning vaja stat based asju ikka omada - kuid naljakas ka kui mängid first person's ning kõik, mis teed langeb lõpuks ikka täringuviskele. FPS vaates tahaks, et mängija enda skillil oleks ka ikka märgatav mõju.
| Kommentaarid: 25 loe/lisa |
25 |
Erx15
28.03.2011 22:37:44
Mina küll olen nõus vanillat mängida, täitsa kobe tegelikult(kuigi marksman on jah suht nali).
Skyrimi võiks panna ka Fallout 3-st pärit limb cripple-i, et kõigepealt lased vandile jalga, tüüp hakkab lonkama, siis sihid täpselt ja lõpetad headshotiga samas võiksid erinevatesse kehaosadesse lastud nooled teha ka erinevat dämmi.
| Kommentaarid: 17 loe/lisa |
16 |
Redikate
29.03.2011 01:43:15
Loodetavasti on Skyrim'i devvid samamoodi arvanud nagu siin eespool jutuks.
Oleksin samuti huvitatud, et kuigi see vibutamine võiks oleneda ka statidest, siis enda skill peaks ka suurt rolli mängima.
Minupoolest võib selle vibu sihik level 1 juures kasvõi üle screeni väriseda, aga kui ma ikkagi suudan õigel momendil noole teele saata, siis ootan ka tulemust.
Seda huvitavam ja raskem on oma rünnakuid planeerida ja teostada, sest võimalus, et esimene nool läheb mööda ja sind märgatakse on suur.
Mis puutub stre'sse, siis tõesti oleks kaugus üks lahendus (sealt tuleb ka dmg erinevus, sest mida kaugemale nool lendab, seda tugevamini see tabab lähemal olevaid targete = suurem dmg neile)
Loomulikult ei tohiks puudu olla kenad ning sädelevad maagia vibud. Poleks ilmselt midagi paremat kui saata üks põlev nooleke üle mäeserva mõnele skeletonile ribidevahele. Samuti ei ütleks ära ühest noolest draakoni silmevahel.
_________________ http://nodejs.org/
"I'm also a person. Programming is just one thing I do." |
| Kommentaarid: 34 loe/lisa |
33 |
Ertai
29.03.2011 02:14:42
Jah, devvid juba öelnud ka kuskil, et vibud on sellised suudad 1-2 laksu panna, aga siis ole valmis juba, et ollakse melees. Osavamad muidugi ronivad majakatusele või kuhu iganes ja snipe'ivad sealt, aga ehk on ka selle vastu midagi välja mõeldud. Vibu on palju kõvema latakaga = võib 1-2 laksuga maha tappa küll, aga selle reload pidi ikka mõnusalt aeglane olema ja sihtiminegi tehti kõvasti raskemaks.
Ei taha ära sõnada, aga usun juba praegu sellesse mängu. TES on ikka TES ja seda ei ole väga võimalik ära nu**ida ma loodan
minu aasta oodatuim mäng igatahes, mass effect 3 ja witcher on kohe kannul. DA:II juba kukkus kolinal sellest listist paraku peale demot.
47 |
LightsabeR
29.03.2011 02:52:07
| Ertai kirjutas: |
TES on ikka TES ja seda ei ole väga võimalik ära nu**ida ma loodan |
Kõike on võimalik ära nu**ida. :p Seda on erinevad developerid ja publisherid juba korduvalt tõestanud.
Kuid peab lootma, et ehk TES seeria veel seda teed ei lähe.
14 |
Redikate
29.03.2011 15:01:27
LightsabeR räägib tõtt, kahjuks on võimalik kõik ära rikkuda.
Kuid siinkohal loodan isegi, et äkki leidub ka neid developereid kes teavad mis on hea ja jäävad selle juurde. Kuigi ma pean tunnistama, et ma pole ühtegi TES'i mängu läbi teinud, siis mängurõõmu on neis kõigis olnud. Oblivion läks aina huvitavamaks, mida rohkem ma seda uuesti alustasin ja Morrowind oli lihtsalt kuld.
Skyrim'i pilte vaadates ma juba kujutan ette, mis käike, tunneleid ning huvitavaid itemeid / mobe võib leida nendest avaratest ja ilusatest kohtadest. Eks see avastamise rõõm ongi kõige suurem ja huvitavam ning ometigi viisid paljud questid kohtadesse, millest ma olin muidu väga lähedalt mööda jalutanud, kuid siiski mitte märganud.
33 |
Markxy10
29.03.2011 15:45:41
Ei tea, kas mingisuguseid online-feature'sid ka tuleb ?
Minuarust võiks mingi co-op või arena moodi värk tulla, aga jällegi, see võib kas ülihea või BS tulla.
Redikate
29.03.2011 16:01:02
Vaevalt. TES'il pole kunagi olnud online-feature (afaik?) ja ei looda eriti et ka nüüd tuleb. Muidugi oleks puhas kuld, kui oleks co-op.
33 |
Markxy10
29.03.2011 16:45:02
| Kui isegi tuleb, siis oleks imo kõvasti vähem piraatlust, sest siis oleks mille nimel osta. Mitte muidugi, et single player seda ostu väärt ei oleks. Aga piraadid saavad kerge klikiga sp cracki peale ja rahu majas. Mp-ga oleks teine jutt.
Ertai
29.03.2011 17:14:57
Ma pigem mõtlesin seda, et see aasta ma panustaks oma raha Skyrimi peale (tuntud devvidest), et nemad mängu persse ei keera.
Mass Effect 3 suhtes on mul kerged eelarvamused, kui juba co-opi tahetakse lisada jne., no mine tea, aga DA:II feili vaadates tekib hirm ka ME3 puhul
47 |
Sakurai
30.03.2011 11:28:30
| Seda mängu ei jõua küll ära oodata.
SirAskAlot
30.03.2011 13:01:03
| Ertai kirjutas: |
Ma pigem mõtlesin seda, et see aasta ma panustaks oma raha Skyrimi peale (tuntud devvidest), et nemad mängu <b>piixu</b> ei keera.
Mass Effect 3 suhtes on mul kerged eelarvamused, kui juba co-opi tahetakse lisada jne., no mine tea, aga DA:II feili vaadates tekib hirm ka ME3 puhul  |
Ma panustaks pigem sellele , et ME:3 pole RPG huvilistel isegi mõtet piraatida.
MPZ
30.03.2011 14:10:47
PC gamerist
...pls make it happen. Ise asi kui hästi välja tuleb. |
Kui natukenegi midagi taolist tehakse nagu Magicka's siis peaks see spellide värk suht epic tulema. Jääb ootama.
| Kommentaarid: 22 loe/lisa |
22 |
Erx15
30.03.2011 21:24:18
| Huvitav kas lisatakse ka New Vegasest tuttav Hardcore mode? Muudaks mängu kindlasti palju huvitavamaks.
16 |
marcor1
31.03.2011 10:42:01
| Erx15 kirjutas: |
| Huvitav kas lisatakse ka New Vegasest tuttav Hardcore mode? Muudaks mängu kindlasti palju huvitavamaks. |
Miks tahetakse mikromajandamist - kohustuslik söömine, magamine, joomine, kingapaelte sidumine?
Huvitav oleks, et lisataks New Vegasest tuttav stiil - vali enda poolele ja vastu keda tahad. Mitte "kill the great evil" + möödaminnes püüa kalu ja too kadunud müts koopast ära.
_________________ War. War never changes.
Malkavian: [to a stop sign] No, you stop! |
| Kommentaarid: 70 loe/lisa |
aivo80
31.03.2011 11:11:00
| marcor1, miks mitte endale suppi keeta, kui see täidab paremini kõhtu (annab rohkem elu punkte), kui toored kartulid ja vesi?
| Kommentaarid: 31 loe/lisa |
29 |
Scart
31.03.2011 11:16:28
| New Vegase hardcore mode oli kergelt öeldes nali. Küll õiged asjad modidega mängu lisatakse mõne aja jooksul.
101 |
madfury
31.03.2011 11:56:43
marcor1, Ega keegi ei käsi seda peale keerata, kui ei meeldi. Minule meeldivad küll nö. hardcore raskusastmed RPG-des, sunnib taktikaliselt lähenema asjadele ning ei saa oma tooni willy-nilly üles ehitada, tuleb mõelda. Kas just supikeetmine on see õige "extra" mis hardocre modega kaasa peaks tulema, on küsitav, kuid see, et sulle ei meeldi, ei tähenda, et teistele ei meeldi....
28 |
marcor1
31.03.2011 20:17:05
| aivo80 kirjutas: |
| marcor1, miks mitte endale suppi keeta, kui see täidab paremini kõhtu (annab rohkem elu punkte), kui toored kartulid ja vesi? |
Kui see on võimalus siis on see hea ... kui kohustus siis veits nüri.
Ning mtak, pole supikeetmisel mitte midagi ühist, "madfury" poolt mainitud "taktikalise lähenemisega"...
...kui see pole just supp, mis serveeritakse lossi valvuritele ja tekib räige pa5anteeria - seetõttu saad varasalve ja relvakambri rahus tühjaks varastada.
madfury
31.03.2011 20:53:15
marcor1, Vegase hardcore settingust meeldis mulle näiteks väga, et ammol on raskus. See söögi-joogi teema...noh, minul see mängimist raskemaks ei teinud ja ma olen nõus Scartiga, et üldpildis oli Vegase hardcore mode nali. Ei pea ma ka õigeks lihtsalt vaenlaste hp üles pumbata või armorit juurde kütta. Just sellised gimmickud nagu ammo raskus on need, mida ma ootaks.
Küll aga meeldib mulle su mõte idee pasataudi levitamisest Esmatähtis on ikkagi l00t ning nodi tuleb kokku hoorata vahendeid valimata ja vajadusel kõikidest üle rullides.
28 |
