MONX33
06.10.2008 10:42:07
NBA 2K9 |
Kuna PC peale on tulemas revolutsioonile korvpalli simulaator NBA 2k9 mille seeria on 7 aastat järjest saanud erinevaid tiitleid siis mõtlesin ka siia ühe teema teha.
See aasta tuleb 2k9 PC peale mis on Xbox 360 port, ehk siis xboxi 360 välja nägemist featuridega ja lisadega mäng jõuab ka PC peale
www.2ksports.com/games/nba2k9
Pilte, videosi, jne:
http://www.operationsports.com/game.php?id=502
Key features:
2K HD Breathtaking action in full HD resolution brings you
radically improved facial textures and eye movement, true-to-life crowd
reactions and celebration sequences, and much more.
Styles Upon Styles New Signature Defensive Styles and
more Signature Shots, dunks and free throws give you EVEN MORE
distinctive player styles.
Adaptive AI Now your teammates and your opponents read,
react, and adjust in real time to match your gameplay strategies.
The Association 2.0 - All-new NBA.com interface, Player
Ambitions, Player Scouting, and more options for the casual player make
this the most robust Franchise mode ever
1) System Requirements
1.1 Operating Systems
Microsoft(R) Windows(R) 2000
Microsoft(R) Windows(R) XP (SP 2)
Microsoft Vista(TM)
1.2 Minimum System Requirements
CPU: Pentium 4 2.4 GHz Single Core processor or equivalent (2.8 GHz for Vista)
RAM: 512 MB or more (1 GB for Vista)
Disc Drive: 8x or faster DVD drive
Hard Drive: 10.5 GB or more free space
Video: DirectX 9.0c compatible (see below)
Sound: DirectX 9.0c compatible
Input: Keyboard or dual-analog gamepad
Video card with 128 MB or more memory and one of the following chipsets is required:
ATI x1300 or greater;
NVIDIA 6600 or greater;
DirectX 9.0c compatible card with Shader Model 3.0 support.
Important Note: Game requires Internet connection for activation
1.3 Recommended System Requirements
CPU: 3 GHz Dual Core processor or equivalent
RAM: 2 GB
Video: Shader Model 3.0 support with 512 Ram (Nvidia(R) Geforce(R) 7900 GT or better)
Sound: 100% DirectX 9.0c compatible sound card
Input: Dual-analog gamepad
Release dates:
EU: 10 okt (XBOX360, PS2, PS3); 17.okt (PC)
US: 7.okt (PS2, PS3, XBOX360), 21.okt (PC)
EDIT:
* Does not support any online functionality, including but not limited to online games, 2K Share, ReelMaker or Living Rosters
** Internet access required to install and authenticate game
viimati muutis MONX33 27.10.2008 10:18:18, muudetud 3 korda |
Renq
06.10.2008 15:54:22
täna otsisin netist andmeid, nba 2k9 kohta ja tundub et tulebki PC'le, kindlalt päeva parim uudis
Does not support any online functionality <--- võrgumängu tugi puudub? :O
jako07
06.10.2008 17:25:44
Re: NBA 2K9 |
| MONX33 kirjutas: |
Key features:
Minimum Requirements:
OS: Windows Vista, XP, or 2000 CPU | CPU: Pentium 4 2.4 GHz Single Core
processor or equivalent (2.8 GHz for Vista) RAM: 512 MB or more (1 GB for Vista) Disc Drive: 8x or
faster DVD drive | Hard Drive: 10.5 GB or more free space | Video: DirectX 9.0c compatible * | Sound:
DirectX 9.0c compatible | Input: Keyboard or dual-analog gamepad
* Video card with 128 MB or more memory and one of the following chipsets is required: ATI x1300
or greater | NVIDIA 6600 or greater | DirectX 9.0c compatible card with Shader Model 3.0 support.
Ma olen näinud NBA 2k8 graafikat ja tahaks näha, kuidas see jookseb arvuti peal, loodetavasti pole väga kokku hoitud pildi kvaliteedi alandamisega.
Ja muidugi- parim aeg NBA 2k9 avaldada, sest see aasta ju NBA Live ei tule
| Kommentaarid: 19 loe/lisa |
19 |
Renq
06.10.2008 17:48:10
Re: NBA 2K9 |
| jako07 kirjutas: |
Ja muidugi- parim aeg NBA 2k9 avaldada, sest see aasta ju NBA Live ei tule  |
lootetavasti pole väga kokku hoitud pilti kvaliteedi alandamisega. ühesõnaga sa loodad, et on detaile kõvasti vähemaks keeratud?
minu jaoks ei ole nba live seeriat eriti pärast 05't olnud eriti 07/08, kui hakkas tulema see freestyle superstari teema ja igast lisavidinad, mäng ise oli aga suht praht.
live'is oli ka probleem, suurte skooridega, kuna ma armastasin mängida 12min veeranditega
ühesõnaga GTA 4, NBA 2K9, ja mõned head mängud veel... CHRISTMAS COMES EARLY THIS YEAR
MAGNA
06.10.2008 18:43:59
Hea uudis jah .
Ei tea kas radeon 9100 seriesiga ei venita seda välja ?
Ülejäänud nagu vastab nõuetele aga jahm.. Peaks maybe uue videokaardi sebima
Vana raal mis sa ikka tahad .
jako07
06.10.2008 20:17:40
Re: NBA 2K9 |
[quote="Renq"]
| jako07 kirjutas: |
| lootetavasti pole väga kokku hoitud pilti kvaliteedi alandamisega. ühesõnaga sa loodad, et on detaile kõvasti vähemaks keeratud? |
Ma just loodan, et ei ole. Sõnastus failis veidi.
Videotest nähtu põhjal muidugi superb, nagu alati
19 |
Renq
06.10.2008 21:45:19
Re: NBA 2K9 |
[quote="jako07"]
| Renq kirjutas: |
| jako07 kirjutas: |
Videotest nähtu põhjal muidugi superb, nagu alati  |
no tänapäeva mänguarvutid ei jää mitte millegi poolest xboxile või PS3'le alla, vastupidi hoopis, nii et loodetavasti tuleb üks masterpiece sellest mängust.
MONX33
08.10.2008 18:27:25
| Renq kirjutas: |
Does not support any online functionality <--- võrgumängu tugi puudub? :O |
Online osa puudub jah PC'l aga selle eest need online featured: living roster, 2kinsider jne on olemas
Mis mulle on natuke tähtsamad kui see online osa.
Üks review kah siis: http://xbox360.ign.com/articles/916/916726p1.html
Üks kuulujutt käis ka läbi et järgmine aasta võib olla ei tule NBA 2k10 PS3 peale, kuna selle tegemine pidi olema kallim kui X360 ja PC peale portimine
Renq
08.10.2008 21:25:11
| MONX33 kirjutas: |
| Renq kirjutas: |
Üks kuulujutt käis ka läbi et järgmine aasta võib olla ei tule NBA 2k10 PS3 peale, kuna selle tegemine pidi olema kallim kui X360 ja PC peale portimine |
oot, a mis online osa siis puudu on? see et ei saa teiste tüüpidega läbi neti mängida??? see on küll pagana suur miinus.
jako07
08.10.2008 21:43:33
isegi IP kaudu mitte?
mõttetu veidi ...
19 |
Renq
08.10.2008 22:14:32
ja mina veel mõtlesin, et selle mängu ostan tõesti originaali. arvatavasti ostan ikkagist, eriti kui hind on tõesti nii nagu usa's 19.99$, siis on see väga hea hind, võrreldes enamus teise ülehinnatud mängudega
MONX33
MMx
11.10.2008 15:49:57
vaatasin 4-5 esimest videot ära ja mäng tundub ikka jube kräpp...
pallikandmised, jooksud, kohutav AI kaitses jne jne...buge rohkem kui kokku lugeda jõuaks
ja see peaks olema 2009 aastale vastav korvapalli tase arvutimaailmas???
| Kommentaarid: 81 loe/lisa |
Renq
11.10.2008 16:13:19
see on juba mõnda aega teada, et PC versioon ei tule koos konsoolidega, ma loodan väga, et hiljem tulev PC versioonis on neid asju parandatud.
MONX33
recent
11.10.2008 20:08:52
| mõnus =)
| Kommentaarid: 43 loe/lisa |
41 |
Renq
MMx
11.10.2008 20:42:03
siiski seda seal kohal ju veel ei ole...
kirjas et orienteeruv saabumise aeg 22.10.2008
aga kui tõesti asi nii bugine ka pc peal siis on isegi 399 palju küsitud
MONX33
11.10.2008 22:51:16
| MMx kirjutas: |
aga kui tõesti asi nii bugine ka pc peal siis on isegi 399 palju küsitud |
Kohal muidugi ei ole, ma ütlesin et andrico lehel on olemas võimalus tellida.
Need videod mis panin siia ennem oli võetud 99& kui mitte 100% PS3'lt, X360 (online pidi olema vussis seal ainult vms.) pidi olema OK, niiet PC peaks kah olema OK, kui just nad portimisel vigu ei ole sisse teinud. Arvestades seda et online PC'l ei ole siis enamus bugid on välja jäetud, õnneks.
Infoks veel:
** NOTICE: Product offered subject to your acceptance of the 2K Games License (see www.take2games.com/eula and Steam Subscriber Agreement ("SSA"). You must activate this product via the Internet by registering for a Steam account and accepting the SSA. Please see www.steampowered.com/agreement to view the SSA prior to purchase. If you do not agree with the provisions of the 2K Games License or SSA, you should return this game unopened to your retailer in accordance with their return policy. Any online features require internet connection, may be retired on 30 days notice, and may not be available to all users.
Jux
17.10.2008 13:10:56
| MONX33 kirjutas: |
** NOTICE: Product offered subject to your acceptance of the 2K Games License (see www.take2games.com/eula and Steam Subscriber Agreement ("SSA"). You must activate this product via the Internet by registering for a Steam account and accepting the SSA. Please see www.steampowered.com/agreement to view the SSA prior to purchase. If you do not agree with the provisions of the 2K Games License or SSA, you should return this game unopened to your retailer in accordance with their return policy. Any online features require internet connection, may be retired on 30 days notice, and may not be available to all users. |
Aga oskab keegi sellist asja kommenteerida, et näiteks mul on kodus 2 arvutit - laua arvuti ja läpp ning kodus olles mängiksin laua arvutiga ja kui reisin vms, siis sooviks seda mängu läpil mängida. Seda arvesse võttes, kas mul õnnestub sellisel juhul seda mängu mõlemale arvutile registreerida?
| Kommentaarid: 9 loe/lisa |
9 |
Renq
18.10.2008 08:01:29
| Jux kirjutas: |
| MONX33 kirjutas: |
Aga oskab keegi sellist asja kommenteerida, et näiteks mul on kodus 2 arvutit - laua arvuti ja läpp ning kodus olles mängiksin laua arvutiga ja kui reisin vms, siis sooviks seda mängu läpil mängida. Seda arvesse võttes, kas mul õnnestub sellisel juhul seda mängu mõlemale arvutile registreerida? |
no steami puhul on ju see, et paned cd key sinna oma konto alt ja tirid mängu kuhu tahad. nagu counter strike'iga oli. eks näis kuidas sellega on.
henri200
18.10.2008 08:27:39
Samamoodi on, paned koodi (või ostad läbi steami), ja siis on see sul mängude all. Saad ükskõik mis arvuti alt ligi
| Kommentaarid: 62 loe/lisa |
59 |
Renq
21.10.2008 15:53:56
mäng olemas, hüvasti EA Sports ja LIVE seeria. 2 mängu tegin praegu, väga kõva on. nüüd ootan vaid, kuni see poodi jõuab, siis saab ausal teel ka asja omandada:P
kuna asi on xboxi port, siis on natukene keerukas mängus ringi liikuda esialgu, a küll ära harjub. ise mängin logitech cordless rumblepad 2'ga.
MONX33
21.10.2008 22:23:43
| Renq kirjutas: |
kuna asi on xboxi port, siis on natukene keerukas mängus ringi liikuda esialgu, a küll ära harjub. ise mängin logitech cordless rumblepad 2'ga. |
Täpselt sama siin, sai ka mäng muretsetud ja päeval proovisin kuskil 3h ja tõesti suuuuuurepärane mäng soovitan soojalt kõigile minu profiilis oleva masinaga mängin kõik MAX (+ MSAA ja AA mis seal peale sai panna) @ 1280x1024 ja ~120fps . Nüüd peab 29.10.08 ootama kui Andrico'st originaali saan, seda mängu peab toetama(Y).
Renq
21.10.2008 23:03:56
ma väga loodan, et järgmine aasta tuleb samuti arvutile ja siis ka online mängu võimalus.
MONX33
21.10.2008 23:10:51
| Renq kirjutas: |
| ma väga loodan, et järgmine aasta tuleb samuti arvutile ja siis ka online mängu võimalus. |
loodame aga mind eriti see online osa ei huvitagi vaid hoopis see living roster, see tundub huvitav lisa olevat
Renq
22.10.2008 14:50:33
see mäng on lihtsalt wicked... ma alustasin täna association mode'i lakersiga ja tegin esimese mängu blazersi vastu... ei ole midagi öelda, klass omaette.
MONX33
22.10.2008 14:58:40
| Renq kirjutas: |
| see mäng on lihtsalt wicked... ma alustasin täna association mode'i lakersiga ja tegin esimese mängu blazersi vastu... ei ole midagi öelda, klass omaette. |
Kas sul on ka niiet pidevalt CPU loobib suvalt kohalt kõik sisse või on see minu kaitse tehnika viga?
Renq
22.10.2008 15:01:02
| MONX33 kirjutas: |
| Renq kirjutas: |
Kas sul on ka niiet pidevalt CPU loobib suvalt kohalt kõik sisse või on see minu kaitse tehnika viga? |
loopima hakkasid nad siis, kui ma taktikat vähe muutsin, siis jäi pidevalt mõni mees kolmese tagant vabaks ja siis laksasid valusalt. a muidu ei old hullu.
okei, nüüd päris kossu mängima.
jako07
22.10.2008 17:24:01
Kust on võimalik netist osta ?
Krediitkaart olemas.
19 |
henri200
59 |
Renq
24.10.2008 14:48:36
| MONX33 kirjutas: |
| Renq kirjutas: |
loodame aga mind eriti see online osa ei huvitagi vaid hoopis see living roster, see tundub huvitav lisa olevat  |
minumeelest ei ole living rosterit PC versioonis.
MONX33
25.10.2008 10:08:39
| Renq kirjutas: |
| MONX33 kirjutas: |
| Renq kirjutas: |
minumeelest ei ole living rosterit PC versioonis. |
NBA 2K9 ei ole jah seda lisa aga siis oli juttu 2K10
TruePlaya
26.10.2008 18:26:23
| Kas siis PC versal on samad glitchid ja bugid, mis ma praegu seal youtube videotes nägin??? Ja kas mingid patchid ka juba väljas on?
| Kommentaarid: 30 loe/lisa |
defqon
26.10.2008 19:11:54
| KUIDAS ALLIE OOPI TEHA SAAB PC VERSOL?
MONX33
26.10.2008 20:34:39
| TruePlaya kirjutas: |
| Kas siis PC versal on samad glitchid ja bugid, mis ma praegu seal youtube videotes nägin??? Ja kas mingid patchid ka juba väljas on? |
Need videod mis ennem panin siia teemasse on tehtud PS3'lt kuigi jah seda inbound bug eksisteerib ka PC peal aga selleks on rohi olemas. Muidu on mäng tõesti kõva ja nauditav
| defqon kirjutas: |
| KUIDAS ALLIE OOPI TEHA SAAB PC VERSOL? |
Post-Up+Pass nupud pead ise vaatama mis sul sätistatud on.
Renq
26.10.2008 20:57:34
krt, mul tekksi siuke jama association mode'is, et trade'ides ei lase enam trade pickide peale valida ja kui 3 meeskonna vahel on trade' sis ei lase valida, mis mansale mingi mees läheb.
TruePlaya
26.10.2008 21:06:58
MONX33, Krt see usb bug-lag on küll jama...
Ja mis rohi täpsemalt?
Ja kas kellelgi on häid slidereid anda?
_________________ Puhastan, hooldan, parandan, uuendan ja koostan lauaarvuteid. Lisainfo PS-i teel! |
defqon
26.10.2008 21:22:41
selline küsimus siis veel, et mis aitaks selle vastu kui mäng jookseb liiga kiiresti nagu ebanormaalselt kiiresti. ja kui mängu tempo madalamaks keerad siis nt vabavisete ajal on pall nagu õhupall liialt aeglane
btw, nüüd loadib ka imelikult kiiresti.. introd ja asjad käivad varasemast poole kiiremini ära jne. kuskilt oleks nagu pitchi juurde keeratud kogu mängule nii menüüle kui gameplayle:D
Renq
26.10.2008 21:27:36
Ja kas kellelgi on häid slidereid anda? |
usb bug lag??
ma läksin slideritesse ja tõmbasin nees kohad, kus olid success 50'lt alla poole, 40'le ja natukene peale, teisi ei puutunud, ei hakanud süvenema.
TruePlaya
26.10.2008 21:30:29
jah mul usb klaveriga mäng lagib menüüs täiega paned tavalise otsaga klaveri taha ja kõik puhas...
MONX33
26.10.2008 21:43:18
Inbound bug tekib siis kui sa lähed mängima Tutorial modes 5on5, seal pidi mingine süsteem teine olema ja saveb settingutesse ära ja siis kui läheb päris 5on5 mängima kasutab neid ja tekib see bug.
http://2ksports.com/forums/showthread.php?t=190935
Slideritest kasutan praegu ja tunduvad täitsa ok olevat
http://www.operationsports.com/forums/nba-2k-sliders/275705-blue-lightnings-sliders-2ksports-forum.html
45/40
50/50
50/45
50/40
40/30
30/30
70/70
50/50
45/43
50/50
25/25
75/75
50/50
80/70
65/40
60/60
50/50
50/45
50/40
50/50
40/40
50/50
50/50
55/40
40/15
50/50
60/40
50/50
50/25
50/75
50/45
50/30
25/25
50/40
50/55
50/55
20/50
50/40
50/50
55/65
65/50
45/45
70/45
60/60
TruePlaya
26.10.2008 22:22:13
Tänud Ise otsisn ka sealt samast aga ei leidnud millegi pärast...
Nüüd tuleks vist mingi pult osta kuna klaviatuuriga on seda mängu suht imelik mängida vms?
Oskab keegi soovitada?
MONX33
26.10.2008 22:35:35
Oskab keegi soovitada? |
Endal selline ja ajab asja ära
http://www.zebra.ee/S2/Product.aspx?iShopID=1&iItemID=66249
Renq
TruePlaya
27.10.2008 15:41:57
| Ise olen koguaeg Live klaveriga teinud...7 a. mängisin online liigat ka (euroslam.com'is) aga see aasta augustis pandi liiga kinni kuna aktiivsus oli nuli lähedal..kahju... ning Live ei tulnud PC peale ka see aaasta...seega 2k on mul hetkel veel väga võõras...
MONX33
27.10.2008 17:02:00
| Ise olen koguaeg Live klaveriga teinud...7 a. mängisin online liigat ka (euroslam.com'is) aga see aasta augustis pandi liiga kinni kuna aktiivsus oli nuli lähedal..kahju... ning Live ei tulnud PC peale ka see aaasta...seega 2k on mul hetkel veel väga võõras... |
Sama siis 2K suhtes, ma ka esimest korda mängin seda seeriat ja tegelt mulje on on hea kuigi vaidedavalt jäi 2K mängu tegemisega aeg napiks. kuna tõesti kahtlasi buge on mängus mis ennem ei olnud
Renq
27.10.2008 18:12:26
mina olen live'i alates 99'nda aasta mängust mänginud ja puldi ostsin põhiliselt 08 jaoks, et oleks mugavam mängida ja siis ma mängisin mingi mõned mängud vist ainult, ei suutnud lihtsalt....halb oli. ja k29 bugidele vaatamata on tegu parima kossumänguga arvutile. minumeelest on ps3'le patch väljas. loodetavasti mehed ei maga ja töötavad ka pc versiooni parandamise kallal.
MONX33
27.10.2008 20:58:12
| Renq kirjutas: |
| mina olen live'i alates 99'nda aasta mängust mänginud ja puldi ostsin põhiliselt 08 jaoks, et oleks mugavam mängida ja siis ma mängisin mingi mõned mängud vist ainult, ei suutnud lihtsalt....halb oli. ja k29 bugidele vaatamata on tegu parima kossumänguga arvutile. minumeelest on ps3'le patch väljas. loodetavasti mehed ei maga ja töötavad ka pc versiooni parandamise kallal. |
PC suhtes nüüd natuke kahtlen et nad ei tee patchi, kuna 2K otsustas üldse mängu X360 pordiga teha ainult väikeste bugidega siis peaks patch kah tulema ainult sõltub kui palju asju see muudab.
http://2ksports.com/forums/showthread.php?t=193090
rico_ee
27.10.2008 22:38:50
| defqon kirjutas: |
btw, nüüd loadib ka imelikult kiiresti.. introd ja asjad käivad varasemast poole kiiremini ära jne. kuskilt oleks nagu pitchi juurde keeratud kogu mängule nii menüüle kui gameplayle:D |
sama mul.
