mine lehele eelmine  1, 2, 3 ... 313, 314, 315 ... 318, 319, 320  järgmine
Hardi
Hardi
sõnum 04.05.2025 10:15:34 vasta tsitaadiga
Kommentaarid: 84 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 70
Optimist
Optimist
sõnum 13.05.2025 00:10:01 vasta tsitaadiga
https://www.techpowerup.com/336670/sata-io-publishes-amd-ryzen-threadripper-pro-9000-wx-series-page
https://www.techpowerup.com/336647/amd-epyc-venice-leak-2-nm-zen-6-and-zen-6c-to-offer-up-to-256c-512t-and-1-gb-of-l3-in-a-single-socket
2nm & Venice will support both 16-channel (SP7) and 12-channel (SP8) DDR5 configurations, accommodating up to 6 TB of system RAM per socket.
LLM gang be like: Bro do you even MCP
Kommentaarid: 10 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 8
1dumbpcuser
sõnum 14.05.2025 04:49:57 vasta tsitaadiga
AMD says AM5 platforms can support CUDIMMs, but won't commit to a release date
https://www.tomshardware.com/pc-components/cpus/amd-says-am5-platforms-can-support-cudimms-but-wont-commit-to-a-release-date
Even though AMD's AM5 platform is designed to support all features of DDR5 memory modules, including CUDIMMs, the company's existing Ryzen 7000 cannot work with CUDIMMs at all, whereas Ryzen 8000, and Ryzen 9000-series CPUs do not fully support such modules. Nonetheless, AMD's AMD's AM5 infrastructure has everything to support clock unbuffered memory modules, according to Sourabh Dhir, product management lead for gaming and workstations, who spoke to Digital Trends.
For now, Ryzen 7000-series processors are completely incompatible with CUDIMM memory modules: if installed, the system will fail to boot. By contrast, Ryzen 8000 and 9000 series CPUs can technically work with CUDIMMs, but only in a limited fallback configuration known as 'bypass mode', which ignores the clock driver chip on the module and, therefore, offers no advantage. This means that the system will start in DDR5-3200 mode and will require manual adjustment of the memory transfer rate, and therefore, there will be no performance guarantees.
M: MSI B660M MORTAR
M: Dell RTX 2060
O: AM5 ITX emaplaat
sõnum 14.05.2025 10:28:34 vasta tsitaadiga
Intelil töötab ja AI teemas annab kasu. Samas minu meelest neid teste veel väga vähe, eriti kui AMD-ga võrrelda ei saa icon_lol.gif
Optimist
Optimist
sõnum 22.05.2025 16:36:51 vasta tsitaadiga
Juulis uued Threadripperid samale socketile
https://www.techpowerup.com/337070/amd-announces-ryzen-threadripper-pro-9000-shimada-peak-hedt-processors
1dumbpcuser
sõnum 26.05.2025 17:08:35 vasta tsitaadiga
1dumbpcuser kirjutas:
Asrocki vastus:
Link
M: MSI B660M MORTAR
M: Dell RTX 2060
O: AM5 ITX emaplaat
Zonerman
Zonerman
sõnum 28.05.2025 13:43:52 vasta tsitaadiga
Sisuliselt Asrock mätsis kinni AMD prohmaka. Arusaadav, kuna mõlemad on pikaaaegsed partnerid ja ei taha teineteisele jalga lasta. AMD agesa ja bios andis ette väga kõrge piiri emaplaadi tootjatele ja ASrock kasutas selle maksimumi ära. Kuid mingitel tingimustel võib see 3D prose kahjustada. Viimane bios alandas emaplaadi seatud piire prosele, kui temp ja voldid seda lubasid eriti AIO'ga.
Sõim ja räuskamine läheb SIIA
sõnum 28.05.2025 15:07:04 vasta tsitaadiga
AMD B650 Chipset Is Reportedly Discontinued In Favor Of B850 Chipset, But The Remaining Stock Will Be Available For A Few Months
https://wccftech.com/amd-b650-chipset-is-reportedly-discontinued-in-favor-of-b850-chipset/
B650 väidetavalt EOL. Laojäägid veel.
Vaatasin Geizhals'st, et B650 on saadaval 71 plaati vahemikus ~80-300.
B850 on saadaval 56 plaati vahemikus ~106-300. Seega plaatide valik väiksem ja madalamas otsas hind kõrgem.
neoman
sõnum 07.06.2025 21:12:39 vasta tsitaadiga
Millal rohkem kui 16 tuuma oodata on AM5 platvormile? Või peab ikka workstation poole vaatama.
Kommentaarid: 80 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 72
heretic666
heretic666
sõnum 07.06.2025 21:32:07 vasta tsitaadiga
Lähiaastatel ei usu küll et consumer platform niipea üle 16 (performance) core saab
Optimist
Optimist
sõnum 07.06.2025 23:23:43 vasta tsitaadiga
neoman kirjutas:
Ca 2026 Zen6 pidi tulema 12 tuuma per CCD ehk siis 24 kiiret tuuma kahe CCD peale praeguse 18 asemel. Zen6C tuumadega (väiksem cache, takt) mahutab üks CCD isegi 16 tuuma ära aga siiani on sellised tuumad valdavalt EPYCute sisse panded nende klientide jaoks kellel max arv tuumasi vaja per socket.
https://wccftech.com/amd-next-gen-ryzen-zen-6-medusa-ridge-cpus-12-24-32-core-up-to-128-mb-l3-cache/
Saadavuse kohta pole kindlat inffi täna ja EPYC/Threadripper on ainuke asjalik viis kohe praegu palju tuumasid saada.
siinus
siinus
sõnum 08.06.2025 01:19:28 vasta tsitaadiga
neoman kirjutas:
Mis usecase see >16core nõudega on kui mitte workstation?
Selline kõrge multithreading workload jääb üldiselt juba mälu bandwidthis või pci-e lane'des bottleneckima, niiet HEDT platvormist enivei ei pääse.
Kui päriselt põhjendadki ära, siis keegi sinu jaoks ei hakka ühte unikaalset proset arendama.
suck less | no slop grenade
Kommentaarid: 70 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 63
Kristoferr
Kristoferr
sõnum 08.06.2025 09:23:36 vasta tsitaadiga
Jah, ilmselt Zen6 AM5 tippmudel tuleb 24tuuma, aga sealt ülespoole on vaja juba ThreadRipper.
Ma isiklikult rohkematest tuumadest puudust ei tunne, aga oluliselt kiiremate tuumadega võiks AMD küll üllatada. +20% IPC oleks täitsa ahvatlev.
Liitu Opencode Go soodsa coding plaaniga ja saa 5€ soodust!
Liitu Wise'ga!
Kommentaarid: 267 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 218
sõnum 08.06.2025 13:05:06 vasta tsitaadiga
Ma pigem tahaks rohkem tuumasi samal kivil mis tundub, et ka juhtub kui minnakse 8 pealt 12 peale. Üldine tuumade hulk sellega suureneb, aga see pole minu jaoks nii kriitiline.
Ühtlasi loodan, et mälukontrollerit parandatakse oluliselt, et kõrgemad sagedused ja neli pulka samaaegselt oleks ka kõrgetel sagedustel stabiilne. Ühtlasi, et latentsus oleks sama madal või madalam.
Paha ei teeks ka see kui L3 kogus suureneks. Kellade osas ma kahtlen, et eriti ruumi on ja kahtlen, et 6Ghz näeme stockis.
Optimist
Optimist
sõnum 08.06.2025 17:50:56 vasta tsitaadiga
Tomorrow kirjutas:
Quote mu üleval pandud lingist "The standard AMD Zen 6 CCDs will offer a 50% increase in cache count over the Zen 5 cores"
sõnum 08.06.2025 19:19:27 vasta tsitaadiga
4mb per core. 8-core zen5 ccd seega 32mb. 12-core zen6 ccd seega 48mb. 50% increase...
- londiste
Vael
sõnum 09.06.2025 15:50:59 vasta tsitaadiga
Mul kahtlane tunne, et kuna VRAMi puhverdamist on viimasel ajal mängudes juurde tulnud, siis madalam latentsus mäluk8ntrolleri osas ja ddr6 või stabiilne 4kanaliga ddr5@ 8000MHz võiks hetkel kõvasti perfi anda...
Kui vaadata i7 8700+ 8GB 9060xt tulemusi, siis sellist PCIe kiirusest sõltuvust nagu ei mäleta. Alati sai selle 5% erinevust 8/4x kanaliga eelmistel PCIe põlvkondadel vs kõige uuem kätte. Aga nüüd kukkus ikkagi x16 perf täitsa ära...
sõnum 09.06.2025 16:23:37 vasta tsitaadiga
vram puhverdamist? see on gpu peal. gpu on parimal juhul pcie 5.0 x16 siini taga, 63GB/s-ish max. see on dual-channel ddr5 puhul lihtsalt kätte tulev läbialse. viide mälukontrolleris kahvatub pci-e oma juures. lisaks siis ei ole see puhverdamine reeglina nii viitetundlik niikuinii. ehk siis ddr5 mälukontroller proses on gpu mälusüsteemi ja selle andmete liigutamise juures pea täies ulatuses kõrvaline.
integreeritud video on teine lugu aga seal on see pudelikaelandus niikuinii keerulisem.
- londiste
sõnum 13.06.2025 16:19:43 vasta tsitaadiga
AMD Silently Releases the Ryzen 5 5500X3D CPU
https://www.techpowerup.com/338001/amd-silently-releases-the-ryzen-5-5500x3d-cpu
Renq
Renq
sõnum 13.06.2025 22:40:17 vasta tsitaadiga
Tomorrow kirjutas:
Ma olen ammu hellitanud mingit lootust, et tuleks veel üks am4 high end gaming CPU välja... Võib-olla roosa unistus a no loota ju võib.
sõnum 31.07.2025 09:01:43 vasta tsitaadiga
Renq kirjutas:
Tomorrow kirjutas:
Pole nagu eriti midagi välja pigistada sealt. Mängude jaoks oli 5800X3D. Nüüd 5700X3D. MT jaoks 5950X.
Micron lõpetas ka DDR4 tootmise, seega DDR4 hinnad hakkavad samuti tõusma.
EDIT:
AMD Readies Ryzen 5 9600X3D to Spice Up the Mid-range
https://www.techpowerup.com/338186/amd-readies-ryzen-5-9600x3d-to-spice-up-the-mid-range
EDIT 2:
AMD to Rely on TSMC’s N2P Process for Most Zen 6 Products, Lower-End Laptop SKUs Likely to Use N3P
https://wccftech.com/amd-to-rely-on-tsmc-n2p-process-for-most-zen-6-products/
Ühtlasi on jutt, et Zen 6 tuleb 7Ghz, aga ma ei usu seda. Selle ennustamisega on juba varem näppu lõigatud, kui Zen 3 ennustati 5Ghz, aga tuli 4.9Ghz (5950X) ja Zen 4 ennustati 6Ghz, aga tuli 5.7Ghz ja Zen 5 jäi samaks ega olnud isegi 5.8
Mina pakun, et tuleb 6-6.4Ghz parimal juhul. Üle 6.4 ei usu.
EDIT 3:
AMD Prepares Granite Ridge PRO Chips And Ryzen 7 9700F For Consumers As Spotted On ASUS Website; Core Clock, Cache, And TDP Leaked
https://wccftech.com/amd-prepares-granite-ridge-pro-chips-and-ryzen-7-9700f-for-consumers-as-spotted-on-asus-website-core-clock-cache-and-tdp-leaked/
EDIT 4:
AMD to Rehash Ryzen 8000G Desktop APUs as 9000G Series: Rumor
https://www.techpowerup.com/339420/amd-to-rehash-ryzen-8000g-desktop-apus-as-9000g-series-rumor
AMD Now "World's Fastest" in Nearly all Processor Form-factors
https://www.techpowerup.com/339435/amd-now-worlds-fastest-in-nearly-all-processor-form-factors
anubis
anubis
sõnum 04.08.2025 17:24:19 vasta tsitaadiga
Link
Vael
sõnum 05.08.2025 07:43:29 vasta tsitaadiga
Nagu sai juba mainitus, siis uus 2700 i7 Sandy Bridge.
Ainuke jama on selles, et bottleneck on juba hetkel, UE5 on väga prose nõudlik.
sõnum 11.08.2025 17:41:35 vasta tsitaadiga
AMD Readies Two New 3D V-Cache Ryzen 9000 "Zen 5" Desktop CPUs, 8 Core With 96 MB & 16 Core With 192 MB "Dual X3D"
https://wccftech.com/amd-readies-new-3d-v-cache-ryzen-9000-zen-5-desktop-cpus-8-core-96-mb-16-core-192-mb-dual-x3d/
Potentsiaalselt uus 16c dual-X3D tulemas. 9990X3D?
See 8c on ilmselt 9700X3D. Sama nagu 9800X3D aga veidi madalamate kelladega.
EDIT:
AMD's Next-Gen AM6 Socket Expected to Boost Pin Count to 2100 While Matching AM5 Size
https://www.techpowerup.com/339636/amds-next-gen-am6-socket-expected-to-boost-pin-count-to-2100-while-matching-am5-size
EDIT 2:
AMD Ryzen 7 5700X3D Disappears from the Market
https://www.techpowerup.com/339805/amd-ryzen-7-5700x3d-disappears-from-the-market
lauri23
lauri23
sõnum 14.08.2025 15:40:52 vasta tsitaadiga
Biosest kuskil saab määrata et 5700x3d ennast ei downclockiks oma nägemise järgi? Koormuse all BF6 betas 70C peal surub vägisi ennast 3950 MHz peale, tahaks ikka kogu lubatud võimsust kasutada. Samas desktopil ei ole ka vaja idles max clocki peal istuda.
Tasuta 50$pokkeri kontole. Registreeri, õpi strateegiat ja vasta küsimustele. Saad valitud pokkerituppa 50$+veel boonust, kui mängida oskad. Isiklikult saanud 285$ sealt.
c4v6
c4v6
sõnum 14.08.2025 15:43:34 vasta tsitaadiga
No mis sul sellest kas ta on idles max kloki peal või mitte?
Aga ühesõnaga see vana hea läbi käidud PBO teema ilmselt. Normaalset jahutust tahab ka saada.
Suvalise õhu + BCLK'ga sain ise nii https://hwbot.org/benchmarks/cinebench_-_r23_multi_core_with_benchmate/submissions/5729353
Emotsionaalne suruja
https://hwbot.org/users/tannu013/ C'mos, Simmo... Pole hullu, ma klokin esimest korda
https://discord.gg/4CKG5Vnqc - PC huviliste discord
Kommentaarid: 72 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 68
lauri23
lauri23
sõnum 14.08.2025 16:07:06 vasta tsitaadiga
212 hyper black on peal aga x3d jaoks võiks beed 70 esimesse poolde jäävad tempid ju ok olla? Hea meelega ei hakkaks undervoltima a kui ei saa muudmoodi siis peab proovima.
Snaxez
Snaxez
sõnum 14.08.2025 16:21:17 vasta tsitaadiga
see 3950mhz on sul ilmselt all core load, mis võiks olla täiesti fine tava 5700x3d puhul. Default boost clock on 4100, aga see on pigem single thread loadi all mõeldud. Sa võid limiteerida threade, mida BF6 kasutab.
https://www.reddit.com/r/Battlefield/comments/1mldunn/fixing_common_pc_issues_in_battlefield_6_beta/
Ja undervoltimine on sul puhas win, kui sa OC-da ei taha. Jookseb jahedamalt, seega saab ka kõrgemale boostida. Miinuseid ei ole.
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 54
sõnum 14.08.2025 16:42:52 vasta tsitaadiga
Undervolt on jah win-win. Traditsioonilist allcore OC ei ole mõtet teha kui päevad läbi allcore workloadi ei jooksuta.
Nagu öeldud, siis undervolt muudab selle jahedamaks ja lubab kõrgemale boostida.
-30 on maksimaalne mille saab curve optimizeris seada. Enamus peaks sellega stabiilsed olema. Kui ei ole, siis võib tõsta -25 peale. Selle peal peaks iga isend stabiilne olema.
fgth
sõnum 18.08.2025 00:08:47 vasta tsitaadiga
BF6 betas 5700x3d (õhkjahutus) hakkas 80 kraadi juures protsessori takt langema 4025mhz-ni, seni oli stabiiselt 4050mhz.
Muutsin natuke cpu ventilaatori fan curve-i, siis püsis temperatuur kuni 77 kraadi maksimaalselt ning siis jäi takt 4050mhz peale
muidu mul on ka -30 kõikidel tuumadel undervolt
anubis
anubis
sõnum 18.08.2025 00:18:39 vasta tsitaadiga
CO on jah, kõige elementaarsem ja esimene asi mis kohe ära teha Ryzenil. Win-Win.
sõnum 18.08.2025 09:33:52 vasta tsitaadiga
Tomorrow kirjutas:
võib-olla on mulle lihtsalt sattunud kehvad isendid reas aga ei, -25 ega ka -15 ei ole teps mitte iga isendiga stabiilsed. iga tüüpi random crashid, kaasa arvatud need pealtnäha gpu crashid nagu inteliga olid, tulevad liigse co agarusest päris lihtsalt.
- londiste
fgth
sõnum 18.08.2025 10:35:20 vasta tsitaadiga
5600x puhul sain toimima maksimaalselt -20 aga 5700x3d -30 toimib ilusti, eks seal loto moment ka sees
sõnum 18.08.2025 10:43:05 vasta tsitaadiga
londiste kirjutas:
Tomorrow kirjutas:
Zen 3 üldiselt või ainult 5700X3D?
Snaxez
Snaxez
sõnum 18.08.2025 10:47:20 vasta tsitaadiga
See PBO värk on loto jah, paned kõrgema ja lased alla vaikselt, kuni on stable.
busta
busta
sõnum 18.08.2025 11:46:59 vasta tsitaadiga
Snaxez kirjutas:
Minu 5800x3d'l on -30 pidanud algusest saati ja 9800x3d'l on jäänud -35 peale pidama. Viimasel on 30C Idle temp, võib vast rahule jääda.
Mõni õnnelik võib saada ka -39 peale, mis on hea.
sõnum 18.08.2025 16:42:46 vasta tsitaadiga
5x00X3D peal on see kunstlikult piiratud -30 peale. -35 vms saab tehniliselt küll windowsis vastava kolmanda osapoole programmiga määrata, aga see ei rakendu ja jääb reaalsuses -30 peale.
Arvestades seda, et CO on unbervolt oli selline AMD disaini otsus arusaamatu. 5800X3D launchil puudus BIOS valik üldse CO seada (kõigil plaatidel). Esimesed loetud kuud pidid kasutajad CO seadma eraldi programmiga.
sõnum 18.08.2025 22:19:58 vasta tsitaadiga
Tomorrow kirjutas:
londiste kirjutas:
Tomorrow kirjutas:
5600x äkki tõesti lasi -30ga. 5800x3d lasi -25 peal pikalt ja peale tükki aega crashide troubleshootimist -15 ja lõpuks vist isegi veel vähem. 7800x3d oli juba -15 ja -10 päris korralikult ebastabiilne. natukene üritasin per core ka taga ajada aga see oli juba väga tüütu.
- londiste
sõnum 19.08.2025 07:40:26 vasta tsitaadiga
Minu sample size on küll ainult üks, aga minu 5800X3D on algusest peale olnud stabiilne -30 peal ja seda juba kolm aastat järjest.
Arx07
Arx07
sõnum 19.08.2025 08:41:56 vasta tsitaadiga
londiste kirjutas:
Ma proovisin ka core by core undervoltida oma 7800X3D, SMUDebugtool on selleks mugav vahend, saab Windowsis reaalajas undervolti muuta.
Mul küll see 7800X3D veits veider, üks core tahab -13, et oleks stabiilne. Ülejäänutele sai -15 jäetud, kui proovin ükstaspuha mis corega alla -15 minna siis lõpuks ikka seesama -13 core hakkab errorit andma... Ei tea kas teiste corede undervoltimine mõjutab ka siis selle ühe core volti vms... igatahes sai mässatud väga pikalt ja alla -15 ei saanud ühegi corega lõpuks.
5800X3D oli stabiilne all cores -25.
c4v6
c4v6
sõnum 19.08.2025 09:10:46 vasta tsitaadiga
Arx07 kirjutas:
londiste kirjutas:
Mul millalgi oli isend kus üks core tahtis -10 ja teine -15 kuid ülejäänud tegid -25
sõnum 22.08.2025 09:42:02 vasta tsitaadiga
AMD Reportedly Made Changes To The Ryzen 7 7800X3D By Eliminating The SMD Components From The Top Half
https://wccftech.com/amd-reportedly-removed-smd-components-from-top-half-of-7800x3d/
Selline muudatus põhjustab ebavajalikku segadust thumbs_down.gif . Nüüd arvavad inimesed, et uus versioon on fake.
Arx07
Arx07
sõnum 22.08.2025 10:06:01 vasta tsitaadiga
See on väga vana teema juba, üle poole aasta tagasi olid sellised turul.
https://www.reddit.com/r/pcmasterrace/comments/1iktikz/amd_ryzen_7_7800x3d_fake/
sõnum 01.09.2025 23:34:26 vasta tsitaadiga
MSI B450-A PRO MAX peal on hetkel R1700 ning 2x 8GB Gskill 3200 C16 mälu. AMD oli vist nelja mälupesa osas pirtsakas? St hea meelega paneks veel kaks pulka juurde olemasolevatele, mitte ei hakkaks ühtesid müüma ja teisi ostma - aga kui hea mõte see on?
sõnum 02.09.2025 00:01:28 vasta tsitaadiga
Dirty Harry, See sõltub rohkem prosest kui platest.
Kas esimese põlvkonna 1700 mudeli peal on kõige mõistlikum olla?
AM4 vanad prosed liiguvad väga odavalt.
Kui ma õigesti mäletan, siis Zen 1'ga sõltus see mälukividest kah. 8GB 3200 CL16 ei ütle kahjuks mis kivid seal pulkadel kasutuses on.
Kui on Samsung B-Die ja ostad teise kiti Samsung B-Die juurde (eeldusel, et leiad sama), siis on hea võimalus kõik neli tööle saada 3200 peal.
Kui need on Hynixi või Microni kividega pulgad, siis ma pigem kahtlen selles.
Ilmselt parim programm detailse info vaatamiseks mälupulkade kohta on Thaiphoon Burner, aga paistab, et koduleht on kadunud (mitte lihtsalt maas, juba mitu kuud), seega tuleb alla laadida siit: https://www.softpedia.com/get/Tweak/Memory-Tweak/Thaiphoon-Burner.shtml
Auron
Auron
sõnum 02.09.2025 06:45:25 vasta tsitaadiga
Endal joosknud 9800X3D vaikimisi ja pole otseselt probleeme olnud aga mõtsin, et prooviks ka siis twiikida - et siis biossist otsin curve optimizeri ja panen lihtsalt negative -30 näiteks ja kui mingeid uusi anomaaliaid ei teki nagu lambicrashid asjades milles ennem polnud siis nagu ongi okoo või? icon_confused.gif Selles mõttes, et intel oli mul ka kõva undervoldiga aga kui miski 15 mintsa OCCT stresstestis ei jamand ja mängudes pikemalt mängides ka mitte siis ma ausalt öeldes mingeid terveks ööks jooksma jätvaid stressteste ei viitsi lasta - nii hardcore ka pole icon_biggrin.gif
sõnum 02.09.2025 06:54:59 vasta tsitaadiga
Auron, Nõus. 24h stress testid on võrdlemisi mõttetud. 15-60 minutit aitab küll.
Parim stress test ongi igapäevane kasutamine. 24h testist pole kasu kui see on seal stabiilne aga mingil põhjusel crashib hoopis mingis programmis või mängus mida igapäevaselt kasutad/käivitad.
Siis on see 24h test mahavisatud aeg ja tuleb midagi muuta sätetes ja jälle 24h lasta.
High-Q
High-Q
sõnum 02.09.2025 12:32:13 vasta tsitaadiga
Dirty Harry kirjutas:
1gen ryzen (ja 2gen ka) mälukontrad olid väga piprad. nii kiiruse, kui pulkade arvu poolelt. ma ei saanudki 3200-seid pulki (2x8) gen1 r5 1600-l isegi 3000 peal töölegi, pidin 2666-ga leppima. 2gen (r5 2600) elasid juba 3066, aga ikkagi mitte 3200. ehk siis xmp-d ma ei gen1-l ega gen2-l tööle ei saanud, pidin käsitsi sättima. samas 3gen 3600x peal elasid täpselt samad pulgad isegi 3400+, ilma igasugu kägisemiseta (täpselt sama emaplaadil nagu sinul). kusjuures tegu oli "ryzen optimized" gskill flarex pulkadega pealekauba. mingi aeg lisasin 2 samasugust juurde (4x8 siis), hetkel tiksunud juba aastaid 3400CL14 peal.
sõnum 02.09.2025 13:39:13 vasta tsitaadiga
Tomorrow, High-Q, aitäh. Ilmselt vahetan CPU ka 5800x peale ära.
Täitsa erinevaid mälupulkasid vist pole hea kokku segada? St ma mõtlen, et kui panna 2x8 kõrvale 2x16 (üle ühe muidugi), et mis võiks tulemuseks olla.
Ahjaa, kui seal on vahet, siis op.süsiks on linux mitte Windows, kuid tegu on ikkagi mängumasinaga. Steam (Proton) töötab täitsa kenasti.
anubis
anubis
sõnum 02.09.2025 14:10:12 vasta tsitaadiga
R7 1700 peal jah, oli üsna keeruline 3000+ saavutada.
https://valid.x86.fr/0yaa73
2933 samas tuli mäletamistmööda lihtsalt kahe pulgaga.
Nelja pulgaga oli vist 2666 suht lagi.
https://valid.x86.fr/kye6ga
https://valid.x86.fr/bckt1w
(Igapäevakasutuseks siis, jõuga ja voldiga ning uhke jahutusega sai lühiajaliselt rohkem kätte)
uus teema   vasta Raud »  Protsessorid »  AMD Zen/Ryzen/Threadripper/Epyc arutelu mine lehele eelmine  1, 2, 3 ... 313, 314, 315 ... 318, 319, 320  järgmine
