ceemic
24/7@kalal
25.09.2019 13:42:30
Drake, proovi Thaiphoon burneri ja DRAM Calculatoriga seaded kätte saada.
Kommentaarid: 421 loe/lisa |
322 |
Drake
25.09.2019 13:52:34
bios on loomulikult viima ver.
See oli esimene asi out of the box mis ma tegin.
Thaiphoon burnerit pole proovinud veel.
Eks üritab kalkulaatori panna SAFE peale ja natuke volti vb juurde.
Thx.
d.
_________________ On the other hand, I've turned rivers into blood... kings into cripples... cities into salt. So I don't think that I have to explain myself to you. -Gabriel- |
Kommentaarid: 89 loe/lisa |
84 |
Viilutaja
Kommentaarid: 225 loe/lisa |
195 |
25.09.2019 20:59:25
AMD Ryzen 3000 DDR4 Scaling – Part II – Samsung B-Die vs Micron E-Die vs Hynix CJR – English version
https://lab501.ro/procesoare-chipseturi/amd-ryzen-3000-ddr4-scaling-part-ii-samsung-b-die-vs-micron-e-die-vs-hynix-cjr-english-version
tsitaat: |
Thus, if Samsung B-Die was the only viable option in order to get the best performance when the first Ryzen generation was launched, this time things have changed, Ryzen fans having a wide array of RAM kits to choose from, some of them with amazing price/performance value. Ultimately, the decision belongs to each and everyone of you, and we can only hope the two parts of our scaling study will help you when you have to choose the memory kit that is best for you. |
Pole vaja maksta üle B-Die eest. Muidu kui teha HV's otsing 3200 CL14 või 3600 CL14-16 kittidele mis laos on, siis on tulemuseks 0. Ise julgen oma kogemuse põhal CJR soovitada küll. Mul on küll JJR aga see käitub sarnaselt. 110€ eest saab 2x8GB 3200 CL16 kiti mis teeb 3733 16-20-20-36 1T
Kommentaarid: 92 loe/lisa |
Oliverk
25.09.2019 21:05:55
80 € eest saab 2x8 gbCorsair CMK16GX4M2B3200C16 mis teeb 3800 16-19-19-38-57 1T
Kommentaarid: 27 loe/lisa |
26 |
25.09.2019 21:14:06
Oliverk, Mina näen HV's seda 95€+ eest.
Ja see pole RGB nagu Kingstoni HX432C16PB3AK2/16
Oliverk
25.09.2019 21:14:55
Tomorrow kirjutas: |
Ja see pole RGB nagu Kingstoni HX432C16PB3AK2/16  |
Ei ole ise kontrollinud. Võtsin ise Amazonist paar kuud tagasi koos ryzen 3600-ga.
26 |
25.09.2019 21:16:18
Oliverk, Tundub loogiline . Huvitav mis kiipe see kasutab? B-Die see pole. Vb samuti CJR. Oled Thaiphoon Burneriga vaadanud?
Oliverk
25.09.2019 21:19:01
Typhoon näitab Hynix A-die
26 |
Kristocfc
25.09.2019 23:03:49
IMHO 2019/09 pole enam see koht kus 2*8gb vaadata
Kommentaarid: 64 loe/lisa |
55 |
anubis
25.09.2019 23:38:25
Tõhus rukkilill.
Kommentaarid: 332 loe/lisa |
280 |
25.09.2019 23:40:51
Kristocfc kirjutas: |
IMHO 2019/09 pole enam see koht kus 2*8gb vaadata |
Keegi ei keela kaks 2x8 kitti võtta. Kokku alla 200€ pole paha
Muidugi 4x8 ülekiirendamine on raskem kui 2x8.
anubis
280 |
26.09.2019 23:38:16
Tomorrow, kindlasti 2x16 mõistlikum
Kommentaarid: 196 loe/lisa |
182 |
anubis
280 |
ceemic
24/7@kalal
27.09.2019 15:06:38
09.09 kuupäevaga ABB beta on ära korjatud
322 |
6kantv6ti
27.09.2019 15:17:58
MSI biositreialid ei maga, kuu ajaga TOMAHAWK MAX platele ka juba hunnik uusi BIOS-eid valmis tehtud.
Kommentaarid: 17 loe/lisa |
17 |
Megadux
27.09.2019 15:58:21
Eelmine nädal sai oma emaplaadile MSI ABBA-t proovitud. 3700X-l enam tuumad üle 3600 Mhz sellega millegipärast ei läinud. Kui BIOS-es siis optimiseeritud vaikeseaded panin, siis Windows 10 vaatamata minu jõupingutustele enam ei buutinud. Panin heaga ABB tagasi peale seda.
Kommentaarid: 36 loe/lisa |
36 |
27.09.2019 19:00:18
AMD 3rd Gen Ryzen Threadripper CPUs With Zen 2 Cores Rumored To Get New Socket, No Backwards Compatibility With X399 Motherboards
https://wccftech.com/amd-ryzen-threadripper-3rd-gen-zen-2-cpu-new-socket-chipset-rumor/
Tundub väheusutav. Esiteks on lekkeid olnud kus TR3 on jooksnud X399 peal. Teiseks PCIe 4.0 on kiibistiku teema ja ei vaja socketi vahetust. Ja kolmandaks X399 on seni toetanud nii NUMA kui ka UMA mäluhaldust.
Neljandaks EPYC Rome on socket ühilduv eksisteerivate emaplaatidega ja seega ma ei näe põhjust miks TR3 ei peaks olema, kuna see on lihtsalt cut down EPYC.
hempadonok
Kommentaarid: 11 loe/lisa |
Oliverk
27.09.2019 20:53:33
Pani oma Tomahwakile ja 3600-le ABBA BIOSI peale. Kõik tuumad teevad 4200, idle temp 36 kraadi. Keskmine mingi 45-50. Cine skooris ei muutunud sittagi. Mälu tahab vähem volti samade timingute juures.
26 |
terric
28.09.2019 01:38:21
AMD protsessoritega ikka igav ei hakka seiklust kui palju (ps. kes lugeda ei viitsi 3900x töötab aga ot all mõned
tähelepanekud ja ka enda kogemuste puudumine AMD maailmast ). Kui vaalium toimima hakkab siis proovib
ikka uusima BIOS toimima saada, v18 tundub, et ühelõime takt üle 4.1Ghz ei lähe, multi tundub ok (3113 cb15)?
PS. Päris häbi oleks olnud cpu garantiisse saata testijal oleks muidugi nalja nabani olnud...
Box jahuti tundub ok, kuigi tald pole kuumatorudega päris ühtlaseks lihvitud ju sellepärast panevad
pastat liiga palju. Hetkel MX4 millalgi vaja ikka üle vaadata kas pasta sai korralikult aga hetkel sai IPA otsa ...
ot: |
Sain ka oma 3900x kätte ja istutasin b450 tomahawk plaadile,
millel bios oli vist 1.A (1.0.0.3ab) peaks nagu 3900x olema toetatud.
Aga ei postinud, cpu led punane (resettisin CMOS, patarei välja jne) ei posti.
Mõtlesin juba, et panin CPU valesti pessa (ei tea kas võimalik aga kahtlus tekkis),
jahuti maha ja cpu korra pesast välja ja tagasi, edutult (AMD paneb pastat liiga palju).
Tegin ka BIOS "flashback" kõige uusimale 1C aga edutu POST.
Panin siis r3 1200 tagasi ja POSTis, uuesti r9 3900x peale ja sama teema ei POSTi.
Mõistus otsas aeg alustada googeldamisega algul palju targemaks ei saanud kui, et
proovida kõige esimest BIOS mis 3000 seeriat toetama hakkas 1.80 (v18).
Algul sama teema edutu siis sattusin ühe YT otsa, kus tal taoline probleem
aga tekkis peale toimival tomahawk 3600 bios uuendamist.
Ja ta soovitas eemaldada CMOS patarei (tegelt ma seda ka tegin aga "valesti") 5 minutiks.
Ei paistnud aitavat aga raal jäi 1+ minutiks käima (lootus otsas, mis seda power nuppu ikka litsuda) ja
siis hakkas asi lootust andma st. LED kustus ja POST...
Ma olen kindel, et uusima BIOSiga oli raal 1+ minutit surnud olekus aga ei POSTinud (samas patarei eemaldamine vist jäi proovimata).
Seega kogenumad AMD kasutajad, kas CPU vahetus tahtis lihtsalt saada aega
sätete häälestamiseks (tagantjägi tuli meelde ühe YT millel b350 plaadil aeti 3900x
käima aga too plaat resettis miski 5x ennem kui pilt ette tuli.
Kommentaarid: 2 loe/lisa |
28.09.2019 04:59:55
terric, Jep vanematel platedel tahab mitu tsüklit läbi käia enne kui pildi ette võtab. Lisaks ei pruugi kohe uusima BIOS peale minemine võimalik olla vaid pead uuendama järk-järgult mis minule on üsna kummaline. Sõltub muidugi platest endast. Mõned on valutumad kui teised.
Paul's Hardware ühes videos oli sellest juttu ja samuti B450 Tomahawk:
Vael
28.09.2019 10:21:10
Pole mitte ainult AMD teema, i3570k + RAM ülejellamisel näiyeks teeb mu MSI Z77-G65 ka mitu tsüklit läbi, enne kui bootib. BIOS on isegi säte: BIOS try count vms, default peaks 3 olema.
Kuna uusimad kiibid kasutavad juba algoritme kümnete\sadade(vegal oli 64 termosensorit?) sensorite põhjal parima pinge/takti leidmiseks ja kõik kiibid käituvad erinevalt, siis pole ka ime kui kõigi 12 tuuma "esmakordsel käima õpetamisl" aega läheb.
Iseküsimus kui kaua r9 3900x käivitamine aega võtab ja kas nii pikk proysess õigustatud... Enda meelest i5 rappa läinud oc päädis ka 1-2min bios mõtlemisega....
16 |
