MONX33
06.10.2008 10:42:07
NBA 2K9 |
Kuna PC peale on tulemas revolutsioonile korvpalli simulaator NBA 2k9 mille seeria on 7 aastat järjest saanud erinevaid tiitleid siis mõtlesin ka siia ühe teema teha.
See aasta tuleb 2k9 PC peale mis on Xbox 360 port, ehk siis xboxi 360 välja nägemist featuridega ja lisadega mäng jõuab ka PC peale
www.2ksports.com/games/nba2k9
Pilte, videosi, jne:
http://www.operationsports.com/game.php?id=502
Key features:
2K HD Breathtaking action in full HD resolution brings you
radically improved facial textures and eye movement, true-to-life crowd
reactions and celebration sequences, and much more.
Styles Upon Styles New Signature Defensive Styles and
more Signature Shots, dunks and free throws give you EVEN MORE
distinctive player styles.
Adaptive AI Now your teammates and your opponents read,
react, and adjust in real time to match your gameplay strategies.
The Association 2.0 - All-new NBA.com interface, Player
Ambitions, Player Scouting, and more options for the casual player make
this the most robust Franchise mode ever
1) System Requirements
1.1 Operating Systems
Microsoft(R) Windows(R) 2000
Microsoft(R) Windows(R) XP (SP 2)
Microsoft Vista(TM)
1.2 Minimum System Requirements
CPU: Pentium 4 2.4 GHz Single Core processor or equivalent (2.8 GHz for Vista)
RAM: 512 MB or more (1 GB for Vista)
Disc Drive: 8x or faster DVD drive
Hard Drive: 10.5 GB or more free space
Video: DirectX 9.0c compatible (see below)
Sound: DirectX 9.0c compatible
Input: Keyboard or dual-analog gamepad
Video card with 128 MB or more memory and one of the following chipsets is required:
ATI x1300 or greater;
NVIDIA 6600 or greater;
DirectX 9.0c compatible card with Shader Model 3.0 support.
Important Note: Game requires Internet connection for activation
1.3 Recommended System Requirements
CPU: 3 GHz Dual Core processor or equivalent
RAM: 2 GB
Video: Shader Model 3.0 support with 512 Ram (Nvidia(R) Geforce(R) 7900 GT or better)
Sound: 100% DirectX 9.0c compatible sound card
Input: Dual-analog gamepad
Release dates:
EU: 10 okt (XBOX360, PS2, PS3); 17.okt (PC)
US: 7.okt (PS2, PS3, XBOX360), 21.okt (PC)
EDIT:
* Does not support any online functionality, including but not limited to online games, 2K Share, ReelMaker or Living Rosters
** Internet access required to install and authenticate game
viimati muutis MONX33 27.10.2008 10:18:18, muudetud 3 korda |
Renq
06.10.2008 15:54:22
täna otsisin netist andmeid, nba 2k9 kohta ja tundub et tulebki PC'le, kindlalt päeva parim uudis
Does not support any online functionality <--- võrgumängu tugi puudub? :O
jako07
06.10.2008 17:25:44
Re: NBA 2K9 |
| MONX33 kirjutas: |
Key features:
Minimum Requirements:
OS: Windows Vista, XP, or 2000 CPU | CPU: Pentium 4 2.4 GHz Single Core
processor or equivalent (2.8 GHz for Vista) RAM: 512 MB or more (1 GB for Vista) Disc Drive: 8x or
faster DVD drive | Hard Drive: 10.5 GB or more free space | Video: DirectX 9.0c compatible * | Sound:
DirectX 9.0c compatible | Input: Keyboard or dual-analog gamepad
* Video card with 128 MB or more memory and one of the following chipsets is required: ATI x1300
or greater | NVIDIA 6600 or greater | DirectX 9.0c compatible card with Shader Model 3.0 support.
Ma olen näinud NBA 2k8 graafikat ja tahaks näha, kuidas see jookseb arvuti peal, loodetavasti pole väga kokku hoitud pildi kvaliteedi alandamisega.
Ja muidugi- parim aeg NBA 2k9 avaldada, sest see aasta ju NBA Live ei tule
| Kommentaarid: 19 loe/lisa |
19 |
Renq
06.10.2008 17:48:10
Re: NBA 2K9 |
| jako07 kirjutas: |
Ja muidugi- parim aeg NBA 2k9 avaldada, sest see aasta ju NBA Live ei tule  |
lootetavasti pole väga kokku hoitud pilti kvaliteedi alandamisega. ühesõnaga sa loodad, et on detaile kõvasti vähemaks keeratud?
minu jaoks ei ole nba live seeriat eriti pärast 05't olnud eriti 07/08, kui hakkas tulema see freestyle superstari teema ja igast lisavidinad, mäng ise oli aga suht praht.
live'is oli ka probleem, suurte skooridega, kuna ma armastasin mängida 12min veeranditega
ühesõnaga GTA 4, NBA 2K9, ja mõned head mängud veel... CHRISTMAS COMES EARLY THIS YEAR
MAGNA
06.10.2008 18:43:59
Hea uudis jah .
Ei tea kas radeon 9100 seriesiga ei venita seda välja ?
Ülejäänud nagu vastab nõuetele aga jahm.. Peaks maybe uue videokaardi sebima
Vana raal mis sa ikka tahad .
jako07
06.10.2008 20:17:40
Re: NBA 2K9 |
[quote="Renq"]
| jako07 kirjutas: |
| lootetavasti pole väga kokku hoitud pilti kvaliteedi alandamisega. ühesõnaga sa loodad, et on detaile kõvasti vähemaks keeratud? |
Ma just loodan, et ei ole. Sõnastus failis veidi.
Videotest nähtu põhjal muidugi superb, nagu alati
19 |
Renq
06.10.2008 21:45:19
Re: NBA 2K9 |
[quote="jako07"]
| Renq kirjutas: |
| jako07 kirjutas: |
Videotest nähtu põhjal muidugi superb, nagu alati  |
no tänapäeva mänguarvutid ei jää mitte millegi poolest xboxile või PS3'le alla, vastupidi hoopis, nii et loodetavasti tuleb üks masterpiece sellest mängust.
MONX33
08.10.2008 18:27:25
| Renq kirjutas: |
Does not support any online functionality <--- võrgumängu tugi puudub? :O |
Online osa puudub jah PC'l aga selle eest need online featured: living roster, 2kinsider jne on olemas
Mis mulle on natuke tähtsamad kui see online osa.
Üks review kah siis: http://xbox360.ign.com/articles/916/916726p1.html
Üks kuulujutt käis ka läbi et järgmine aasta võib olla ei tule NBA 2k10 PS3 peale, kuna selle tegemine pidi olema kallim kui X360 ja PC peale portimine
Renq
08.10.2008 21:25:11
| MONX33 kirjutas: |
| Renq kirjutas: |
Üks kuulujutt käis ka läbi et järgmine aasta võib olla ei tule NBA 2k10 PS3 peale, kuna selle tegemine pidi olema kallim kui X360 ja PC peale portimine |
oot, a mis online osa siis puudu on? see et ei saa teiste tüüpidega läbi neti mängida??? see on küll pagana suur miinus.
jako07
08.10.2008 21:43:33
isegi IP kaudu mitte?
mõttetu veidi ...
19 |
Renq
08.10.2008 22:14:32
ja mina veel mõtlesin, et selle mängu ostan tõesti originaali. arvatavasti ostan ikkagist, eriti kui hind on tõesti nii nagu usa's 19.99$, siis on see väga hea hind, võrreldes enamus teise ülehinnatud mängudega
MONX33
MMx
11.10.2008 15:49:57
vaatasin 4-5 esimest videot ära ja mäng tundub ikka jube kräpp...
pallikandmised, jooksud, kohutav AI kaitses jne jne...buge rohkem kui kokku lugeda jõuaks
ja see peaks olema 2009 aastale vastav korvapalli tase arvutimaailmas???
| Kommentaarid: 78 loe/lisa |
69 |
Renq
11.10.2008 16:13:19
see on juba mõnda aega teada, et PC versioon ei tule koos konsoolidega, ma loodan väga, et hiljem tulev PC versioonis on neid asju parandatud.
MONX33
recent
11.10.2008 20:08:52
| mõnus =)
| Kommentaarid: 43 loe/lisa |
41 |
Renq
MMx
11.10.2008 20:42:03
siiski seda seal kohal ju veel ei ole...
kirjas et orienteeruv saabumise aeg 22.10.2008
aga kui tõesti asi nii bugine ka pc peal siis on isegi 399 palju küsitud
69 |
MONX33
11.10.2008 22:51:16
| MMx kirjutas: |
aga kui tõesti asi nii bugine ka pc peal siis on isegi 399 palju küsitud |
Kohal muidugi ei ole, ma ütlesin et andrico lehel on olemas võimalus tellida.
Need videod mis panin siia ennem oli võetud 99& kui mitte 100% PS3'lt, X360 (online pidi olema vussis seal ainult vms.) pidi olema OK, niiet PC peaks kah olema OK, kui just nad portimisel vigu ei ole sisse teinud. Arvestades seda et online PC'l ei ole siis enamus bugid on välja jäetud, õnneks.
Infoks veel:
** NOTICE: Product offered subject to your acceptance of the 2K Games License (see www.take2games.com/eula and Steam Subscriber Agreement ("SSA"). You must activate this product via the Internet by registering for a Steam account and accepting the SSA. Please see www.steampowered.com/agreement to view the SSA prior to purchase. If you do not agree with the provisions of the 2K Games License or SSA, you should return this game unopened to your retailer in accordance with their return policy. Any online features require internet connection, may be retired on 30 days notice, and may not be available to all users.
Jux
17.10.2008 13:10:56
| MONX33 kirjutas: |
** NOTICE: Product offered subject to your acceptance of the 2K Games License (see www.take2games.com/eula and Steam Subscriber Agreement ("SSA"). You must activate this product via the Internet by registering for a Steam account and accepting the SSA. Please see www.steampowered.com/agreement to view the SSA prior to purchase. If you do not agree with the provisions of the 2K Games License or SSA, you should return this game unopened to your retailer in accordance with their return policy. Any online features require internet connection, may be retired on 30 days notice, and may not be available to all users. |
Aga oskab keegi sellist asja kommenteerida, et näiteks mul on kodus 2 arvutit - laua arvuti ja läpp ning kodus olles mängiksin laua arvutiga ja kui reisin vms, siis sooviks seda mängu läpil mängida. Seda arvesse võttes, kas mul õnnestub sellisel juhul seda mängu mõlemale arvutile registreerida?
| Kommentaarid: 9 loe/lisa |
9 |
Renq
18.10.2008 08:01:29
| Jux kirjutas: |
| MONX33 kirjutas: |
Aga oskab keegi sellist asja kommenteerida, et näiteks mul on kodus 2 arvutit - laua arvuti ja läpp ning kodus olles mängiksin laua arvutiga ja kui reisin vms, siis sooviks seda mängu läpil mängida. Seda arvesse võttes, kas mul õnnestub sellisel juhul seda mängu mõlemale arvutile registreerida? |
no steami puhul on ju see, et paned cd key sinna oma konto alt ja tirid mängu kuhu tahad. nagu counter strike'iga oli. eks näis kuidas sellega on.
henri200
18.10.2008 08:27:39
Samamoodi on, paned koodi (või ostad läbi steami), ja siis on see sul mängude all. Saad ükskõik mis arvuti alt ligi
| Kommentaarid: 62 loe/lisa |
59 |
Renq
21.10.2008 15:53:56
mäng olemas, hüvasti EA Sports ja LIVE seeria. 2 mängu tegin praegu, väga kõva on. nüüd ootan vaid, kuni see poodi jõuab, siis saab ausal teel ka asja omandada:P
kuna asi on xboxi port, siis on natukene keerukas mängus ringi liikuda esialgu, a küll ära harjub. ise mängin logitech cordless rumblepad 2'ga.
MONX33
21.10.2008 22:23:43
| Renq kirjutas: |
kuna asi on xboxi port, siis on natukene keerukas mängus ringi liikuda esialgu, a küll ära harjub. ise mängin logitech cordless rumblepad 2'ga. |
Täpselt sama siin, sai ka mäng muretsetud ja päeval proovisin kuskil 3h ja tõesti suuuuuurepärane mäng soovitan soojalt kõigile minu profiilis oleva masinaga mängin kõik MAX (+ MSAA ja AA mis seal peale sai panna) @ 1280x1024 ja ~120fps . Nüüd peab 29.10.08 ootama kui Andrico'st originaali saan, seda mängu peab toetama(Y).
Renq
21.10.2008 23:03:56
ma väga loodan, et järgmine aasta tuleb samuti arvutile ja siis ka online mängu võimalus.
