mine lehele eelmine  1, 2, 3 ... 312, 313, 314 ... 635, 636, 637  järgmine
ceemic
24/7@kalal
ceemic
sõnum 25.09.2019 13:42:30 vasta tsitaadiga
Drake, proovi Thaiphoon burneri ja DRAM Calculatoriga seaded kätte saada.
Drake
sõnum 25.09.2019 13:52:34 vasta tsitaadiga
bios on loomulikult viima ver.
See oli esimene asi out of the box mis ma tegin.
Thaiphoon burnerit pole proovinud veel.
Eks üritab kalkulaatori panna SAFE peale ja natuke volti vb juurde.
Thx.
d.
On the other hand, I've turned rivers into blood... kings into cripples... cities into salt. So I don't think that I have to explain myself to you. -Gabriel-
Kommentaarid: 89 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 84
Viilutaja
Viilutaja
sõnum 25.09.2019 18:09:51 vasta tsitaadiga
https://www.guru3d.com/news-story/amd-delayed-ryzen-9-3950x-launch-due-to-unsatisfactory-clock-speeds.html
sõnum 25.09.2019 20:59:25 vasta tsitaadiga
AMD Ryzen 3000 DDR4 Scaling – Part II – Samsung B-Die vs Micron E-Die vs Hynix CJR – English version
https://lab501.ro/procesoare-chipseturi/amd-ryzen-3000-ddr4-scaling-part-ii-samsung-b-die-vs-micron-e-die-vs-hynix-cjr-english-version
Thus, if Samsung B-Die was the only viable option in order to get the best performance when the first Ryzen generation was launched, this time things have changed, Ryzen fans having a wide array of RAM kits to choose from, some of them with amazing price/performance value. Ultimately, the decision belongs to each and everyone of you, and we can only hope the two parts of our scaling study will help you when you have to choose the memory kit that is best for you.
Pole vaja maksta üle B-Die eest. Muidu kui teha HV's otsing 3200 CL14 või 3600 CL14-16 kittidele mis laos on, siis on tulemuseks 0. Ise julgen oma kogemuse põhal CJR soovitada küll. Mul on küll JJR aga see käitub sarnaselt. 110€ eest saab 2x8GB 3200 CL16 kiti mis teeb 3733 16-20-20-36 1T thumbs_up.gif
Oliverk
sõnum 25.09.2019 21:05:55 vasta tsitaadiga
80 € eest saab 2x8 gbCorsair CMK16GX4M2B3200C16 mis teeb 3800 16-19-19-38-57 1T
sõnum 25.09.2019 21:14:06 vasta tsitaadiga
Oliverk, Mina näen HV's seda 95€+ eest.
Ja see pole RGB nagu Kingstoni HX432C16PB3AK2/16 icon_biggrin.gif
Oliverk
sõnum 25.09.2019 21:14:55 vasta tsitaadiga
Tomorrow kirjutas:
Ei ole ise kontrollinud. Võtsin ise Amazonist paar kuud tagasi koos ryzen 3600-ga.
sõnum 25.09.2019 21:16:18 vasta tsitaadiga
Oliverk, Tundub loogiline thumbs_up.gif . Huvitav mis kiipe see kasutab? B-Die see pole. Vb samuti CJR. Oled Thaiphoon Burneriga vaadanud?
Oliverk
sõnum 25.09.2019 21:19:01 vasta tsitaadiga
Typhoon näitab Hynix A-die
sõnum 25.09.2019 21:28:28 vasta tsitaadiga
Kristocfc
Kristocfc
sõnum 25.09.2019 23:03:49 vasta tsitaadiga
IMHO 2019/09 pole enam see koht kus 2*8gb vaadata
Kommentaarid: 64 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 55
anubis
anubis
sõnum 25.09.2019 23:38:25 vasta tsitaadiga
Tõhus rukkilill.
sõnum 25.09.2019 23:40:51 vasta tsitaadiga
Kristocfc kirjutas:
Keegi ei keela kaks 2x8 kitti võtta. Kokku alla 200€ pole paha thumbs_up.gif
Muidugi 4x8 ülekiirendamine on raskem kui 2x8.
anubis
anubis
sõnum 25.09.2019 23:45:06 vasta tsitaadiga
https://valid.x86.fr/243e4f
Oi kuidas 3900x armastab mälu tweakimist...oioioi.
sõnum 26.09.2019 23:38:16 vasta tsitaadiga
Tomorrow, kindlasti 2x16 mõistlikum
anubis
anubis
sõnum 27.09.2019 14:48:56 vasta tsitaadiga
https://www.msi.com/Motherboard/support/B450M-MORTAR
ABBA tuli välja.
ceemic
24/7@kalal
ceemic
sõnum 27.09.2019 15:06:38 vasta tsitaadiga
6kantv6ti
sõnum 27.09.2019 15:17:58 vasta tsitaadiga
MSI biositreialid ei maga, kuu ajaga TOMAHAWK MAX platele ka juba hunnik uusi BIOS-eid valmis tehtud.
Megadux
Megadux
sõnum 27.09.2019 15:58:21 vasta tsitaadiga
anubis kirjutas:
ABBA tuli välja.
Eelmine nädal sai oma emaplaadile MSI ABBA-t proovitud. 3700X-l enam tuumad üle 3600 Mhz sellega millegipärast ei läinud. Kui BIOS-es siis optimiseeritud vaikeseaded panin, siis Windows 10 vaatamata minu jõupingutustele enam ei buutinud. Panin heaga ABB tagasi peale seda.
Kommentaarid: 36 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 36
sõnum 27.09.2019 19:00:18 vasta tsitaadiga
AMD 3rd Gen Ryzen Threadripper CPUs With Zen 2 Cores Rumored To Get New Socket, No Backwards Compatibility With X399 Motherboards
https://wccftech.com/amd-ryzen-threadripper-3rd-gen-zen-2-cpu-new-socket-chipset-rumor/
Tundub väheusutav. Esiteks on lekkeid olnud kus TR3 on jooksnud X399 peal. Teiseks PCIe 4.0 on kiibistiku teema ja ei vaja socketi vahetust. Ja kolmandaks X399 on seni toetanud nii NUMA kui ka UMA mäluhaldust.
Neljandaks EPYC Rome on socket ühilduv eksisteerivate emaplaatidega ja seega ma ei näe põhjust miks TR3 ei peaks olema, kuna see on lihtsalt cut down EPYC.
hempadonok
hempadonok
sõnum 27.09.2019 19:43:16 vasta tsitaadiga
Loodetavasti pole tegu lihtsalt näpuveaga, 65w TDP 12-tuumaline
https://www.anandtech.com/show/14912/amds-ryzen-9-3900-a-12core-65w-cpu-listed-by-motherboard-maker
Monero kaevajatele peaks imehästi maitsema
Hommik on õhtust kainem ...Aegopodium!
Oliverk
sõnum 27.09.2019 20:53:33 vasta tsitaadiga
Pani oma Tomahwakile ja 3600-le ABBA BIOSI peale. Kõik tuumad teevad 4200, idle temp 36 kraadi. Keskmine mingi 45-50. Cine skooris ei muutunud sittagi. Mälu tahab vähem volti samade timingute juures.
terric
terric
sõnum 28.09.2019 01:38:21 vasta tsitaadiga
AMD protsessoritega ikka igav ei hakka seiklust kui palju (ps. kes lugeda ei viitsi 3900x töötab aga ot all mõned
tähelepanekud ja ka enda kogemuste puudumine AMD maailmast icon_redface.gif ). Kui vaalium toimima hakkab siis proovib
ikka uusima BIOS toimima saada, v18 tundub, et ühelõime takt üle 4.1Ghz ei lähe, multi tundub ok (3113 cb15)?
PS. Päris häbi oleks olnud cpu garantiisse saata icon_redface.gif testijal oleks muidugi nalja nabani olnud...
Box jahuti tundub ok, kuigi tald pole kuumatorudega päris ühtlaseks lihvitud ju sellepärast panevad
pastat liiga palju. Hetkel MX4 millalgi vaja ikka üle vaadata kas pasta sai korralikult aga hetkel sai IPA otsa ...
ot:
Sain ka oma 3900x kätte ja istutasin b450 tomahawk plaadile,
millel bios oli vist 1.A (1.0.0.3ab) peaks nagu 3900x olema toetatud.
Aga ei postinud, cpu led punane (resettisin CMOS, patarei välja jne) ei posti.
Mõtlesin juba, et panin CPU valesti pessa (ei tea kas võimalik aga kahtlus tekkis),
jahuti maha ja cpu korra pesast välja ja tagasi, edutult (AMD paneb pastat liiga palju).
Tegin ka BIOS "flashback" kõige uusimale 1C aga edutu POST.
Panin siis r3 1200 tagasi ja POSTis, uuesti r9 3900x peale ja sama teema ei POSTi.
Mõistus otsas aeg alustada googeldamisega algul palju targemaks ei saanud kui, et
proovida kõige esimest BIOS mis 3000 seeriat toetama hakkas 1.80 (v18).
Algul sama teema edutu siis sattusin ühe YT otsa, kus tal taoline probleem
aga tekkis peale toimival tomahawk 3600 bios uuendamist.
Ja ta soovitas eemaldada CMOS patarei (tegelt ma seda ka tegin aga "valesti") 5 minutiks.
Ei paistnud aitavat aga raal jäi 1+ minutiks käima (lootus otsas, mis seda power nuppu ikka litsuda) ja
siis hakkas asi lootust andma st. LED kustus ja POST...
Ma olen kindel, et uusima BIOSiga oli raal 1+ minutit surnud olekus aga ei POSTinud (samas patarei eemaldamine vist jäi proovimata).
Seega kogenumad AMD kasutajad, kas CPU vahetus tahtis lihtsalt saada aega
sätete häälestamiseks (tagantjägi tuli meelde ühe YT millel b350 plaadil aeti 3900x
käima aga too plaat resettis miski 5x ennem kui pilt ette tuli.
sõnum 28.09.2019 04:59:55 vasta tsitaadiga
terric, Jep vanematel platedel tahab mitu tsüklit läbi käia enne kui pildi ette võtab. Lisaks ei pruugi kohe uusima BIOS peale minemine võimalik olla vaid pead uuendama järk-järgult mis minule on üsna kummaline. Sõltub muidugi platest endast. Mõned on valutumad kui teised.
Paul's Hardware ühes videos oli sellest juttu ja samuti B450 Tomahawk:
Vael
sõnum 28.09.2019 10:21:10 vasta tsitaadiga
Pole mitte ainult AMD teema, i3570k + RAM ülejellamisel näiyeks teeb mu MSI Z77-G65 ka mitu tsüklit läbi, enne kui bootib. BIOS on isegi säte: BIOS try count vms, default peaks 3 olema.
Kuna uusimad kiibid kasutavad juba algoritme kümnete\sadade(vegal oli 64 termosensorit?) sensorite põhjal parima pinge/takti leidmiseks ja kõik kiibid käituvad erinevalt, siis pole ka ime kui kõigi 12 tuuma "esmakordsel käima õpetamisl" aega läheb.
Iseküsimus kui kaua r9 3900x käivitamine aega võtab ja kas nii pikk proysess õigustatud... Enda meelest i5 rappa läinud oc päädis ka 1-2min bios mõtlemisega....
uus teema   vasta Raud »  Protsessorid »  AMD Zen/Ryzen/Threadripper/Epyc arutelu mine lehele eelmine  1, 2, 3 ... 312, 313, 314 ... 635, 636, 637  järgmine
