mine lehele eelmine  1, 2, 3 ... 626, 627, 628 ... 632, 633, 634  järgmine
Hardi
Hardi
sõnum 04.05.2025 09:15:34 vasta tsitaadiga
Kommentaarid: 84 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 70
Optimist
Optimist
sõnum 12.05.2025 23:10:01 vasta tsitaadiga
https://www.techpowerup.com/336670/sata-io-publishes-amd-ryzen-threadripper-pro-9000-wx-series-page
https://www.techpowerup.com/336647/amd-epyc-venice-leak-2-nm-zen-6-and-zen-6c-to-offer-up-to-256c-512t-and-1-gb-of-l3-in-a-single-socket
2nm & Venice will support both 16-channel (SP7) and 12-channel (SP8) DDR5 configurations, accommodating up to 6 TB of system RAM per socket.
LLM gang be like: Bro do you even MCP
Kommentaarid: 10 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 8
1dumbpcuser
sõnum 14.05.2025 03:49:57 vasta tsitaadiga
AMD says AM5 platforms can support CUDIMMs, but won't commit to a release date
https://www.tomshardware.com/pc-components/cpus/amd-says-am5-platforms-can-support-cudimms-but-wont-commit-to-a-release-date
Even though AMD's AM5 platform is designed to support all features of DDR5 memory modules, including CUDIMMs, the company's existing Ryzen 7000 cannot work with CUDIMMs at all, whereas Ryzen 8000, and Ryzen 9000-series CPUs do not fully support such modules. Nonetheless, AMD's AMD's AM5 infrastructure has everything to support clock unbuffered memory modules, according to Sourabh Dhir, product management lead for gaming and workstations, who spoke to Digital Trends.
For now, Ryzen 7000-series processors are completely incompatible with CUDIMM memory modules: if installed, the system will fail to boot. By contrast, Ryzen 8000 and 9000 series CPUs can technically work with CUDIMMs, but only in a limited fallback configuration known as 'bypass mode', which ignores the clock driver chip on the module and, therefore, offers no advantage. This means that the system will start in DDR5-3200 mode and will require manual adjustment of the memory transfer rate, and therefore, there will be no performance guarantees.
M:
Kommentaarid: 102 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 97
sõnum 14.05.2025 09:28:34 vasta tsitaadiga
Intelil töötab ja AI teemas annab kasu. Samas minu meelest neid teste veel väga vähe, eriti kui AMD-ga võrrelda ei saa icon_lol.gif
Optimist
Optimist
sõnum 22.05.2025 15:36:51 vasta tsitaadiga
Juulis uued Threadripperid samale socketile
https://www.techpowerup.com/337070/amd-announces-ryzen-threadripper-pro-9000-shimada-peak-hedt-processors
1dumbpcuser
sõnum 26.05.2025 16:08:35 vasta tsitaadiga
1dumbpcuser kirjutas:
Asrocki vastus:
Link
M:
Zonerman
Zonerman
sõnum 28.05.2025 12:43:52 vasta tsitaadiga
Sisuliselt Asrock mätsis kinni AMD prohmaka. Arusaadav, kuna mõlemad on pikaaaegsed partnerid ja ei taha teineteisele jalga lasta. AMD agesa ja bios andis ette väga kõrge piiri emaplaadi tootjatele ja ASrock kasutas selle maksimumi ära. Kuid mingitel tingimustel võib see 3D prose kahjustada. Viimane bios alandas emaplaadi seatud piire prosele, kui temp ja voldid seda lubasid eriti AIO'ga.
Sõim ja räuskamine läheb SIIA
sõnum 28.05.2025 14:07:04 vasta tsitaadiga
AMD B650 Chipset Is Reportedly Discontinued In Favor Of B850 Chipset, But The Remaining Stock Will Be Available For A Few Months
https://wccftech.com/amd-b650-chipset-is-reportedly-discontinued-in-favor-of-b850-chipset/
B650 väidetavalt EOL. Laojäägid veel.
Vaatasin Geizhals'st, et B650 on saadaval 71 plaati vahemikus ~80-300.
B850 on saadaval 56 plaati vahemikus ~106-300. Seega plaatide valik väiksem ja madalamas otsas hind kõrgem.
Win11 25H2 upgrade skriptid neile kelle masin ise ei taha 23H2 või 24H2 pealt ennast uuendada:
neoman
sõnum 07.06.2025 20:12:39 vasta tsitaadiga
Millal rohkem kui 16 tuuma oodata on AM5 platvormile? Või peab ikka workstation poole vaatama.
Kommentaarid: 79 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 71
heretic666
heretic666
sõnum 07.06.2025 20:32:07 vasta tsitaadiga
Lähiaastatel ei usu küll et consumer platform niipea üle 16 (performance) core saab
Optimist
Optimist
sõnum 07.06.2025 22:23:43 vasta tsitaadiga
neoman kirjutas:
Ca 2026 Zen6 pidi tulema 12 tuuma per CCD ehk siis 24 kiiret tuuma kahe CCD peale praeguse 18 asemel. Zen6C tuumadega (väiksem cache, takt) mahutab üks CCD isegi 16 tuuma ära aga siiani on sellised tuumad valdavalt EPYCute sisse panded nende klientide jaoks kellel max arv tuumasi vaja per socket.
https://wccftech.com/amd-next-gen-ryzen-zen-6-medusa-ridge-cpus-12-24-32-core-up-to-128-mb-l3-cache/
Saadavuse kohta pole kindlat inffi täna ja EPYC/Threadripper on ainuke asjalik viis kohe praegu palju tuumasid saada.
siinus
siinus
sõnum 08.06.2025 00:19:28 vasta tsitaadiga
neoman kirjutas:
Mis usecase see >16core nõudega on kui mitte workstation?
Selline kõrge multithreading workload jääb üldiselt juba mälu bandwidthis või pci-e lane'des bottleneckima, niiet HEDT platvormist enivei ei pääse.
Kui päriselt põhjendadki ära, siis keegi sinu jaoks ei hakka ühte unikaalset proset arendama.
suck less | ANNA MU SAI!
Kommentaarid: 70 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 63
Kristoferr
Kristoferr
sõnum 08.06.2025 08:23:36 vasta tsitaadiga
Jah, ilmselt Zen6 AM5 tippmudel tuleb 24tuuma, aga sealt ülespoole on vaja juba ThreadRipper.
Ma isiklikult rohkematest tuumadest puudust ei tunne, aga oluliselt kiiremate tuumadega võiks AMD küll üllatada. +20% IPC oleks täitsa ahvatlev.
Liitu Z.ai soodsa coding plaaniga
Liitu Wise'ga!
Kommentaarid: 265 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 216
sõnum 08.06.2025 12:05:06 vasta tsitaadiga
Ma pigem tahaks rohkem tuumasi samal kivil mis tundub, et ka juhtub kui minnakse 8 pealt 12 peale. Üldine tuumade hulk sellega suureneb, aga see pole minu jaoks nii kriitiline.
Ühtlasi loodan, et mälukontrollerit parandatakse oluliselt, et kõrgemad sagedused ja neli pulka samaaegselt oleks ka kõrgetel sagedustel stabiilne. Ühtlasi, et latentsus oleks sama madal või madalam.
Paha ei teeks ka see kui L3 kogus suureneks. Kellade osas ma kahtlen, et eriti ruumi on ja kahtlen, et 6Ghz näeme stockis.
Optimist
Optimist
sõnum 08.06.2025 16:50:56 vasta tsitaadiga
Tomorrow kirjutas:
Quote mu üleval pandud lingist "The standard AMD Zen 6 CCDs will offer a 50% increase in cache count over the Zen 5 cores"
sõnum 08.06.2025 18:19:27 vasta tsitaadiga
4mb per core. 8-core zen5 ccd seega 32mb. 12-core zen6 ccd seega 48mb. 50% increase...
- londiste
Vael
sõnum 09.06.2025 14:50:59 vasta tsitaadiga
Mul kahtlane tunne, et kuna VRAMi puhverdamist on viimasel ajal mängudes juurde tulnud, siis madalam latentsus mäluk8ntrolleri osas ja ddr6 või stabiilne 4kanaliga ddr5@ 8000MHz võiks hetkel kõvasti perfi anda...
Kui vaadata i7 8700+ 8GB 9060xt tulemusi, siis sellist PCIe kiirusest sõltuvust nagu ei mäleta. Alati sai selle 5% erinevust 8/4x kanaliga eelmistel PCIe põlvkondadel vs kõige uuem kätte. Aga nüüd kukkus ikkagi x16 perf täitsa ära...
sõnum 09.06.2025 15:23:37 vasta tsitaadiga
vram puhverdamist? see on gpu peal. gpu on parimal juhul pcie 5.0 x16 siini taga, 63GB/s-ish max. see on dual-channel ddr5 puhul lihtsalt kätte tulev läbialse. viide mälukontrolleris kahvatub pci-e oma juures. lisaks siis ei ole see puhverdamine reeglina nii viitetundlik niikuinii. ehk siis ddr5 mälukontroller proses on gpu mälusüsteemi ja selle andmete liigutamise juures pea täies ulatuses kõrvaline.
integreeritud video on teine lugu aga seal on see pudelikaelandus niikuinii keerulisem.
- londiste
sõnum 13.06.2025 15:19:43 vasta tsitaadiga
AMD Silently Releases the Ryzen 5 5500X3D CPU
https://www.techpowerup.com/338001/amd-silently-releases-the-ryzen-5-5500x3d-cpu
Renq
Renq
sõnum 13.06.2025 21:40:17 vasta tsitaadiga
Tomorrow kirjutas:
Ma olen ammu hellitanud mingit lootust, et tuleks veel üks am4 high end gaming CPU välja... Võib-olla roosa unistus a no loota ju võib.
sõnum 31.07.2025 08:01:43 vasta tsitaadiga
Renq kirjutas:
Tomorrow kirjutas:
Pole nagu eriti midagi välja pigistada sealt. Mängude jaoks oli 5800X3D. Nüüd 5700X3D. MT jaoks 5950X.
Micron lõpetas ka DDR4 tootmise, seega DDR4 hinnad hakkavad samuti tõusma.
EDIT:
AMD Readies Ryzen 5 9600X3D to Spice Up the Mid-range
https://www.techpowerup.com/338186/amd-readies-ryzen-5-9600x3d-to-spice-up-the-mid-range
EDIT 2:
AMD to Rely on TSMC’s N2P Process for Most Zen 6 Products, Lower-End Laptop SKUs Likely to Use N3P
https://wccftech.com/amd-to-rely-on-tsmc-n2p-process-for-most-zen-6-products/
Ühtlasi on jutt, et Zen 6 tuleb 7Ghz, aga ma ei usu seda. Selle ennustamisega on juba varem näppu lõigatud, kui Zen 3 ennustati 5Ghz, aga tuli 4.9Ghz (5950X) ja Zen 4 ennustati 6Ghz, aga tuli 5.7Ghz ja Zen 5 jäi samaks ega olnud isegi 5.8
Mina pakun, et tuleb 6-6.4Ghz parimal juhul. Üle 6.4 ei usu.
EDIT 3:
AMD Prepares Granite Ridge PRO Chips And Ryzen 7 9700F For Consumers As Spotted On ASUS Website; Core Clock, Cache, And TDP Leaked
https://wccftech.com/amd-prepares-granite-ridge-pro-chips-and-ryzen-7-9700f-for-consumers-as-spotted-on-asus-website-core-clock-cache-and-tdp-leaked/
EDIT 4:
AMD to Rehash Ryzen 8000G Desktop APUs as 9000G Series: Rumor
https://www.techpowerup.com/339420/amd-to-rehash-ryzen-8000g-desktop-apus-as-9000g-series-rumor
AMD Now "World's Fastest" in Nearly all Processor Form-factors
https://www.techpowerup.com/339435/amd-now-worlds-fastest-in-nearly-all-processor-form-factors
anubis
anubis
sõnum 04.08.2025 16:24:19 vasta tsitaadiga
Link
Vael
sõnum 05.08.2025 06:43:29 vasta tsitaadiga
Nagu sai juba mainitus, siis uus 2700 i7 Sandy Bridge.
Ainuke jama on selles, et bottleneck on juba hetkel, UE5 on väga prose nõudlik.
sõnum 11.08.2025 16:41:35 vasta tsitaadiga
AMD Readies Two New 3D V-Cache Ryzen 9000 "Zen 5" Desktop CPUs, 8 Core With 96 MB & 16 Core With 192 MB "Dual X3D"
https://wccftech.com/amd-readies-new-3d-v-cache-ryzen-9000-zen-5-desktop-cpus-8-core-96-mb-16-core-192-mb-dual-x3d/
Potentsiaalselt uus 16c dual-X3D tulemas. 9990X3D?
See 8c on ilmselt 9700X3D. Sama nagu 9800X3D aga veidi madalamate kelladega.
EDIT:
AMD's Next-Gen AM6 Socket Expected to Boost Pin Count to 2100 While Matching AM5 Size
https://www.techpowerup.com/339636/amds-next-gen-am6-socket-expected-to-boost-pin-count-to-2100-while-matching-am5-size
EDIT 2:
AMD Ryzen 7 5700X3D Disappears from the Market
https://www.techpowerup.com/339805/amd-ryzen-7-5700x3d-disappears-from-the-market
lauri23
lauri23
sõnum 14.08.2025 14:40:52 vasta tsitaadiga
Biosest kuskil saab määrata et 5700x3d ennast ei downclockiks oma nägemise järgi? Koormuse all BF6 betas 70C peal surub vägisi ennast 3950 MHz peale, tahaks ikka kogu lubatud võimsust kasutada. Samas desktopil ei ole ka vaja idles max clocki peal istuda.
Tasuta 50$pokkeri kontole. Registreeri, õpi strateegiat ja vasta küsimustele. Saad valitud pokkerituppa 50$+veel boonust, kui mängida oskad. Isiklikult saanud 285$ sealt.
uus teema   vasta Raud »  Protsessorid »  AMD Zen/Ryzen/Threadripper/Epyc arutelu mine lehele eelmine  1, 2, 3 ... 626, 627, 628 ... 632, 633, 634  järgmine
