uus teema   See teema on lukus, sa ei saa siin muuta postitusi või vastata teemale! Raud »  Protsessorid »  Intel Core i3/i5/i7/i9/Xeon protsessorite arutelu (Lisatud küsitlus: "Mis pesaga emaplaat kasutuses 1. oktoobri seisuga? märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 7, 8, 9 ... 346, 347, 348  järgmine
Mis pesaga Intel lauaarvuti emaplaat on kasutuses 2014 1. oktoobri seisuga?
Socket 478
2%
 2%  [ 13 ]
LGA 775
13%
 13%  [ 83 ]
LGA 1366
4%
 4%  [ 30 ]
LGA 1155
32%
 32%  [ 209 ]
LGA 1150
38%
 38%  [ 243 ]
LGA 1156
3%
 3%  [ 23 ]
LGA 2011
5%
 5%  [ 35 ]
hääli kokku : 636
G80
G80
sõnum 18.09.2008 19:06:23 vasta tsitaadiga
X58 boards with separate voltage possible
http://www.fudzilla.com/index.php?option=com_content&task=view&id=9489&Itemid=1
2.66GHz Nehalem clocks to 4GHz
Mingi 1M ära teha siis resa ka icon_biggrin.gif Kui 24/7 kannataks siis oleks tegija.
http://www.fudzilla.com/index.php?option=com_content&task=view&id=9490&Itemid=1
Ära siia kliki
Kommentaarid: 256 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 210
heretic666
heretic666
sõnum 18.09.2008 19:22:03 vasta tsitaadiga
Our sources have confirmed that...
Must be true !
G80
G80
sõnum 19.09.2008 13:56:54 vasta tsitaadiga
Intel Decides to Unlock the Memory Mutiplier of its Core i7-920 and Core i7-940 CPUs
Thanks to some inside information that was published today by various hardware portals, now we know that Intel has decided to enhance the overclocking capabilities of two of its still to be released non-Extreme Core i7 processors. Intel's LGA 1366 Core i7-940 and Core i7-920, which are clocked at 2.93GHz and 2.66GHz respectively will now boast unlocked memory controlers, meaning that users will be able to change the memory multiplier and thus the memory frequency beyond the stock DDR3 800/1066MHz speed. The unlocked memory multiplier will also allow the QPI speed to be changed. The Quick Path Interconnect (QPI) bus resembles AMD's Hypertransport bus. A slide change in the memory frequency will result in higher QPI bus speed, just like in the current AMD processor family. Previously, we knew that only the Core i7 Extreme processors like the 3.2GHz Core i7-965 Extreme Edition will have these overclocking features. I sincerely hope that with this last minute change Intel will make us overclockers really happy.
http://www.techpowerup.com/71752/Intel_Decides_to_Unlock_the_Memory_Mutiplier_of_its_Core_i7-920_and_Core_i7-940_CPUs.html
Ära siia kliki
sõnum 19.09.2008 14:00:15 vasta tsitaadiga
G80 kirjutas:
POMM icon_eek.gif .Loodetavasti on tõsi.Siis ei imesta üldse kui i7 920 klokkub ~4Ghz-ni thumbs_up.gif thumbs_up.gif
Win11 25H2 upgrade skriptid neile kelle masin ise ei taha 23H2 või 24H2 pealt ennast uuendada:
G80
G80
sõnum 19.09.2008 14:06:08 vasta tsitaadiga
tomorrow kirjutas:
G80 kirjutas:
Ära siia kliki
WäntWõll
make.believe
WäntWõll
sõnum 19.09.2008 15:16:57 vasta tsitaadiga
Intel Core i7-920 (2.66GHz,8MB L3, LGA1366, Product Code BX80601920 & QPI 4.8GT/sec) Estimated Price in EU : ~260€
ooatme nüüd oktobri teise poole ära ja siis hindame olukorda uuesti icon_wink.gif
SogegaTyyp
SogegaTyyp
sõnum 19.09.2008 15:44:52 vasta tsitaadiga
Einoh, kui see tavaline 2,66 GHz ja ca 4k maksev prose teeks õhuga 4Ghz, siis pole ju mingit kahtlust, mida järgmiseks masinasse osta icon_smile.gif Clock versus clock peaks see loom ju C2Duost selgelt kiirem olema, kui nüüd veel Q9650-ga samale kellale läheb...no see tundub liigagi hea, et olla tõsi. Aga tõesti, eks aeg annab arutust. Mingist konkreetsest kuupäevast ikkagi pole juttu olnud, et näiteks sel ja sel päeval tohib teste avaldada? Tõesti, praegu on seda segast infi liga palju.
Kommentaarid: 54 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 51
G80
G80
sõnum 20.09.2008 21:13:23 vasta tsitaadiga
Nehalem 3.2GHz goes up to 4.5GHz on air
We learned that Nehalem 3.2GHz should reach over 4GHz easily, and if you are a really good overclocker, you should hit up to 4.5GHz on air. Of course, for such a task you need a great motherboard.
Furthermore, if you want to go over 5GHz and even 5.2 to 5.3GHz you need to play with LN2 but apparently this is possible and it has been done with demo CPUs. These are some of the numbers you should be reaching once the CPU is out.
Naturally, the Core i7 Extreme edition at 3.2GHz and overvoltage protection removed should be able to reach the highest clocks. It is safe to say that whatever speeds you’we seen on Core 2 Quad 45nm Yorkfield parts, you should be getting with Nehalems or you should at least be within that range.
Looks like overclockers will like this one; but beware, the memory speeds will suck, especially compared with X48 memory scores.
http://www.fudzilla.com/index.php?option=com_content&task=view&id=9513&Itemid=1[/b]
Ära siia kliki
sõnum 21.09.2008 01:05:21 vasta tsitaadiga
Kust otsast mälukiirused sakivad siis? icon_lol.gif .See vend ikka haige kuju ma ütlen.Keegi juba kommenteeris,et ta nehalemi kohta iga variandi välja käinud.Pärast saab siis öelda - i told you so icon_lol.gif
Flavius
sõnum 21.09.2008 08:33:12 vasta tsitaadiga
fuadi novellide jaoks võiks eraldi teema teha,
uudiste ja faktidega pole seal kunagi midagi pistmist
Kommentaarid: 126 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 118
Killhoven
OC`er
Killhoven
sõnum 21.09.2008 11:32:09 vasta tsitaadiga
Tõepoolest, solgiks seda teemat kah vähem. Pärast halb lugeda kui teema "müra" täis. icon_wink.gif
Kommentaarid: 408 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 351
G80
G80
sõnum 23.09.2008 14:00:52 vasta tsitaadiga
Intel Nehalem-Architecture-Preview
http://translate.google.de/translate?u=http%3A%2F%2Fwww.hardware-infos.com%2Fberichte.php%3Fbericht%3D36&hl=de&ie=UTF-8&sl=de&tl=en
Core i7 965 XE Unboxed, Stock Cooler and Processor Exposed
http://www.techpowerup.com/72047/Core_i7_965_XE_Unboxed_Stock_Cooler_and_Processor_Exposed.html
Ära siia kliki
sõnum 26.09.2008 09:15:15 vasta tsitaadiga
ASUS breaks 3DMark world record with Core i7?
G80
G80
sõnum 26.09.2008 11:46:35 vasta tsitaadiga
tomorrow kirjutas:
Ära siia kliki
WäntWõll
make.believe
WäntWõll
sõnum 26.09.2008 11:52:43 vasta tsitaadiga
Pole paha jah aga eks näis mis saama hakkab kui NDA kukub.
Cb4
Cb4
sõnum 26.09.2008 11:54:43 vasta tsitaadiga
Just...Ma olen kahe vahel, kas uuendada praegust riistvara, või oodata ja minna kohe uuele platele üle 8)
Kui alguses suuremaid ämbreid ei ilmne, siis võiks uue võtta küll!
Ma ei ole agressiivne juht, olen lihtsalt võistlushimuline.
Kommentaarid: 113 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 95
ceemic
24/7@kalal
ceemic
sõnum 26.09.2008 23:45:11 vasta tsitaadiga
Coolaleri kodukalt natuke pilte uuest MSI platest: http://translate.google.com/translate?u=http%3A%2F%2Fforum.coolaler.com%2Fshowthread.php%3Ft%3D190809&hl=en&ie=UTF-8&sl=auto&tl=en
Paar testi ka:
http://www.abload.de/image.php?img=06-2eff.jpg i7-920 @ 4Ghz 3DMark06 CPU punnid
http://www.abload.de/image.php?img=0642w.jpg i7-965 @ 3.61Ghz 3DMark06 CPU punnid
http://www.abload.de/image.php?img=pi1m89k.jpg i7-965 @ 3.2Ghz spii1M - 40000pp thumbs_up.gif
AJ
AJ
sõnum 26.09.2008 23:48:40 vasta tsitaadiga
ceemic kirjutas:
sõnum 01.10.2008 07:36:46 vasta tsitaadiga
ASUS P6T Deluxe X58 Board First Look
Tundub,et plate on peaaegu valmis.Karp juba olemas ja puha thumbs_up.gif .Piltidel siis näha 2x4870X2 CF platel ja GTX280 SLI ja kamaluga Kingston HyperX mälusid icon_razz1.gif :
AJ
AJ
sõnum 01.10.2008 08:58:36 vasta tsitaadiga
Intelin Core i7 920- ja 940-prosessorit käsissä
http://plaza.fi/muropaketti/intelin-core-i7-920-ja-940-prosessorit-kasissa#kommentit
G80
G80
sõnum 02.10.2008 12:14:05 vasta tsitaadiga
tomorrow kirjutas:
Kaks sellist võiks olla küll kodus.
Corsair working on three way memory kits
http://www.fudzilla.com/index.php?option=com_content&task=view&id=9742&Itemid=1
Ära siia kliki
sõnum 03.10.2008 11:50:28 vasta tsitaadiga
Veidike halbu uudiseid icon_confused.gif :
ASUS P6T Deluxe Retail
Intel works on Nehalem Skulltrail
*Possible* Core i7 Release Date - Monday, November 17, 2008
G80
G80
sõnum 03.10.2008 13:37:03 vasta tsitaadiga
A-Data Releases Tri-Channel Memory Kits for Intel X58 Platform
http://www.techpowerup.com/72926/A-Data_Releases_Tri-Channel_Memory_Kits_for_Intel_X58_Platform.html
Ära siia kliki
Ho Ho
Ho Ho
sõnum 03.10.2008 14:01:20 vasta tsitaadiga
Umm, kas mitte umbes sarnaseid hoiatusi pole ka iga teise emaplaadi peal? A'la "liiga kõrge voldiga võid oma rauda kahjustada"?
WäntWõll
make.believe
WäntWõll
sõnum 03.10.2008 14:03:50 vasta tsitaadiga
uus teema   See teema on lukus, sa ei saa siin muuta postitusi või vastata teemale! Raud »  Protsessorid »  Intel Core i3/i5/i7/i9/Xeon protsessorite arutelu (Lisatud küsitlus: "Mis pesaga emaplaat kasutuses 1. oktoobri seisuga? mine lehele eelmine  1, 2, 3 ... 7, 8, 9 ... 346, 347, 348  järgmine
