sõnum ![Teata moderaatorile Teata moderaatorile](./images/icon_move_w.gif) |
One
![Winterwind Winterwind](https://foorum.hinnavaatlus.ee/images/avatars/upload/3c12bc5c4b79b23ccbcf9d738d1eac55.jpg)
Kommentaarid: 1007 loe/lisa |
![](./images/komment/img_10_1.gif) ![](./images/komment/img_10_0.gif) ![](./images/komment/img_10_2.gif) |
727 |
![](templates/HinnaVaatlus/imagesHV/spacer.gif) |
Zonerman
![Zonerman Zonerman](https://foorum.hinnavaatlus.ee/images/avatars/upload/95c6a5b0d5d2c37a69b715a16aa08cf2.jpg)
11.09.2019 17:35:33
Masendav. Tundub, et suuremas osas kogu inteli cpu arhitektuur on üks suur šveitsi juust ükskõik mis otsast seda ei vaata.
Kommentaarid: 63 loe/lisa |
62 |
![londiste londiste](https://foorum.hinnavaatlus.ee/images/avatars/upload/14e8b2a8ca7fc07a1be7f79f613c69f5.gif)
11.09.2019 19:22:59
https://www.vusec.net/projects/netcat/ kirjutas: |
More precisely, with NetCAT, we can leak the arrival time of the individual network packets from a SSH session using a remote cache side channel. Why is this useful? In an interactive SSH session, every time you press a key, network packets are being directly transmitted. As a result, every time a victim you type a character inside an encrypted SSH session on your console, NetCAT can leak the timing of the event by leaking the arrival time of the corresponding network packet. Now, humans have distinct typing patterns. For example, typing ‘s’ right after ‘a’ is faster than typing ‘g’ after ‘s’. As a result, NetCAT can operate statical analysis of the inter-arrival timings of packets in what is known as a keystroke timing attack to leak what you type in your private SSH session. |
uurimustöö: https://www.vusec.net/download/?t=papers/netcat_sp20.pdf
edit:
ründevektor on muidugi päris ja selle ümber saab veel olema kõvasti tegemist.
aga seekordne poc on veidi nõrgem kui näitevideost paistab.
tl;dr
kaks masinat üle võrgu sama masina küljes (2 erinevat nic).
- ohvermasinas interactive ssh sessioon, ehk iga nupuvajutus saadab kohe paketi.
- ründavast masinast saadetakse üle võrgu pakette ja mõõdetakse viidet, mis märgib paketi kohale jõudmist.
- saadud infost - kohale jõudnud paketid ja saadetud paketid - tuletatakse välja need hetked ajas, kus saabus muu pakett kui ründavast masinast saadetud.
- nüüd on teada, millistel ajahetkedel jõudis serverisse pakett, mis ei tulnud ründavast masinast -> järelikult tuli ohvermasinast.
- pakettide vahelistele ajavahemikele rakendatakse paar kavalat algoritmi ja korralik dataset tähtedevahelisest viitest sõnade tippimisel.
video on muuseas kliendi poolt automated trükkimine (dataseti viidete järgi), mitte inimene
_________________ - londiste
Kommentaarid: 238 loe/lisa |
213 |
Vael
12.09.2019 16:25:23
Ühesõnaga kui parooli trükid, siis tee mõttepaus;)
Ja miljoni $ prohekt tippi masinasse ja saada enkrüptitult pilve.
Kommentaarid: 17 loe/lisa |
16 |
![Tomorrow Tomorrow](https://foorum.hinnavaatlus.ee/files/me3_667.jpg)
19.09.2019 08:38:39
Intel Core i9-9900KS 5.0 GHz Flagship CPU TDP Detailed – 127W at Base Frequency, Higher When Hitting Boost Across All Cores
https://wccftech.com/intel-core-i9-9900ks-5-GHz-cpu-127w-tdp-october-launch/
9900K(F) baasklokk on 3.6Ghz @ 95W
9900KS baasklokk on 4.0Ghz @ 127W
See tähendab, et 400Mhz = 32W
Seega kui nad 5Ghz allcore TDP reklaamiks oleks tegemist 207W TDP prosega (2x400Mhz+200Mhz = 32+32+16)
Ja see on veel konservatiivne pakkumine, kuna prose on oma efektiiivsuskurvist väljas seega mida lähemale 5Ghz-le seda rohkem voolu tarbib.
Ma ei imestaks kui reaalne number oleks 250W+
Jaa jaa ärge tulle mulle siin rääkima, et Inteli TDP ei võrdu voolutarve. Intel ise kasutab seda TDP meetodit.
Kommentaarid: 89 loe/lisa |
79 |
WäntWõll
make.believe
![WäntWõll WäntWõll](https://foorum.hinnavaatlus.ee/images/avatars/upload/12b7604805e4b01442f66b968a236c3f.jpeg)
19.09.2019 09:29:22
Keda see voolutarve kotib sellise isendi puhul
Säästuässadele on teised jupid poes müüa
Kommentaarid: 373 loe/lisa |
299 |
Anna tooli
Kommentaarid: 354 loe/lisa |
295 |
19.09.2019 14:50:52
WäntWõll kirjutas: |
Säästuässadele on teised jupid poes müüa ![thumbs_up.gif](images/smiles/thumbs_up.gif) |
Ju siis temperatuur mis selle voolutarbega kaasneb ja emaplaatide võime seda jooksutada pole tähtis . Kindlasti kõik KS ostjad paaritavad selle custom loopi ja Z390 Dark või Maximus Extreme/Apex platedega
79 |
WäntWõll
make.believe
19.09.2019 15:18:07
Tomorrow kirjutas: |
Ju siis temperatuur mis selle voolutarbega kaasneb ja emaplaatide võime seda jooksutada pole tähtis . Kindlasti kõik KS ostjad paaritavad selle custom loopi ja Z390 Dark või Maximus Extreme/Apex platedega ![thumbs_up.gif](images/smiles/thumbs_up.gif) |
Jep, ega ei olegi mõeldud 75€ emplaadi peal jooksutamiseks, sinna pistab i3 ja passiive ALU klots offitsa jooksutamiseks.
Custom loop kindlasti ei ole vaja, sest suht 100€ saab piisava AIO.
299 |
eix666
![eix666 eix666](https://foorum.hinnavaatlus.ee/images/avatars/upload/17ae2b10554110c9957e54ba3630b526.jpg)
19.09.2019 15:27:34
Tomorrow: Kuna tegu on eeldatavasti binnitud kividega, siis peaks ta jooksma võrreldes samale kellale ülekiirendatud 9900k'ga madalamal voldil. Ja seega jahedamalt. Või siis on rohkem pearuumi ülekiirendamiseks kui see soov on. Või on ka tavaliste 9900k'de ülekiirendamine härra arvates võimalik ainult eelpoolmainitet vahendite abil?
Ja mis tdp'sse puutub, siis ei võta näiteks 3900x teps mitte reklaamitud 105w (eriti kui veel PBO'd peaks soovima kasutada), ehk siis ootaks vastavasisulist tiraadi ka AMD teemasse.
Kommentaarid: 39 loe/lisa |
39 |
WäntWõll
make.believe
19.09.2019 15:31:31
eix666, ää pane tähele herr Tomorrow, on lihtsalt kibestunud
Siin maailmas on veel palju asju mis talle pähe ei mahu.
299 |
19.09.2019 19:36:42
Custom loop kindlasti ei ole vaja, sest suht 100€ saab piisava AIO. |
Mõeldud loomulikult pole aga arvad, et see kedagi takistab kui ühilduvus on paberil olemas?
Loodetavasti Intel väljastab siis emaplaatide loetelu mis on KS valideeritud. 127W TDP prose jooksutamine pole triviaalne ülesanne emaplaatidele. Kas ma pean meelde tuletama Faildozeri aegasid?
100€ AIO - naer saalist
eix666 kirjutas: |
Tomorrow: Kuna tegu on eeldatavasti binnitud kividega, siis peaks ta jooksma võrreldes samale kellale ülekiirendatud 9900k'ga madalamal voldil. Ja seega jahedamalt. |
Võibolla aga kõrgem baasklokk nullib selle teooria ära. Võib vabalt ka olla rohkem lekkiv silikoon, et saavutada kõrgemaid kellasid.
eix666 kirjutas: |
Või siis on rohkem pearuumi ülekiirendamiseks kui see soov on. |
See võib olla küll aga eks näis kui palju.
eix666 kirjutas: |
Või on ka tavaliste 9900k'de ülekiirendamine härra arvates võimalik ainult eelpoolmainitet vahendite abil? |
Muidugi tavaline 9900K(F) manual OC kui ka KS default Turbo käivad samale kellale aga KS baasklokk paneb emaplaatidele siiski suurema koormuse.
eix666 kirjutas: |
Ja mis tdp'sse puutub, siis ei võta näiteks 3900x teps mitte reklaamitud 105w (eriti kui veel PBO'd peaks soovima kasutada), ehk siis ootaks vastavasisulist tiraadi ka AMD teemasse. |
3900X omab ka neli tuuma rohkem. Muidugi see pole 105W aga tänu 7nm pole see ka 250W.
Siin maailmas on veel palju asju mis talle pähe ei mahu. |
Ei maksa isiklikuks minna kui argumendid otsa saavad
79 |
Auron
![Auron Auron](https://foorum.hinnavaatlus.ee/images/avatars/upload/2f375c04925deebbc53ce1b04e4219c7.jpg)
19.09.2019 19:59:42
Ei mina usu, et KF paremini kellub kui 9900K - pigem on tegu golden sample 9900K prosedega mis mõistliku voldiga kannatavad allcore 5Ghz ja kogu moos - edasi on suht sein ees. Pole ju nö. tavajahutustega 9900K'd ju mingeid imeklokke suutnud toota.
Mis puutub ilgelt high end prose käkk VRM'ga platele panemisse siis siin pole ka AMD mingi erand.
Kommentaarid: 150 loe/lisa |
127 |
eix666
19.09.2019 21:19:42
Tomorrow: Kui me räägime ülekiirendamisest, siis miks üleüldse baaskellast jutt käib? Kõikide tuumade käsitisi ülekiirendamise puhul kaotab baaskell kui selline igasuguse tähtsuse. Ehk siis kui samamoodi käsitsi ülekiirendada nii 9900K ja 9900KS, siis tehase baaskell ei mõjuta mitte midagi. Ei voolutarvet, ei koormust emaplaatidele, mitte midagi.
Ja kuidas mõjutab 3900x tuumade arv seda, et AMD tdp number on samamoodi naljanumber nagu Inteli oma? Või tuli AMD'le tdp numbri määramisel sinumeelest üllatusena, et mitu tuuma protsessoril on, nad vaesekesed arvasid, et see on ikka 8tuumane? Kui tdp mängud ei meeldi, siis tuleb mõlemale ühtemoodi lajatada, muidu on tegu puhtal kujul silmakirjalikkusega.
39 |
WäntWõll
make.believe
19.09.2019 22:56:44
Tomorrow, ei olegi isiklik, kohati lähed lihtsalt oma Inteli irooniga põõsa alla, hoia tagasi ja kõik on ookoo
Ei saa argumendid otsa vaid sul on lihtsalt paha tuju ja mulle teeb see nalja ning vastan irooniaga
299 |
20.09.2019 00:26:50
eix666, Aga ongi silmakirjalikkus tootjate poolt. Meil on vaja ühtset mõõdetavat TDP standardit.
Ja see peaks baseeruma stock sätetel ja sellel palju prose maksimaalselt voolu võtab allcore turboga mitte baaskellal.
WäntWõll, Tohoh psühhiaater mul välja ilmunud siin
Ei mul on väga hea tuju hetkel tänan küsimast.
See, et teie eixiga siin nii valulikult reageerisite minu postile paneb pigem muigama.
Kui 9900K nii hea on ja TDP on tähtsusetu nagu te väidate miks te seda siis ei kasuta?
79 |
eix666
20.09.2019 00:35:22
Tomorrow: puhtalt uudishimust, kui ma käiks AMD teemas iga natukese aja tagant jauramas, kuidas AMD tdp ei vasta reaalsusele ja turbokellad ei vasta lubatule ja mida iganes veel leida õnnestub, kas sa noogutaksid mõistvalt kaasa, või "reageeriksid valulikult"?
Ja mina ise ei vaatagi kunagi tdp numbreid (ei AMD ega Inteli puhul), selleks on ülevaated, mis mõõdavad täpselt palju prose erinevatel tingimustel voolu võtab. Selleks ülevaated ongi, et marketingi BS'ist läbi närida.
39 |
20.09.2019 00:39:47
eix666, Mina postitan teemadesse asjakohaseid uudiseid. Sae tõmbas käima ikka väntvõll. Samamoodi postitan AMD teemase uudiseid ja videoid kui AMD-ga midagi valesti on. Samamoodi Nvidia teemasse.
Kui kellelgi on probleem uudisega, siis pöörduge uudise tegija poole. Mina lisan tavaliselt oma arvamuse uudisele juhul kui mul just kiire pole. Kui on kiire postitan ainult pealkirja ja lingi.
79 |
eix666
20.09.2019 00:49:17
Tomorrow: mina ei vastanud ju siiski mitte uudisele, vaid uudisele lisatud veidi kaheldavatele väidetele, mis vajasid natuke korrigeerimist (näiteks see baaskella teema, millest ma siiani aru ei saa). Ja seeläbi väidetavalt "valuliselt reageerisin".
39 |
Vael
20.09.2019 16:02:48
Nagu Shasanksi vaataks uuesti
16 |
WäntWõll
make.believe
24.09.2019 15:19:04
Tomorrow,
tsitaat: |
Mis sa sokid jälle.
Minu vastus oli puht isiklik sinu linkitud "uudise peale"
tsitaat: |
Säästuässadele on teised jupid poes müüa |
Sulle lihtsalt ei mahtunud pähe, et kedagi eksisteerib, kellel pole TDP-st sooja ega külma.
Loe enda plära rahulikult läbi ja ära keeruta.
299 |
24.09.2019 16:24:53
WäntWõll, Saag on juba katki aga sinna ikka jaurad siin veel. Kes siin lõpuks siis plärab?
Sinul ehk pole TDP-st sooja ega külga aga paljudel on. Niikaua kui need inimesed on enamuses, niikaua TDP numbreid ka tsiteeritakse.
Kui sind ei koti siis olgu pealegi. Mõistetamatuks jääb miks on seda vaja sellises salvavas toonis siis postitada üldse?
79 |
WäntWõll
make.believe
24.09.2019 17:11:18
tsitaat: |
Salvavast toonist siin rääkides
Lepi sellega et kade meel on ja seda jupi üle mida sa nagunii ei osta.
Ja veel, Kes on enamus? Youtuuberid ja revjuu soperdised, Tädi Maali käest sa ju ei küsi.
On, on mõistetamatu teema ja sae saab alti soojaks lasta
299 |
24.09.2019 17:58:03
tsitaat: |
On, on mõistetamatu teema ja sae saab alti soojaks lasta ![thumbs_up.gif](images/smiles/thumbs_up.gif) |
Ma vastasin sulle samas toonis nagu sina alustasid. Ma ei näinud põhjust sellisele tobedale väitele ilusti vastama hakata.
Nii, et pmst sina sisestad snarky kommentaari ja kui keegi sulle samas toonis vastab pööritad silmi? Kui sa ei suuda kriitikat taluda, siis ära kritiseeri.
Kade meel mille üle? 9900KS või - ei tänan? Ei plaani osta jah. Miks peakski kui mul on juba sama või parema jõudlusega 3800X olemas.
Ära hakka siin tädi maalist jahuma. Jutt käib ilmselgelt DIY inimestest kes selliseid asju jälgivad ja mitte ka ainult revieweritest.
79 |
Reaper
![Reaper Reaper](https://foorum.hinnavaatlus.ee/images/avatars/upload/ac546f1fff780b1b3d9b1e8e9ba9f6d9.jpg)
25.09.2019 10:35:43
Energiasääst tõesti meie kliimas teemaks ei ole: mul niigi elektriradikas müttab kogu aja, kui kodus olen.
Samas rohkem soojust eraldav prose nõuab suuremat, kallimat ja tihti häälekamat jahutust. Nii et see võib juba oluline olla.
viimati muutis Reaper 25.09.2019 13:28:38, muudetud 1 kord |
Kommentaarid: 29 loe/lisa |
