uus teema   vasta Tarkvara »  Arvutimängude foorum »  NBA 2K9 märgi kõik teemad loetuks
mine lehele 1, 2  järgmine
MONX33
sõnum 06.10.2008 11:42:07 NBA 2K9 vasta tsitaadiga
Kuna PC peale on tulemas revolutsioonile korvpalli simulaator NBA 2k9 mille seeria on 7 aastat järjest saanud erinevaid tiitleid siis mõtlesin ka siia ühe teema teha.
See aasta tuleb 2k9 PC peale mis on Xbox 360 port, ehk siis xboxi 360 välja nägemist featuridega ja lisadega mäng jõuab ka PC peale
www.2ksports.com/games/nba2k9
Pilte, videosi, jne:
http://www.operationsports.com/game.php?id=502
Key features:
2K HD – Breathtaking action in full HD resolution brings you
radically improved facial textures and eye movement, true-to-life crowd
reactions and celebration sequences, and much more.
Styles Upon Styles
– New Signature Defensive Styles and
more Signature Shots, dunks and free throws give you EVEN MORE
distinctive player styles.
Adaptive AI – Now your teammates and your opponents read,
react, and adjust in real time to match your gameplay strategies.
The Association 2.0 - All-new NBA.com interface, Player
Ambitions, Player Scouting, and more options for the casual player make
this the most robust Franchise mode ever
1) System Requirements
1.1 Operating Systems
Microsoft(R) Windows(R) 2000
Microsoft(R) Windows(R) XP (SP 2)
Microsoft Vista(TM)
1.2 Minimum System Requirements
CPU: Pentium 4 2.4 GHz Single Core processor or equivalent (2.8 GHz for Vista)
RAM: 512 MB or more (1 GB for Vista)
Disc Drive: 8x or faster DVD drive
Hard Drive: 10.5 GB or more free space
Video: DirectX 9.0c compatible (see below)
Sound: DirectX 9.0c compatible
Input: Keyboard or dual-analog gamepad
Video card with 128 MB or more memory and one of the following chipsets is required:
ATI x1300 or greater;
NVIDIA 6600 or greater;
DirectX 9.0c compatible card with Shader Model 3.0 support.
Important Note: Game requires Internet connection for activation
1.3 Recommended System Requirements
CPU: 3 GHz Dual Core processor or equivalent
RAM: 2 GB
Video: Shader Model 3.0 support with 512 Ram (Nvidia(R) Geforce(R) 7900 GT or better)
Sound: 100% DirectX 9.0c compatible sound card
Input: Dual-analog gamepad
Release dates:
EU: 10 okt (XBOX360, PS2, PS3); 17.okt (PC)
US: 7.okt (PS2, PS3, XBOX360), 21.okt (PC)
EDIT:
* Does not support any online functionality, including but not limited to online games, 2K Share, ReelMaker or Living Rosters
** Internet access required to install and authenticate game
viimati muutis MONX33 27.10.2008 11:18:18, muudetud 3 korda
Renq
Renq
sõnum 06.10.2008 16:54:22 vasta tsitaadiga
täna otsisin netist andmeid, nba 2k9 kohta ja tundub et tulebki PC'le, kindlalt päeva parim uudis icon_smile.gif
Does not support any online functionality <--- võrgumängu tugi puudub? :O
jako07
jako07
sõnum 06.10.2008 18:25:44 Re: NBA 2K9 vasta tsitaadiga
MONX33 kirjutas:
Key features:
Minimum Requirements:
OS: Windows Vista, XP, or 2000 CPU | CPU: Pentium 4 2.4 GHz Single Core
processor or equivalent (2.8 GHz for Vista) RAM: 512 MB or more (1 GB for Vista) Disc Drive: 8x or
faster DVD drive | Hard Drive: 10.5 GB or more free space | Video: DirectX 9.0c compatible * | Sound:
DirectX 9.0c compatible | Input: Keyboard or dual-analog gamepad
* Video card with 128 MB or more memory and one of the following chipsets is required: ATI x1300
or greater | NVIDIA 6600 or greater | DirectX 9.0c compatible card with Shader Model 3.0 support.
Ma olen näinud NBA 2k8 graafikat ja tahaks näha, kuidas see jookseb arvuti peal, loodetavasti pole väga kokku hoitud pildi kvaliteedi alandamisega.
Ja muidugi- parim aeg NBA 2k9 avaldada, sest see aasta ju NBA Live ei tule icon_biggrin.gif
Renq
Renq
sõnum 06.10.2008 18:48:10 Re: NBA 2K9 vasta tsitaadiga
jako07 kirjutas:
lootetavasti pole väga kokku hoitud pilti kvaliteedi alandamisega. ühesõnaga sa loodad, et on detaile kõvasti vähemaks keeratud?
minu jaoks ei ole nba live seeriat eriti pärast 05't olnud eriti 07/08, kui hakkas tulema see freestyle superstari teema ja igast lisavidinad, mäng ise oli aga suht praht.
live'is oli ka probleem, suurte skooridega, kuna ma armastasin mängida 12min veeranditega
ühesõnaga GTA 4, NBA 2K9, ja mõned head mängud veel... CHRISTMAS COMES EARLY THIS YEAR icon_biggrin.gif
MAGNA
MAGNA
sõnum 06.10.2008 19:43:59 vasta tsitaadiga
Ülejäänud nagu vastab nõuetele aga jahm.. Peaks maybe uue videokaardi sebima
jako07
jako07
sõnum 06.10.2008 21:17:40 Re: NBA 2K9 vasta tsitaadiga
[quote="Renq"]
jako07 kirjutas:
Ma just loodan, et ei ole. Sõnastus failis veidi.
Renq
Renq
sõnum 06.10.2008 22:45:19 Re: NBA 2K9 vasta tsitaadiga
[quote="jako07"]
Renq kirjutas:
jako07 kirjutas:
no tänapäeva mänguarvutid ei jää mitte millegi poolest xboxile või PS3'le alla, vastupidi hoopis, nii et loodetavasti tuleb üks masterpiece sellest mängust.
MONX33
sõnum 08.10.2008 19:27:25 vasta tsitaadiga
Renq kirjutas:
Online osa puudub jah PC'l aga selle eest need online featured: living roster, 2kinsider jne on olemas icon_smile.gif
Mis mulle on natuke tähtsamad kui see online osa.
Üks review kah siis: http://xbox360.ign.com/articles/916/916726p1.html
Üks kuulujutt käis ka läbi et järgmine aasta võib olla ei tule NBA 2k10 PS3 peale, kuna selle tegemine pidi olema kallim kui X360 ja PC peale portimine
Renq
Renq
sõnum 08.10.2008 22:25:11 vasta tsitaadiga
MONX33 kirjutas:
Renq kirjutas:
oot, a mis online osa siis puudu on? see et ei saa teiste tüüpidega läbi neti mängida??? see on küll pagana suur miinus.
jako07
jako07
sõnum 08.10.2008 22:43:33 vasta tsitaadiga
isegi IP kaudu mitte?
mõttetu veidi ...
Renq
Renq
sõnum 08.10.2008 23:14:32 vasta tsitaadiga
ja mina veel mõtlesin, et selle mängu ostan tõesti originaali. arvatavasti ostan ikkagist, eriti kui hind on tõesti nii nagu usa's 19.99$, siis on see väga hea hind, võrreldes enamus teise ülehinnatud mängudega icon_smile.gif
MONX33
sõnum 11.10.2008 11:25:19 vasta tsitaadiga
PC release date lükkus EU's natuke edasi
EU: 17.oct (PC)
NB!: Enamus klipid on võetus PS3'lt, niiet kui valite ostmist siis soovitan PS3 valiku välja jätta ja valida X360 või siis PC.
ENJOY!!!
When scoring once on a single possession is never enough
http://www.youtube.com/watch?v=ydXRtCPf7Es
http://www.youtube.com/watch?v=PQBu2AZZsK8
http://www.youtube.com/watch?v=IoZzuEq-P6g
Go further than ever before with the ball
http://www.youtube.com/watch?v=NfGbDIS5Bg4
Rebounding fundamentals Sim style in action
http://www.youtube.com/watch?v=2qz2dxuBem0
I'm scared!!! The Defense is a ghost
http://www.youtube.com/watch?v=bFYHX0xI9vQ
http://www.youtube.com/watch?v=2o1lDEp2tGc
http://www.youtube.com/watch?v=zsCu53Ekgec
http://www.youtube.com/watch?v=t2YsvsoGaps
http://www.youtube.com/watch?v=exR4k66lSYI
You can now swat at flies instead of the ball defense
http://www.youtube.com/watch?v=Kvim6F4qNlA
http://www.youtube.com/watch?v=7FX7Mi23AEE
http://www.youtube.com/watch?v=LfZLwcLnY6s
http://www.youtube.com/watch?v=TjyawtB7SHg
Not even the Floor Sweeper can stop Lebron
http://www.youtube.com/watch?v=uJ-ONa1dRyQ
No court necessary
http://www.youtube.com/watch?v=mE3U7UsmKBc
Lag OFFline....so you can now experience Online play offline
http://www.youtube.com/watch?v=NkIRFXH_j9E
Barron Davis does the moonwalk
http://www.youtube.com/watch?v=sc09WVPupjY
Not even the backboard can stop Kobe
http://www.youtube.com/watch?v=fVAYg8ge2eA
I lost my head and skin playing NBA 2K9
http://www.youtube.com/watch?v=161fIV6tNeQ
Your NEW 2K9 Camera views
http://www.youtube.com/watch?v=lg44Xqm0FWs
Your NEW 5vs5 online play
http://www.youtube.com/watch?v=_AWBXc8vzdU
Meet the Guys at 2K responsible for all this and hear their new direction of the game
"Make game more accessible to users that aren't interested in running plays" (aka...Welcome cheesers, we will make you good at this game!!!)
http://www.youtube.com/watch?v=Adz8TccjvZA
Don't be a dork!!!
http://www.youtube.com/watch?v=_3wLdPWZSX8
http://www.youtube.com/watch?v=36YEXjIODWY
MMx
MMx
sõnum 11.10.2008 16:49:57 vasta tsitaadiga
vaatasin 4-5 esimest videot ära ja mäng tundub ikka jube kräpp...
pallikandmised, jooksud, kohutav AI kaitses jne jne...buge rohkem kui kokku lugeda jõuaks
ja see peaks olema 2009 aastale vastav korvapalli tase arvutimaailmas???
Kommentaarid: 79 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 69
Renq
Renq
sõnum 11.10.2008 17:13:19 vasta tsitaadiga
see on juba mõnda aega teada, et PC versioon ei tule koos konsoolidega, ma loodan väga, et hiljem tulev PC versioonis on neid asju parandatud.
MONX33
sõnum 11.10.2008 20:45:57 vasta tsitaadiga
http://www.andrico.ee/pood/product_info.php/products_id/11099
HIND: 399kr
recent
recent
sõnum 11.10.2008 21:08:52 vasta tsitaadiga
mõnus =)
Kommentaarid: 43 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 41
Renq
Renq
sõnum 11.10.2008 21:16:01 vasta tsitaadiga
MONX33 kirjutas:
HIND: 399kr
ilusti on hinnale 100% otsa keevitatud.
http://take2store.stores.yahoo.net/nba2k9pcp.html
MMx
MMx
sõnum 11.10.2008 21:42:03 vasta tsitaadiga
MONX33 kirjutas:
HIND: 399kr
siiski seda seal kohal ju veel ei ole...
kirjas et orienteeruv saabumise aeg 22.10.2008
aga kui tõesti asi nii bugine ka pc peal siis on isegi 399 palju küsitud
MONX33
sõnum 11.10.2008 23:51:16 vasta tsitaadiga
MMx kirjutas:
MONX33 kirjutas:
HIND: 399kr
Kohal muidugi ei ole, ma ütlesin et andrico lehel on olemas võimalus tellida.
Need videod mis panin siia ennem oli võetud 99& kui mitte 100% PS3'lt, X360 (online pidi olema vussis seal ainult vms.) pidi olema OK, niiet PC peaks kah olema OK, kui just nad portimisel vigu ei ole sisse teinud. Arvestades seda et online PC'l ei ole siis enamus bugid on välja jäetud, õnneks.
Infoks veel:
** NOTICE: Product offered subject to your acceptance of the 2K Games License (see www.take2games.com/eula and Steam Subscriber Agreement ("SSA"). You must activate this product via the Internet by registering for a Steam account and accepting the SSA. Please see www.steampowered.com/agreement to view the SSA prior to purchase. If you do not agree with the provisions of the 2K Games License or SSA, you should return this game unopened to your retailer in accordance with their return policy. Any online features require internet connection, may be retired on 30 days notice, and may not be available to all users.
Jux
sõnum 17.10.2008 14:10:56 vasta tsitaadiga
MONX33 kirjutas:
Aga oskab keegi sellist asja kommenteerida, et näiteks mul on kodus 2 arvutit - laua arvuti ja läpp ning kodus olles mängiksin laua arvutiga ja kui reisin vms, siis sooviks seda mängu läpil mängida. Seda arvesse võttes, kas mul õnnestub sellisel juhul seda mängu mõlemale arvutile registreerida?
Renq
Renq
sõnum 18.10.2008 09:01:29 vasta tsitaadiga
Jux kirjutas:
MONX33 kirjutas:
no steami puhul on ju see, et paned cd key sinna oma konto alt ja tirid mängu kuhu tahad. nagu counter strike'iga oli. eks näis kuidas sellega on.
henri200
sõnum 18.10.2008 09:27:39 vasta tsitaadiga
Samamoodi on, paned koodi (või ostad läbi steami), ja siis on see sul mängude all. Saad ükskõik mis arvuti alt ligi icon_wink.gif
Renq
Renq
sõnum 21.10.2008 16:53:56 vasta tsitaadiga
mäng olemas, hüvasti EA Sports ja LIVE seeria. 2 mängu tegin praegu, väga kõva on. nüüd ootan vaid, kuni see poodi jõuab, siis saab ausal teel ka asja omandada:P
kuna asi on xboxi port, siis on natukene keerukas mängus ringi liikuda esialgu, a küll ära harjub. ise mängin logitech cordless rumblepad 2'ga.
MONX33
sõnum 21.10.2008 23:23:43 vasta tsitaadiga
Renq kirjutas:
Täpselt sama siin, sai ka mäng muretsetud ja päeval proovisin kuskil 3h ja tõesti suuuuuurepärane mäng soovitan soojalt kõigile minu profiilis oleva masinaga mängin kõik MAX (+ MSAA ja AA mis seal peale sai panna) @ 1280x1024 ja ~120fps thumbs_up.gif. Nüüd peab 29.10.08 ootama kui Andrico'st originaali saan, seda mängu peab toetama(Y).
Renq
Renq
sõnum 22.10.2008 00:03:56 vasta tsitaadiga
ma väga loodan, et järgmine aasta tuleb samuti arvutile ja siis ka online mängu võimalus.
MONX33
sõnum 22.10.2008 00:10:51 vasta tsitaadiga
Renq kirjutas:
loodame aga mind eriti see online osa ei huvitagi vaid hoopis see living roster, see tundub huvitav lisa olevat icon_razz1.gif
Renq
Renq
sõnum 22.10.2008 15:50:33 vasta tsitaadiga
see mäng on lihtsalt wicked... ma alustasin täna association mode'i lakersiga ja tegin esimese mängu blazersi vastu... ei ole midagi öelda, klass omaette.
MONX33
sõnum 22.10.2008 15:58:40 vasta tsitaadiga
Renq kirjutas:
Kas sul on ka niiet pidevalt CPU loobib suvalt kohalt kõik sisse või on see minu kaitse tehnika viga?
Renq
Renq
sõnum 22.10.2008 16:01:02 vasta tsitaadiga
MONX33 kirjutas:
Renq kirjutas:
loopima hakkasid nad siis, kui ma taktikat vähe muutsin, siis jäi pidevalt mõni mees kolmese tagant vabaks ja siis laksasid valusalt. a muidu ei old hullu.
okei, nüüd päris kossu mängima.
jako07
jako07
sõnum 22.10.2008 18:24:01 vasta tsitaadiga
Kust on võimalik netist osta ?
Krediitkaart olemas.
henri200
sõnum 22.10.2008 19:28:06 vasta tsitaadiga
jako07, http://www.game.co.uk/PC/Sport/Basketball/~r337360/NBA-2K9/?s=NBA%202K9
Renq
Renq
sõnum 24.10.2008 15:48:36 vasta tsitaadiga
MONX33 kirjutas:
Renq kirjutas:
minumeelest ei ole living rosterit PC versioonis.
MONX33
sõnum 25.10.2008 11:08:39 vasta tsitaadiga
Renq kirjutas:
MONX33 kirjutas:
Renq kirjutas:
TruePlaya
TruePlaya
sõnum 26.10.2008 19:26:23 vasta tsitaadiga
Kas siis PC versal on samad glitchid ja bugid, mis ma praegu seal youtube videotes nägin??? Ja kas mingid patchid ka juba väljas on?
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 27
defqon
defqon
sõnum 26.10.2008 20:11:54 vasta tsitaadiga
KUIDAS ALLIE OOPI TEHA SAAB PC VERSOL?
MONX33
sõnum 26.10.2008 21:34:39 vasta tsitaadiga
TruePlaya kirjutas:
Need videod mis ennem panin siia teemasse on tehtud PS3'lt kuigi jah seda inbound bug eksisteerib ka PC peal aga selleks on rohi olemas. Muidu on mäng tõesti kõva ja nauditav thumbs_up.gif
defqon kirjutas:
Post-Up+Pass nupud pead ise vaatama mis sul sätistatud on.
Renq
Renq
sõnum 26.10.2008 21:57:34 vasta tsitaadiga
krt, mul tekksi siuke jama association mode'is, et trade'ides ei lase enam trade pickide peale valida ja kui 3 meeskonna vahel on trade' sis ei lase valida, mis mansale mingi mees läheb.
TruePlaya
TruePlaya
sõnum 26.10.2008 22:06:58 vasta tsitaadiga
MONX33, Krt see usb bug-lag on küll jama...
Ja mis rohi täpsemalt?
Ja kas kellelgi on häid slidereid anda?
Puhastan, hooldan, parandan, uuendan ja koostan lauaarvuteid. Lisainfo PS-i teel!
defqon
defqon
sõnum 26.10.2008 22:22:41 vasta tsitaadiga
selline küsimus siis veel, et mis aitaks selle vastu kui mäng jookseb liiga kiiresti nagu ebanormaalselt kiiresti. ja kui mängu tempo madalamaks keerad siis nt vabavisete ajal on pall nagu õhupall liialt aeglane
btw, nüüd loadib ka imelikult kiiresti.. introd ja asjad käivad varasemast poole kiiremini ära jne. kuskilt oleks nagu pitchi juurde keeratud kogu mängule nii menüüle kui gameplayle:D
Renq
Renq
sõnum 26.10.2008 22:27:36 vasta tsitaadiga
TruePlaya kirjutas:
usb bug lag??
ma läksin slideritesse ja tõmbasin nees kohad, kus olid success 50'lt alla poole, 40'le ja natukene peale, teisi ei puutunud, ei hakanud süvenema.
TruePlaya
TruePlaya
sõnum 26.10.2008 22:30:29 vasta tsitaadiga
jah mul usb klaveriga mäng lagib menüüs täiega paned tavalise otsaga klaveri taha ja kõik puhas...
MONX33
sõnum 26.10.2008 22:43:18 vasta tsitaadiga
TruePlaya kirjutas:
Inbound bug tekib siis kui sa lähed mängima Tutorial modes 5on5, seal pidi mingine süsteem teine olema ja saveb settingutesse ära ja siis kui läheb päris 5on5 mängima kasutab neid ja tekib see bug.
http://2ksports.com/forums/showthread.php?t=190935
Slideritest kasutan praegu ja tunduvad täitsa ok olevat
http://www.operationsports.com/forums/nba-2k-sliders/275705-blue-lightnings-sliders-2ksports-forum.html
45/40
50/50
50/45
50/40
40/30
30/30
70/70
50/50
45/43
50/50
25/25
75/75
50/50
80/70
65/40
60/60
50/50
50/45
50/40
50/50
40/40
50/50
50/50
55/40
40/15
50/50
60/40
50/50
50/25
50/75
50/45
50/30
25/25
50/40
50/55
50/55
20/50
50/40
50/50
55/65
65/50
45/45
70/45
60/60
TruePlaya
TruePlaya
sõnum 26.10.2008 23:22:13 vasta tsitaadiga
Tänud thumbs_up.gif Ise otsisn ka sealt samast aga ei leidnud millegi pärast...
Nüüd tuleks vist mingi pult osta kuna klaviatuuriga on seda mängu suht imelik mängida vms?
Oskab keegi soovitada?
MONX33
sõnum 26.10.2008 23:35:35 vasta tsitaadiga
TruePlaya kirjutas:
http://www.zebra.ee/S2/Product.aspx?iShopID=1&iItemID=66249
Renq
Renq
sõnum 26.10.2008 23:58:01 vasta tsitaadiga
MONX33 kirjutas:
TruePlaya kirjutas:
http://www.logitech.com/index.cfm/gaming/pc_gaming/gamepads/devices/287&cl=US,EN
ja mul selline, lihtsalt öeldes sweet. klaveriga ei kipu küll enam pärast pulti fifat, nba'd mängima icon_razz.gif
TruePlaya
TruePlaya
sõnum 27.10.2008 16:41:57 vasta tsitaadiga
Ise olen koguaeg Live klaveriga teinud...7 a. mängisin online liigat ka (euroslam.com'is) aga see aasta augustis pandi liiga kinni kuna aktiivsus oli nuli lähedal..kahju... ning Live ei tulnud PC peale ka see aaasta...seega 2k on mul hetkel veel väga võõras...
MONX33
sõnum 27.10.2008 18:02:00 vasta tsitaadiga
TruePlaya kirjutas:
Sama siis 2K suhtes, ma ka esimest korda mängin seda seeriat ja tegelt mulje on on hea kuigi vaidedavalt jäi 2K mängu tegemisega aeg napiks. kuna tõesti kahtlasi buge on mängus mis ennem ei olnud
Renq
Renq
sõnum 27.10.2008 19:12:26 vasta tsitaadiga
mina olen live'i alates 99'nda aasta mängust mänginud ja puldi ostsin põhiliselt 08 jaoks, et oleks mugavam mängida ja siis ma mängisin mingi mõned mängud vist ainult, ei suutnud lihtsalt....halb oli. ja k29 bugidele vaatamata on tegu parima kossumänguga arvutile. minumeelest on ps3'le patch väljas. loodetavasti mehed ei maga ja töötavad ka pc versiooni parandamise kallal.
MONX33
sõnum 27.10.2008 21:58:12 vasta tsitaadiga
Renq kirjutas:
PC suhtes nüüd natuke kahtlen et nad ei tee patchi, kuna 2K otsustas üldse mängu X360 pordiga teha ainult väikeste bugidega siis peaks patch kah tulema ainult sõltub kui palju asju see muudab.
http://2ksports.com/forums/showthread.php?t=193090
rico_ee
sõnum 27.10.2008 23:38:50 vasta tsitaadiga
defqon kirjutas:
sama mul.
uus teema   vasta Tarkvara »  Arvutimängude foorum »  NBA 2K9 mine lehele 1, 2  järgmine
