uus teema   vasta Tarkvara »  Arvutimängude foorum »  NBA 2K9 märgi kõik teemad loetuks
mine lehele 1, 2, 3, 4  järgmine
MONX33
sõnum 06.10.2008 10:42:07 NBA 2K9 vasta tsitaadiga
Kuna PC peale on tulemas revolutsioonile korvpalli simulaator NBA 2k9 mille seeria on 7 aastat järjest saanud erinevaid tiitleid siis mõtlesin ka siia ühe teema teha.
See aasta tuleb 2k9 PC peale mis on Xbox 360 port, ehk siis xboxi 360 välja nägemist featuridega ja lisadega mäng jõuab ka PC peale
www.2ksports.com/games/nba2k9
Pilte, videosi, jne:
http://www.operationsports.com/game.php?id=502
Key features:
2K HD – Breathtaking action in full HD resolution brings you
radically improved facial textures and eye movement, true-to-life crowd
reactions and celebration sequences, and much more.
Styles Upon Styles
– New Signature Defensive Styles and
more Signature Shots, dunks and free throws give you EVEN MORE
distinctive player styles.
Adaptive AI – Now your teammates and your opponents read,
react, and adjust in real time to match your gameplay strategies.
The Association 2.0 - All-new NBA.com interface, Player
Ambitions, Player Scouting, and more options for the casual player make
this the most robust Franchise mode ever
1) System Requirements
1.1 Operating Systems
Microsoft(R) Windows(R) 2000
Microsoft(R) Windows(R) XP (SP 2)
Microsoft Vista(TM)
1.2 Minimum System Requirements
CPU: Pentium 4 2.4 GHz Single Core processor or equivalent (2.8 GHz for Vista)
RAM: 512 MB or more (1 GB for Vista)
Disc Drive: 8x or faster DVD drive
Hard Drive: 10.5 GB or more free space
Video: DirectX 9.0c compatible (see below)
Sound: DirectX 9.0c compatible
Input: Keyboard or dual-analog gamepad
Video card with 128 MB or more memory and one of the following chipsets is required:
ATI x1300 or greater;
NVIDIA 6600 or greater;
DirectX 9.0c compatible card with Shader Model 3.0 support.
Important Note: Game requires Internet connection for activation
1.3 Recommended System Requirements
CPU: 3 GHz Dual Core processor or equivalent
RAM: 2 GB
Video: Shader Model 3.0 support with 512 Ram (Nvidia(R) Geforce(R) 7900 GT or better)
Sound: 100% DirectX 9.0c compatible sound card
Input: Dual-analog gamepad
Release dates:
EU: 10 okt (XBOX360, PS2, PS3); 17.okt (PC)
US: 7.okt (PS2, PS3, XBOX360), 21.okt (PC)
EDIT:
* Does not support any online functionality, including but not limited to online games, 2K Share, ReelMaker or Living Rosters
** Internet access required to install and authenticate game
viimati muutis MONX33 27.10.2008 10:18:18, muudetud 3 korda
Renq
Renq
sõnum 06.10.2008 15:54:22 vasta tsitaadiga
täna otsisin netist andmeid, nba 2k9 kohta ja tundub et tulebki PC'le, kindlalt päeva parim uudis icon_smile.gif
Does not support any online functionality <--- võrgumängu tugi puudub? :O
jako07
jako07
sõnum 06.10.2008 17:25:44 Re: NBA 2K9 vasta tsitaadiga
MONX33 kirjutas:
Key features:
Minimum Requirements:
OS: Windows Vista, XP, or 2000 CPU | CPU: Pentium 4 2.4 GHz Single Core
processor or equivalent (2.8 GHz for Vista) RAM: 512 MB or more (1 GB for Vista) Disc Drive: 8x or
faster DVD drive | Hard Drive: 10.5 GB or more free space | Video: DirectX 9.0c compatible * | Sound:
DirectX 9.0c compatible | Input: Keyboard or dual-analog gamepad
* Video card with 128 MB or more memory and one of the following chipsets is required: ATI x1300
or greater | NVIDIA 6600 or greater | DirectX 9.0c compatible card with Shader Model 3.0 support.
Ma olen näinud NBA 2k8 graafikat ja tahaks näha, kuidas see jookseb arvuti peal, loodetavasti pole väga kokku hoitud pildi kvaliteedi alandamisega.
Ja muidugi- parim aeg NBA 2k9 avaldada, sest see aasta ju NBA Live ei tule icon_biggrin.gif
Renq
Renq
sõnum 06.10.2008 17:48:10 Re: NBA 2K9 vasta tsitaadiga
jako07 kirjutas:
lootetavasti pole väga kokku hoitud pilti kvaliteedi alandamisega. ühesõnaga sa loodad, et on detaile kõvasti vähemaks keeratud?
minu jaoks ei ole nba live seeriat eriti pärast 05't olnud eriti 07/08, kui hakkas tulema see freestyle superstari teema ja igast lisavidinad, mäng ise oli aga suht praht.
live'is oli ka probleem, suurte skooridega, kuna ma armastasin mängida 12min veeranditega
ühesõnaga GTA 4, NBA 2K9, ja mõned head mängud veel... CHRISTMAS COMES EARLY THIS YEAR icon_biggrin.gif
MAGNA
MAGNA
sõnum 06.10.2008 18:43:59 vasta tsitaadiga
Ülejäänud nagu vastab nõuetele aga jahm.. Peaks maybe uue videokaardi sebima
jako07
jako07
sõnum 06.10.2008 20:17:40 Re: NBA 2K9 vasta tsitaadiga
[quote="Renq"]
jako07 kirjutas:
Ma just loodan, et ei ole. Sõnastus failis veidi.
Renq
Renq
sõnum 06.10.2008 21:45:19 Re: NBA 2K9 vasta tsitaadiga
[quote="jako07"]
Renq kirjutas:
jako07 kirjutas:
no tänapäeva mänguarvutid ei jää mitte millegi poolest xboxile või PS3'le alla, vastupidi hoopis, nii et loodetavasti tuleb üks masterpiece sellest mängust.
MONX33
sõnum 08.10.2008 18:27:25 vasta tsitaadiga
Renq kirjutas:
Online osa puudub jah PC'l aga selle eest need online featured: living roster, 2kinsider jne on olemas icon_smile.gif
Mis mulle on natuke tähtsamad kui see online osa.
Üks review kah siis: http://xbox360.ign.com/articles/916/916726p1.html
Üks kuulujutt käis ka läbi et järgmine aasta võib olla ei tule NBA 2k10 PS3 peale, kuna selle tegemine pidi olema kallim kui X360 ja PC peale portimine
Renq
Renq
sõnum 08.10.2008 21:25:11 vasta tsitaadiga
MONX33 kirjutas:
Renq kirjutas:
oot, a mis online osa siis puudu on? see et ei saa teiste tüüpidega läbi neti mängida??? see on küll pagana suur miinus.
jako07
jako07
sõnum 08.10.2008 21:43:33 vasta tsitaadiga
isegi IP kaudu mitte?
mõttetu veidi ...
Renq
Renq
sõnum 08.10.2008 22:14:32 vasta tsitaadiga
ja mina veel mõtlesin, et selle mängu ostan tõesti originaali. arvatavasti ostan ikkagist, eriti kui hind on tõesti nii nagu usa's 19.99$, siis on see väga hea hind, võrreldes enamus teise ülehinnatud mängudega icon_smile.gif
MONX33
sõnum 11.10.2008 10:25:19 vasta tsitaadiga
PC release date lükkus EU's natuke edasi
EU: 17.oct (PC)
NB!: Enamus klipid on võetus PS3'lt, niiet kui valite ostmist siis soovitan PS3 valiku välja jätta ja valida X360 või siis PC.
ENJOY!!!
When scoring once on a single possession is never enough
http://www.youtube.com/watch?v=ydXRtCPf7Es
http://www.youtube.com/watch?v=PQBu2AZZsK8
http://www.youtube.com/watch?v=IoZzuEq-P6g
Go further than ever before with the ball
http://www.youtube.com/watch?v=NfGbDIS5Bg4
Rebounding fundamentals Sim style in action
http://www.youtube.com/watch?v=2qz2dxuBem0
I'm scared!!! The Defense is a ghost
http://www.youtube.com/watch?v=bFYHX0xI9vQ
http://www.youtube.com/watch?v=2o1lDEp2tGc
http://www.youtube.com/watch?v=zsCu53Ekgec
http://www.youtube.com/watch?v=t2YsvsoGaps
http://www.youtube.com/watch?v=exR4k66lSYI
You can now swat at flies instead of the ball defense
http://www.youtube.com/watch?v=Kvim6F4qNlA
http://www.youtube.com/watch?v=7FX7Mi23AEE
http://www.youtube.com/watch?v=LfZLwcLnY6s
http://www.youtube.com/watch?v=TjyawtB7SHg
Not even the Floor Sweeper can stop Lebron
http://www.youtube.com/watch?v=uJ-ONa1dRyQ
No court necessary
http://www.youtube.com/watch?v=mE3U7UsmKBc
Lag OFFline....so you can now experience Online play offline
http://www.youtube.com/watch?v=NkIRFXH_j9E
Barron Davis does the moonwalk
http://www.youtube.com/watch?v=sc09WVPupjY
Not even the backboard can stop Kobe
http://www.youtube.com/watch?v=fVAYg8ge2eA
I lost my head and skin playing NBA 2K9
http://www.youtube.com/watch?v=161fIV6tNeQ
Your NEW 2K9 Camera views
http://www.youtube.com/watch?v=lg44Xqm0FWs
Your NEW 5vs5 online play
http://www.youtube.com/watch?v=_AWBXc8vzdU
Meet the Guys at 2K responsible for all this and hear their new direction of the game
"Make game more accessible to users that aren't interested in running plays" (aka...Welcome cheesers, we will make you good at this game!!!)
http://www.youtube.com/watch?v=Adz8TccjvZA
Don't be a dork!!!
http://www.youtube.com/watch?v=_3wLdPWZSX8
http://www.youtube.com/watch?v=36YEXjIODWY
MMx
MMx
sõnum 11.10.2008 15:49:57 vasta tsitaadiga
vaatasin 4-5 esimest videot ära ja mäng tundub ikka jube kräpp...
pallikandmised, jooksud, kohutav AI kaitses jne jne...buge rohkem kui kokku lugeda jõuaks
ja see peaks olema 2009 aastale vastav korvapalli tase arvutimaailmas???
Kommentaarid: 79 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 69
Renq
Renq
sõnum 11.10.2008 16:13:19 vasta tsitaadiga
see on juba mõnda aega teada, et PC versioon ei tule koos konsoolidega, ma loodan väga, et hiljem tulev PC versioonis on neid asju parandatud.
MONX33
sõnum 11.10.2008 19:45:57 vasta tsitaadiga
http://www.andrico.ee/pood/product_info.php/products_id/11099
HIND: 399kr
recent
recent
sõnum 11.10.2008 20:08:52 vasta tsitaadiga
mõnus =)
Kommentaarid: 43 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 41
Renq
Renq
sõnum 11.10.2008 20:16:01 vasta tsitaadiga
MONX33 kirjutas:
HIND: 399kr
ilusti on hinnale 100% otsa keevitatud.
http://take2store.stores.yahoo.net/nba2k9pcp.html
MMx
MMx
sõnum 11.10.2008 20:42:03 vasta tsitaadiga
MONX33 kirjutas:
HIND: 399kr
siiski seda seal kohal ju veel ei ole...
kirjas et orienteeruv saabumise aeg 22.10.2008
aga kui tõesti asi nii bugine ka pc peal siis on isegi 399 palju küsitud
MONX33
sõnum 11.10.2008 22:51:16 vasta tsitaadiga
MMx kirjutas:
MONX33 kirjutas:
HIND: 399kr
Kohal muidugi ei ole, ma ütlesin et andrico lehel on olemas võimalus tellida.
Need videod mis panin siia ennem oli võetud 99& kui mitte 100% PS3'lt, X360 (online pidi olema vussis seal ainult vms.) pidi olema OK, niiet PC peaks kah olema OK, kui just nad portimisel vigu ei ole sisse teinud. Arvestades seda et online PC'l ei ole siis enamus bugid on välja jäetud, õnneks.
Infoks veel:
** NOTICE: Product offered subject to your acceptance of the 2K Games License (see www.take2games.com/eula and Steam Subscriber Agreement ("SSA"). You must activate this product via the Internet by registering for a Steam account and accepting the SSA. Please see www.steampowered.com/agreement to view the SSA prior to purchase. If you do not agree with the provisions of the 2K Games License or SSA, you should return this game unopened to your retailer in accordance with their return policy. Any online features require internet connection, may be retired on 30 days notice, and may not be available to all users.
Jux
sõnum 17.10.2008 13:10:56 vasta tsitaadiga
MONX33 kirjutas:
Aga oskab keegi sellist asja kommenteerida, et näiteks mul on kodus 2 arvutit - laua arvuti ja läpp ning kodus olles mängiksin laua arvutiga ja kui reisin vms, siis sooviks seda mängu läpil mängida. Seda arvesse võttes, kas mul õnnestub sellisel juhul seda mängu mõlemale arvutile registreerida?
Renq
Renq
sõnum 18.10.2008 08:01:29 vasta tsitaadiga
Jux kirjutas:
MONX33 kirjutas:
no steami puhul on ju see, et paned cd key sinna oma konto alt ja tirid mängu kuhu tahad. nagu counter strike'iga oli. eks näis kuidas sellega on.
henri200
sõnum 18.10.2008 08:27:39 vasta tsitaadiga
Samamoodi on, paned koodi (või ostad läbi steami), ja siis on see sul mängude all. Saad ükskõik mis arvuti alt ligi icon_wink.gif
Renq
Renq
sõnum 21.10.2008 15:53:56 vasta tsitaadiga
mäng olemas, hüvasti EA Sports ja LIVE seeria. 2 mängu tegin praegu, väga kõva on. nüüd ootan vaid, kuni see poodi jõuab, siis saab ausal teel ka asja omandada:P
kuna asi on xboxi port, siis on natukene keerukas mängus ringi liikuda esialgu, a küll ära harjub. ise mängin logitech cordless rumblepad 2'ga.
MONX33
sõnum 21.10.2008 22:23:43 vasta tsitaadiga
Renq kirjutas:
Täpselt sama siin, sai ka mäng muretsetud ja päeval proovisin kuskil 3h ja tõesti suuuuuurepärane mäng soovitan soojalt kõigile minu profiilis oleva masinaga mängin kõik MAX (+ MSAA ja AA mis seal peale sai panna) @ 1280x1024 ja ~120fps thumbs_up.gif. Nüüd peab 29.10.08 ootama kui Andrico'st originaali saan, seda mängu peab toetama(Y).
Renq
Renq
sõnum 21.10.2008 23:03:56 vasta tsitaadiga
ma väga loodan, et järgmine aasta tuleb samuti arvutile ja siis ka online mängu võimalus.
uus teema   vasta Tarkvara »  Arvutimängude foorum »  NBA 2K9 mine lehele 1, 2, 3, 4  järgmine
