G80
17.02.2008 23:14:01
ATi RV770 aka HD4K seeria |
Kuna esimene korralik inff väljas siis võiks teema teha.
Muidu hakatakse teisi teemasid solkima.
ATI Radeon HD 4000 seeria tuleb siis välja kuskil Q2 lõpus/Q3 algus.
2TFLOPS:
RV770 will break 1TFLOPS, while the R700, with two RV770, should be capable of twice that, more than 2TFLOPS. This is higher than what he had expected, but then again the core frequencies are also higher than expected. All cores are made by TSMC and their 55nm process. We're still trying to hunt down more reliable information on the design of the "core". |
Lubatakse GDDR5:
| The information published elsewhere suggests that ATI will use GDDR5 to a great extent, which surprise us a little. On the other hand, ATI may know something about GDDR5 that we don't (we would be surprised otherwise). RV770 has GDDR5 support, but whether ATI will actually use it remains to be seen. GDDR4 with most of the high-end cards is a highly likely scenario. The frequencies suggested here are actually lower than what good GDDR4 chips are capable of. |
32 TMU-s:
| The number of TMUs have finally been increased, actually doubled, to 32 with RV770, while RV740 sports 24 TMUs, and the low-end RV710 has 8 TMUs. Don't bother getting upset with the 256-bit memory bus because it will not become any kind of bottleneck. The only time it might be even close to that is when you're pouring liquid nitrogen into the container and have the GPU running at +50% of stock frequency, which will happen though. |
Lõpuks ometi siis üle 1GHz peal töötav GPU(kuigi nvidial SP juba kõrgemal).
GDDR 2200MHz (4400MHz) on ka võimas aga selleks ajaks suht võimalik.
Tundub, et tuleb kõva võitlus Nvidia ja ATI vahel.
Voolutarve on ka suht inimlik.
http://www.nordichardware.com/news,7356.html
http://www.xbitlabs.com/news/video/display/20080121140756_AMD_Reportedly_On_Track_with_Next_Generation_Graphics_Chips.html
http://www.fudzilla.com/index.php?option=com_content&task=view&id=5675&Itemid=1
http://en.expreview.com/?p=182
210 |
One
17.02.2008 23:30:01
| hetkel on kõik need lekked puhas väljamõeldis
728 |
G80
18.02.2008 00:03:29
| Winterwind kirjutas: |
| hetkel on kõik need lekked puhas väljamõeldis |
Kohe kindlasti mitte kõik!!
Aga 100% tõsi see ka pole aga eks näis.
Üldiselt läheb suht täppi.
210 |
Syncmahv
18.02.2008 00:09:35
| Q2 lõpp, 3 algus? Suht hästi isegi. Loodame et jõuab siis kah selleks ajaks nagu lubatud.
102 |
A-Circus.
18.02.2008 20:04:04
| Syncmahv kirjutas: |
| Q2 lõpp, 3 algus? Suht hästi isegi. Loodame et jõuab siis kah selleks ajaks nagu lubatud. |
No sahinad on juba pikemat aega olnud, et kuskil aasta keskel (juuni-juuli) peaks need välja tulema. Samas neis andmetes midagi ebainimlikku nagu pole, et neid mitte uskuda. Kuigi see DDr4400 tundub natuke liiga suur hüpe . Loodetavasti on ka peale shaderite jms lisamise ning takti tõstmise neid ka efektiivsemaks muudetud.
| Kommentaarid: 50 loe/lisa |
48 |
heretic666
18.02.2008 22:18:55
A-Circus., Pentium 4 to Core 2 Duo oli ka suur hüpe, aga ikkagi toimus
| Kommentaarid: 73 loe/lisa |
tonism
19.02.2008 11:47:33
| heretic666 kirjutas: |
A-Circus., Pentium 4 to Core 2 Duo oli ka suur hüpe, aga ikkagi toimus  |
OT: Kas see hüpe mitte Pentium 4 > Pentium Dual Core > Core > Core 2 välja ei näinud? parandage kui eksin
tqz
19.02.2008 12:06:22
| tonx kirjutas: |
OT: Kas see hüpe mitte Pentium 4 > Pentium Dual Core > Core > Core 2 välja ei näinud? parandage kui eksin |
Ei olnud nii.
Kõigepealt tulid Core 2 Duo'd, hiljem kärbitud Pentium DC prosed.
| Kommentaarid: 74 loe/lisa |
71 |
One
19.02.2008 13:11:22
täiesti offtopic.. a mis see teema siis ikka muud on..
tqz, mis need 65nm preslerid ja 90nm prescotti baasil dualcore pentium d-d siis on?
728 |
tqz
19.02.2008 13:27:02
Jutt käis Conroe-põhistest Pentium Dual Core prosedest, mitte Netburstil põhinevatest Pentium D-dest. Vähemalt nii sain mina aru.
71 |
heretic666
19.02.2008 17:16:08
| Winterwind, üks on "Pentium D" (see sitem variant) ja teine "Pentium Dual Core". Käks erinevat nime ju.
rycyve
19.02.2008 19:11:19
[/quote]
Kuigi see DDr4400 tundub natuke liiga suur hüpe [/quote]
Ei saanud aru mida selle all mõtlesid.Kas mälusid või kaardi mudelit?
| Kommentaarid: 99 loe/lisa |
G80
19.02.2008 19:15:35
| rycyve kirjutas: |
Kuigi see DDr4400 tundub natuke liiga suur hüpe |
Ei saanud aru mida selle all mõtlesid.Kas mälusid või kaardi mudelit?[/quote]
Mina ei näe seal midagi ulmelist,ongi juba paras aeg,et GDDR5 välja tuua.
ATI võttis GDDR4 ka varakult kasutusse.
viimati muutis G80 19.02.2008 19:16:37, muudetud 1 kord |
210 |
heretic666
19.02.2008 19:16:10
| rycyve, graafikakaardi mälu jah mõtles ilmselgelt. Ja paranda tsitaat õigeks.
rycyve
19.02.2008 19:38:50
| rycyve, graafikakaardi mälu jah mõtles ilmselgelt. Ja paranda tsitaat õigeks. |
Ei teadnudki,et kaardi mälu on ddr4400.Varem oli ikka gddr2,3,4.
Tahtsin lihtsalt öelda,et ATI-l juba ammu GDDR4 kasutusel aga kasutaja G80 jõudis selle ära mainida.Lihtsalt tahtsin seda tsitaati parandada,et kui tulevikus keegi loeb siis ei aja segadusse.
WäntWõll
make.believe
19.02.2008 23:44:00
See jutt käib vist siia
Jutujärgi saab Juunis või Juulis päris palju nalja saama
If German site called HARTWARE.NET is to be believed, AMDs next generation of Radeon graphics cards could be released as early as June this year. According to the site, an AMD roadmap it has managed to acquire shows seven upcoming cards, the Radeon HD 4450, Radeon HD 4470, Radeon HD 4650, Radeon HD 4670, Radeon HD 4850, Radeon HD 4870, and Radeon HD 4870 X2. The 4400 cards will apparently feature 40 stream processors, the 4600 cards will have 240 and the 4800 cards will have 480 (with the X2 featuring 960 overall, 480 on each core). There is no firm indication of clock speeds, but the 4600 and 4800 cards are expected to run somewhere between 800MHz and 1050MHz depending on the model, ranging from 128MB of DDR2 to 1GB of GDDR5 memory. However, there are no details of which cards will be released when, just that the initial launch could be sometime in June. Remember that this information might not be completely reliable and shouldnt be interpreted as firm facts.
http://www.hartware.de/news_44085.html
300 |
CoiL
20.02.2008 00:20:58
Täitsa piix... krt miks need kaardid kõik suht lühikeste launch`ide vahega tulevad... niimoodi raske ju osta... tekib isu uuem ära oodata
| Kommentaarid: 95 loe/lisa |
83 |
its2cold
20.02.2008 00:24:45
Eks need esimesed uudised yks suur mull ole nagu alati aga julgen loota, et ATIle on head ajad tulemas. Kui Nvidia 9800GTX t6esti G92 baasil on siis v6ib ATI isegi highend turul end osaliselt maksma panna.
Olekski juba aeg 8800GTXilt kui parimalt singlechip kaardil koht 2ra v6tta ja miks mitte ka Nvidia yheksandale seeriale p2he astuda.
174 |
erick
20.02.2008 01:18:12
Re: ATI RV770 aka HD4K seeria |
| G80 kirjutas: |
Tuletan kahtlejatele meelde Samsungi GDDR5 mälude specce. Kuni 24GB/s per kiip, ATI 512bit mälusiiniga kaardile saaks neid panna 16. Ribalaius tuleks neil settingutel 384GB/s ja kiirus peaks selle saavutamiseks olema 3000MHz (6GHz DDR). Arvata võib, et ATi piirdub siiski madalama 4,4GHz või pigem isegi 4GHz mäluga. Viimane variant annaks 512bit mälusiini puhul ribalaiuseks ilusa numbri 256GB/s.
96 |
LWD
20.02.2008 09:30:50
| erick kirjutas: |
| Tuletan kahtlejatele meelde Samsungi GDDR5 mälude specce. Kuni 24GB/s per kiip, ATI 512bit mälusiiniga kaardile saaks neid panna 16. Ribalaius tuleks neil settingutel 384GB/s ja kiirus peaks selle saavutamiseks olema 3000MHz (6GHz DDR). Arvata võib, et ATi piirdub siiski madalama 4,4GHz või pigem isegi 4GHz mäluga. Viimane variant annaks 512bit mälusiini puhul ribalaiuseks ilusa numbri 256GB/s. |
gDDR5 on tõesti vägagi võimalik, ATI 256bitine laius koos 2200(4400) Mhz on tegelikult gddr5 jaoks tavaline, jääb ruumi ka overclockingu jaoks.
ATI võttis gddr4 esimesena kasutusele, seega peaks ta ka gddr5 esimesena oma kaartidele panema. gddr5 kiipide tootmine peaks algama 2008. aasta veebruaris (testkiibid jagati ATIle välja juba aasta alguses või eelmise aasta lõpus), juuniks peaks neid kiipe olema piisavalt
A-Circus.
20.02.2008 11:21:04
| CorsairX kirjutas: |
Täitsa piix... krt miks need kaardid kõik suht lühikeste launch`ide vahega tulevad... niimoodi raske ju osta... tekib isu uuem ära oodata  |
Siis jääbki raha rohkem järgi ning seda on võimalik millegi mõistlikuma peale kasutada .
48 |
G80
210 |
ppg
23.02.2008 14:08:53
| Vaadates nvidia 9 seeria teemat ja seda siis peaks Atil olema hea võimalus tõusta nvidia ees taas ette, vaadates oodatavate kaartide näitajaid.
138 |
Degwees
23.02.2008 20:00:37
Radeon HD 4870
Core clock 1050mhz
Memory clock 2200mhz(GDDR5)
Shader units 480
Täiesti haige
Tunnen nvidiale kaasa hetkel. Algul oli küll tore kuulda, et nvidia kavatseb oma 1TFLOPS kätte saada, aga siin käib jutt juba 2TFLOPSist
| Kommentaarid: 111 loe/lisa |
101 |
G80
23.02.2008 22:17:34
Kuna nvidia 9-seeria on totaalne inimeste mõnitamine, siis loodan südamest, et ATI-l õnnestub uus seeria välja tuua kiiresti ning et kõik töötaks hästi.
Samas noh R680 on juba 1TFLOPS, 2TFLOPS-i pole palju.
210 |
