uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  ATi RV770 aka HD4K seeria märgi kõik teemad loetuks
mine lehele 1, 2, 3 ... 210, 211, 212  järgmine
G80
G80
sõnum 17.02.2008 23:14:01 ATi RV770 aka HD4K seeria vasta tsitaadiga
Kuna esimene korralik inff väljas siis võiks teema teha.
Muidu hakatakse teisi teemasid solkima.
ATI Radeon HD 4000 seeria tuleb siis välja kuskil Q2 lõpus/Q3 algus.
2TFLOPS:
RV770 will break 1TFLOPS, while the R700, with two RV770, should be capable of twice that, more than 2TFLOPS. This is higher than what he had expected, but then again the core frequencies are also higher than expected. All cores are made by TSMC and their 55nm process. We're still trying to hunt down more reliable information on the design of the "core".
Lubatakse GDDR5:
The information published elsewhere suggests that ATI will use GDDR5 to a great extent, which surprise us a little. On the other hand, ATI may know something about GDDR5 that we don't (we would be surprised otherwise). RV770 has GDDR5 support, but whether ATI will actually use it remains to be seen. GDDR4 with most of the high-end cards is a highly likely scenario. The frequencies suggested here are actually lower than what good GDDR4 chips are capable of.
32 TMU-s:
The number of TMUs have finally been increased, actually doubled, to 32 with RV770, while RV740 sports 24 TMUs, and the low-end RV710 has 8 TMUs. Don't bother getting upset with the 256-bit memory bus because it will not become any kind of bottleneck. The only time it might be even close to that is when you're pouring liquid nitrogen into the container and have the GPU running at +50% of stock frequency, which will happen though.
Lõpuks ometi siis üle 1GHz peal töötav GPU(kuigi nvidial SP juba kõrgemal).
GDDR 2200MHz (4400MHz) on ka võimas aga selleks ajaks suht võimalik.
Voolutarve on ka suht inimlik.
http://www.nordichardware.com/news,7356.html
http://www.xbitlabs.com/news/video/display/20080121140756_AMD_Reportedly_On_Track_with_Next_Generation_Graphics_Chips.html
http://www.fudzilla.com/index.php?option=com_content&task=view&id=5675&Itemid=1
http://en.expreview.com/?p=182
Ära siia kliki
Kommentaarid: 256 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 210
One
sõnum 17.02.2008 23:30:01 vasta tsitaadiga
hetkel on kõik need lekked puhas väljamõeldis
G80
G80
sõnum 18.02.2008 00:03:29 vasta tsitaadiga
Winterwind kirjutas:
Kohe kindlasti mitte kõik!!
Aga 100% tõsi see ka pole aga eks näis.
Ära siia kliki
Syncmahv
Syncmahv
sõnum 18.02.2008 00:09:35 vasta tsitaadiga
Q2 lõpp, 3 algus? Suht hästi isegi. Loodame et jõuab siis kah selleks ajaks nagu lubatud.
A-Circus.
A-Circus.
sõnum 18.02.2008 20:04:04 vasta tsitaadiga
Syncmahv kirjutas:
No sahinad on juba pikemat aega olnud, et kuskil aasta keskel (juuni-juuli) peaks need välja tulema. Samas neis andmetes midagi ebainimlikku nagu pole, et neid mitte uskuda. Kuigi see DDr4400 tundub natuke liiga suur hüpe icon_rolleyes.gif . Loodetavasti on ka peale shaderite jms lisamise ning takti tõstmise neid ka efektiivsemaks muudetud.
heretic666
heretic666
sõnum 18.02.2008 22:18:55 vasta tsitaadiga
A-Circus., Pentium 4 to Core 2 Duo oli ka suur hüpe, aga ikkagi toimus thumbs_up.gif
tonism
sõnum 19.02.2008 11:47:33 vasta tsitaadiga
heretic666 kirjutas:
OT: Kas see hüpe mitte Pentium 4 > Pentium Dual Core > Core > Core 2 välja ei näinud? parandage kui eksin
tqz
tqz
sõnum 19.02.2008 12:06:22 vasta tsitaadiga
tonx kirjutas:
Ei olnud nii.
Kõigepealt tulid Core 2 Duo'd, hiljem kärbitud Pentium DC prosed.
Kommentaarid: 75 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 72
One
sõnum 19.02.2008 13:11:22 vasta tsitaadiga
täiesti offtopic.. a mis see teema siis ikka muud on..
tqz, mis need 65nm preslerid ja 90nm prescotti baasil dualcore pentium d-d siis on?
tqz
tqz
sõnum 19.02.2008 13:27:02 vasta tsitaadiga
Jutt käis Conroe-põhistest Pentium Dual Core prosedest, mitte Netburstil põhinevatest Pentium D-dest. Vähemalt nii sain mina aru. icon_rolleyes.gif
heretic666
heretic666
sõnum 19.02.2008 17:16:08 vasta tsitaadiga
Winterwind, üks on "Pentium D" (see sitem variant) ja teine "Pentium Dual Core". Käks erinevat nime ju.
rycyve
rycyve
sõnum 19.02.2008 19:11:19 vasta tsitaadiga
[/quote]
Kuigi see DDr4400 tundub natuke liiga suur hüpe icon_rolleyes.gif [/quote]
Ei saanud aru mida selle all mõtlesid.Kas mälusid või kaardi mudelit?
Kommentaarid: 100 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 83
G80
G80
sõnum 19.02.2008 19:15:35 vasta tsitaadiga
rycyve kirjutas:
Ei saanud aru mida selle all mõtlesid.Kas mälusid või kaardi mudelit?[/quote]
Mina ei näe seal midagi ulmelist,ongi juba paras aeg,et GDDR5 välja tuua.
Ära siia kliki
viimati muutis G80 19.02.2008 19:16:37, muudetud 1 kord
heretic666
heretic666
sõnum 19.02.2008 19:16:10 vasta tsitaadiga
rycyve, graafikakaardi mälu jah mõtles ilmselgelt. Ja paranda tsitaat õigeks.
rycyve
rycyve
sõnum 19.02.2008 19:38:50 vasta tsitaadiga
Ei teadnudki,et kaardi mälu on ddr4400.Varem oli ikka gddr2,3,4.
Tahtsin lihtsalt öelda,et ATI-l juba ammu GDDR4 kasutusel aga kasutaja G80 jõudis selle ära mainida.Lihtsalt tahtsin seda tsitaati parandada,et kui tulevikus keegi loeb siis ei aja segadusse.
WäntWõll
make.believe
WäntWõll
sõnum 19.02.2008 23:44:00 vasta tsitaadiga
Jutujärgi saab Juunis või Juulis päris palju nalja saama
If German site called HARTWARE.NET is to be believed, AMD’s next generation of Radeon graphics cards could be released as early as June this year. According to the site, an AMD roadmap it has managed to acquire shows seven upcoming cards, the Radeon HD 4450, Radeon HD 4470, Radeon HD 4650, Radeon HD 4670, Radeon HD 4850, Radeon HD 4870, and Radeon HD 4870 X2. The 4400 cards will apparently feature 40 stream processors, the 4600 cards will have 240 and the 4800 cards will have 480 (with the X2 featuring 960 overall, 480 on each core). There is no firm indication of clock speeds, but the 4600 and 4800 cards are expected to run somewhere between 800MHz and 1050MHz depending on the model, ranging from 128MB of DDR2 to 1GB of GDDR5 memory. However, there are no details of which cards will be released when, just that the initial launch could be sometime in June. Remember that this information might not be completely reliable and shouldn’t be interpreted as firm facts.
http://www.hartware.de/news_44085.html
CoiL
CoiL
sõnum 20.02.2008 00:20:58 vasta tsitaadiga
Täitsa piix... krt miks need kaardid kõik suht lühikeste launch`ide vahega tulevad... niimoodi raske ju osta... tekib isu uuem ära oodata icon_neutral.gif
Kommentaarid: 95 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 83
its2cold
sõnum 20.02.2008 00:24:45 vasta tsitaadiga
Eks need esimesed uudised yks suur mull ole nagu alati aga julgen loota, et ATIle on head ajad tulemas. Kui Nvidia 9800GTX t6esti G92 baasil on siis v6ib ATI isegi highend turul end osaliselt maksma panna.
Olekski juba aeg 8800GTXilt kui parimalt singlechip kaardil koht 2ra v6tta ja miks mitte ka Nvidia yheksandale seeriale p2he astuda.
Kommentaarid: 197 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 174
erick
erick
sõnum 20.02.2008 01:18:12 Re: ATI RV770 aka HD4K seeria vasta tsitaadiga
G80 kirjutas:
Tuletan kahtlejatele meelde Samsungi GDDR5 mälude specce. Kuni 24GB/s per kiip, ATI 512bit mälusiiniga kaardile saaks neid panna 16. Ribalaius tuleks neil settingutel 384GB/s ja kiirus peaks selle saavutamiseks olema 3000MHz (6GHz DDR). Arvata võib, et ATi piirdub siiski madalama 4,4GHz või pigem isegi 4GHz mäluga. Viimane variant annaks 512bit mälusiini puhul ribalaiuseks ilusa numbri 256GB/s.
LWD
sõnum 20.02.2008 09:30:50 Re: ATI RV770 aka HD4K seeria vasta tsitaadiga
erick kirjutas:
gDDR5 on tõesti vägagi võimalik, ATI 256bitine laius koos 2200(4400) Mhz on tegelikult gddr5 jaoks tavaline, jääb ruumi ka overclockingu jaoks.
ATI võttis gddr4 esimesena kasutusele, seega peaks ta ka gddr5 esimesena oma kaartidele panema. gddr5 kiipide tootmine peaks algama 2008. aasta veebruaris (testkiibid jagati ATIle välja juba aasta alguses või eelmise aasta lõpus), juuniks peaks neid kiipe olema piisavalt
A-Circus.
A-Circus.
sõnum 20.02.2008 11:21:04 vasta tsitaadiga
CorsairX kirjutas:
Siis jääbki raha rohkem järgi ning seda on võimalik millegi mõistlikuma peale kasutada icon_biggrin.gif.
G80
G80
sõnum 22.02.2008 12:50:48 vasta tsitaadiga
R700 based on shared memory architecture
R700 architecture is different from R680 as it posesses the ability for the 2 RV770 GPUs to address a common pool of memory. R700 could possibly the first card to run Crysis flawlessly. Also the recent specs leaked on Radeon HD 4000 series are fake according to them.
http://forums.vr-zone.com/showthread.php?t=239077
R700 is still not HD4000
http://www.fudzilla.com/index.php?option=com_content&task=view&id=5863&Itemid=1
Ära siia kliki
ppg
ppg
sõnum 23.02.2008 14:08:53 vasta tsitaadiga
Vaadates nvidia 9 seeria teemat ja seda siis peaks Atil olema hea võimalus tõusta nvidia ees taas ette, vaadates oodatavate kaartide näitajaid.
Kommentaarid: 171 loe/lisa Kasutajad arvavad:  :: 1 :: 5 :: 138
Degwees
sõnum 23.02.2008 20:00:37 vasta tsitaadiga
Radeon HD 4870
Core clock 1050mhz
Memory clock 2200mhz(GDDR5)
Shader units 480
Tunnen nvidiale kaasa hetkel. Algul oli küll tore kuulda, et nvidia kavatseb oma 1TFLOPS kätte saada, aga siin käib jutt juba 2TFLOPSist icon_biggrin.gif
Kommentaarid: 111 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 101
G80
G80
sõnum 23.02.2008 22:17:34 vasta tsitaadiga
Kuna nvidia 9-seeria on totaalne inimeste mõnitamine, siis loodan südamest, et ATI-l õnnestub uus seeria välja tuua kiiresti ning et kõik töötaks hästi.
Ära siia kliki
Degwees
sõnum 23.02.2008 22:23:15 vasta tsitaadiga
Kõige lahedam on vast see, et selle HD 4870 saab panna CF-X icon_biggrin.gif
G80
G80
sõnum 23.02.2008 22:31:00 vasta tsitaadiga
Degwees kirjutas:
Ei tea kuidas selle HD 4870X2-ga on aga HD 3870X2 saab panna ainult CF.Ehk siis kui ATI muudatusi ei tee siis 4TFLOPS.
Ära siia kliki
noonius
noonius
sõnum 23.02.2008 22:39:41 vasta tsitaadiga
jube elajas, mis mul täpselt puudu on.
Ootasin nvidia 9 seeria gtx-i, et saaks upgrade' ära teha, kuid nüüd, kus on teada, et 9 seeria on vaid hädine rahastusprojekt G92 kiibi turjal, tuleb ATI ära oodata.
Igatahes, preagused andmed ati kohta on vägagi lootustandvad
Mingi paks pihv paugub siin
Degwees
sõnum 23.02.2008 22:54:21 vasta tsitaadiga
Killhoven
OC`er
Killhoven
sõnum 24.02.2008 12:57:41 vasta tsitaadiga
ATI HD4K seerial on tõesti igati head väljavaated, sest see 9xxx seeria ei paku midagi uut.
Kommentaarid: 409 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 351
CoiL
CoiL
sõnum 24.02.2008 13:56:00 vasta tsitaadiga
Mnjah... mina hetkel veel ei rõõmustaks väga (kuigi tahaks icon_biggrin.gif ). Loodan, et HD4K tuleb õigel ajal välja ja töötab ilma probleemideta.
G80
G80
sõnum 24.02.2008 14:02:30 vasta tsitaadiga
CorsairX kirjutas:
Väga palju inimesi mõtleb nii, isegi nvidia fännid.
Päris paljud inimesed on ikka vihased/pettund nvidia 9-seeria pärast.
Ära siia kliki
heretic666
heretic666
sõnum 24.02.2008 14:26:29 vasta tsitaadiga
G80, khm, võhikud ikkagi foorumites ahhetavad, et wooow, 9800GTX, how much more powerful it will be than 8800GTX. Im so waiting for this (järgnevad emotikonid).
G80
G80
sõnum 24.02.2008 14:28:20 vasta tsitaadiga
Mingi taunid jah ,et ooooooo 9800GTX OMGWOOOFWOAH. icon_lol.gif icon_lol.gif icon_lol.gif
Ära siia kliki
Scart
Scart
sõnum 24.02.2008 14:36:43 vasta tsitaadiga
G80 kirjutas:
Nii. Edasi? Vähem möla ja rohkem villa või kuidas see reklaam välja nägigi.
Kui nende specidega tuleb, siis saab lõpuks oma 8800GTSi välja vahetada ehk isegi jälle korraliku AMD kaardi vastu. Natuke imelik juba, sama kaart masinas 2006 talvest saadik beer_yum.gif
EDIT: mul on üsna ükskõik, milline uus Nvidia lipulaev tuleb. Mind huvitab see, et keskklass tuleks võimalikult kiire ja odav mõlema tootja jaoks, nii et oleks ka reaalselt seekord valida enne ostu.
heretic666
heretic666
sõnum 24.02.2008 14:50:19 vasta tsitaadiga
Scart, ole ei imelik midagi, rahakott võidab.
ppg
ppg
sõnum 10.03.2008 00:49:16 vasta tsitaadiga
G80
G80
sõnum 10.03.2008 09:30:59 vasta tsitaadiga
AMD lowers RV770 reference frequencies
Back in February, figures said that final RV770 would be <50% faster than RV670. Right now, the reference design is somewhere in the range of 40% faster. We're three months from the first unveilment, but the figure is looking quite solid.
http://www.nordichardware.com/news,7470.html
Ära siia kliki
Xenomorph
sõnum 11.03.2008 14:25:47 vasta tsitaadiga
HD4870 hind tuleb siis umbes 3kilo kanti ?
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 29
rycyve
rycyve
sõnum 11.03.2008 20:42:16 vasta tsitaadiga
StaticX kirjutas:
Mille järgi sa seda arvad?
noonius
noonius
sõnum 11.03.2008 21:04:12 vasta tsitaadiga
millegipärast arvan, et nii 299 taala ehk siis meil koos igasuguste mõnusate juurdehindlustega nii 4K.
Xenomorph
sõnum 11.03.2008 22:21:42 vasta tsitaadiga
Arvan , et mitte :=) pakuks , et 299 taala +18%käibemaksu
aiff
sõnum 12.03.2008 00:08:45 vasta tsitaadiga
veel uudiseid!
http://www.nordichardware.com/news,7489.html
erick
erick
sõnum 12.03.2008 14:26:44 vasta tsitaadiga
Head uudised on siia teemasse vahepeal lisandunud. 32 TMU-d - oli ka viimane aeg. Seda oodati juba 2005 kui X1800 XT välja tuli. Võib arvata, millist fillrate'i pakuvad 32 TMU-d @ ~1GHz. Ootan huviga suve icon_smile.gif
EDIT: uurisin järele, et 8800 GTX/Ultra omavad juba 64 TMU-d @ 575/612MHz. Niiet suht blah. icon_razz.gif
Draco
Draco
sõnum 28.03.2008 12:22:29 vasta tsitaadiga
Uusi uudiseid
http://forums.vr-zone.com/showthread.php?t=255294
EDIT: On mingeid kindlamaid launch date`e ka avaldatud HD4000 seeria kohta?
noonius
noonius
sõnum 28.03.2008 13:13:57 vasta tsitaadiga
Ei midagi. Alguses käis jutt Q2 (juuni lõpp), kuid see tundub vägagi ebatõenäoline. Nüüd on hakatud spekuleerima Q3/Q4 aega ehk sama mis uuel nvidial. Hullemad heietavad regilaulu isegi Q1 2009-st. Loodetavasti tuleb ikka 2008 välja, kindlamalt saab öelda siis, kui kaarti on kusagil messil näidatud. Tavaliselt läheb pärast seda nii kuu aega, kui kaart väljas on.
Draco
Draco
sõnum 28.03.2008 13:58:12 vasta tsitaadiga
Nii , et mingeid mai-juuni sonimisi ei tasu siis tõsiselt võtta icon_rolleyes.gif
EDIT: Siin räägib midagi mai lõpust
http://vr-zone.com/articles/AMD_%26_Nvidia_New_Graphics_Cards_Line-Up_For_Q2/5679.html
djkiller
djkiller
sõnum 28.03.2008 13:58:45 vasta tsitaadiga
Nt mina kes ple eriti mängur ootan selle ati imekaardi ära ja ostan kah sügiseks:D uhke tunne .Loodame ,etATI ei põru läbi icon_wink.gif
Kommentaarid: 223 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 202
One
sõnum 28.03.2008 14:10:06 vasta tsitaadiga
eks see reaalne launch ole juuni-august vahel.
Draco
Draco
sõnum 09.04.2008 11:13:18 vasta tsitaadiga
RV770 kiibid ahjus?
http://www.fudzilla.com/index.php?option=com_content&task=view&id=6721&Itemid=1
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  ATi RV770 aka HD4K seeria mine lehele 1, 2, 3 ... 210, 211, 212  järgmine
