uus teema   vasta Hinnavaatlus »  Microsoft »  Skype üldteema märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 8, 9, 10 ... 137, 138, 139  järgmine
.Scorps.
.Scorps.
sõnum 24.02.2005 13:22:02 vasta tsitaadiga
borru, funny.exe kujutab endast viirust W32.Funner. Lähemalt siit.
tiith
maxnorm
tiith
sõnum 24.02.2005 19:26:11 vasta tsitaadiga
hmm..kust saada seda plugiini, mis paneb mulle peakirja, mis lugu on winampis mängimas?
mTim
mTim
sõnum 24.02.2005 20:04:35 vasta tsitaadiga
NxP kirjutas:
Lexuse summutist tuleb vaid lilleõisi ja ükssarvepeeru - HV foorum
M: E36 varuosad
Rix
Rix
sõnum 24.02.2005 20:18:33 vasta tsitaadiga
NxP kirjutas:
Song2Nick plugin
function: Changes automaticly your nick with the current playing song.
supported players: Windows Media Player 9, MusicMatch JukeBox 8.1, Winamp 2, Winamp 3, Winamp 5, iTunes
thread: http://msgplus.mybboard.com/showthread.php?tid=18116
author: Wouter
MPWinamp Plugin
function: Changes automaticly your nick at certain intervals with the current playing song.
supported players: Winamp
note: open-source! (released under the GPL license at Sourceforge)
thread: http://msgplus.mybboard.com/showthread.php?tid=33673
author: ErikSchierboom
MSN Winamp Auto Nick Changer
description: This is not a Messenger Plus! plugin; it doesn't require Messenger Plus!
supported players: Winamp 2, Winamp 3
thread: http://msgplus.mybboard.com/showthread.php?tid=13384&pid=143203#pid143203
author: monty_burns_007
BK's Winamp Extension plugin
function: Alternative for (!WAT)
description: With this (old) plugin you can also send other info about the song to your contacts, by using directly the ID-tags of the songs (ID3v1, Lyrics3-tags).
thread: http://msgplus.mybboard.com/showthread.php?tid=20313&pid=192927#pid192927
author: BKqc
WMPlus2 plugin
description: With this plugin you can also send other info about the song to your contacts.
supported players: Windows Media Player, Winamp 2, Winamp 5, Sonique
homepage: http://www.x2software.net/wmplus/
thread: http://msgplus.mybboard.com/showthread.php?tid=15675
author: PsychoMark
NowPlaying plugin
description: With this (old) plugin you can also send other info about the song to your contacts and even sending the song itself.
supported players: Winamp 2, Winamp 3, Winamp 5, MusicMatch JukeBox (partial)
download: http://www.msgplus.net/pluginsdb/down/pafiledb.php?action=file&id=46
author: DJMystic (TheBlasphemer) based on Lareamond's work.
FooBar plugin
description: With this (old) plugin you can also send other info (song, songtitle, artist) about the song to your contacts.
supported players: FooBar2000
thread: (v1.5) http://msgplus.mybboard.com/showthread.php?tid=18075
thread: (v1.52) http://msgplus.mybboard.com/showthread.php?tid=24386
author: wipey
Others (iTunes)
description: If you use iTunes, you can have also an alternative for the (!WAT) tag. But this requires adding a plugin to iTunes itself, not to Plus!.
supported players: iTunes
thread: http://msgplus.mybboard.com/showthread.php?tid=22911&pid=219394#pid219394
note: There is also a request being made to make a real Plus! plugin for this program, so far nobody has made one (see http://msgplus.mybboard.com/showthread.php?tid=16882).
rmg
rmg
sõnum 24.02.2005 22:59:36 vasta tsitaadiga
|V|355 VV17|-| 7}{3 |3357, [)13 (_1|<3 7]-[3 R357
crv
sõnum 27.02.2005 20:39:19 vasta tsitaadiga
Rix kirjutas:
NxP kirjutas:
Song2Nick plugin
author: Wouter
MPWinamp Plugin
author: BKqc
WMPlus2 plugin
author: PsychoMark
NowPlaying plugin
FooBar plugin
author: wipey
Others (iTunes)
Lisan siia veel s3ven winamp msn nick plugina ;)
http://www.s3ven.freesurf.fr/index.php?l=EN&menuid=2a
borru
borru
sõnum 03.03.2005 11:24:47 vasta tsitaadiga
kuidas seda ära saada:
Your buddy has a new Buddy Icon. Take a look! http://buddies.funbuddyicons.com/?ZUxdm072YYEE
@[fwpscript]Icon:none@[/fwpscript]
Rajareits
Rajareits
sõnum 03.03.2005 17:29:05 vasta tsitaadiga
borru kirjutas:
Siis, kui selle saasta arvutist minema saadad ja enam ei tõmba.
Kuna antud juhul oli sõbra arvutis see jama, siis pead teda aitama.
borru
borru
sõnum 03.03.2005 21:35:21 vasta tsitaadiga
Rajareits kirjutas:
borru kirjutas:
ehk peab ta siis sellise teekonna läbima.[/url]
only
sõnum 04.03.2005 22:17:14 vasta tsitaadiga
mul mingi niimoodi selle krdim 6.2 -ga et kui m2ngin cs:source siis vahes see tähendab mitte alati kuid suht tihti ei l2he msn 6.2 enam k2ima..task manageris n2itab et protsess töötab ja kui uuesti proovin siis ei juhtu ka midagi(tekib lihtsalt üks lisa protsess)..aitab ainult restart..btw sisse saan alati logida win messengeriga mis suuht kaka...
keegi oskab äkki selle msn 6.2 juures aidata???
Dominus
Dominus
sõnum 04.03.2005 23:39:33 vasta tsitaadiga
http://join.msn.com/?page=dept/dialup&pgmarket=en-us&ST=1&xAPID=1983&DI=1402 no näiteks www.msn.com peaks midagi ytlema kui midagi uut peaks tulema icon_smile.gif
.Scorps.
.Scorps.
sõnum 05.03.2005 00:25:51 vasta tsitaadiga
MSN Messengeri seadetes Tools --> Options --> General on linnukese kast "Display MSN Today when Messenger signs in". Vajutasin Help ja kõige "informatiivsem" leht on SEE. Mis on MSN Today?
John Smith
sõnum 05.03.2005 19:46:27 vasta tsitaadiga
icon_redface.gif No ei leidnud sellist teemat. Aga need sisse ja välja jne logimis helid kadunud, lambist olid, enam pole. Kasutasin 7.0 betat nüüd panin 6.2 tagasi ikka pole. Teisel kasutajal on olemas. Ja ei ole ka võimalust neid muuta st. windooza helide all on küll MSN kõige viimane kuid alajaotused puuduvad. Ei ole küll suur mure aga jube tüütu, kui ei pane tähele kui keegi kirjutab
icon_lol.gif kuna pole foorumis nii ammu kirjutanud panin kaks korda järjest "vasta" aseme "uus teema" icon_redface.gif
Kui te panete midagi mällu, jätke meelde, kuhu te panete.
atu1234
sõnum 05.03.2005 19:58:16 vasta tsitaadiga
Mis kamm on, et ei saa neid icon_eek.gif icon_evil.gif panna msn custom emotconideks, pilt jääb siuke `karvane`
Msn 6.2
UMMI9999
UMMI9999
sõnum 05.03.2005 20:05:56 vasta tsitaadiga
John Smith kirjutas:
Kas optionsitest on helide mängimise ees linnukesed olemas?
Quid est veritas?
Kes teab vastust?
John Smith
sõnum 05.03.2005 20:17:47 vasta tsitaadiga
No ikka on, igal pool on ainult helisid pole?
mTim
mTim
sõnum 05.03.2005 20:24:16 vasta tsitaadiga
M: E36 varuosad
John Smith
sõnum 05.03.2005 20:28:44 vasta tsitaadiga
No ma saan aru, et mu küsimus oli võib olla rumal aga no ma ikka saan aru kas arvuti teeb häält või mitte,
KADUNUD on AINULT MSN-iga seotud helid ja Windowsist ei lase neid muuta, Helide all puudub MSN kohapeal alajaotus
mTim
mTim
sõnum 05.03.2005 20:49:57 vasta tsitaadiga
MSN optioni alt saab kah helisid OFF/ON lülitada, aga võibolla ei leia ta neid helisid üles mida ta peab mängima
M: E36 varuosad
UMMI9999
UMMI9999
sõnum 05.03.2005 20:57:05 vasta tsitaadiga
Igaks juhuks võid ju ka vaadata, kas MSN Messengeri kaustas on helide failid olemas
Quid est veritas?
Kes teab vastust?
John Smith
sõnum 05.03.2005 20:59:42 vasta tsitaadiga
No sa lugesid minu esimesest postitusest, et teisel kasutajal kõik korras! Järelikult need helid ka seal kaustas olemas icon_rolleyes.gif
.Scorps.
.Scorps.
sõnum 05.03.2005 21:18:26 vasta tsitaadiga
atu1234 kirjutas:
Msn 6.2
HV emotikonid on MSNi omadest mõõtmetelt väiksemad, seetõttu MSN suurendab neid ja suurendamise tõttu jääbki pilt karvane.
WerteX
sõnum 06.03.2005 12:17:17 vasta tsitaadiga
Täna panin huvitavat asja tähele, kui minna MSN-i allalaadima, siis esmalt pakutakse MSN 7.0 BETAT mitte enam 6.2-te.
X
X
sõnum 06.03.2005 14:38:00 vasta tsitaadiga
Et nagu, laadsin siis selle 7.0 beta ja msn pplus 7 beta ka. Aga suke probleem, et kui ennem kui parema klahviga nime peale vajutasid tuli tema e-maili aadress ka, aga nüüd enam seda pole, kuda ma tean kes on kes?
Kangur
sõnum 06.03.2005 15:24:25 vasta tsitaadiga
X kirjutas:
Kui hiirega suunad mingi nime peale, kas siis ei näita e-maili?
X
X
sõnum 06.03.2005 19:42:05 vasta tsitaadiga
ei näita jah icon_sad.gif .
Edit:Tegelt näitab küll ,aga seal tuleb natuke rohkem otsida, aga käib küll. 8)
Nganasan
Nganasan
sõnum 07.03.2005 10:57:25 vasta tsitaadiga
keegi selle msn 7-ga samas võrgus asuvasse arvutisse mingit suurt faili on õnnestunud saata? Endal tekks vajadus saata ~700MB faili ja msn 7 ei tulnud sellega toime, võttis enda alla faili suuruse jagu virtuaalmälu ja jäigi kõvakat ragistama, vastu võtta suurt faili sai küll. Tol hetkel oli kiireim lahendus 6.2 peale ja probleemid kadusid.
borru
borru
sõnum 07.03.2005 12:52:43 vasta tsitaadiga
Nganasan kirjutas:
selle jaoks. Muidu saadad faile läbi usa lääneranniku.
ja järgmine küsimus siis, et kas on mõnda sellist messengeri olemas mis lubaks igale minu kontaktnimekirjas olevatele tegelasele erineva sisselogimisel esitatava tunnusheli seada?
Rajareits
Rajareits
sõnum 07.03.2005 15:48:01 vasta tsitaadiga
borru, ega ei saada ikka küll. Võrgus ühendused loodud siis lähevad failid nagu lipsti.
Nganasan, miks välja ei jaganud?
crv
sõnum 07.03.2005 16:26:24 vasta tsitaadiga
borru
borru
sõnum 07.03.2005 17:55:30 vasta tsitaadiga
parool võõrastes kätes.
Rajareits
Rajareits
sõnum 07.03.2005 18:45:38 vasta tsitaadiga
borru, ei ole. Mingi viiruseke jälle liikuma saanud, mis igast jama nüüd saadab. Seepärast soovitangi alati asjad üle küsida enne kui midagi vastu võtate. Vaadake nimed ka üle.
prints
sõnum 07.03.2005 19:30:19 vasta tsitaadiga
sama siingi soovitan ennem üle küsida kas asi on ikka õige
k2iguvahetaja
sõnum 07.03.2005 19:30:58 vasta tsitaadiga
Yea, ma märkasin ka, et viiruseid levikul. Dumbuserid vaatavad ohhooooo, lahe pic. .pif icon_rolleyes.gif
mTim
mTim
sõnum 07.03.2005 21:11:06 vasta tsitaadiga
Mul logib MSN sisse ära ja sis ütleb, et ma olen kuskil mujal ennast sisse loginud icon_biggrin.gif
Kuigi tglt ei ole & midagi ei juhtu kah
M: E36 varuosad
asus_cusl2
sõnum 07.03.2005 21:42:07 vasta tsitaadiga
mtimmo kirjutas:
Mul oli ka midagi sarnast vahepeal.
Aga mul selline probleem, et msn lgib mind korraks välja ja siis kohe sisse tagasi? millest see võib tulla?
borru
borru
sõnum 07.03.2005 22:19:07 vasta tsitaadiga
Rajareits kirjutas:
borru, ei ole.
Nganasan
Nganasan
sõnum 07.03.2005 23:34:19 vasta tsitaadiga
Rajareits kirjutas:
Olin just winile repairi teinud, muist seaded olid paigst ära ja see kellele saata tahtsin ei pääsenud kohaliku võrgu kaudu ligi, praegu väljajagamine jälle toimib, a 6.2 jätan vast esialgu alles.
Millal see msn 7 oma beetastaatusest välja jõuda võiks?
aksel
aksel
sõnum 08.03.2005 16:06:08 vasta tsitaadiga
asus_cusl2 kirjutas:
mtimmo kirjutas:
See Reconnect - imine ja ise automaatselt connectimine on viimasel ajal tekkinud jah ja jube tihedalt. Ühtegi faili avanud pole nii et viirusega ei tohiks tegemist olla. F-secure peal ka. Mis jama on?
crv
sõnum 08.03.2005 16:13:31 vasta tsitaadiga
aksel kirjutas:
mtimmo kirjutas:
Mul logib MSN sisse ära ja sis ütleb, et ma olen kuskil mujal ennast sisse loginud :D
Kusjuures sama siin,samas on hea ilma multimsnita seda värki kasutada,mul jääb teine msn tavaliselt lahti :D
Ja siis mul endal ka üks mure moodi asi...msn plus ei hakka tööle startupiga...mitte kuidagi kohe.
Reinstalli olen proovind jne.
Alien
Alien
sõnum 08.03.2005 17:52:29 vasta tsitaadiga
kus msn 7.0 seda paika saaks panna et kui kontaktisik offline läheb et aknas ka seda näitaks (no vanasti oli see kollane kiri et.. appears to be offline) icon_rolleyes.gif icon_redface.gif
dvd vader
sõnum 08.03.2005 21:17:32 vasta tsitaadiga
kas kellelgi on kah olnud selline imelik probleem nagu mul:
mul on msn-i kontaktides üsna palju inimesi, aga ainult ühe puhul on selline jama, et alati kui ta sisse logib, viskab msn mulle ette teate, et peab nüüd sulgema ja kas tahan saata bugi reporti. siis paneb end kinni ja ma pean msn-i uuesti kävitama. see on absoluutselt alati 100% juhtudest nii, et kui see teine kasutaja logib end sisse, kohe viskab mind välja. mulle tundub, et see jama on alates sellest ajast, kui läksin üle versioonile nr. 7.0. teisel kasutajal sama versioon, aga jah, mitte ühegi muu kasutaja puhul sellist nalja ei ole. meie operatsioonisüsteemide puhul ei ole ka sellist kombinatsiooni, mida muude kasutajatega ei esineks, ja üldse kõik tundub väga tavapärane
Ra*
Ra*
sõnum 08.03.2005 21:34:46 vasta tsitaadiga
dvd vader kirjutas:
see ei tundu loogiline.
võibolal sul mingi lisa- nt msn plus! ja pandud valik,et kui ta sisse tulab mingi eriline hääl või muu tzikibriki tuleks- ja siis seal kuskil kokkujooksnud
dvd vader
sõnum 08.03.2005 22:05:16 vasta tsitaadiga
ei ole midagi pandud. kõik on täpselt samamoodi nagu kõigil teistel listis olijatel, ainult selle vahega, et ühe konkreetse inimese sisselogimisel alati lükatakse mul msn kinni ja pakutakse error reporti saatmise võimalust. mul läks päris tükk aega, enne kui ma sellest seosest aru sain
Blody_Hell
Blody_Hell
sõnum 09.03.2005 19:06:24 vasta tsitaadiga
Bropia viirus !!!!!!
nmida teha?
Only the dead have seen the end of war…
Kangur
sõnum 10.03.2005 00:01:15 vasta tsitaadiga
Blody_Hell kirjutas:
nmida teha?
Loe:
https://foorum.hinnavaatlus.ee/viewtopic.php?t=161138
Ehk saad targemaks.
Rix
Rix
sõnum 10.03.2005 01:32:35 vasta tsitaadiga
http://www.mmaailm.net/modules.php?name=News&file=article&sid=86
svenman
sõnum 10.03.2005 15:10:40 vasta tsitaadiga
dvd vader kirjutas:
Tasuks vaadata selle kasutaja nimi kriitilise pilguga üle. Nii palju kui ise 7.0-i natuke proovisin, siis osade tähemärkide ja sümbolite peale, kasutaja nimes hakkas erroreid pilduma. Muud ei oska praegu arvata. Ikkagi beeta icon_wink.gif
K3891
K3891
sõnum 11.03.2005 09:58:45 vasta tsitaadiga
Kas on mingit võimalust MSN panna kõiki minu listis olevaid tervitada nende sisselogimisel minu poolt?
lapsesuu: "kui sa surnud oled, siis ei saa sa ise sellest aru, ainult teistel on raske. samamoodi on siis, kui sa loll oled"
v1per
sõnum 11.03.2005 17:55:43 vasta tsitaadiga
kas keegi teab kust saaks tasuta tõmmata msnile emotione mis oleksid suured ja liikuvad ja koht võiks olla selline kust ei tuleks kaasa igasugu muud pahna nagu üks koht on emotionid olid lahedad aga browserile ilmus kohe mingi web bar ja viiruse tõrje pani üürgama
uus teema   vasta Hinnavaatlus »  Microsoft »  Skype üldteema mine lehele eelmine  1, 2, 3 ... 8, 9, 10 ... 137, 138, 139  järgmine
