| Mis pesaga Intel lauaarvuti emaplaat on kasutuses 2014 1. oktoobri seisuga? |
| Socket 478 |
2% |
[ 13 ] |
| LGA 775 |
13% |
[ 83 ] |
| LGA 1366 |
4% |
[ 30 ] |
| LGA 1155 |
32% |
[ 209 ] |
| LGA 1150 |
38% |
[ 243 ] |
| LGA 1156 |
3% |
[ 23 ] |
| LGA 2011 |
5% |
[ 35 ] |
| hääli kokku : 636 |
G80
210 |
heretic666
18.09.2008 19:22:03
2.66GHz Nehalem clocks to 4GHz
Mingi 1M ära teha siis resa ka icon_biggrin.gif Kui 24/7 kannataks siis oleks tegija.
http://www.fudzilla.com/index.php?option=com_content&task=view&id=9490&Itemid=1
Our sources have confirmed that...
Must be true !
| Kommentaarid: 73 loe/lisa |
G80
19.09.2008 13:56:54
Intel Decides to Unlock the Memory Mutiplier of its Core i7-920 and Core i7-940 CPUs
| Thanks to some inside information that was published today by various hardware portals, now we know that Intel has decided to enhance the overclocking capabilities of two of its still to be released non-Extreme Core i7 processors. Intel's LGA 1366 Core i7-940 and Core i7-920, which are clocked at 2.93GHz and 2.66GHz respectively will now boast unlocked memory controlers, meaning that users will be able to change the memory multiplier and thus the memory frequency beyond the stock DDR3 800/1066MHz speed. The unlocked memory multiplier will also allow the QPI speed to be changed. The Quick Path Interconnect (QPI) bus resembles AMD's Hypertransport bus. A slide change in the memory frequency will result in higher QPI bus speed, just like in the current AMD processor family. Previously, we knew that only the Core i7 Extreme processors like the 3.2GHz Core i7-965 Extreme Edition will have these overclocking features. I sincerely hope that with this last minute change Intel will make us overclockers really happy. |
http://www.techpowerup.com/71752/Intel_Decides_to_Unlock_the_Memory_Mutiplier_of_its_Core_i7-920_and_Core_i7-940_CPUs.html
210 |
19.09.2008 14:00:15
| G80 kirjutas: |
http://www.techpowerup.com/71752/Intel_Decides_to_Unlock_the_Memory_Mutiplier_of_its_Core_i7-920_and_Core_i7-940_CPUs.html |
POMM .Loodetavasti on tõsi.Siis ei imesta üldse kui i7 920 klokkub ~4Ghz-ni
| Kommentaarid: 92 loe/lisa |
G80
19.09.2008 14:06:08
| tomorrow kirjutas: |
| G80 kirjutas: |
POMM .Loodetavasti on tõsi.Siis ei imesta üldse kui i7 920 klokkub ~4Ghz-ni  |
Vaikselt hakkan nehalem jälle isu äratavaks minema.
Aga jah eks varsti ole näha, kui AHV-del masinas.
210 |
WäntWõll
make.believe
19.09.2008 15:16:57
Intel Core i7-920 (2.66GHz,8MB L3, LGA1366, Product Code BX80601920 & QPI 4.8GT/sec) Estimated Price in EU : ~260
See oleks ikka päris roogitav räim seljuhul
ooatme nüüd oktobri teise poole ära ja siis hindame olukorda uuesti
300 |
SogegaTyyp
19.09.2008 15:44:52
Einoh, kui see tavaline 2,66 GHz ja ca 4k maksev prose teeks õhuga 4Ghz, siis pole ju mingit kahtlust, mida järgmiseks masinasse osta Clock versus clock peaks see loom ju C2Duost selgelt kiirem olema, kui nüüd veel Q9650-ga samale kellale läheb...no see tundub liigagi hea, et olla tõsi. Aga tõesti, eks aeg annab arutust. Mingist konkreetsest kuupäevast ikkagi pole juttu olnud, et näiteks sel ja sel päeval tohib teste avaldada? Tõesti, praegu on seda segast infi liga palju.
| Kommentaarid: 54 loe/lisa |
51 |
G80
20.09.2008 21:13:23
Nehalem 3.2GHz goes up to 4.5GHz on air
We learned that Nehalem 3.2GHz should reach over 4GHz easily, and if you are a really good overclocker, you should hit up to 4.5GHz on air. Of course, for such a task you need a great motherboard.
Furthermore, if you want to go over 5GHz and even 5.2 to 5.3GHz you need to play with LN2 but apparently this is possible and it has been done with demo CPUs. These are some of the numbers you should be reaching once the CPU is out.
Naturally, the Core i7 Extreme edition at 3.2GHz and overvoltage protection removed should be able to reach the highest clocks. It is safe to say that whatever speeds youwe seen on Core 2 Quad 45nm Yorkfield parts, you should be getting with Nehalems or you should at least be within that range.
Looks like overclockers will like this one; but beware, the memory speeds will suck, especially compared with X48 memory scores. |
http://www.fudzilla.com/index.php?option=com_content&task=view&id=9513&Itemid=1[/b]
210 |
21.09.2008 01:05:21
Kust otsast mälukiirused sakivad siis? .See vend ikka haige kuju ma ütlen.Keegi juba kommenteeris,et ta nehalemi kohta iga variandi välja käinud.Pärast saab siis öelda - i told you so
Flavius
21.09.2008 08:33:12
fuadi novellide jaoks võiks eraldi teema teha,
uudiste ja faktidega pole seal kunagi midagi pistmist
118 |
Killhoven
OC`er
21.09.2008 11:32:09
Tõepoolest, solgiks seda teemat kah vähem. Pärast halb lugeda kui teema "müra" täis.
_________________ Foorumis on ühe lolli kohta kümme tarka, nii et jõud on enam-vähem võrdsed.™ |
| Kommentaarid: 405 loe/lisa |
349 |
G80
210 |
G80
210 |
WäntWõll
make.believe
26.09.2008 11:52:43
Pole paha jah aga eks näis mis saama hakkab kui NDA kukub.
Oktoobri teine pool peaks nati selgust tooma
300 |
Cb4
26.09.2008 11:54:43
Just...Ma olen kahe vahel, kas uuendada praegust riistvara, või oodata ja minna kohe uuele platele üle 8)
Kui alguses suuremaid ämbreid ei ilmne, siis võiks uue võtta küll!
_________________ Ma ei ole agressiivne juht, olen lihtsalt võistlushimuline.
Did i ever tell you the definition of "Insanity"? |
| Kommentaarid: 113 loe/lisa |
95 |
ceemic
24/7@kalal
322 |
AJ
26.09.2008 23:48:40
Täitsa kena plate.
| Kommentaarid: 37 loe/lisa |
36 |
01.10.2008 07:36:46
ASUS P6T Deluxe X58 Board First Look
Tundub,et plate on peaaegu valmis.Karp juba olemas ja puha .Piltidel siis näha 2x4870X2 CF platel ja GTX280 SLI ja kamaluga Kingston HyperX mälusid :
AJ
36 |
G80
210 |
G80
210 |
Ho Ho
03.10.2008 14:01:20
Umm, kas mitte umbes sarnaseid hoiatusi pole ka iga teise emaplaadi peal? A'la "liiga kõrge voldiga võid oma rauda kahjustada"?
86 |
WäntWõll
make.believe
03.10.2008 14:03:50
Ho Ho, Pole veel ühelgi näinud
Äkki oskad linkida midagi
300 |
