uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  G70/71 ehk GF7800/7900/7600 seeria teema märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 18, 19, 20 ... 294, 295, 296  järgmine
stepzter
stepzter
sõnum 13.07.2005 17:05:56 vasta tsitaadiga
Graafikakaartide kiirus on tõusnud märgatavalt kiiremini, kui prosade oma. Seega, kui paar aastat tagasi koormas mäng 50% prosat ja videokaart oli täies ulatuses pudelikaelaks, siis nüüd videokaart ( või -kaardid) istub pool aega tööta ja prosa ägab 100% koormuse all.
One
sõnum 13.07.2005 21:00:27 vasta tsitaadiga
NVIDIA GeForce 7800GT Has 20 Pipes
VR-Zone has learned that the upcoming GeForce 7800 GT will be 20 pipes instead
of 24 pipes as intially reported. The vertex shader could probably stay at 8 and
ROP at 16. The core clock for 7800GT is 400MHz instead of 335MHz initially thought.
It will be interesting to see if the 4 hidden pipes can unlocked on the 7800 GT to
become GTX. The 7800GT is slated for launch on 11th Aug at Quakecon 2005 and
MRSP for this card is US$449. Also NVIDIA won't release their 7800 Standard yet
until their 6800 inventory are cleared.
http://www.techpowerup.com/?4153
NVIDIA's Secret Weapon : G71
At first we thought that G71 is for mid range segment to replace 6600 series but it turned
out otherwise. The secret weapon for NVIDIA against ATi's R520 is actually G71, the successor
to the current G70. VR-Zone has learned that G71 is based on a finer 90nm process technology
at TSMC like the R520. NVIDIA is likely to make a switch when the process technology is more
mature like towards end of the year. No doubt, the core frequency can be clocked higher on
finer process. However, we can't rule out the possibility of releasing 7800Ultra on the 90nm
G71 core when R520 launched since volume production are not expected for such a high-end
GPU. Of course it could be based on 110nm process initially as INQ has suggested. 32-pipes
or not, it is still unknown.
http://www.vr-zone.com/?i=2445&s=1
Elof
Elof
sõnum 13.07.2005 21:05:10 vasta tsitaadiga
umm, nvidia ju kardab räigelt seda 90nm tehnoloogiat
Peaks aga matrosovlikut pea ees pimedusse hüppama ?
viimati muutis Elof 13.07.2005 21:06:34, muudetud 2 korda
Ho Ho
Ho Ho
sõnum 13.07.2005 21:05:18 vasta tsitaadiga
Loomulikult et kardab, vaata kuidas läks tehnoloogia vahetusega NV30 seerial ning kuidas ATI r520'ga vaevles/vaevleb. Kui pole korralikku uurimustööd tehtud pole mõtet kiirustada, eriti siis kui praeguse tehnoloogiaga tehtud kaardid on hetkel saada olevast kiireimad ning konkurents puudub.
HDTanel
Overclocker
HDTanel
sõnum 13.07.2005 21:16:24 vasta tsitaadiga
Kas mitte pole nVidia kaardid suts aeglasemad 3DMark05-s, et kasutavad PS3 kui ATI kaardid PS2 tuge? Winter möliseb siin, et see ei mõjuta midagi. Ei tahaks nagu uskuda, et midagi ei mõjuta
Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
lamp
lamp
sõnum 13.07.2005 21:25:04 vasta tsitaadiga
PlatoonSgtElias kirjutas:
kas 3dmark05 kasutab ps3?
eriti julm
Kommentaarid: 191 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 168
HDTanel
Overclocker
HDTanel
sõnum 13.07.2005 21:56:58 vasta tsitaadiga
Noh on ju valikud olemas ja by default on nvidial Pixel shader 3
Vertex Shader Profile 3_0
Pixel Shader Profile 3_0
Krüpto
One
sõnum 13.07.2005 22:00:28 vasta tsitaadiga
Ho Ho
Ho Ho
sõnum 13.07.2005 22:03:23 vasta tsitaadiga
Aga on keegi kiiruses vahet märganud?
Kusagilt peaks ju saama muuta kas kasutada sm3 või sm2
One
sõnum 13.07.2005 22:06:11 vasta tsitaadiga
Ho Ho kirjutas:
muuta saab aint PRO userina...
aga:
http://www.clubic.com/actualite-12835-far-cry-les-performances-sm2-vs-sm3.html
näiteks farcry-s on sm3 kiirem kui sm2, vaevalt, et 3dmarkis vastupidi on...
HDTanel
Overclocker
HDTanel
sõnum 13.07.2005 22:09:23 vasta tsitaadiga
by default lasevad kõik ikka... nii nagu ette nähtud. Lihtsalt tahan näha kas vahet ka on neil asjadel. Ei tasu ikka niisama ka naerma hakata kui proovinud ple.
Krüpto
margusser
sõnum 14.07.2005 23:58:20 vasta tsitaadiga
http://www.vr-zone.com.sg/Shamino/39880.gif
Kommentaarid: 215 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 167
HDTanel
Overclocker
HDTanel
sõnum 15.07.2005 00:00:05 vasta tsitaadiga
Kahtlane... kus link on?
Krüpto
viimati muutis HDTanel 15.07.2005 00:01:19, muudetud 1 kord
One
sõnum 15.07.2005 00:00:55 vasta tsitaadiga
varsti 3dmark 05 ka seal 50k kandis ja prosed ikka venivad täiega icon_lol.gif
Ho Ho
Ho Ho
sõnum 15.07.2005 00:08:35 vasta tsitaadiga
Vast siis kui dualcored on FX/PM efektiivsusega ~6GHz juures või siis kui Inteli Itanium2 ja Xeon lõpuks kokku saavad ~4-5GHz kandis, varem tõenäoliselt mitte. Prose on ikka väga jõhkraks piduriks selliste kaartide puhul nign praegu pole midagi näha kah et olukord märgatavalt paraneks.
Auron
Auron
sõnum 15.07.2005 09:45:38 vasta tsitaadiga
Justnimelt.PS3'ga on lihtsam renderdada ja sellest peaks tulema ka kiirusekasv.
Boot
sõnum 15.07.2005 16:30:05 vasta tsitaadiga
Ho Ho kirjutas:
mängude puhul kindlasti aga 3dmarkis(uuemates) pole prose küll hetkel piduriks.
razor
sõnum 15.07.2005 16:30:46 vasta tsitaadiga
05'es just prose hetkel piduriks...
Kommentaarid: 132 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 120
margusser
sõnum 15.07.2005 16:31:01 vasta tsitaadiga
tonism
sõnum 15.07.2005 16:41:12 vasta tsitaadiga
niipalju, kui mina olen aru saanud, ei ole SM2 ja SM3 mitte mingit pildi vahet. erinevus pidavat olema sellest, et SM3's saab asjad tunduvalt lihtsamini ära teha, tänu millele lüheneb ka käskude mälumise aeg. vähemalt kusagilt kunagi hakkas nii silma, aga võin ka eksida
razor
sõnum 15.07.2005 17:55:05 vasta tsitaadiga
kui programm ei ole SM3 native siis ei saa ta mitte midagi juurde sellest...
One
sõnum 15.07.2005 20:14:19 vasta tsitaadiga
razor kirjutas:
eks igalpool ole prose piduriks..
aga mis sa tahad öelda, et 2 x 32 piibuga kaarti @ SLI/CF oleks tulemus sama?
razor
sõnum 16.07.2005 13:30:50 vasta tsitaadiga
ainult GT3 pealt...
One
sõnum 16.07.2005 18:39:27 vasta tsitaadiga
link :: Nvidia's G71 is also dual slot
igasugu toredat "infi"
seda 800mhz on air värki tahaks küll näha
Scart
Scart
sõnum 16.07.2005 20:03:59 vasta tsitaadiga
Winterwind kirjutas:
arvestades, et käivad jutud nvidia pullitegemisest ehk siis 7800GTX on sama, mis eelmise põlvkonna 6600 ning g71 on 90nm peal.... siis miks mitte icon_wink.gif (antud info oli nvzone'is aga eemaldati nvidia käsul)
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  G70/71 ehk GF7800/7900/7600 seeria teema mine lehele eelmine  1, 2, 3 ... 18, 19, 20 ... 294, 295, 296  järgmine
