borru
13.05.2005 22:47:39
tellisin 20 x86 ja 10 a64
kohale tuli 10 x86 ja 10 a64
aega võttis ca 2 kuud
| Kommentaarid: 13 loe/lisa |
raido357
14.05.2005 08:15:19
borru, aga see eest saad tasuta et tasuks rahul olla
| Kommentaarid: 78 loe/lisa |
borru
14.05.2005 10:57:17
lisaks paistis pakk korduvalt lahti võetud olema ja ülimalt kortsus oli.
aga jah.. siin need viimased mul seisavad.. enamus sai kohe külapeale laiali jagatud
Alari A.
14.05.2005 17:39:30
mul sama lugu ju siis kontrolliti,et hollandist rohelist puru vms.ei saadetaks
ps.keegi teba kuidas muuta gaimi system tray iconit?
edit:sain korda!
| Kommentaarid: 671 loe/lisa |
547 |
tolm
15.05.2005 09:20:23
nüüd probleem siis GCC'ga. asi selles, et proovin kerneli sortsu (2.6.10) kaustas teha make oldconfig ja siis make gconfigm, aga ette viskab ta mingeid gcc erroreid:
root@koduarvuti:/usr/src/linux # make oldconfig
/usr/src/linux/scripts/gcc-version.sh: line 1: gcc: command not found
HOSTCC scripts/basic/fixdep
/bin/sh: line 1: gcc: command not found
make[1]: *** [scripts/basic/fixdep] Error 127
make: *** [scripts_basic] Error 2
peale on installitud uusib gcc, mingid gcclibid ja gcc-base.
| Kommentaarid: 12 loe/lisa |
12 |
Hardi
15.05.2005 13:33:08
Devilguy,
| sudo apt-get install build-essential |
, peale seda ka sama jama ?
_________________ ツ |
| Kommentaarid: 84 loe/lisa |
tolm
15.05.2005 20:49:10
root@koduarvuti:~ # apt-get install build-essential
Reading Package Lists... Done
Building Dependency Tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
build-essential: Depends: libc6-dev but it is not going to be installed or
libc-dev
Depends: g++ (>= 3:3.3) but it is not going to be installed
E: Broken packages
root@koduarvuti:~ #
kui apt-get install build-essential teen.
12 |
Alari A.
15.05.2005 23:56:01
| lõpuks sain mplyeri korralikult tööle kuid kuidas subtiitreid suuremaks saaks?
547 |
cbr
16.05.2005 00:00:08
Kui su mplayer on pärit marillat'i repost, siis
| # dpkg-reconfigure mplayer-fonts |
ja sealt valid suurema fondisuuruse.
| Kommentaarid: 48 loe/lisa |
39 |
Alari A.
17.05.2005 11:53:41
tänud asi korras
kas gnome bakeriga saab dvd isot kärsatada?vaatan,et menüüs ainult cd image olemas
1 hea vidin,et kiirendada startupi http://www.marzocca.net/linux/ubm.html
547 |
lammas
19.05.2005 00:43:08
Ega keegi ubuntuga vpn ühendust ei kasuta?
Krt hetkel netitoru vaid 100kbit/s vaja vpn ühendus luua siis saab 512kbit/s
_________________ SEO teenused - https://seo-teenus.ee/ | Kodulehtede tegemine - https://kodulehetegemine.me |
| Kommentaarid: 113 loe/lisa |
102 |
muri666
19.05.2005 01:50:10
| digweed kirjutas: |
mul oli samuti pakk lahti võetud ja ära nässutatud. Mõtlesin juba postkontoris häält tõstma hakata.
| Kommentaarid: 41 loe/lisa |
39 |
Kert1
19.05.2005 10:43:01
kas keeg ivõix täpselt seletad kuidas ma ubuntus firefoxi 1.0.2'elt 1.0.4'jale saaxin updateda.... apt-get seda ei tee sest näitab et kõige uuem ver. on 1.0.2. Kuidas vana ver eemaldada ja uus ilusti tööle saada ? Abi palux
| Kommentaarid: 28 loe/lisa |
26 |
Alari A.
547 |
Kert1
19.05.2005 12:50:54
tänud:)
updatesin ära ... Help/about näitab et 1.0.4 aga kui themesid tahan tõmmata siis firefoxi lehel ütleb ikke et UPDATE:P
26 |
Hardi
19.05.2005 18:02:11
Kert1, mõnedel juhtudel on masinale restardi tegemine aidanud.
droz
19.05.2005 18:50:02
| hardi_k kirjutas: |
| Kert1, mõnedel juhtudel on masinale restardi tegemine aidanud. |
aidanud firefoxile uut theme panna
| Kommentaarid: 4 loe/lisa |
Hardi
19.05.2005 19:03:10
irw .. ei , mitte seda. Aidanud ses suhtes ,et siis tunnistab see theme site ka firefox 1.0.4 õieti.
Kert1
19.05.2005 20:46:23
| hardi_k kirjutas: |
| irw .. ei , mitte seda. Aidanud ses suhtes ,et siis tunnistab see theme site ka firefox 1.0.4 õieti. |
seekord see nii ei ole
26 |
Hardi
19.05.2005 21:05:49
Niih , siin siis variant mis aitama peaks:
Firefoxi adress reale - about:config
ning siis seal > general.useragent.vendorSub, muuta 1.0.4 peale.
Kert1
19.05.2005 21:36:31
| hardi_k kirjutas: |
ning siis seal > general.useragent.vendorSub, muuta 1.0.4 peale. |
Toimis ... tänud:)
Siis tyytan veel nati:P ... Kas Firefoxil linuxis on QuickTime toetus ka? kui on siis kust saada ja kuda...mulle jäi mulje et puudub veel siiamaani. Aga vb exin.
ja see asi: et kui Ubuntus akna alla paned... siis tuelvad need akstikesed onja ( lähevad väiksemax: ) kudagi seda maha ei saa võtta? et nuh aken lisalt kohe eest ära lähex mitte ei animeerix seal kes teab mida:P
26 |
gandalf
19.05.2005 21:40:38
QuickTime'i asendusena toimib Mplayer ja mplayerplug-in. selle kooslusega saab peaaegu kõik tööle.
Hangid MPlayer'i (selle kohta siin õpetusi enam kui küll) ja selle plugina pakinimi peaks olema mozilla-mplayer (vähemalt debian unstable'l on, nii et võiks ka ubuntul olla)
Kert1
19.05.2005 22:03:15
| gandalf kirjutas: |
Hangid MPlayer'i (selle kohta siin õpetusi enam kui küll) ja selle plugina pakinimi peaks olema mozilla-mplayer (vähemalt debian unstable'l on, nii et võiks ka ubuntul olla) |
kuidas ma step by step selle Mplayeri siis ikkagi tööle saan ... apt-get seda mul küll ette ei too ... source list on muudetud õieti minu arust
26 |
Hardi
19.05.2005 22:03:30
jah , Mplayer ajab asja ära küll. täpsemalt siis ka siin sellest > http://www.ubuntuguide.org/#mplayer
Selle akende minimize-maximize animatsiooni sai imo kuidagi Gconf-editoris maha keerata.
Kuigi sellega kaasnes ka see ,et akende liigutamisel muutusid need läbipaistvateks ruutudeks :]
Kert1
19.05.2005 23:36:23
mplayer igatahes tööle ei hakka tegin selle õpetuse järgi
siis tuleb starting Mplayer ja kõik sinna see jääbgi
26 |
