connect
17.10.2007 18:46:11
viimati muutis connect 12.06.2013 17:55:42, muudetud 1 kord |
RassK
17.10.2007 19:14:48
neid omega drivereid HD 2600XT'le ka on? ise esialgu ei pannud küll tähele.
E: Sain
viimati muutis RassK 17.10.2007 20:20:05, muudetud 1 kord |
102 |
TheIV
17.10.2007 20:02:16
| TanelJ kirjutas: |
| 7.10 driverid juba paar päeva kasutuses ja probleeme ei esine. |
Tore mul on su üle hea meel mul endal 7.7 peal ja probleeme ei esine DAAAA. Iseeneset kui, mõelda kui komplitseeritud ehitusega juba arvuti on ja kogu see driverita ja windoosa koostöö siis pole ime kui, viga on kuskil imepisikeses koodi jupis mingi X programmiga ja kõik. Enamusel töötab vot mull mitte. homme muudad endal mingit setingut installid midagi uninsatllid midagi .....
| Kommentaarid: 15 loe/lisa |
14 |
trv
31.10.2007 21:46:03
kes soovib, siis linuxile on mõnda aega juba saadaval ka 8.42.3 ehk 7.10 ajurid. toetab kaarte alates r300 seeriast, suur performance boost, aiglx support.
_________________ I need a break. I just tried to read 'Oxford' as a hexadecimal. |
| Kommentaarid: 139 loe/lisa |
126 |
G80
21.11.2007 23:14:42
AMD releases Catalyst 7.11
A little later than expected AMD has finally released the Catalyst 7.11, a release supporting the most graphics capr of the Spider platform, the Radeon HD 3800 series. The full list of supported cards includes the HD 3800s, X850s, HD 2900s, X800s, HD 2600s, X700s, HD 2400s, X600s, X1950s, X550s, X1900s, X300s, X1800s, 9800s, X1650s, 9700s, X1600s 9600s, X1550s, 9550s, X1300s, 9500 and X1050s and features lots of fixes like:
- Bioshock: Pulling the lever in the chamber no longer results in the game failing
- Bioshock, Lost Planet, and World In Conflict: Connecting certain dual link display devices to certain ATI Radeon 2x00 series of cards no longer results in limited display resolutions being available
- Call of Juarez: Enabling CrossFire no longer results in flickering being noticed when playing the DX10 version of the game
- Doom 3: Playing the game on a system containing an ATI Radeon HD 2600 series of product and running the Windows Vista operating system no longer results in display corruption being noticed when using the console commands
- Fable: A black ring is no longer seen around the player character
- Hellgate, Lord of the Rings, PT Boat, and World in Conflict: Corruption is no longer noticed when AA is enabled
- Rainbow Six Vegas: Setting the display resolution to 1600x1200 and applying the in-game settings to high no longer results in corruption being noticed when using an HDMI display device
- Roxio Creator Premier v9: MyDVD: Attempting to burn a DVD no longer results in the burn process failing at the encoding preview
- Serious Sam: the Second Encounter Demo: Game play is no longer delayed when playing the game on a system running Windows XP and containing an ATI Radeon HD 2400 series of product
http://ati.amd.com/support/driver.html
http://game.amd.com/us-en/drivers_catalyst.aspx
210 |
WäntWõll
make.believe
22.11.2007 00:22:15
G80, 5+ post just lasin 7.10 testid om a 2900pro-ga
aga nüüd anname endast parima 8)
300 |
TheIV
24.11.2007 18:21:56
Hmm sama jama muidu ok, kui steami käima paned color 8 pit. Aga muidu on parem küll.
14 |
WäntWõll
make.believe
300 |
heretic666
21.12.2007 18:55:50
Lasin Catalysti peale, kuid imelik asi on see, et kohati on boldiga kirjutatud hyperlingid nüüd pruuni värvi, mitte sinised (n juutuubis olevad "related videos" pealkirjad on pruunid).
EDIT : samalaadne mure ka kasutajal Syncmahvil, ATI jälle mingi käkiga hakkama saanud.
| Kommentaarid: 73 loe/lisa |
21.12.2007 19:07:10
| wanawoll kirjutas: |
Mõni mode võiks pealkirja kah täpseks panna |
heh, lõpuks lisati siis ka HD2900GT tugi...
proovisin täna - töötas.
_________________ MÜÜA: Xbox 360 E 250GB (UUS) |
313 |
Syncmahv
22.12.2007 12:01:34
| heretic666 kirjutas: |
EDIT : samalaadne mure ka kasutajal Syncmahvil, ATI jälle mingi käkiga hakkama saanud. |
Jep, Mitte ainult Youtubes kirjad muutunud vaid ka mõnes teises kohas mõned kirjad teist värvi
102 |
heretic666
22.12.2007 12:17:10
| Jah, sisuliselt igal pool. Ka neti.ee-s
Marduuhin
108 |
masterx
22.12.2007 18:51:24
Mul ka selline värk operaga (explorer ja avant on korras) ning arvuti käivitamisel see winni tekst ka pruunikate äärtega.
Käkk need draivud kindlasti pole,kaardi pervomants tõusis kõvasti
164 |
G80
26.12.2007 09:24:19
Comparsion test: Catalyst 7.11 vs 7.12
WIC-is on päris kena FPS-i lisa. 8)
http://en.expreview.com/?p=144
edit: Vanaks hakkad jääma.
viimati muutis G80 26.12.2007 09:30:16, muudetud 1 kord |
210 |
| Kommentaarid: 92 loe/lisa |
heretic666
26.12.2007 12:50:46
Firefox siis seda asja ei taha
emarrdos
27.12.2007 23:32:16
Ega ta vist praegust ole veel toores hd 3800 seeria jaoks...mul igatahes läks seele draiveri paigaldus üle kivide ja kändude.
Win XP juhtis minu tähelepanu asjaolule,et mingi kala on draiveris...aga nüüdseks on asi kuidagi iseenesest paika lokksunud...
ühesõnaga tööötab
| Kommentaarid: 11 loe/lisa |
9 |
WäntWõll
make.believe
11.01.2008 22:10:33
link :: Siin nad siis on,kuid veel betad ATI Catalyst 8.1 Vista 32/64-bit (beta)
Ainult VISTA esialgu
AMD is preparing a brand new Catalyst driver for its Radeon graphics card series. But, at least Vista users, don't have to wait much as a beta version of the new Catalyst 8.1 has found its way online.
Featuring the 8.452 display driver, the Catalyst 8.1 for both the 32 and 64bit version of Windows Vista comes with support for almost everything released since the days of the Radeon 9550 plus a few cards and IGPs that haven't been released - the Radeon HD 3200, 3450, 3470, 3650 and the dual-RV670 Radeon HD 3870 X2. |
300 |
entusiast
13.01.2008 21:34:30
sain murest lahti.
_________________ JÖUDU! |
102 |
Hardi
| Kommentaarid: 84 loe/lisa |
WäntWõll
make.believe
17.01.2008 00:19:36
kohe laseme peale
300 |
masterx
17.01.2008 00:23:01
Julm hüpe (viimased cat 7,2).Eks paneb ka siis tõmbama
164 |
WäntWõll
make.believe
17.01.2008 00:28:06
WTF 8)
7.12 ja dets. 07
300 |
masterx
17.01.2008 00:42:30
WTF 8)
7.12 ja dets. 07
Eino, vahepeal oleks nagu pidanud olema 7,3 jne
täpsemalt siis cat 7.12 ja dets (20.12.2007)
Pruun värv on ka kadunud
164 |
