Kui vana on sinu igapäevaselt enimkasutatav teler? |
Alla 1 aasta |
10% |
[ 47 ] |
1-3 aastat |
32% |
[ 140 ] |
4-6 aastat |
25% |
[ 113 ] |
7-10 aastat |
18% |
[ 81 ] |
11-13 aastat |
7% |
[ 33 ] |
14-16 aastat |
3% |
[ 14 ] |
17-20 aastat |
0% |
[ 4 ] |
Üle 20 aasta |
1% |
[ 5 ] |
hääli kokku : 437 |
somnambuul
Kommentaarid: 60 loe/lisa |
54 |
d_m
07.01.2021 12:29:01
m2ka kirjutas: |
SKG kirjutas: |
FYI: See jublakas pidavat LG-dele sobima: https://www.amazon.ca/gp/aw/d/B00BBD7NFU
tsitaat: |
I've been the happy owner of a 65" LG OLED B7 TV for 3 years, but the one caveat that has always stuck in my craw has been LG's use of a 100base-T fast ethernet interface on the set. For the majority of use cases, this likely suffices, however if you want to direct play high bitrate 4K HDR remuxes over the LG Plex app, it's a bit of a showstopper. I'm happy to say I've finally solved the problem—without having to compromise (either downloading lower bitrate files, or purchasing an android box or Shield or something)—and have my OLED B7 connected to my home network at gigabit speeds. I purchased a cheap ($20 CAD) Cable Matters USB3 to Gig Ethernet Adaptor, plugged it in the USB3 port on the back of the LG, and switched my ethernet cable from the built-in RJ45 to the adapter. When powering up the TV, it reports no wired network connection, and no wifi connection (I have it turned off), however the set does have a network connection, and shows green on my switch, indicating a gigabit connection. When playing back high bitrate remuxes, my plex dashboard on my server shows spikes up to 248 mbps to the LG B7, and buffering pauses are nonexistent now. See in the comments below for pics. |
Endal samamoodi adapter kasutusel ja toimib normaalselt:
https://www.tp-link.com/us/home-networking/usb-converter/ue300/ |
Keegi oskab soovitada sarnast ETH adapterit mis Android TV'ga töötab? Või see TP-Link võiks ka toimida?
Mul annab hetkel üks Logilink "unknown device connected" (nii USB2.0 kui USB3.0 pesas) vms errorit - peaks olema sama RTL8153 chipiga USB3.0 adapter, samas sellel on veel lisaks USB hub juures, äkki seepärast?
Kommentaarid: 10 loe/lisa |
smoolae
07.01.2021 14:18:36
Selline natuke teistsugune küsimus.
Tegelased, kes on liikunud QLEDi peal OLEDi peale - kas vahe ereduses on väga märgatav?
Praegu täisvalge täisekraan annab välja kuskil 950 nitti ja HDRi highlight'ide puhul köhib välja pisut alla 2000de niti.
Kommentaarid: 41 loe/lisa |
34 |
pots4t4j4
07.01.2021 14:25:54
nii ja mis sa selle eredusega peale hakkad? 50% OLED light kiirgab ka silmad peast välja juba.
Kommentaarid: 491 loe/lisa |
399 |
danny
07.01.2021 22:48:02
Tere.
Uut telekat vaja kodu tuua ja ootaks mõningaid soovitusi. Hetkel ~10 aastat vana Sony 50 tolline.
Uue kriteeriumid
65"
Android OP
Hind max 1800.-
Mängimist ei harrasta, pigem saated, filmid.Xbox käib korra kuus, seda ka youtube jaoks.
Kommentaarid: 49 loe/lisa |
42 |
07.01.2021 22:52:22
danny kirjutas: |
Tere.
Uue kriteeriumid
65"
Android OP
Hind max 1800.-
Mängimist ei harrasta, pigem saated, filmid.Xbox käib korra kuus, seda ka youtube jaoks. |
Kõik ju ok, viska 66€ juurde ja case closed
https://www.hinnavaatlus.ee/1851388/philips-65-65oled805/
Miks androidi vaja üldse?
Kommentaarid: 71 loe/lisa |
danny
07.01.2021 23:00:22
jeesus188 kirjutas: |
danny kirjutas: |
Tere.
Uue kriteeriumid
65"
Android OP
Hind max 1800.-
Miks androidi vaja üldse? |
Kusjuures korra ka vaatasin seda telekat. Lihtsalt pole kunagi vajadus olnud jälgida telekate turgu ja tänu sellele ei tea nendest midagi.
Kurat seda teab miks android, paljud räägivad sellest nagu mingist jumalast, teen ka näo, et just androidi mul vaja. Võimalusi rohkem?
42 |
smoolae
07.01.2021 23:04:25
pots4t4j4 kirjutas: |
nii ja mis sa selle eredusega peale hakkad? 50% OLED light kiirgab ka silmad peast välja juba. |
Aken asub telekat vaadates täpselt selja taga.
Ere+vähe peegelduv=parem vaadata
34 |
07.01.2021 23:09:28
tsitaat: |
No ma küsisingi reaalselt, et milleks sul seda vaja on...ega LG-ga hinnavahe olematu. Kui nii palju juba plaan, siis (varsti jälle sõimatakse) ostad oledi.
Isiklikult androidi järgi vajadust ei tunne, midagi puudu pole. Sp ka reaalne küsimus, milleks?
danny
07.01.2021 23:43:25
tsitaat: |
Isiklikult androidi järgi vajadust ei tunne, midagi puudu pole. Sp ka reaalne küsimus, milleks? |
No ütleme, et ei ole androidi vaja. Kumb võtta, kas sinu pakutud see Philips või siis mingi LG? Vaatame rohkem pildi kvaliteeti ja vastupidavust.
42 |
08.01.2021 00:29:11
danny kirjutas: |
tsitaat: |
No ütleme, et ei ole androidi vaja. Kumb võtta, kas sinu pakutud see Philips või siis mingi LG? Vaatame rohkem pildi kvaliteeti ja vastupidavust. |
Reaalselt ma ei tea...guugelda vähe...mina amblighti fänn ei ole, nii et minu silmis langeb võrdlusest välja....
Magic remote lg..l +9
McCoffin
08.01.2021 10:32:30
Kuidas uued Philipsid menüüdes toimetavad? Siiani pole ühtegi Android TVd näinud, mis nobe oleks (sest kasutavad suht low end või iidseid chipsette OP jooksutamiseks). C9 on rakett menüü kiiruselt.
47 |
Anna tooli
08.01.2021 10:53:09
Möödunud aasta OLED mudelid on võrreldes varasematega nobedamad
Kommentaarid: 363 loe/lisa |
299 |
McCoffin
08.01.2021 11:56:01
Lootsin jah, et mingi areng toimunud. Lugesin, et ka Sony on saanud natuke paremaks selle koha pealt.
47 |
miga
Kommentaarid: 34 loe/lisa |
08.01.2021 12:05:42
tsitaat: |
A90J Master Series 4K (OLED)
83-inch
Hmm, huvitav..... kust nad paneeli saavad?
LG lineupis pole sellises mõõdus telekat
MummikAl
Kommentaarid: 42 loe/lisa |
39 |
08.01.2021 12:35:35
MummikAl,
Aga see on hea, et nad teevad selle 4k, mitte 8k
seeru
08.01.2021 14:47:24
Nagu digi foorumist lugeda oli, siis pealik ütles, et LG äpp on valmis ja ootavad LG firma poolt selle heakskiitu.
Draqula
08.01.2021 15:46:22
Draqula kirjutas: |
Tuhat tänu!
See oli õpetus mille järgi ka kuskile jõudis.
EDIT:
Kas keegi oskab öelda kas see on normaalne, et Sony 4K teleka puhul KODI raporteerib resolutsiooniks FullHD?
Seadete alt oli grayed-out - ainult kuvati info. |
2018 mudeli Sony android telekal jookseb KODI peal Jupiter väga kenasti sujuvalt, subtiitrid ja kõik jutud.
Ainult müstikaks jääb, et miks KODI raporteerib 4K teleka olevat FullHD.
Samas see paistab miski üldine probleem olevat kui googeldada ja arvestades Jupiteri sisuga ei ole veel teema. Netflix mängib ilusti 4K.
34 |
pois11
08.01.2021 15:52:35
Draqula kirjutas: |
Samas see paistab miski üldine probleem olevat kui googeldada ja arvestades Jupiteri sisuga ei ole veel teema. Netflix mängib ilusti 4K. |
Võin juurde lisada, et 2016a. androidiga Philipsil jooksevad ka jupiteri asjad sujuvalt. Aga kodiga 4K filme vaadata ei kannata. Ma enam ei mäleta mis probleem oli, äkki ka 4K ei saanud kasutada. Teine probleem oli heliga. Filmide vaatamiseks kasutan ikkagi välist seadet.
Kommentaarid: 112 loe/lisa |
109 |
08.01.2021 16:17:16
McCoffin kirjutas: |
Kuidas uued Philipsid menüüdes toimetavad? Siiani pole ühtegi Android TVd näinud, mis nobe oleks (sest kasutavad suht low end või iidseid chipsette OP jooksutamiseks). C9 on rakett menüü kiiruselt. |
Kui suuremad nõudmised, siis võibolla parem eraldi Android box osta.
_________________ Müüa: Xbox 360 S 4GB (UUS)
Müüa: Xbox 360 S 250GB (UUS) |
Kommentaarid: 373 loe/lisa |
313 |
Snaxez
08.01.2021 16:21:03
SKG kirjutas: |
Kui suuremad nõudmised, siis võibolla parem eraldi Android box osta. |
Nvidia Shield on väga mõistlik iga teleka juurde.
Kommentaarid: 58 loe/lisa |
53 |
Draqula
08.01.2021 17:10:46
Snaxez kirjutas: |
SKG kirjutas: |
Nvidia Shield on väga mõistlik iga teleka juurde. |
Kui mu teleka oma nuti nõdraks hakkab jääma siis tõenäoliselt hangin Chromecast with Google TV lisaks:
https://www.cnet.com/news/chromecast-with-google-tv-review-a-worthy-rival-to-roku-and-amazon-fire-tv-streaming-sticks/
Eelmise teleka puhul sai tavaline Chromecast hangitud.
34 |
VR53
08.01.2021 19:08:21
danny kirjutas: |
Kvaliteedi poolest kindlasti LG. Philips oma Androidiga on üsna bugine, lambist mingid anomaaliad nagu Androidiga ikka.
_________________ Uued Lenovo sülearvutid: www.lenovoarvutid.ee - kasuta koodi "HINNAVAATLUS", et saada 50€ alla P14s Gen 6 R7 hinnast!
Kommentaarid: 842 loe/lisa |
636 |
