mine lehele eelmine  1, 2, 3 ... 156, 157, 158 ... 319, 320, 321  järgmine
ceemic
24/7@kalal
ceemic
sõnum 25.09.2019 13:42:30 vasta tsitaadiga
Drake, proovi Thaiphoon burneri ja DRAM Calculatoriga seaded kätte saada.
Drake
sõnum 25.09.2019 13:52:34 vasta tsitaadiga
bios on loomulikult viima ver.
See oli esimene asi out of the box mis ma tegin.
Thaiphoon burnerit pole proovinud veel.
Eks üritab kalkulaatori panna SAFE peale ja natuke volti vb juurde.
Thx.
d.
On the other hand, I've turned rivers into blood... kings into cripples... cities into salt. So I don't think that I have to explain myself to you. -Gabriel-
Kommentaarid: 90 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 85
Viilutaja
Viilutaja
sõnum 25.09.2019 18:09:51 vasta tsitaadiga
https://www.guru3d.com/news-story/amd-delayed-ryzen-9-3950x-launch-due-to-unsatisfactory-clock-speeds.html
Parim kodukino projektor müügis: https://foorum.hinnavaatlus.ee/viewtopic.php?p=11790090#11790090
sõnum 25.09.2019 20:59:25 vasta tsitaadiga
AMD Ryzen 3000 DDR4 Scaling – Part II – Samsung B-Die vs Micron E-Die vs Hynix CJR – English version
https://lab501.ro/procesoare-chipseturi/amd-ryzen-3000-ddr4-scaling-part-ii-samsung-b-die-vs-micron-e-die-vs-hynix-cjr-english-version
Thus, if Samsung B-Die was the only viable option in order to get the best performance when the first Ryzen generation was launched, this time things have changed, Ryzen fans having a wide array of RAM kits to choose from, some of them with amazing price/performance value. Ultimately, the decision belongs to each and everyone of you, and we can only hope the two parts of our scaling study will help you when you have to choose the memory kit that is best for you.
Pole vaja maksta üle B-Die eest. Muidu kui teha HV's otsing 3200 CL14 või 3600 CL14-16 kittidele mis laos on, siis on tulemuseks 0. Ise julgen oma kogemuse põhal CJR soovitada küll. Mul on küll JJR aga see käitub sarnaselt. 110€ eest saab 2x8GB 3200 CL16 kiti mis teeb 3733 16-20-20-36 1T thumbs_up.gif
Oliverk
sõnum 25.09.2019 21:05:55 vasta tsitaadiga
80 € eest saab 2x8 gbCorsair CMK16GX4M2B3200C16 mis teeb 3800 16-19-19-38-57 1T
sõnum 25.09.2019 21:14:06 vasta tsitaadiga
Oliverk, Mina näen HV's seda 95€+ eest.
Ja see pole RGB nagu Kingstoni HX432C16PB3AK2/16 icon_biggrin.gif
Oliverk
sõnum 25.09.2019 21:14:55 vasta tsitaadiga
Tomorrow kirjutas:
Ei ole ise kontrollinud. Võtsin ise Amazonist paar kuud tagasi koos ryzen 3600-ga.
sõnum 25.09.2019 21:16:18 vasta tsitaadiga
Oliverk, Tundub loogiline thumbs_up.gif . Huvitav mis kiipe see kasutab? B-Die see pole. Vb samuti CJR. Oled Thaiphoon Burneriga vaadanud?
Oliverk
sõnum 25.09.2019 21:19:01 vasta tsitaadiga
Typhoon näitab Hynix A-die
sõnum 25.09.2019 21:28:28 vasta tsitaadiga
Kristocfc
Kristocfc
sõnum 25.09.2019 23:03:49 vasta tsitaadiga
IMHO 2019/09 pole enam see koht kus 2*8gb vaadata
Kommentaarid: 64 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 55
anubis
anubis
sõnum 25.09.2019 23:38:25 vasta tsitaadiga
Tõhus rukkilill.
sõnum 25.09.2019 23:40:51 vasta tsitaadiga
Kristocfc kirjutas:
Keegi ei keela kaks 2x8 kitti võtta. Kokku alla 200€ pole paha thumbs_up.gif
Muidugi 4x8 ülekiirendamine on raskem kui 2x8.
anubis
anubis
sõnum 25.09.2019 23:45:06 vasta tsitaadiga
https://valid.x86.fr/243e4f
Oi kuidas 3900x armastab mälu tweakimist...oioioi.
sõnum 26.09.2019 23:38:16 vasta tsitaadiga
Tomorrow, kindlasti 2x16 mõistlikum
anubis
anubis
sõnum 27.09.2019 14:48:56 vasta tsitaadiga
https://www.msi.com/Motherboard/support/B450M-MORTAR
ABBA tuli välja.
ceemic
24/7@kalal
ceemic
sõnum 27.09.2019 15:06:38 vasta tsitaadiga
6kantv6ti
sõnum 27.09.2019 15:17:58 vasta tsitaadiga
MSI biositreialid ei maga, kuu ajaga TOMAHAWK MAX platele ka juba hunnik uusi BIOS-eid valmis tehtud.
Megadux
Megadux
sõnum 27.09.2019 15:58:21 vasta tsitaadiga
anubis kirjutas:
ABBA tuli välja.
Eelmine nädal sai oma emaplaadile MSI ABBA-t proovitud. 3700X-l enam tuumad üle 3600 Mhz sellega millegipärast ei läinud. Kui BIOS-es siis optimiseeritud vaikeseaded panin, siis Windows 10 vaatamata minu jõupingutustele enam ei buutinud. Panin heaga ABB tagasi peale seda.
Kommentaarid: 36 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 36
sõnum 27.09.2019 19:00:18 vasta tsitaadiga
AMD 3rd Gen Ryzen Threadripper CPUs With Zen 2 Cores Rumored To Get New Socket, No Backwards Compatibility With X399 Motherboards
https://wccftech.com/amd-ryzen-threadripper-3rd-gen-zen-2-cpu-new-socket-chipset-rumor/
Tundub väheusutav. Esiteks on lekkeid olnud kus TR3 on jooksnud X399 peal. Teiseks PCIe 4.0 on kiibistiku teema ja ei vaja socketi vahetust. Ja kolmandaks X399 on seni toetanud nii NUMA kui ka UMA mäluhaldust.
Neljandaks EPYC Rome on socket ühilduv eksisteerivate emaplaatidega ja seega ma ei näe põhjust miks TR3 ei peaks olema, kuna see on lihtsalt cut down EPYC.
hempadonok
hempadonok
sõnum 27.09.2019 19:43:16 vasta tsitaadiga
Loodetavasti pole tegu lihtsalt näpuveaga, 65w TDP 12-tuumaline
https://www.anandtech.com/show/14912/amds-ryzen-9-3900-a-12core-65w-cpu-listed-by-motherboard-maker
Monero kaevajatele peaks imehästi maitsema
★Hommik on õhtust kainem ...Aegopodium!
Oliverk
sõnum 27.09.2019 20:53:33 vasta tsitaadiga
Pani oma Tomahwakile ja 3600-le ABBA BIOSI peale. Kõik tuumad teevad 4200, idle temp 36 kraadi. Keskmine mingi 45-50. Cine skooris ei muutunud sittagi. Mälu tahab vähem volti samade timingute juures.
terric
terric
sõnum 28.09.2019 01:38:21 vasta tsitaadiga
AMD protsessoritega ikka igav ei hakka seiklust kui palju (ps. kes lugeda ei viitsi 3900x töötab aga ot all mõned
tähelepanekud ja ka enda kogemuste puudumine AMD maailmast icon_redface.gif ). Kui vaalium toimima hakkab siis proovib
ikka uusima BIOS toimima saada, v18 tundub, et ühelõime takt üle 4.1Ghz ei lähe, multi tundub ok (3113 cb15)?
PS. Päris häbi oleks olnud cpu garantiisse saata icon_redface.gif testijal oleks muidugi nalja nabani olnud...
Box jahuti tundub ok, kuigi tald pole kuumatorudega päris ühtlaseks lihvitud ju sellepärast panevad
pastat liiga palju. Hetkel MX4 millalgi vaja ikka üle vaadata kas pasta sai korralikult aga hetkel sai IPA otsa ...
ot:
Sain ka oma 3900x kätte ja istutasin b450 tomahawk plaadile,
millel bios oli vist 1.A (1.0.0.3ab) peaks nagu 3900x olema toetatud.
Aga ei postinud, cpu led punane (resettisin CMOS, patarei välja jne) ei posti.
Mõtlesin juba, et panin CPU valesti pessa (ei tea kas võimalik aga kahtlus tekkis),
jahuti maha ja cpu korra pesast välja ja tagasi, edutult (AMD paneb pastat liiga palju).
Tegin ka BIOS "flashback" kõige uusimale 1C aga edutu POST.
Panin siis r3 1200 tagasi ja POSTis, uuesti r9 3900x peale ja sama teema ei POSTi.
Mõistus otsas aeg alustada googeldamisega algul palju targemaks ei saanud kui, et
proovida kõige esimest BIOS mis 3000 seeriat toetama hakkas 1.80 (v18).
Algul sama teema edutu siis sattusin ühe YT otsa, kus tal taoline probleem
aga tekkis peale toimival tomahawk 3600 bios uuendamist.
Ja ta soovitas eemaldada CMOS patarei (tegelt ma seda ka tegin aga "valesti") 5 minutiks.
Ei paistnud aitavat aga raal jäi 1+ minutiks käima (lootus otsas, mis seda power nuppu ikka litsuda) ja
siis hakkas asi lootust andma st. LED kustus ja POST...
Ma olen kindel, et uusima BIOSiga oli raal 1+ minutit surnud olekus aga ei POSTinud (samas patarei eemaldamine vist jäi proovimata).
Seega kogenumad AMD kasutajad, kas CPU vahetus tahtis lihtsalt saada aega
sätete häälestamiseks (tagantjägi tuli meelde ühe YT millel b350 plaadil aeti 3900x
käima aga too plaat resettis miski 5x ennem kui pilt ette tuli.
sõnum 28.09.2019 04:59:55 vasta tsitaadiga
terric, Jep vanematel platedel tahab mitu tsüklit läbi käia enne kui pildi ette võtab. Lisaks ei pruugi kohe uusima BIOS peale minemine võimalik olla vaid pead uuendama järk-järgult mis minule on üsna kummaline. Sõltub muidugi platest endast. Mõned on valutumad kui teised.
Paul's Hardware ühes videos oli sellest juttu ja samuti B450 Tomahawk:
Vael
sõnum 28.09.2019 10:21:10 vasta tsitaadiga
Pole mitte ainult AMD teema, i3570k + RAM ülejellamisel näiyeks teeb mu MSI Z77-G65 ka mitu tsüklit läbi, enne kui bootib. BIOS on isegi säte: BIOS try count vms, default peaks 3 olema.
Kuna uusimad kiibid kasutavad juba algoritme kümnete\sadade(vegal oli 64 termosensorit?) sensorite põhjal parima pinge/takti leidmiseks ja kõik kiibid käituvad erinevalt, siis pole ka ime kui kõigi 12 tuuma "esmakordsel käima õpetamisl" aega läheb.
Iseküsimus kui kaua r9 3900x käivitamine aega võtab ja kas nii pikk proysess õigustatud... Enda meelest i5 rappa läinud oc päädis ka 1-2min bios mõtlemisega....
terric
terric
sõnum 28.09.2019 11:10:56 vasta tsitaadiga
Jama on selles, et ega plaat ei ürita peab ise "reseti" vajutama muidu jääb ootele ja mul "stock" mälu muudan ainult profiil2.
Peab vist plaati vahetama või ootama b550 tulekut natuke nigel nii "resetti" igal korral kui
toide väljas olnud, kui PSU on ootepingel siis toimib.
anubis
anubis
sõnum 28.09.2019 11:19:05 vasta tsitaadiga
Plaadil viga miskit, see pole ootuspärane käitumine.
Kas muidu on viimased chipseti jms driverid peal?
Vael
sõnum 28.09.2019 11:29:22 vasta tsitaadiga
terric kirjutas:
Ma nagu mäletaks mingist postist\YT videos, et pidi laskma 15min+ "läbi järada", siis hakkas tööle...
BIOS peaks salvestama parimad seaded pärast pingete paika kruttimist, selleks BIOS patarei ongi. Sellepärast tulebki pärast, GPU\CPU vahetust patarei välja võtta, et kõik vaikeseaded, mis ühele kiibile sobivad aga teisele ei pruugi, ära kustutada. Siis on lihtsalt kehva BIOS, sest mu oma teeb "hard reseti", kõvaketas ei "plõksu" nii, aga on kohe aru saada kui reset teeb emaplaat- "plõksu" on kuulda, toiteahela ümberlülitus vms? Aga kui sa pead ise käsitsi seda hard reset tegema, siis on jah tüütu.
AdoreTV is back:
Midagi väga huvitavat ei ole aga ~20 min peal hea iva välja toodud. Kogu video mõte? AMD müüb lowest of the lowest end chiplete praegu isegi Threadripperi pähe;) Sest 6core chiplet on 20% vigaste hulgas, ja 24tuuma\4 teeb 6core\per chiplet ja 24tuumane Threadripper on välja tulemas. Edasi räägib ka AMD kui korporatsiooni valikutest antud olukorras. Kuidas GF väljajäämine järgmise aasta konsoolide tootmist mõjutama hakkab, saame veel näha. Aga Epycuga jaoks on arvatavasti plaanid ammu tehtud.
Ma arvan, et TR3 oli plaanitud, aga kuna 3900x läheb hästi, siis kusagilt tuleb pakkumist maha lõigata ja tuuakse miskit "vigaste" 6core 24tuumane TR turule, et näe tegime. 3950x oleks ka siis kaval kõrvale jätta, sest see lõikaks TR kasutajaskonda. Huvitav, et Navit nüüd juba jagub turule ja veel väikeste kividega Navi ka lubatud. Aga noh, eks see ka juba pikalt ette plaanitud ja täitse ignoreerida ei saa turgu, sest pärast ei mäleta sind enam keegi...
terric
terric
sõnum 28.09.2019 12:19:48 vasta tsitaadiga
anubis kirjutas:
Paistab jah plaadiga seotud probleem (kui interneti avarustest lugeda siis taolist jama esineb ka teistel).
Küpsise draiverid on kasulikud ainult widowsi all kui plaat üldse käima läheb.
Aga kui toimib siis toimib nii nagu vaja, panen uuesti 1C peale "cmos reset+bat" ja vaatab mis saab.
sõnum 28.09.2019 12:21:37 vasta tsitaadiga
Ryzeniga on seda "trainingu" juttu esile kerkinud küll, et ei posti, vaid treenib end ja pead korduvalt laskma force-restarti, et siis end üles laseks...
Vael, core = tuum
ceemic
24/7@kalal
ceemic
sõnum 28.09.2019 21:50:03 vasta tsitaadiga
ABBA BIOSiga tekkis uus alamenüü "AMD Overclocking", mis sisuliselt dubleerib juba olemasolevaid OC seadeid. Mis värk sellega on?
sõnum 28.09.2019 22:15:13 vasta tsitaadiga
ceemic, Teatud dubleerimine on juba vähemalt B450-st saati olnud. See pole AGESA versiooniga seotud. Eks ta häiriv ole jah, sest sa muudad sätte ühes kohas ära aga teises see ei muutu ja siis mõtled kumba sätet BIOS nüüd kasutab.
Niipalju kui mulle silma on jäänud, siis AMD Overclocking alajotuse sätteid muudab hoopis Ryzen Master.
EDIT:
terric
terric
sõnum 29.09.2019 11:43:45 vasta tsitaadiga
anubis kirjutas:
Selline küsimus, kas sul on protsessor vcore "auto" või oled OC ja ise määranud (suure tõenäosusega stockis ei jooksuta icon_wink.gif )?
Endal kõik toimib senikaua kuni toiteplokk on juhtmega seinas (siis võib sisse välja lülida jne, sama teema nagu ASUSel oli kunagi lisa sata kontrolleriga)
kui toide on miski 5 minutit ära siis hakkab huumor peale vaja mõned korrad "power või reset" vajutada, et postiks (msi foorum ka seda hala täis).
Aga tundub, et need probleemid ainult nn. "stock" kasutajatel.
sõnum 29.09.2019 15:10:06 vasta tsitaadiga
terric, Minul üldiselt postib ka siis kui on toide pikalt väljas olnud. Muidugi teise tootja plate kah. Ainukesed probleemid on selles, et Gigabyte on miskipärast määranud mingi fixed 15 sekundit enne kui pildi ette võtab ja saab DEL/F12 vajutada. Seega sinna läheb pool 30 sek boot ajast windowsisse jõudmiseks.
Teine asi on see, et kui PCI-E 3.0 kaarti jooksutada aga BIOS-is on sisse lülitatud Gen4 säte võib mõnel käivitusel ees olla must pilt kuigi taustab boodib ilusti. Seega ühilduvuse jaoks tuleb panna käsitsi Gen3.
EDIT:
AT's 17tk kohal 3900X icon_eek.gif https://arvutitark.ee/est/tootekataloog/Arvutikomponendid-Protsessorid-CPU-Socket-AM4-protsessorid/447115
pots4t4j4
sõnum 29.09.2019 22:04:50 vasta tsitaadiga
3900x hind @ AT võiks ka MSRP olla mitte MSRP+100€
anubis
anubis
sõnum 29.09.2019 22:40:32 vasta tsitaadiga
Praegu on MSRP +70.
(MSRP üldkastutatavas mõistes on USA hind ja ilma maksudeta, EUs paistab baashind olema 529)
Longero
sõnum 01.10.2019 12:32:57 vasta tsitaadiga
Kas Threadripper vajab samuti kiiret mälu nagu Ryzen või piisab 1950x jaoks 2667MHz ja rohkem pole vaja?
1950x - System Memory Specification 2667MHz
3900X - System Memory Specification 3200MHz
Win ISO'd ja uuendused
Artiklid jagatud
Kommentaarid: 58 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 54
anubis
anubis
sõnum 01.10.2019 12:41:53 vasta tsitaadiga
Armastavad kiiret mälu nad kõik, lihtsalt Zen ja Zen+ sweetspot on pigem 3200 juures (lisa ei anna väga palju juurde) kuid Zen2 tahab saada võimalikult lähedale IF maksimaalkiirusele, ehk siis ~3800 (fclk 1900Mhz).
Longero
sõnum 01.10.2019 13:12:42 vasta tsitaadiga
anubis, Ei taha siia teemasse postitada, aga äkki aitaksid heade unbuffered ECC mäludega https://foorum.hinnavaatlus.ee/viewtopic.php?t=765332
Artiklid jagatud
d3t
d3t
sõnum 01.10.2019 14:25:54 vasta tsitaadiga
Tomorrow, praegu juba 2 vahem...
IsAiUseful.com - tee oma esimesed sammud kohaliku AI suunas
Kommentaarid: 85 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 72
sõnum 01.10.2019 14:51:50 vasta tsitaadiga
ORDI pakub ka sama hinnaga... 1 TLN ja 2 TRT
Reaper
Reaper
sõnum 01.10.2019 16:46:43 vasta tsitaadiga
Mis on kõige lahjem/odavam AMD prose, mida 3xx seeria platedel kasutada? Et saaks BIOS-i uuendada.
Kommentaarid: 29 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 27
Froggy
Froggy
sõnum 01.10.2019 16:51:47 vasta tsitaadiga
Reaper, ilmselt 200GE. poest 50€ kanti ja foorumis paar tükki ~30€ müügis
E: ryzen 3 1200 kah
sõnum 01.10.2019 19:46:09 vasta tsitaadiga
Reaper kirjutas:
200GE.
Üldiselt on sul neli valikut:
1. Telli AMD-lt boot kit.
2. Vii plate kuhugi poodi mis BIOS uuenduse teenust pakub.
3. Laena kellegi käest prose või lase kellelgi uuendus ära teha.
4. Osta ise kasutatud prose.
Kristocfc
Kristocfc
sõnum 01.10.2019 20:07:38 vasta tsitaadiga
200 oli just foorumis müügil
eedit
https://foorum.hinnavaatlus.ee/viewtopic.php?t=765299
sõnum 02.10.2019 18:27:06 vasta tsitaadiga
Keegi oskab öelda, mis hinnaga tutikad Wraith PRISM-id liiguvad? Üle üks...
-kasutaja-
-kasutaja-
sõnum 02.10.2019 20:19:35 vasta tsitaadiga
Poes liikusid Wraith PRISM RGB 25€
Kommentaarid: 32 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 31
anubis
anubis
sõnum 03.10.2019 22:39:47 vasta tsitaadiga
20-25 jah, raha millega ära võetakse. Seda raha on ta ka väärt kindlasti.
edit: Proovin täna nelja 16Gb (HX426C13PB3/16) klotsiga veidi häid sätteid leida. Lisaks viskasin oma masinast AIO välja ja panin NH-U14S sisse. Sobib nagu valatult. thumbs_up.gif
edit: http://valid.x86.fr/4vu4aw
3533cl16
edit: CB20 @4.3Ghz
Launger
Launger
sõnum 04.10.2019 09:50:40 vasta tsitaadiga
https://www.tomshardware.com/reviews/amd-ryzen-9-3900-overclock-65w-world-record-unreleased,6371.html
Vahest ma mõtlen miks AMD Üldse neid X versioone teeb või miks kohe kõiki prosesid ei või mõlemat poodi saata.
Saan aru, et binningu vahe, aga erinevaid silikoone tuleb ju tootmise algusest saati? Praegune turu domineerimine oleks ju veel kõvem, kui saaks kõikidele tahtjatele erinevaid variante pakkuda.
https://store.simracing.ee/eval-lounge-simulaatori-rent
Kommentaarid: 120 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 109
sõnum 04.10.2019 10:11:06 vasta tsitaadiga
eriti kui see "65w" cpu cinebenchis kuni 160w tarbib, siis pole x ja nonx prosedel küll mingit vahet.
- londiste
uus teema   vasta Raud »  Protsessorid »  AMD Zen/Ryzen/Threadripper/Epyc arutelu mine lehele eelmine  1, 2, 3 ... 156, 157, 158 ... 319, 320, 321  järgmine
