mine lehele eelmine  1, 2, 3 ... 143, 144, 145 ... 205, 206, 207  järgmine
Alla 1 aasta
11%
 11%  [ 50 ]
1-3 aastat
31%
 31%  [ 142 ]
4-6 aastat
25%
 25%  [ 114 ]
7-10 aastat
18%
 18%  [ 84 ]
11-13 aastat
7%
 7%  [ 33 ]
14-16 aastat
3%
 3%  [ 15 ]
17-20 aastat
0%
 0%  [ 4 ]
Üle 20 aasta
1%
 1%  [ 5 ]
hääli kokku : 447
somnambuul
sõnum 06.01.2021 19:07:37 vasta tsitaadiga
m2ka kirjutas:
Seda vist kuidagi WebOS-i teleritele peale ei õnnestu peale ajada?
Praegu veel veebibrauseris otse vaatamine toimib, aga Jupiteri kohalt tuli juba teade, et seda brauserit ei toeta. Teleriks LG C9
See Jupiteri pealik lubas, jaanuaris tuleb webos ja tizen äpp. Paar nädalat on veel aega.
E: https://menu.err.ee/1142126/jupiter-jouab-peagi-apple-tv-vahendusel-nutiteleritesse
d_m
sõnum 07.01.2021 12:29:01 vasta tsitaadiga
m2ka kirjutas:
SKG kirjutas:
FYI: See jublakas pidavat LG-dele sobima: https://www.amazon.ca/gp/aw/d/B00BBD7NFU
I've been the happy owner of a 65" LG OLED B7 TV for 3 years, but the one caveat that has always stuck in my craw has been LG's use of a 100base-T fast ethernet interface on the set. For the majority of use cases, this likely suffices, however if you want to direct play high bitrate 4K HDR remuxes over the LG Plex app, it's a bit of a showstopper. I'm happy to say I've finally solved the problem—without having to compromise (either downloading lower bitrate files, or purchasing an android box or Shield or something)—and have my OLED B7 connected to my home network at gigabit speeds. I purchased a cheap ($20 CAD) Cable Matters USB3 to Gig Ethernet Adaptor, plugged it in the USB3 port on the back of the LG, and switched my ethernet cable from the built-in RJ45 to the adapter. When powering up the TV, it reports no wired network connection, and no wifi connection (I have it turned off), however the set does have a network connection, and shows green on my switch, indicating a gigabit connection. When playing back high bitrate remuxes, my plex dashboard on my server shows spikes up to 248 mbps to the LG B7, and buffering pauses are nonexistent now. See in the comments below for pics.
Endal samamoodi adapter kasutusel ja toimib normaalselt:
https://www.tp-link.com/us/home-networking/usb-converter/ue300/
Keegi oskab soovitada sarnast ETH adapterit mis Android TV'ga töötab? Või see TP-Link võiks ka toimida?
Mul annab hetkel üks Logilink "unknown device connected" (nii USB2.0 kui USB3.0 pesas) vms errorit - peaks olema sama RTL8153 chipiga USB3.0 adapter, samas sellel on veel lisaks USB hub juures, äkki seepärast?
Kommentaarid: 10 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 7
smoolae
sõnum 07.01.2021 14:18:36 vasta tsitaadiga
Selline natuke teistsugune küsimus.
Tegelased, kes on liikunud QLEDi peal OLEDi peale - kas vahe ereduses on väga märgatav?
Praegu täisvalge täisekraan annab välja kuskil 950 nitti ja HDRi highlight'ide puhul köhib välja pisut alla 2000de niti.
Kommentaarid: 41 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 34
pots4t4j4
sõnum 07.01.2021 14:25:54 vasta tsitaadiga
nii ja mis sa selle eredusega peale hakkad? 50% OLED light kiirgab ka silmad peast välja juba.
danny
danny
sõnum 07.01.2021 22:48:02 vasta tsitaadiga
Tere.
Uut telekat vaja kodu tuua ja ootaks mõningaid soovitusi. Hetkel ~10 aastat vana Sony 50 tolline.
Uue kriteeriumid
65"
Android OP
Hind max 1800.-
Mängimist ei harrasta, pigem saated, filmid.Xbox käib korra kuus, seda ka youtube jaoks.
Kommentaarid: 49 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 42
sõnum 07.01.2021 22:52:22 vasta tsitaadiga
danny kirjutas:
Tere.
Uue kriteeriumid
65"
Android OP
Hind max 1800.-
Kõik ju ok, viska 66€ juurde ja case closed
https://www.hinnavaatlus.ee/1851388/philips-65-65oled805/
Miks androidi vaja üldse?
danny
danny
sõnum 07.01.2021 23:00:22 vasta tsitaadiga
jeesus188 kirjutas:
danny kirjutas:
Tere.
Uue kriteeriumid
65"
Android OP
Hind max 1800.-
Kusjuures korra ka vaatasin seda telekat. Lihtsalt pole kunagi vajadus olnud jälgida telekate turgu ja tänu sellele ei tea nendest midagi.
Kurat seda teab miks android, paljud räägivad sellest nagu mingist jumalast, teen ka näo, et just androidi mul vaja. Võimalusi rohkem?
smoolae
sõnum 07.01.2021 23:04:25 vasta tsitaadiga
pots4t4j4 kirjutas:
Aken asub telekat vaadates täpselt selja taga.
sõnum 07.01.2021 23:09:28 vasta tsitaadiga
No ma küsisingi reaalselt, et milleks sul seda vaja on...ega LG-ga hinnavahe olematu. Kui nii palju juba plaan, siis (varsti jälle sõimatakse) ostad oledi.
Isiklikult androidi järgi vajadust ei tunne, midagi puudu pole. Sp ka reaalne küsimus, milleks?
danny
danny
sõnum 07.01.2021 23:43:25 vasta tsitaadiga
jeesus188 kirjutas:
No ütleme, et ei ole androidi vaja. Kumb võtta, kas sinu pakutud see Philips või siis mingi LG? Vaatame rohkem pildi kvaliteeti ja vastupidavust.
sõnum 08.01.2021 00:29:11 vasta tsitaadiga
danny kirjutas:
jeesus188 kirjutas:
Reaalselt ma ei tea...guugelda vähe...mina amblighti fänn ei ole, nii et minu silmis langeb võrdlusest välja....
Magic remote lg..l +9
McCoffin
sõnum 08.01.2021 10:32:30 vasta tsitaadiga
Kuidas uued Philipsid menüüdes toimetavad? Siiani pole ühtegi Android TVd näinud, mis nobe oleks (sest kasutavad suht low end või iidseid chipsette OP jooksutamiseks). C9 on rakett menüü kiiruselt.
Kommentaarid: 52 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 50
Anna tooli
sõnum 08.01.2021 10:53:09 vasta tsitaadiga
Möödunud aasta OLED mudelid on võrreldes varasematega nobedamad
McCoffin
sõnum 08.01.2021 11:56:01 vasta tsitaadiga
Lootsin jah, et mingi areng toimunud. Lugesin, et ka Sony on saanud natuke paremaks selle koha pealt.
miga
miga
sõnum 08.01.2021 12:01:45 vasta tsitaadiga
Sony 2021 telerid: https://www.theverge.com/2021/1/7/22218693/sony-tv-lineup-8k-4k-z9j-a90j-a80j-x95j-x90j-ces-2021?fbclid=IwAR1zywJBGiTibuCqDVLbf11RvnQ498ood_eW61h-ISQDh4O14FFbMQ-pa4s
sõnum 08.01.2021 12:05:42 vasta tsitaadiga
A90J Master Series 4K (OLED)
83-inch
Hmm, huvitav..... kust nad paneeli saavad?
LG lineupis pole sellises mõõdus telekat
MummikAl
MummikAl
sõnum 08.01.2021 12:29:15 vasta tsitaadiga
jeesus188 kirjutas:
83-inch
https://allhomecinema.com/lg-83-inch-oled-tv-is-going-to-launch-in-next-year/
Kommentaarid: 42 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 39
sõnum 08.01.2021 12:35:35 vasta tsitaadiga
Aga see on hea, et nad teevad selle 4k, mitte 8k
seeru
sõnum 08.01.2021 14:47:24 vasta tsitaadiga
somnambuul kirjutas:
Nagu digi foorumist lugeda oli, siis pealik ütles, et LG äpp on valmis ja ootavad LG firma poolt selle heakskiitu.
Draqula
sõnum 08.01.2021 15:46:22 vasta tsitaadiga
Draqula kirjutas:
bladerunner kirjutas:
Draqula, see on Kodi plugin. Juhend kuidas plugin Kodi sees paigaldada on https://yllar.github.io/kodi/
Tuhat tänu!
See oli õpetus mille järgi ka kuskile jõudis.
EDIT:
Kas keegi oskab öelda kas see on normaalne, et Sony 4K teleka puhul KODI raporteerib resolutsiooniks FullHD?
Seadete alt oli grayed-out - ainult kuvati info.
2018 mudeli Sony android telekal jookseb KODI peal Jupiter väga kenasti sujuvalt, subtiitrid ja kõik jutud.
Ainult müstikaks jääb, et miks KODI raporteerib 4K teleka olevat FullHD.
Samas see paistab miski üldine probleem olevat kui googeldada ja arvestades Jupiteri sisuga ei ole veel teema. Netflix mängib ilusti 4K.
pois11
sõnum 08.01.2021 15:52:35 vasta tsitaadiga
Draqula kirjutas:
Võin juurde lisada, et 2016a. androidiga Philipsil jooksevad ka jupiteri asjad sujuvalt. Aga kodiga 4K filme vaadata ei kannata. Ma enam ei mäleta mis probleem oli, äkki ka 4K ei saanud kasutada. Teine probleem oli heliga. Filmide vaatamiseks kasutan ikkagi välist seadet.
sõnum 08.01.2021 16:17:16 vasta tsitaadiga
McCoffin kirjutas:
Kui suuremad nõudmised, siis võibolla parem eraldi Android box osta.
Snaxez
Snaxez
sõnum 08.01.2021 16:21:03 vasta tsitaadiga
SKG kirjutas:
McCoffin kirjutas:
Nvidia Shield on väga mõistlik iga teleka juurde.
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 54
Draqula
sõnum 08.01.2021 17:10:46 vasta tsitaadiga
Snaxez kirjutas:
SKG kirjutas:
McCoffin kirjutas:
Kui mu teleka oma nuti nõdraks hakkab jääma siis tõenäoliselt hangin Chromecast with Google TV lisaks:
https://www.cnet.com/news/chromecast-with-google-tv-review-a-worthy-rival-to-roku-and-amazon-fire-tv-streaming-sticks/
Eelmise teleka puhul sai tavaline Chromecast hangitud.
VR53
VR53
sõnum 08.01.2021 19:08:21 vasta tsitaadiga
danny kirjutas:
Kvaliteedi poolest kindlasti LG. Philips oma Androidiga on üsna bugine, lambist mingid anomaaliad nagu Androidiga ikka.
Uued Lenovo sülearvutid: www.lenovoarvutid.ee
Sülearvuti ekraan katki? www.displayseek.com
Kommentaarid: 842 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 636
NATAS999
sõnum 08.01.2021 21:51:46 vasta tsitaadiga
sõnum 08.01.2021 21:53:17 vasta tsitaadiga
HV-s ID-kaardiga autentimine
NATAS999
sõnum 08.01.2021 22:05:20 vasta tsitaadiga
las olla praegu. 43" läks juba kasutusse ka. 65" käib praegu ülejõu tulusi/kulusi/reservi arvesse võttes icon_biggrin.gif siin ikka räägitakse 50"-60" puhul summadest 1000€ ja üles, mu oma 330€ icon_biggrin.gif sama firma/seeria, mis mu 43" oli. kuna selle pildiga olen rahul, siis ei vajadust 3-5x kallima aparaadi järele icon_biggrin.gif
MaitK
MaitK
sõnum 09.01.2021 06:50:00 vasta tsitaadiga
NATAS999 kirjutas:
Minu puhul ongi see, et kui see 65" OLED kunagi alla peaks andma, siis rahakotile saab ikka väga valus olema. Tagasiminekut ju ei soovi ja järgmine võiks ju pisut suurem olla. Sul paistab olevat veel järgmiste sammudeni pisut maad õnneks icon_smile.gif
Aga kui netist, siis 14 päeva saab tagastada ja proovida midagi edevamat, olenemata sellest, et eelarvesse ei mahu. icon_biggrin.gif icon_razz.gif
Hiid
Hiid
sõnum 09.01.2021 13:33:03 vasta tsitaadiga
nii 14 päeva kaupa eri kohtadest telekaid koju tellida, et kokku 365 päeva aastas telekas laua peal on, ka keegi viljeleb? icon_razz.gif
Hapud viinamarjad
Kommentaarid: 663 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 512
olc
olc
sõnum 09.01.2021 18:52:37 vasta tsitaadiga
Hiid kirjutas:
Et nagu pööritad raha lihtsalt erinevate ettevõtete vahel? päris palju vaba raha on kinni, selle asemel, et lihtsalt teler osta.
Kommentaarid: 142 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 130
wirx
wirx
sõnum 09.01.2021 18:59:25 vasta tsitaadiga
Draqula kirjutas:
Tuhat tänu!
Tõesti hea lisa, kas Telia TV jaoks miskit analoogset asja pole. Jõle tüütu nvidia shieldiga läbi brauseri hiirega mässata.
miga
miga
sõnum 11.01.2021 17:14:52 vasta tsitaadiga
CES algas: LG’s 2021 TV lineup includes its brightest OLED ever
sõnum 11.01.2021 17:18:21 vasta tsitaadiga
lg oledidel tekib rohkem segmenteerumist. pikalt oli minimaalne reaalne vahe, milline mudel võtta.
siis jäi b veidi kehvema paneeliga ja viimati ka nõrgema pilditöötlusprosega.
kui nüüd see evo paneel on g-mudel (ja eeldatavasti kõrgemale), siis nähtavasti saab ühest küljest lisaraha eest midagi aga teisest küljest see uus feature või tase saab hinnasildi icon_sad.gif
- londiste
sõnum 11.01.2021 17:23:49 vasta tsitaadiga
Heledamat pilti saab vast vaid tippmudel, panasonicu abiga. Teistel lihtsalt väike facelift.
Ja see hinnavahe tuleb suht suur, mis minu silmis hinnavahet ei õigusta...eks paista kui reaalne saadavus tekib.
Päeval päiksega telekat ei vahi, nii et ei tohiks suur probleem olla anyway.
Hetkel nagu liiga pime küll pole
sõnum 11.01.2021 17:28:27 vasta tsitaadiga
miga kirjutas:
sõnum 11.01.2021 17:33:16 vasta tsitaadiga
SKG kirjutas:
miga kirjutas:
Ei usu
Enam ei anta telefonidega laadijaid ka kaasa, sa tahad, et nad maksaks mingit litsentsitasu icon_lol.gif
miga
miga
sõnum 11.01.2021 17:35:18 vasta tsitaadiga
Kuna TV vahetus ees ootamas, siis ei näe vajadust küll nüüd selle aasta OLED-i ootama jääda, sest see heledus pole minu jaoks teema nagunii ehk siis nüüd jääb üle, et 65" OLED65GX3LA (hetkel soodsaim hind HV järgi: 2100€) noolima hakata hea hinnaga icon_razz.gif
sõnum 11.01.2021 20:54:47 vasta tsitaadiga
jeesus188 kirjutas:
SKG kirjutas:
miga kirjutas:
Ei usu
Ma pean kerget eeltööd tegema juba, enne kui paneeli taustavalgus täiesti maha sureb.
Ükspäev sai jälle "korda" kui telkut 4-5 korda sisse-välja lülitasin. Hetkel püsib ilusti, aga ega pikka pidu vist pole jah icon_lol.gif
Philips ja Hisense valikusse jäänud.
oliver.
sõnum 11.01.2021 21:16:49 vasta tsitaadiga
SKG kirjutas:
U7QF on endiselt päris mõistlik valik, enda magamistoa teleka kandidaat hetkel.
sõnum 12.01.2021 02:18:22 vasta tsitaadiga
oliver. kirjutas:
SKG kirjutas:
DTS puudub.
Mul see vajalik, kuna kõlarid otse teleri küljes ja AVR ei soovi nii pea osta.
AE7400F parem valik mulle.
oliver.
sõnum 12.01.2021 11:36:48 vasta tsitaadiga
SKG kirjutas:
oliver. kirjutas:
SKG kirjutas:
DTS puudub.
DTS-i ju mängib?
Viskasin peotäis klippe pulgale:
https://thedigitaltheater.com/dts-trailers/
Toimis küll. Samsungi ja LG puhul oli tõesti tumm ja error ees nagu pidigi olema.
sõnum 12.01.2021 14:52:30 vasta tsitaadiga
oliver. kirjutas:
SKG kirjutas:
oliver. kirjutas:
SKG kirjutas:
DTS puudub.
DTS-i ju mängib?
HDMI-st sisse ja optilisest väljundist ka tuleb DTS passthrough?
U7QF? Specis ja manualis pole miskit.
smoolae
sõnum 12.01.2021 18:18:11 vasta tsitaadiga
SKG kirjutas:
oliver. kirjutas:
SKG kirjutas:
oliver. kirjutas:
SKG kirjutas:
DTS puudub.
DTS-i ju mängib?
EDIT:
Mängisin mõnda DTS trailerit siit https://thedigitaltheater.com/dts-trailers/. Endal jookseb heli ARCI kaudu extractorisse mis annab heli välja läbi optilise, RCA ja coaxiali, sealt optiline läheb JBL bar 3.1'te.
Kui valida telekast "Pass through" siis DTS'i puhul viskab bar ERRORi ette. Kuna see soundbar DTS'i ei dekodeeri, siis justkui peaks ERROR näitama, et DTS jookseb tõesti optilisest läbi icon_smile.gif .
Valides nende trailerite puhul heliks PCM või Dolby, siis bar mängib kenasti.
sõnum 12.01.2021 18:54:53 vasta tsitaadiga
miga
miga
sõnum 14.01.2021 13:53:08 vasta tsitaadiga
Olen endale väikestviisi dilemma püstitanud. Kui olin kuulikindel, et lähen 65" LG CX/GX OLED teedpidi, siis olen hakanud natuke uurima ka erinevaid LED variante ehk mu küsimus, mis on tekkinud "Kas ma vajan päriselt OLED-i?" 65" CX hind jääb sinna 1750 € juurde, samas kui LED-i saab soodsamalt ehk mul puudub arusaamine ja teadmine kui palju ma annan ära või võidan kui valin ühe või teise (jah, tean, et OLED-l must on must jne)
Olemasolev TV on 42" Panasonic plasma ja aasta oli siis 2006 kui see sai koju toodud. Siiani ülirahul ja ei kurda. Kuna aga jooksvalt on tehnoloogia arenenud ja teleritele lisandunud palju võimalusi jne, siis olen mõelnud uuendamisele.
Minu/pere harjumus TV ees:
* TV-ga ei mängi ehk ühtki konsooli ei oma ja lähiajal pole plaanis ka.
* Teenusepakkujaks Telia, vaatan filme sisuleidjast, HBO-st, vaatan NBA-d.
* Aegajalt lükkan arvuti/pulga järele ja vaatan mõnd uhkemat filmi paremas kvaliteedis
* Airplay 2 tugi vajalik, kuna kasutan iPhone, siis hea mugav paari klõpsuga pilti edastada.
* Päike telekale peale ei paista. Vaatamist on nii päeval kui õhtul, kuid peamiselt õhtuti. Plaanis teler seinale paigaldada, vaatamiskaugus 3-3.5m ja alla 65" ei plaani soetada.
Kui nüüd peaks LED-i poole vaatama, mis oma omadustelt on hea 65" ja annab ka rahakotile säästva toonuse (selge on see, et kui OLED-i ja LED-i vahe on paarsada €, siis ei ole väga mõelda midagi ja minna OLED-i teed....aga kui on märkimisväärne rahaline võit ilma olulise "must on must" kaudeta, siis mida luurata ?
Kes iganes peaks mu mõttele vastama, siis lähtu mu sisendist mitte tampimisest...
oliver.
sõnum 14.01.2021 14:11:28 vasta tsitaadiga
Kordan mõne lehe tagust arutelu ning kinnitan, et plasmalt LCD peale üleminek on negatiivses mõttes harjumatu ning OLED on loogiline samm edasi.
Euronicsis on teleritel Telia taga, mine vaata üle, kuidas vahe tundub.
Ilmselt on ka BX piisav.
Snaxez
Snaxez
sõnum 14.01.2021 14:32:50 vasta tsitaadiga
Kui ise peaks ostma, siis OLED-i välistades vaataks Sony H90 või H95 poole. Hetkel oman 65" OLED-i, aga vaatan u. 3.8m pealt, seega eelistaks sama raha eest suuremat. (75" või 85")
Sony 65XH90 ~ 1190€
Sony 65XH95 ~ 1398€
LG OLED65BX ~ 1587€
LG OLED65CX ~ 1741€
Sony 75XH90 ~ 1776€
LG OLED65GX ~ 2090€
Sony 75XH95 ~ 2386€
OLED-i hetkel ei võitaks ja ootaks pool aastat, kuni tulevad uued mudelid. Väidetavalt on nüüd paneelid paremad, mis olid varasemalt iga aasta suht samad.
m0z41ek
sõnum 14.01.2021 14:57:52 vasta tsitaadiga
Ostsin omale hiljuti Sony XH90 55" (minu tõttu see arutelu aktiivseks läkski) ning pean tunnistama, et oma raha eest on ta okei. Muud ei midagi. Kui tänasel päeval oleksin endiselt valiku ees, siis see ⅕ hinnavahet ei kallutaks mu valikut odavama kasuks. Bleed on vägev - Peaky Blinders subtiitritega (kuna dialekt kohati maru hüva, siis ei taha nagu millestki ilma ka jääda) oli kohati päris ebameeldiv vaadata. Vaatamise nurk on siinpuhul samuti raskendav asjaolu - otse vaadates on bleed minimaalne, nii kui rohkem nurga alt vaatad, siis enam ei kannata. Muidu olen rahul aga tänasel päeval paneks selle paarsada eurot juurde (seda siis 55" puhul) ning võtaks ikkagi OLED-i.
Kommentaarid: 14 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 11
Lotharius
rallisibul
Lotharius
sõnum 14.01.2021 15:23:10 vasta tsitaadiga
Tunnistan samuti, et ega ma erilist elamuse vahet nüüd oma eelmise Philipsi VA telekaga ei märka, olles CX OLED telekat septembrist saati omanud.
Jah, vaatenurgad on paremad, aga ma vaatan telerit otse eest.
Jah, mustad on paremad, aga Philipsi mustad olid täiesti rahuldavad pärast sättimist ning Ambilight samuti varjutas seda, et teleri must ei olnud see ideaalne OLEDi must kui pimedas vaatasid.
Kuna konsoolide 4K HDR 120Hz on jäänud ka vist ikka tulemata, siis pole ka CX-i super Hz mitte mingit kasu. Praeguse PS4 Pro taga võiks ka mingit tavalisemat telekat kasutada.
2020 mudelitest ma vist täna ostaks hoopis 2x väiksema raha eest Philips 65PUS8505 või ootaks 2021 mudelid ära. Võibolla peakski CX müüki viskama, samas ei viitsi seinalt lahti kruvida... Tülikas nende suurte ekraanide transport.
Edit: Tundub, et lõpuks siuke maitse asi ja vb ka see, kui väga mustade "mitte 100% must" häirib. Aga nagu paljude asjadega selgub tõde alles siis, kui oled oma silmaga ära näinud ja oma käega katsunud mõnda aega. Pidasin end kriitilisemaks vaatajaks, aga tundub, et pole siiski nii kriitiline.
Edit 2: Philipsil pole AirPlay tuge, seega miga jaoks ei kära. Siis võtaks ka Sony XH9 seeria.
Geek it til it MHz
Kommentaarid: 125 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 117
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  Telerite üldteema vol. 2 (Küsitlus: Kui vana on sinu igapäevaselt enimkasutatav teler?) mine lehele eelmine  1, 2, 3 ... 143, 144, 145 ... 205, 206, 207  järgmine
